Are you confused by seeing the Normalize Loudness feature in CapCut? Well, you're one of the many users who wonder if they should enable this feature or keep it disabled. Audio settings can feel risky when you do not know what they actually change. This guide explains what the feature does, how it works, where to find it in the app, and when to use it versus when to leave it off.
The Short Answer
Normalize Loudness automatically adjusts the volume of every audio clip in your project to a consistent, standardized level. It stops sudden, loud volume changes between clips recorded at different levels. A quiet voiceover and loud background audio stay at similar loudness. This removes the need for manual volume slider adjustments. It is CapCut’s built-in, measurement-based audio leveling tool.
How Does Normalize Loudness Actually Work?
CapCut measures each audio clip’s loudness in LUFS and applies a gain adjustment to bring every clip toward a consistent target level. That target aligns with the loudness standards used by major social and streaming platforms, roughly -23 LUFS.
What is LUFS? LUFS stands for Loudness Units Full Scale, a standardized measure of how loud audio sounds to a listener, not just how loud the waveform peaks.
Normalization is not the same as dynamic compression. A compressor changes volume in real time, moment to moment, based on what the audio is doing. Normalize Loudness applies a single, fixed gain shift to each clip so its average loudness hits the target. The underlying audio waveform also gets changed. It is a non-destructive, clip-level process.
This is also different from manually dragging the volume slider. Manual adjustment is a rough, one-off guess. Normalization is a measurement-based calculation applied consistently across every clip in your project.
Where to Find Normalize Loudness in CapCut
Normalize loudness is a Pro feature. But you can try it in the free version as well. Also, this function is openly available in CapCut's desktop application. Whereas in the mobile version, you may need to switch to the paid tier to unlock this feature, as it is not visible in the free tier.
Here's where to find Normalize loudness:
Open your project on CapCut.
Click on the audio file on the audio track timeline to select it.
Go to the Basic tab on the top-right corner of the screen. Locate the Normalize loudness checkbox and enable it.
When to Turn Normalize Loudness On vs. Off
Turn It On When… |
Leave It Off When… |
Clips were recorded with different microphones or devices |
Audio levels are already professionally balanced |
Your voiceover sounds too quiet next to background music |
Music is intentionally kept low for ambient effect |
You are exporting to TikTok or YouTube, where platform-side normalization can cause unpredictable volume shifts |
You have already applied a compressor or limiter externally |
Multiple recording sessions left clips sounding uneven |
You want precise manual control over each individual clip’s level |
Does Normalize Loudness Affect Audio Quality?
The short answer is that it does not change much when used properly. Normalization adjusts the overall gain of a clip. Lowering gain does not degrade quality. Raising gain is where caution is warranted: any background noise or hiss already present in the recording gets amplified along with the intended audio. The feature itself is safe to use, but the quality of the result depends on the quality of the original capture. Recording with a dedicated wireless mic like the Hollyland LARK M2 produces clean audio at consistent levels from the start, which means less gain needs to be added in post and background noise stays inaudible.
Does CapCut normalize loudness automatically, or do I have to enable it?
CapCut does not apply Normalize Loudness by default. You need to enable it per clip inside the audio clip settings. It does not activate on its own when you add a clip to the timeline.
Will normalize loudness make my background music too loud?
It will not make a music clip overly loud just because it is quieter than a voiceover. The tool adjusts overall loudness in a controlled way. Use Normalize Loudness to keep audio at a steady baseline. Then lower the background music with the volume slider under the voiceover.
What loudness level does CapCut normalize to?
CapCut targets a loudness level consistent with major streaming platform standards, approximately -23 LUFS.
Normalize Loudness helps when audio comes from different sources. It reduces extra work in fixing uneven volume levels. Turn it on when clips sound inconsistent in loudness. Keep it off when audio is already balanced. Recording with a wireless mic gives steadier levels from the start. This makes normalization optional instead of required in editing.
