TikTok Studio is TikTok’s official desktop streaming application, and it gives creators far more control over their live streams than the mobile app alone. If you’ve hit the follower threshold and you’re ready to level up your setup, this guide walks you through everything — from download to going live — in a clear, step-by-step format. No guesswork, no getting stuck at a blank screen.
What You Need Before Going Live on TikTok Studio?
Before you download anything, run through this checklist. Skipping this step is the fastest way to hit an error mid-setup.
Minimum 1,000 followers — TikTok requires at least 1,000 followers on your account before live access is unlocked. There are no workarounds.
Age requirement: 18 or older — Accounts under 18 are not eligible to go live, regardless of follower count.
Account in good standing — Accounts with recent strikes, bans, or policy violations may have live access restricted. Check your account status in the TikTok app before proceeding.
Supported operating system — TikTok Studio runs on Windows 10 or later and macOS 10.15 (Catalina) or later.
Stable internet connection — A wired Ethernet connection is strongly recommended. For Wi-Fi, aim for a minimum upload speed of 5 Mbps for a reliable 1080p stream. Run a speed test at fast.com if you’re unsure.
A TikTok account with a verified email or phone number — First-time login in TikTok Studio may trigger an account verification step.
If you can check every box above, you’re ready to move forward.
How to Download and Install TikTok Studio?
Note: TikTok LIVE Studio was the previous name for this application. If you’ve seen that name in older tutorials or search results, it’s the same product — it was officially rebranded to TikTok Studio. Always download from the official source to avoid third-party installer risks.
Open your browser and go to https://www.tiktok.com/studio/download — this is the official download page.
Click the Download button. The site will auto-detect your operating system and serve the correct installer.
Once the installer downloads, open the file:
Windows: Run the .exe file and follow the on-screen prompts. Installation typically takes under two minutes.
Mac: Open the .dmg file, drag TikTok Studio into your Applications folder, and launch it from there.
After installation, open TikTok Studio. Allow it to complete any initial update it prompts on first launch — this ensures you’re running the most stable version.
Confirm your system meets the minimum requirements: at least 4 GB RAM (8 GB recommended for smooth performance) and a dual-core processor or better.
How to Connect Your TikTok Account to TikTok Studio?
Launch TikTok Studio. On the welcome screen, click Log In.
You’ll be presented with two login options:
QR Code: Open the TikTok app on your phone, go to your profile, tap the menu icon, and select Scan QR Code. Point your camera at the code on screen. This is the fastest method.
Username and Password: Enter your TikTok credentials directly. If you use a third-party login (Google, Apple, etc.), select the matching option.
Once logged in, TikTok Studio will request permissions to access your account for streaming. Click Authorize or Allow to proceed.
If prompted, complete any account verification step (email or SMS code). This is a one-time requirement on new devices.
Your account name and profile picture should now appear in the top-left corner of the TikTok Studio dashboard. You’re connected.
How to Set Up Your Camera, Microphone, and Scene?
This is the section where most first-time users get confused. TikTok Studio uses a scene and source system, borrowed from professional streaming software — but don’t let the terminology put you off. Here’s what it means and how to use it.
A scene is a layout. Think of it as a canvas that holds everything your viewers will see. A source is any individual element placed on that canvas — your webcam feed, a screen capture, a background image, or a text overlay.
For a beginner, one scene with one camera source is all you need to go live.
Setting Up Audio Input
In the left-hand sidebar, click Settings, then navigate to Audio.
Under Microphone, click the dropdown menu and select your preferred input device. If you’re using a USB microphone or an audio interface, it should appear here automatically once plugged in.
Speak into your microphone and watch the input meter. You want the levels to peak in the green-to-yellow range during normal speech — not in the red.
Enable Noise Suppression if your recording environment has background noise (fans, air conditioning, street noise).
Audio quality is one of the top reasons viewers leave a live stream early. If you’re finding cables limiting or your built-in mic sounds thin, a wireless option like the Hollyland LARK M2 is worth considering — it only weighs 9 grams, offers a 40-hour battery life, clips onto clothing, and delivers clear audio without the desk-cable clutter that shows up on camera.
Building Your First Scene
In the Scenes panel (bottom-left of the dashboard), click the + icon to create a new scene. Name it something simple like “Main Stream.”
In the Sources panel (directly next to Scenes), click + and select Video Capture Device to add your webcam or capture card.
A properties window will open. Use the Device dropdown to select your camera. Click OK. Your camera feed should now appear in the preview window.
Resize and reposition the camera source in the preview by clicking and dragging the corners.
To add a screen capture (if you’re gaming or presenting), click + in Sources again and choose Display Capture or Window Capture.
Once your scene looks correct in the preview, you’re ready for the final stage.
How to Go Live on TikTok Studio? (The Core Steps)
This is the main event. Follow these steps in order and you’ll be live within a few minutes.
Click “Go Live” in the top-right corner of the TikTok Studio dashboard. This opens the pre-live configuration panel — you are not live yet.
Add a stream title. Keep it descriptive and direct (e.g., “Live Q&A — Ask Me Anything”). Titles appear in TikTok’s live discovery feed, so clarity helps.
Select a category. Choose the category that best matches your content (Gaming, Music, Education, etc.). This helps TikTok surface your stream to the right audience.
Set your stream quality. Under the quality settings, choose your resolution and bitrate:
720p at 2,500–4,000 kbps is a reliable starting point for most connections.
1080p at 4,500–6,000 kbps if your upload speed and CPU can support it.
If you’re unsure, start at 720p — you can always adjust after testing.
Run a test stream first. Before going public, use TikTok Studio’s Preview Mode (sometimes labeled “Test Stream”) to verify your camera, microphone, and layout look correct. Watch 30 seconds of playback. Confirm audio sync matches your video.
Click “Start Live.” Your stream is now public on TikTok. The live dashboard will activate, showing:
Viewer count (top of screen)
Live chat (right panel — respond to keep engagement high)
Gifts and reactions (displayed as they come in)
To end the stream, click the End Live button in the top-right corner. Confirm when prompted. TikTok will process your stream, and it will appear in your profile as a video replay (if you’ve enabled that option in settings).
Pro Tip: Pin a comment in your live chat immediately after going live to set context for new viewers joining mid-stream. Something simple like “Just started — drop a question below!” reduces bounce from cold visitors.
Troubleshooting Common TikTok Studio Issues
Issue |
Likely Cause |
Fix |
Microphone not detected |
Device not connected before launch, or wrong input selected |
Plug in the mic before opening TikTok Studio; go to Settings → Audio and re-select the correct input device |
Black screen/camera not showing |
Camera in use by another app, or the wrong device selected |
Close other apps using the camera (Zoom, Teams, browser); reselect the device under Sources → Video Capture Device properties |
“Not eligible to go live” error |
Below 1,000 followers, account age restriction, or regional limitation |
Verify follower count and account age in the TikTok app; if both are met, contact TikTok Support via Creator Center |
Stream buffering or dropping frames |
Insufficient upload speed or bitrate set too high |
Lower bitrate to 2,500 kbps or switch to a wired Ethernet connection; close background apps consuming bandwidth |
How many followers do you need to go live on TikTok Studio?
You need a minimum of 1,000 followers on your TikTok account to access the live feature through TikTok Studio. This requirement applies regardless of whether you’re streaming from a desktop or mobile. You also need to be 18 or older. If you’ve recently crossed the 1,000-follower mark, allow 24–48 hours for the feature to activate.
Can you go live on TikTok Studio on a Mac?
Yes. TikTok Studio is compatible with macOS 10.15 (Catalina) and later. Download the Mac version directly from studio.tiktok.com. Functionality is the same as the Windows version, though some Mac users with Apple Silicon chips should ensure their OS is fully updated for best performance.
Is TikTok Studio free to use?
Yes, TikTok Studio is completely free to download and use. There are no subscription fees or paywalls for any of the core streaming features, including scene building, camera/audio configuration, and going live. TikTok does not charge creators to stream through the desktop application.
What’s the difference between TikTok Studio and going live on the TikTok app?
The TikTok app lets you go live from your phone with minimal setup, but you’re limited to your device's camera and microphone. TikTok Studio gives you full desktop control: multiple sources, scene layouts, screen capture, external cameras, and better audio input options. For anyone who streams regularly or wants a more professional setup, TikTok Studio is a significant upgrade.
Can you stream to TikTok using OBS instead of TikTok Studio?
Yes. TikTok supports RTMP streaming, which means you can use OBS Studio or similar software by entering your TikTok stream key (found in TikTok Studio under Settings → Stream Key). This is a more advanced route suited for creators who already use OBS and want to add TikTok as a streaming destination without switching applications entirely.
Streaming on TikTok Studio is ready to begin, from installation to your first broadcast. The next step is to run a quick test in Preview Mode. Check that your audio and video look clean before starting the broadcast. When ready to learn more, visit the TikTok Creator Center. It offers live analytics, audience insights, and helpful tips to improve stream performance over time.
