How to Use Multiple Audio Sources on iPhone: Playback & Recording Guide
Your iPhone does a great job playing audio, but some apps love crashing the party. Open one of them, and your music or podcast might suddenly stop. The same problem appears when you try to record two microphones at once, since the built-in apps simply do not support it. This guide breaks both scenarios down clearly, covering how to play audio from multiple apps simultaneously and how to record from multiple inputs, with practical methods that work on current iOS.
What “Multiple Audio Sources” Actually Means on iPhone
This phrase covers two completely different problems, and mixing them up wastes time. Before trying any fixes, first figure out which situation matches your problem.
Playback scenario: You want two audio streams playing at the same time. Background music while following turn-by-turn navigation, or a workout timer running alongside a podcast. The audio already exists somewhere; you just want to hear both streams simultaneously.
Recording scenario: You want to capture audio from two or more physical inputs at the same time. Two microphones for an interview, a microphone plus a guitar, or a wireless lavalier paired with a room mic. The goal is to record multiple sources into a single project or onto separate tracks.
Playback
Recording
Goal
Hear two audio streams at once
Capture two audio inputs simultaneously
Common examples
Music + navigation, podcast + workout app
Interview with two mics, vlog with lavalier + camera mic
Main barrier
Apps interrupt each other by default
Native apps support only one input
Solution type
App settings and compatible app pairs
Audio interface or dual wireless mic system
Both problems happen for the same reason. iOS controls audio through a system called audio sessions. By default, every new audio session can stop the one already playing. Understanding that single rule makes every workaround in this guide make sense.
Playing Audio from Multiple Apps at the Same Time
How iOS Audio Sessions Work and Why They Conflict
When any app on your iPhone wants to play audio, it requests an audio session from iOS. Each app declares how it intends to behave: whether it will pause other audio, lower the volume of other audio (called ducking), or mix alongside audio that is already playing.
Most apps default to the most aggressive option, requesting exclusive audio and pausing everything else. This is why opening YouTube stops Spotify. It is not a bug; it is the app’s deliberate configuration. A smaller number of apps, including most navigation and fitness apps, are designed to mix with whatever is already playing, and those combinations are the reliable ones to build around.
Step-by-Step: Enabling Mixed Audio Playback on iPhone
The approach varies depending on which apps are involved, but these steps cover the most reliable methods.
Method 1: Use an app that is built to mix
  1. Start playing audio in your primary app, such as Spotify or Apple Music.
  2. Open a secondary app designed to run alongside other audio. Google Maps, Waze, Nike Run Club, and most interval timers fall into this category.
  3. If the secondary app is built to mix, your music will continue playing, and voice prompts or cues will play over the top.
Method 2: Check in-app audio settings
  1. Open the settings inside your music or podcast app, not the iPhone Settings app.
  2. Some apps include settings for background playback or audio behavior. Many newer iPhone apps do not offer these options. In most cases, the developer decides how the app manages audio.
  3. In Spotify, no explicit mix toggle exists, but Spotify is coded to respect other audio sessions on iOS when it is started first.
  4. In Overcast (podcast player), audio is mixed with other streams by default, making it one of the most compatible podcast apps for simultaneous playback.
  5. The official YouTube app needs a Premium subscription for background playback. Playing audio with another app depends on how both apps control their audio.
Note: Not all app combinations will mix. If a combination does not work after checking in-app settings, the app’s audio session type is likely hardcoded to interrupt others and cannot be changed from the user side.
Best App Combinations That Support Simultaneous Audio
Scenario
App 1
App 2
Works?
Notes
Music + navigation
Spotify
Google Maps / Waze
Yes
Navigation ducks music briefly, then restores
Music + navigation
Apple Music
Apple Maps
Yes
Native apps are designed to mix
Podcast + navigation
Overcast
Google Maps
Yes
Reliable combination
Music + workout tracker
Spotify
Nike Run Club
Yes
Cues play over music
Music + podcast
Spotify
Overcast
Usually
Depends on which starts first; Overcast mixes
Music + YouTube
Spotify
YouTube
No
The official YouTube app usually stops other audio from playing. The result can change based on the playback mode and app behavior.
Two music apps
Spotify
Apple Music
No
Both claim exclusive audio
Meditation + music
Calm
Spotify
Inconsistent
Varies by session type; test before relying on it
Recording from Multiple Audio Sources on iPhone
The Native iPhone Limitation
The built-in Camera app and Voice Memos only recognize a single audio input at a time, whether that is the internal microphone or whatever is physically connected to the Lightning or USB-C port. There is no option to blend two microphones or record onto separate tracks. Capturing audio from multiple sources simultaneously requires a third-party recording app, external hardware, or both.
Use an Audio Interface for Multi-Input Recording
An audio interface is a small hardware device that plugs into your iPhone’s Lightning or USB-C port and provides multiple analog input channels. Microphones and instruments connect to the interface, and the iPhone receives a single combined digital audio stream that can be split into separate tracks inside a recording app.
What you need:
  • A USB-C or Lightning audio interface (Audient ID4, M Audio Track Solo, Focusrite or Scarlet 2i2, for a compact option)
  • A compatible multi-track recording app (GarageBand is free; Ferrite Recording Studio works well for podcast-style projects)
  • A Lightning-to-USB-C adapter or direct USB-C cable, depending on your iPhone model
Setup steps in GarageBand:
Note: The Audient ID4 is used as an example audio interface in the steps below.
  1. Connect the audio interface to your iPhone’s USB-C or Lightning port.
  1. Plug your microphones or instruments into the interface inputs.
  2. Open GarageBand and start a new project (+ icon).
  1. Scroll to the Audio Recorder page on the app and tap Microphone or Instrument (if you are miking any instrument).
  1. Tap Allow when prompted by the message to let GarageBand access the microphone.
  1. Tap Settings (gear icon) in the top-right corner, scroll down and select Advanced, then enable the Multitrack option. Tap Done.
  1. Assign the correct input channel to Track 1. For example, Input 1. To do that, tap on the Channel option at the bottom-left of the screen and choose your Input.
  1. Now, to add another track, tap the Tracks view option in the top control bar.
  1. Drag the track icon to view the track header. Tap the + icon to add a second track and assign it to the second audio input (for example, Input 2)  by going back to the Channel option.
  1. For each track, tap the track icon to open its options. Then tap the red Record Enable button for every track you want to record.
  1. Press the main record button. Both channels record simultaneously to separate tracks.
Pro Tip: If your audio interface has a headphone output, plug your monitors into the interface rather than the iPhone’s adapter. You will hear a zero-latency mix of all inputs while recording without affecting the recorded signal.
Record Multiple Audio Sources Wirelessly with a Dual Mic System
For creators who need to move freely, such as interview hosts, vloggers, and run-and-gun filmmakers, running cables to an audio interface is not always practical. Dual wireless microphone systems solve this by sending two separate transmitters to a single receiver that plugs directly into your iPhone.
The Hollyland LARK A1 is a straightforward example of this setup. Each kit includes two clip-on lavalier transmitters and a receiver with a USB-C or Lightning connector that plugs directly into an iPhone, with no interface or adapter required. Both voices are captured simultaneously and delivered to the recording app as a stereo signal, with each speaker on a separate channel.
Wireless dual-mic setup steps:
  1. Clip one LARK A1 transmitter on each speaker or place it near each audio source.
  1. Plug the LARK A1 receiver into your iPhone’s USB-C or Lightning port.
  1. Open your recording app of choice, such as the native Camera app for video.
  2. Open the free HollyAudio app from the App Store. Check that the microphone system is set to Stereo audio mode. In Stereo mode, Mic 1 records the left audio channel. Mic 2 records the right audio channel.
  1. To adjust each level separately, edit the stereo file in a desktop DAW. You can also split the channels with a third-party method. For example, duplicate the track and convert each copy to mono. Then pan them left and right.
For professional interview or documentary setups where audio fidelity cannot be compromised, the Hollyland LARK MAX 2 adds 48 kHz / 32-bit Float recording with on-board backup recording built into each transmitter. AI noise cancellation processes audio before it reaches the iPhone, and each transmitter stores a safety copy of raw audio independently of the receiver, protecting against input clipping or a dropped signal regardless of what recording app is in use. Also, you can monitor audio in real time wirelessly via the OWS earphones.
Multi-Track Recording Apps That Support Multiple Inputs
After connecting the hardware, the recording app decides how much control you get over each audio source. These four options cover the most common iPhone multi-source recording workflows:
  • GarageBand (Free): Best for musicians and general multi-track projects. Supports multiple input channels with any compatible audio interface and has a low learning curve for basic recording tasks.
  • Ferrite Recording Studio (Free / Pro upgrade): Optimized for podcasters and interviewers. Clean interface, straightforward track management, and strong mobile editing tools.
  • Dolby On (Free): A good option for quick stereo captures with automatic mastering applied. Limited multi-track control, but useful when you want polished results with minimal setup.
  • Rode Reporter (Free, designed for Rode hardware): Purpose-built for field interviews and journalism. Works well with compatible Rode interfaces and wireless systems.
Choosing the Right Method for Your Use Case
Use Case
Best Method
Suggested Tools
Difficulty
Casual listener (music + navigation)
App mix settings
Spotify + Google Maps or Waze
Low
Podcaster / interviewer (two voices)
Dual wireless mic system
Hollyland LARK A1 + Ferrite or GarageBand
Low-Medium
Musician recording live
USB-C audio interface + multi-track app
Focusrite Scarlet 2i2 or Audient ID4 + GarageBand
Medium
Filmmaker / documentary creator
32-bit Float wireless system + recording app
Hollyland LARK MAX 2 + Ferrite
Medium
Educator / live streamer
Audio interface or wireless mic + streaming app
iRig Pre 2 + preferred platform app
Medium
Can iPhone record two microphones at the same time natively?
No. The built-in Camera app and Voice Memos support only a single audio input. Recording from two microphones simultaneously requires either a USB-C or Lightning audio interface paired with a multi-track recording app. You can also use a dual-channel wireless microphone system like the Hollyland LARK A1 that delivers both signals through one receiver connected to the iPhone.
Why does my music stop when I open another app on my iPhone?
Your music may stop because another app takes control of the iPhone's audio. This often happens with video previews or apps using extra system memory. Autoplay settings inside some apps can also cause this problem. To fix this, turn off autoplay or in-app video previews. Next, check the settings in apps like Instagram, Facebook, or TikTok. Also, if your music stops, open Control Center and press the Play button. Sometimes using that navigation helps play the audio. If that does not help, close both apps completely and open them again.
What is the best free app for recording multiple audio inputs on an iPhone?
GarageBand is the strongest free option. It supports multi-track recording, works with any compatible USB-C or Lightning audio interface, and lets you assign separate input channels to individual tracks. For podcast-style recording focused on voice clarity and easy editing, the free tier of Ferrite Recording Studio is also worth trying.
Can I use two Bluetooth microphones with an iPhone simultaneously?
No. iOS does not support two simultaneous Bluetooth audio inputs. Bluetooth audio connections are managed one device at a time at the system level. Use a wired audio interface with two input channels, or a dual-channel wireless microphone system with a single USB-C or Lightning receiver, to capture two microphones at once.
Does iPhone support 32-bit float recording for multi-source audio?
Yes, with compatible hardware and apps. Wireless microphones like the Hollyland LARK MAX 2 record 32-bit Float audio internally on each transmitter as a backup. This protects against clipping at the input stage regardless of which recording app is used, because the safety copy is stored on the transmitter itself and is not dependent on the iPhone’s input gain settings.
What you should do depends on your recording or playback needs. Want two apps playing together? Check their audio settings first. Also, choose apps that support playing audio at the same time. Recording two sound sources needs extra equipment instead. Pick an audio interface for desk setups and studio recording. Choose a dual wireless microphone system for portable recording. GarageBand or Ferrite can record everything with very little setup.
