How to Configure Zoom Microphone Settings for Clear, Professional Audio
Zoom’s default audio settings are built around the average laptop user with a built-in microphone. If you are using an external mic, those defaults will likely hold your audio quality back. This article covers the Zoom audio options that matter most. The Hollyland LARK MAX 2 serves as the example throughout. You will learn how to choose your microphone and adjust sound settings for clearer calls. The process stays nearly identical on Windows and macOS systems.
Where to Find Microphone Settings in Zoom?
Zoom keeps all microphone configuration inside a single Audio Settings panel. There are two ways to reach it depending on whether you are already on a call or setting up in advance.
Before a call (recommended for initial setup):
  1. Open the Zoom desktop app.
  2. Click on your profile photo and choose Settings from the menu.
  1. Select the Audio tab from the left sidebar menu.
The Audio tab opens, showing the microphone dropdown, input level meter, and all noise suppression controls.
During a live call:
  1. Locate the microphone icon on the bottom-left of the Zoom call screen.
  1. Click the mic icon to mute or unmute.
  1. Click the small chevron (^) immediately to the right of the microphone icon.
  2. Select Audio Settings from the dropdown menu.
  1. The same Audio Settings panel opens without interrupting the call.
Both methods lead to the same panel. The pre-call route is better for first-time configuration because you can adjust and test settings without other participants listening.
Setting up the Hollyland LARK MAX 2 before opening Zoom:
Before navigating to Zoom’s audio settings, connect the LARK MAX 2 USB-C receiver (RX unit) to your laptop. You can also connect the camera RX via a USB-C cable.
Once connected, confirm that  the LCD display on the camera RX should show an active signal bar.
If you have connected the USB-C receiver directly into your laptop, the LED indicator on the RX should turn solid blue.
Likewise, a solid blue LED confirms that the TX transmitter is paired and actively transmitting.
Open Zoom’s Audio settings only after seeing these indicators. If you open Zoom before the RX unit registers, the system will likely default to the built-in microphone.
Note: On Mac, you may need to grant Zoom microphone permission under System Settings > Privacy and Security > Microphone before any external device appears in Zoom’s dropdown.
Selecting the Right Microphone in Zoom
Once the Audio Settings panel is open, the Microphone section appears near the top. This is where you tell Zoom which physical input device to use for all calls.
How to select your microphone:
  1. Click the Microphone dropdown, which may currently show “Same as System” or “Built-in Microphone.”
  1. Review the list of available input devices. Each connected audio device appears by its OS-assigned label.
  2. Select the device corresponding to your external microphone. For the LARK MAX 2, look for the label assigned to the USB audio adapter connected to the RX unit, often listed as “USB Audio Device” or “External Microphone.”
  3. Speak into the microphone and watch the Input Level meter below the dropdown. If the meter moves, Zoom is receiving a signal from the correct device.
  1. Confirm the selection and close the panel if you are completing pre-call setup.
Why Zoom often selects the wrong device:
Zoom’s “Same as System” default mirrors whatever input Windows or macOS is set to globally. When you plug in a USB audio adapter, the OS does not always reassign the system default automatically, so Zoom inherits the built-in microphone setting rather than switching to the newly connected device.
When to avoid “Same as System”:
Avoid this option whenever you are using a dedicated external microphone. With “Same as System” active, any OS-level audio change, such as connecting headphones or another USB device, will silently change Zoom’s input mid-call. Manually selecting a specific device eliminates this risk.
Note: If the LARK MAX 2 does not appear in the dropdown, check that the receiver is fully connected. Then verify the OS is detecting the device.
On Windows, go to Settings > Sound > Input
On Mac, go to System Settings > Sound > Input.
Adjusting Microphone Input Volume in Zoom
Below the microphone dropdown, Zoom provides an Input Level slider and an “Automatically adjust microphone volume” toggle. These two controls have a significant effect on audio quality, and their interaction with an external microphone’s onboard gain matters more than most users realize.
Reading the input level meter:
The horizontal meter next to the Input Level slider displays your signal in real time as you speak. Aim to have speech peaks landing in the 60–75% range of the meter. A signal consistently peaking below 40% will sound thin and distant after Zoom’s compression. A signal that regularly clips the far right of the meter will distort.
Auto Adjust: when it helps and when it works against you:
  • Auto Adjust On, helpful: During calls, some people speak louder than others. Zoom automatically adjusts volume levels to keep voices balanced. This reduces the need for constant audio changes.
  • Auto Adjust On, harmful: Professional recording, webinars, or sessions using a tuned external mic. Zoom will constantly fight the gain you have already set at the hardware level, boosting the signal during silences and attenuating it during peaks. The result is an uneven, pumping quality.
  • Auto Adjust Off, helpful: Any setup where you have set gain at the source. You control the floor, and Zoom leaves it alone.
  • Auto Adjust Off, harmful: Situations with inconsistent input levels where you have no other gain control available.
Setting levels correctly with the LARK MAX 2:
You can set gain through the HollyAudio application from the Dynamic Gain and Set gain to sections.
Alternatively, if you have the camera receiver, you can set Auto and Custom gain for the active transmitter.
Once TX gain is confirmed:
  1. In Zoom’s Audio panel, uncheck “Automatically adjust microphone volume.”
  2. Speak at normal volume and observe where the Zoom input meter peaks.
  3. Adjust the Input volume slider until the speech peaks fall within the healthy mid-range.
  1. Leave the slider in that position.
Turning off "Auto Adjust" can make a noticeable difference. This matters most when using an external mic with separate gain controls. It helps keep the LARK MAX 2 audio unchanged. Zoom will not keep modifying the signal during use.
Zoom’s Noise Suppression Settings — What Each Level Does
Zoom’s noise suppression is found in the Background noise suppression under the Microphone modes section of the Audio tab. Four tiers are available, and each one has its own pros and cons.
Level
What It Filters
Best For
Risk
Auto
Adjusts dynamically based on detected noise
Unpredictable environments, mixed home/office use
Inconsistent processing; may over-suppress speech unexpectedly
Low
Persistent low-level noise (fans, HVAC)
Clean rooms with minor ambient sound; pairs well with hardware noise cancellation
Minimal artifact risk
Medium
Moderate background noise (open offices, street noise)
Busier environments without dedicated hardware noise cancellation
Slight reduction in vocal warmth at higher frequencies
High
Aggressive broadband suppression
Loud environments only
Robotic vocal artifacts; noticeable processing delay
Choosing the right level for your setup:
For most Zoom users working in a quiet home office, Low is sufficient. Medium handles busier spaces. High exists for genuinely loud environments and should not be used as a permanent default.
Using LARK MAX 2’s AI Noise Cancellation alongside Zoom’s suppression:
The LARK MAX 2 includes onboard AI Noise Cancellation, toggleable through the HollyAudio app or directly on the TX unit. This is hardware-level noise processing that runs before the audio ever reaches Zoom.
When both processing layers run simultaneously, the combination matters:
  • LARK MAX 2 AI NC active + Zoom suppression at Low: Recommended for most professional calls. The hardware layer handles the heavy lifting; Zoom’s Low setting adds a light secondary pass. Vocal tone stays natural.
  • LARK MAX 2 AI NC active + Zoom suppression at High: Avoid this. Double-processing at maximum strength hollows out the vocal midrange, creates a phased quality, and adds perceptible latency.
  • Clean, controlled environment: Turn Zoom’s noise suppression off entirely and let the LARK MAX 2’s AI NC handle isolation. Zoom’s processing adds nothing useful in this scenario and may subtly degrade the signal.
Pro Tip: Open the HollyAudio app alongside Zoom’s Audio tab. Turn on AI NC in the application settings menu. Set the Zoom suppression level to the Low option now. Record a short test clip with the Zoom Test Mic tool. Compare it with AI NC off and the Zoom Medium setting. Many users notice more natural sound and less fatigue on long calls.
Advanced Audio Settings Worth Enabling or Disabling
Zoom’s Audio tab includes an Advanced button that reveals a secondary panel with additional controls. Then, there is the Original sound for musicians checkbox under the Microphone modes.
In the Advanced button, you will find:
  • Echo Cancellation (Dropdown): Leave this at Auto for nearly all use cases. Aggressive mode exists for severe echo problems in large or poorly treated rooms, but it introduces its own processing artifacts. If you are using headphones and a dedicated external microphone, echo is rarely an issue, and Auto handles it cleanly without over-processing.
And when you checkmark the Original sound for musicians option, you will see three topics.
  • High Fidelity Music Mode: This setting disables Zoom’s built-in audio normalization and compression, passing your microphone signal to participants with minimal processing applied. Enable it when using a high-quality external microphone in a quiet, controlled space. For LARK MAX 2 users, enabling Original Sound preserves the 48 kHz output the RX unit sends. Without this setting, Zoom adds extra compression. This softens sharp sound details and lowers clarity. The LARK MAX 2 TX also saves a 32-bit Float backup internally. Even if Zoom changes live audio, a clean recording stays on the transmitter.
  • Echo cancellation (Checkbox): In Zoom settings, echo cancellation under Advanced works differently. Microphone modes also manage audio processing at another level. The microphone mode echo cancellation option suits users with external setups and headphones. Musicians and podcasters often fall into this group. It prevents microphone pickup of meeting audio during use. Turning it off without headphones may cause strong echo issues.
  • Stereo Audio: Transmits audio in stereo rather than mono. Enable this only for a stereo microphone setup or a music-focused session. For standard speech-based Zoom calls, mono is more bandwidth-efficient and has no meaningful quality disadvantage.
How to Test Your Microphone Inside Zoom?
Once all settings are configured, use Zoom’s built-in test before your first call.
  1. In Settings > Audio, locate the Test Mic button.
  2. Confirm the LARK MAX 2 TX and RX are paired, and the units have a solid LED indicator. Also ensure that the system is not muted. If it's muted, the LED will turn solid red.
  1. Click Test Mic. Zoom records a short sample and plays it back automatically.
  2. Listen to the playback. Clean, natural audio at a comfortable volume confirms the setup is working correctly.
  3. If the playback is silent or distorted, proceed to the troubleshooting section below.
Fixing Common Zoom Microphone Problems
Problem
Likely Cause
Fix
Mic not detected in Zoom
Wrong device selected or OS not recognizing the input
Select the correct input in the Zoom dropdown; verify OS audio input in Sound Settings (Windows) or System Settings > Sound (Mac). If the LARK MAX 2 RX LCD is blank, the RX unit needs charging via USB-C before it can output audio to the computer.
Voice sounds too quiet
Gain too low or Auto Adjust fighting the signal
Raise TX gain on the LARK MAX 2; disable Auto Adjust in Zoom; raise the Zoom input slider. If the TX LED is blinking red, the TX is muted. A single press of the mute button restores active state and returns the LED to steady green.
Robotic or over-processed audio
Noise suppression too high or double-processing active
Lower Zoom noise suppression to Low or Auto. Confirm that AI NC is not running at full strength in the Hollyland Link app while Zoom is simultaneously set to High. Disable one processing layer.
Echo on the call
Echo Cancellation disabled or speaker audio bleeding into the microphone
Set Echo Cancellation to Auto in Zoom’s Advanced Audio settings. Switch to headphones to prevent speaker output from reaching the microphone.
Q: Why does Zoom keep switching back to my laptop microphone?
Zoom’s “Same as System” default resets the selection whenever a device disconnects or the OS audio input changes. To prevent this, manually select your external device in the Zoom microphone dropdown and confirm that your OS default audio input also points to the same device in Windows Sound Settings or macOS System Settings.
Q: Should I turn off Zoom’s noise suppression if my microphone already has noise cancellation?
Yes, in most cases. Using both systems at full intensity causes double processing effects. This can make voices sound empty or unnatural during calls. Set Zoom to Low or Off and rely on the microphone’s hardware or AI noise cancellation. This produces cleaner, more natural-sounding results with less processing overhead on the call.
Q: What is “High-fidelity music mode” in Zoom and should I enable it?
High-fidelity music mode in Zoom improves audio for music sessions. It reduces noise filtering and echo control for cleaner instrument and vocal sound. It sends higher-quality audio during calls. Turn it on when teaching or learning music online. It also suits singing, playing instruments, or listening sessions. A wired internet connection helps maintain stable performance. Headphones are strongly recommended to avoid feedback. Keep it disabled for regular meetings or casual conversations. Avoid enabling it on weak or unstable Wi-Fi connections. Do not use it in noisy rooms without a proper mic.
Q: How do I stop Zoom from automatically adjusting my microphone volume?
In Settings > Audio, uncheck “Automatically adjust microphone volume.” Then set the input level manually using the slider until the meter peaks at roughly 60–70% during normal speech. This keeps the level stable and prevents Zoom from boosting quiet passages or cutting loud ones unpredictably.
Q: Can I use a wireless lavalier microphone with Zoom on a laptop?
Yes. Connect the wireless receiver to your laptop via its USB-C output or 3.5mm audio output using a USB audio adapter if your laptop lacks a dedicated mic input jack. Then open Settings > Audio in Zoom and select the microphone from the dropdown. The device behaves identically to any other external USB audio input from Zoom’s perspective.
Follow a simple four-step setup in Zoom audio settings. First, open the Audio section inside the Zoom settings menu. Next, choose the correct microphone as your input device. Then turn off automatic mic volume adjustment and set the input volume level manually. Finally, pick a noise suppression level based on your surroundings.
