How to Export Audio Only from Premiere Pro (Step-by-Step)
Exporting audio only from Premiere Pro is a common task for podcasters, video editors, and content creators who need a standalone audio file from a recorded sequence. The process is straightforward once you know where to look, but the Export Settings dialog has a few format-specific options that cause problems if you skip them. This guide covers the fastest native method, format selection, Adobe Media Encoder, and how to isolate a single audio track.
What “Audio Only Export” Actually Means in Premiere Pro
There is a critical distinction to understand before you start: selecting a video format like H.264 and simply disabling the picture does not produce a true audio file. It produces a video container with no image, which many platforms and players will reject or handle incorrectly. To export a real audio file, you need to select an audio-specific format (WAV, MP3, AAC, or AIFF) from the Format dropdown. Only then does Premiere Pro output a proper audio file.
Note: For best results, start with clean source audio. Recordings from a device like the Hollyland LARK MAX 2 (32-bit Float, 48 kHz) export cleanly without needing heavy correction before delivery.
Method 1 — Export Audio Only via File > Export > Media
This is the fastest and most direct way to export audio from any sequence. The entire process happens inside Premiere Pro without launching any additional applications.
Step-by-Step Instructions
  1. Open your sequence in the Timeline. Make sure the correct sequence is active and all track settings are configured the way you want them before proceeding.
  2. Go to File > Export > Media (keyboard shortcut: Ctrl+M on Windows, Cmd+M on Mac). The Export Settings dialog will open.
  3. Open the Format dropdown. This is the most important step. Select an audio format: MP3, AAC, WAV, or AIFF. Do not select H.264, QuickTime, or any other video format here.
  • [Screenshot callout: Show the Format dropdown with WAV selected]
  1. Check the Video tab. When you select an audio-only format, the Video export option should automatically grey out and become unavailable. If it is still active, you have likely selected a video container format rather than an audio format. Go back to the Format dropdown and correct it.
  • [Screenshot callout: Show the greyed-out Video tab after selecting WAV]
  1. Open the Audio tab and configure the following settings:
  • Sample Rate: 44.1 kHz for music and web delivery; 48 kHz for video and broadcast workflows
  • Channels: Stereo for most use cases; Mono for single-voice podcasts or narration-only tracks
  • Bitrate (MP3 and AAC only): 192 kbps is a reliable default for general delivery; 320 kbps for higher-quality output
  1. Set your output file name and destination. Click the blue output name link near the top of the dialog to choose where the file saves.
  2. Click Export. Premiere Pro will render and export the audio file directly to your chosen destination.
Choosing the Right Audio Format
The format you select affects both quality and file size. Use the table below to match the format to your specific workflow.
Format
Best For
Quality
File Size
WAV
Podcasting masters, client deliverables, archiving
Lossless
Large
AIFF
Mac-based workflows, broadcast
Lossless
Large
MP3
Web delivery, YouTube audio, casual sharing
Lossy (compressed)
Small
AAC
Apple platforms, streaming, mobile
Lossy (efficient)
Small to Medium
Use WAV or AIFF when the audio will be edited again, delivered to a client, or stored as a master file. Use MP3 or AAC when the file is going directly to a platform or audience and file size is a practical concern.
Method 2 — Export Audio via Adobe Media Encoder
Adobe Media Encoder is the better option when you need to export in the background while continuing to work in Premiere Pro, or when you are processing multiple files in a batch.
  1. Complete all format and audio settings in the Export Settings dialog following the same steps as Method 1.
  2. Instead of clicking Export, click Queue. This sends the job to Adobe Media Encoder.
  3. Adobe Media Encoder opens automatically with your sequence listed in the encoding queue.
  4. Confirm the format and output destination in the queue panel.
  5. Click the green Play button to begin encoding.
  6. Return to Premiere Pro. It remains fully usable while Media Encoder handles the export in the background.
Pro Tip: Adobe Media Encoder is especially useful when you need to export multiple format versions at once, such as a WAV master and an MP3 distribution copy from the same sequence.
How to Export a Single Audio Track (Not the Full Mix)
By default, Premiere Pro exports a mixdown of all active audio tracks in the sequence. If you only want one specific track, such as a voiceover without background music, you have two options.
Option A: Mute unwanted tracks in the Timeline
  1. In the Timeline, click the M (Mute) button on every track you do not want included in the export.
  2. Only unmuted tracks will be included in the audio mixdown.
  3. Proceed with the export steps from Method 1.
  4. Unmute the tracks again after the export is complete to restore your sequence.
Option B: Use Audio Channel Mapping in Export Settings
  1. In the Export Settings dialog, go to the Audio tab.
  2. Locate the Audio Channel Mapping section.
  3. Disable or reroute the channels that correspond to the tracks you want to exclude from the output.
The muting approach is faster for a one-off export. Audio Channel Mapping is more precise and works well when delivering labeled stems to a client or mixing engineer.
Troubleshooting — Common Export Problems
  • A video file exports instead of an audio file: You selected a video format such as H.264 or QuickTime in the Format dropdown. Open the dropdown and switch to WAV, MP3, AAC, or AIFF.
  • The exported file has no audio or plays back silent: Check that the audio track is not muted in the Timeline and confirm the track output (speaker icon) is active before exporting.
  • The stereo mix sounds wrong or a channel is missing: Open the Audio tab in Export Settings and review the Audio Channel Mapping. Confirm both Left and Right channels are assigned correctly and that Stereo is selected rather than Mono.
Q: Can I export audio only from a specific in/out point in Premiere Pro?
Yes. Set In and Out points in the Timeline using the I and O keys before opening File > Export > Media. In the Export Settings dialog, open the Source Range dropdown and select “Sequence In/Out.” Premiere Pro will export only the audio within those marked boundaries.
Q: Does exporting audio only in Premiere Pro preserve the original quality?
Quality is preserved only when you export to a lossless format such as WAV or AIFF. MP3 and AAC apply compression that slightly reduces quality, which is acceptable for platform delivery but not recommended for archiving source recordings or master files you may need to re-edit later.
Q: Why is the video checkbox still active when I export audio?
This happens when a video format such as H.264 or QuickTime is still selected in the Format dropdown. Switch the Format to an audio-only option (WAV, MP3, or AAC), and the Video panel will grey out automatically. The format selection controls everything.
Q: Can I export multiple audio tracks as separate files at once?
Not in a single step from the standard Export dialog. Use Adobe Media Encoder and create separate queue items configured for each individual track, or use the Export panel in Premiere Pro 2023 and later, which supports stem and loudness export with more granular track-level output control.
For a single quick export, Method 1 through File > Export > Media is the fastest path. If you want to keep working while the file renders, or you are exporting several files at once, send the job to Adobe Media Encoder instead. When you need a specific track rather than the full mix, mute the unwanted tracks in the Timeline before exporting. For further reading, see our guide on the best audio export settings for Premiere Pro to fine-tune bitrate and sample rate for every delivery format.
