How to Add a Product to a TikTok Video (Step-by-Step)
Adding a product to a TikTok video turns a regular post into a direct sales or commission opportunity. Whether you’re a seller with a TikTok Shop or a creator earning affiliate commissions, the process takes under a minute once you know where to look. This guide covers every path — including how to tag a product after your video is already live.
What It Means to “Add a Product” to a TikTok Video?
There are two main situations. If you sell products, you can tag items from your TikTok Shop so people can buy them right from your video. If you are a creator in TikTok’s affiliate program, you tag a brand’s product to earn a commission on any sales. Either way, viewers see the same thing: a shopping bag icon on the video that opens the product page inside TikTok.
Missing the product tag button is the most common frustration — and it almost always comes down to an unmet prerequisite. Before trying to tag a product, confirm the following:
  • You have a TikTok Shop seller account (for tagging your own products), OR you’re enrolled in TikTok’s affiliate program (for tagging brand products). You need one or the other — a standard creator account alone won’t surface the option.
  • Your account is approved and in good standing. Accounts under review or with policy violations may have shopping features restricted.
  • The product is active and approved. For sellers, the listing must be live in the TikTok Seller Center. For affiliates, the product must be added to your affiliate showcase. Pending or delisted products won’t appear in search.
  • Your TikTok app is updated to the latest version. Shopping features roll out incrementally, and older app versions often hide newer UI elements.
  • Your region supports TikTok Shopping. TikTok Shop is not available in all countries. If you’re in an unsupported region, the product tagging option will not appear regardless of account status.
The single most common reason the product tag button is missing: your TikTok Shop application is still under review, or you haven’t yet enrolled in the affiliate program.
How to Add Your Own Product to a TikTok Video (TikTok Shop Sellers)
This is the primary path for brand owners and small businesses that have an active TikTok Shop.
  1. Open TikTok and tap the “+” button to start a new video or upload an existing one from your camera roll.
  1. Record or select your video. Complete any edits — trimming, captions, audio — before tagging.
  1. On the Post screen, tap “Add link” or the product tag icon. It typically appears as a shopping bag or under a “Tag products” label in the posting options.
  1. Tap “TikTok Shop Products” to open the product search within your store.
  2. Search for the product by name or SKU. Your active listings will populate; select the correct product.
  3. Position the product tag on the video frame if prompted, or confirm placement.
  4. Preview the tag to verify it looks correct and taps through to the right listing.
  5. Tap “Post” to publish the shoppable video.
How to Tag Multiple Products in One Video?
TikTok lets sellers add multiple products to a single video by repeating the tagging process for each item before posting. But make sure that you avoid tagging every product in your store. Tag only the products that actually appear or are discussed in the video; over-tagging clutters the viewing experience and can reduce click-through on any individual product.
How to Add an Affiliate Product to a TikTok Video (Creators & Influencers)
If you don’t own a TikTok Shop but you’re enrolled in TikTok’s affiliate program, you can tag products from participating brands and earn a commission on every sale. The workflow is slightly different from the seller path.
  1. Open TikTok Creator Center (Or TikTok Studio; accessible via your profile menu) and navigate to the TikTok Shop for Creator.
  1. Tap the “Discover” tab, browse or search for the product you want to promote, then tap “Add” to save it to your affiliate product list.
  1. Once done, tap “View” when the “Added to Showcase” message pops up to confirm the product is added to the list.
  1. Return to the main TikTok app and tap “+” to upload or record your video.
  2. On the Post screen, tap “Add link” or the product tag option.
  3. Now, choose a product link by tapping the “Add” button next to each product on the “Add product links From Showcase” page.
  1. Confirm the tag and tap “Post.”
The affiliate tag functions identically to a seller tag from the viewer’s perspective, but your commission is tracked automatically through TikTok’s system. You do not need to add any custom tracking links.
How to Add a Product Tag to a Video You’ve Already Posted?
Forgot to tag a product before hitting publish? You can add it retroactively without deleting and reposting.
  1. Open TikTok Shop Creator Center and go to the Videos tab.
  2. Tap the Create tab, then select Link products.
  1. Find a video from the past 30 days without a linked product.
  1. Tap Add Link, pick the product, then tap Add and Confirm.
  1. You can choose items from your showcase or Suggestions.
Note: To manage recommendations, tap the Settings button on the top right and turn off Recommend product links if you don’t want suggested products.
Why You Can’t See the Product Tag Option (Troubleshooting)
If you’ve gone through the steps above and still don’t see a way to tag a product, one of the following is almost certainly the cause:
  • TikTok Shop application is pending or rejected. Check the Seller Center for your approval status.
  • You haven’t enrolled in the affiliate program. A general creator account does not unlock product tagging — affiliate enrollment is required.
  • Your region doesn’t support TikTok Shop. The feature is currently limited to specific markets, including the US, UK, and several Southeast Asian countries.
  • The app needs an update. Force-close TikTok, update it through your app store, and relaunch.
  • The specific product is delisted or pending review. Even with a fully approved account, a product that has been suspended or is under review won’t surface in the tagging search.
  • Your account has a policy strike. Shopping features can be restricted on accounts flagged for Community Guidelines violations.
Tips for Making Shoppable TikTok Videos Actually Convert
Getting the tag on the video is step one. Getting viewers to tap it is the real goal.
  • Demonstrate the product on screen. Viewers tap product tags when they can see the item clearly. Hold it up, use it, or show the results — don’t just mention it verbally.
  • Reference the product tag in your first few seconds. Say something like “link in the video” or “tap the bag icon to grab this” early, before viewers scroll past.
  • Use a TikTok text overlay near the shopping bag icon to draw the eye — a simple arrow or “Tap to shop” label significantly increases tag interaction rates.
  • Focus on one hero product per video. Multi-product videos can dilute attention. If you have one strong product to feature, build the entire video around it.
  • Make sure your audio is clear. When you’re verbally explaining a product, unclear or noisy audio kills credibility fast. A compact wireless mic like the Hollyland LARK M2 — just 9g with up to 40 hours of battery — keeps your product narration clean without adding visible bulk to your setup.
Can I add a product to a TikTok video without a TikTok Shop account?
Yes. Through TikTok’s affiliate program, creators can tag and earn commissions on products they don’t own or sell. You’ll need to enroll in the affiliate program through TikTok Creator Center, add the target product to your showcase, and then tag it during or after video upload. No seller account is required for this path.
How many products can I tag in one TikTok video?
TikTok currently allows sellers to tag multiple products per video, though the limit can vary and is subject to platform updates. As a general best practice, limit tags to products that are actually visible or discussed in the video — tagging unrelated products can feel spammy and may reduce overall click-through.
Does adding a product tag affect video reach or the algorithm?
TikTok has publicly stated that it incentivizes the use of shopping features. Shoppable videos may receive additional distribution in the TikTok Shop tab and in For You feeds for users who have previously engaged with shopping content. In short, tagging a product is unlikely to hurt reach and may help it.
Can I remove a product tag after posting?
Yes. Navigate to the published video, tap the three-dot menu, select “Edit video,” and delete the specific product tag. The video itself does not need to be removed or reposted, and your existing engagement data stays intact.
Why is my product not showing up when I search for it to tag?
The product must be active and approved in TikTok Seller Center. If the listing is pending review, has been flagged, or has run out of stock with inventory-gating enabled, it won’t appear in the tagging search. Log in to Seller Center, confirm the listing status, and resolve any flags before attempting to tag again.
Adding a product to a TikTok video comes down to two clear paths: sellers tag their own TikTok Shop listings directly at upload, while affiliate creators save products to their showcase first and tag from there. Both paths also support retroactive tagging on already-published videos. If you don’t have a TikTok Shop set up yet, start with the TikTok Shop registration guide before returning here. If you’re already enrolled and approved, open your next video draft and tag your first product — then check TikTok analytics in 48 hours to see your product click-through data.
