Your first clean recording in Ableton Live depends on three simple steps. Picking the correct audio device first. Then sending the signal to the right audio track. And pressing the correct record button to start recording. If you’ve armed a track and seen nothing on the meter, or heard an uncomfortable echo while monitoring, these are configuration issues, not software bugs. This guide explains the complete recording process from start to finish. It covers everything from Preferences to your finished recording. You will also learn how to record in both Arrangement View and Session View.
What You Need Before You Start Recording
Gather the following before opening Ableton:
Audio interface: Any USB or Thunderbolt interface (Focusrite Scarlett, SSL 2, PreSonus AudioBox, etc.)
Microphone or instrument: XLR dynamic or condenser mic, electric guitar, or any line-level source
Cable: XLR for mics; TRS or TS for instruments
Ableton Live: Any edition (Lite, Intro, Standard, or Suite) supports full audio recording
A USB microphone also works without a dedicated audio interface. All you need to do is select it as the input device inside Preferences and follow the same steps. If you’re recording vocals wirelessly, a transmitter-based mic like the Hollyland LARK MAX 2 connects directly into your interface’s input and delivers 48 kHz / 32-bit Float audio with AI Noise Cancellation, giving you a clean signal before it ever reaches the DAW.
Set Up Your Audio Interface in Ableton Preferences
This step tells Ableton which audio hardware to use for input and output. Nothing records until this is configured correctly.
Open Ableton Live and press Cmd+, (Mac) or Ctrl+, (Windows) to open Preferences.
Click the Audio tab in the left-hand column.
Set the Driver Type:
Core Audio on Mac
ASIO on Windows if your interface has a manufacturer ASIO driver
ASIO4ALL on Windows if no dedicated driver exists (free download)
Under Audio Input Device, choose your audio interface from the dropdown. If you are using a USB mic directly, select it here instead.
Under Audio Output Device, select your interface, studio monitors, or headphone output.
Set the Sample Rate to 44100 Hz for music or 48000 Hz for video and podcast work. The interface and Ableton must match exactly.
Adjust the Buffer Size. A lower buffer (64 to 256 samples) reduces monitoring latency but increases CPU load. A higher buffer (512 to 1024 samples) is more stable but introduces a perceptible delay when listening to your input. Start at 256 samples and adjust based on your system’s performance.
Note: If your interface does not appear in the Input Device list, close Ableton, confirm the interface is powered on and connected, then relaunch. Windows users should also install the ASIO driver from the manufacturer’s website before selecting it here.
Enabling Input Channels
Selecting your interface in Preferences is not enough on its own. You must also activate the specific physical inputs you plan to use. Skipping this step is the single most common reason beginners see a flat meter on their audio track.
In the Audio tab, click the Input Config button located to the right of the Input Device selector.
A small window displays all available input channels on your interface.
Click to enable the channels matching your physical connections. If your mic is plugged into Input 1, activate 1 (Mono). For a stereo source spanning inputs 1 and 2, activate 1/2 (Stereo).
Close the Input Config window and return to the Audio tab.
Any channel left inactive here will not appear in the track’s Input Channel dropdown later.
Create and Configure an Audio Track
With the interface configured, create the track that will capture your recording.
In Arrangement View or Session View, go to Create → Insert Audio Track, or right-click in the track header area and choose Insert Audio Track.
Confirm the track type. An Audio Track captures microphone and instrument input. A MIDI Track records note data from keyboards and controllers only. Do not use a MIDI Track to record live audio.
In the track’s Input Type dropdown, select your audio interface (displayed as “Ext. In” or by the interface name).
In the Input Channel dropdown directly below it, select the specific channel you activated in Input Config, for example “1 (Mono)” for a mic plugged into input 1.
Mono vs. stereo: Use a mono channel for a single microphone or mono instrument. Use a stereo pair (such as “1/2”) only when recording a stereo source, like a keyboard’s left/right outputs or a pair of room mics. Routing a mono source into a stereo track does not improve audio quality and wastes one channel.
Setting the Monitor Mode
Monitor mode controls whether you hear your live input signal through Ableton’s output during a session. Getting this setting wrong is the leading cause of echo, doubling, and unexpected silence for new users.
Monitor Mode |
When to Use |
Common Pitfall |
In |
When you need to always hear the input, even when the track is not armed |
Running this during playback causes the live input to layer over the recorded track, producing echo |
Auto |
Recommended default — hear input only when the track is armed |
Monitoring cuts off if the track is accidentally disarmed |
Off |
When using hardware Direct Monitoring on the audio interface |
You will not hear yourself through Ableton at all |
Choose Auto for the Monitor setting before you start recording. This setting lets you hear live input on armed tracks. Playback switches to the recorded audio without extra changes. Hearing an echo usually means another monitoring option is also active. Make sure In is not selected. Also, check whether your input is playing through two different places.
Arm the Track and Check Your Signal Level
Before pressing Record, confirm that a live signal is actually reaching Ableton.
Click the Arm Session Recording button on the track header. It is the small circle icon in the track. When armed, it glows red.
Speak into your mic, sing, or play your instrument. Watch the level meter on the track for movement.
Target a peak level between -18 dBFS and -12 dBFS. This range provides enough headroom to prevent digital clipping while keeping the signal strong enough for a clean, usable recording.
If the meter shows no movement, return to Preferences → Audio → Input Config and confirm the correct channel is enabled. Also check the gain knob on your audio interface. It may simply be turned too low.
Gain staging at the hardware level is always preferable to boosting a weak signal inside the DAW. Set your interface gain so that loud peaks land no higher than -12 dBFS on Ableton’s track meter. A recording that is too quiet can be raised in the mix later; a clipped recording cannot be recovered.
Record Audio in Arrangement View
Most people record complete performances in Arrangement View. It follows a timeline from beginning to end. This view suits vocals, guitars, podcasts, voice-overs, and other continuous recordings.
Click the Arrangement Record button (the circle-with-dot icon) in the transport bar at the top of the screen. It lights red to indicate record-ready mode.
Press the Spacebar (or the Play button in the transport) to start the transport. Recording begins immediately on all armed tracks.
Perform your take. A clip region fills in behind the playhead in real time on the audio track.
Press the Spacebar again to stop. The recorded clip now sits in the Arrangement timeline as an audio region.
Press Cmd+S (Mac) or Ctrl+S (Windows) to save the project immediately.
Take lanes and comping (Ableton 11 and later): To record an alternate take without overwriting the original, right-click the track header and select Show Take Lanes. Each new recording pass lands on a separate lane beneath the previous one. Use Ableton’s Comp tool to select the strongest segments from each lane and assemble them into a single polished performance.
To punch in to a specific section only, position the loop brackets in the Control Bar around the region you want to re-record, arm the track, and press Record. Ableton records within the looped region and leaves everything outside it untouched.
Record Audio in Session View
Session View is better suited to looped recording: capturing a live performance in repeating cycles, sketching musical ideas quickly, or gathering multiple short takes without committing to a fixed timeline.
Press Tab to switch to Session View (Tab toggles between Session View and Arrangement View).
Confirm the audio track is still armed (the Arm button should still be red).
Set the Global Launch Quantization in the Control Bar to control clip recording length, for example, “2 Bars” to record in two-bar loops before cycling.
Click an empty clip slot on the armed track (look for the small circle icon inside the slot) to begin recording.
Click the Stop button in the clip slot to end recording. The clip saves into that slot and loops on playback.
To move a Session View clip into the Arrangement timeline, drag it from the clip slot directly onto the desired position in Arrangement View.
Session View is not better than Arrangement View for recording. Each one serves a different recording style. Session View is a good fit for live looping and experimenting with ideas. Arrangement View is better for recording projects in timeline order.
Fix Common Audio Recording Issues in Ableton
No input signal on the track meter after armingCause: Input channel not enabled in Preferences, or wrong channel selected on the track. Fix: Go to Preferences → Audio → Input Config, activate the physical input you are using, then confirm the track’s Input Channel dropdown matches it exactly.
Echo or doubling sound while monitoringCause: Monitor mode is set to “In,” causing Ableton to pass the live input signal to the output at the same time the recorded track plays back. Fix: Switch Monitor from “In” to “Auto.” Alternatively, set Monitor to “Off” and use your audio interface’s built-in Direct Monitoring feature instead.
Noticeable delay when listening to input through headphonesCause: The buffer size in Preferences is large, adding processing latency to the monitored signal. Fix: Lower the buffer size in Preferences → Audio (try 128 or 64 samples). If CPU load becomes a problem, enable Direct Monitoring on your audio interface. Hardware Direct Monitoring routes your signal back to your headphones before it passes through Ableton’s software, delivering near-zero latency regardless of buffer size.
Ableton does not detect the audio interfaceCause: Incorrect driver type selected, driver not installed, or the interface was connected after Ableton was already open. Fix: Close Ableton, ensure the interface is powered on and connected, and relaunch. On Windows, install the ASIO driver from the manufacturer’s website. On Mac, confirm Core Audio is selected as the Driver Type in Preferences.
Can I record audio in Ableton Live Lite?
Yes. The recording workflow in this guide is identical across all Ableton editions, including Live Lite. Lite restricts the number of simultaneous audio and MIDI tracks, the number of scenes, and available plugin types, but the audio recording engine, I/O routing, and track arming process are exactly the same across all editions.
How do I record multiple inputs at the same time in Ableton?
In Preferences → Audio → Input Config, enable every channel you plan to use. Create one audio track per input channel, assign each track to its corresponding Input Channel using the I/O dropdowns, and arm all tracks at the same time. When you initiate recording in Arrangement View, all armed tracks capture simultaneously.
Why is there a delay when I monitor my input through Ableton?
This is software monitoring latency, determined by the buffer size set in Preferences. Reducing the buffer size lowers the latency but increases CPU load. The more reliable fix is to activate Direct Monitoring on your audio interface, which routes your input signal straight to headphones at hardware speed, completely bypassing the software latency.
Can I use a USB microphone to record in Ableton without an audio interface?
Yes. In Preferences → Audio, set the Driver Type to Core Audio (Mac), then select the USB microphone as the Audio Input Device. Enable its input channel in Input Config, create an audio track, set the Input Channel to match the USB mic, arm the track, and record. The process is identical to working with a standard audio interface.
You Are Ready to Record
Recording in Ableton Live follows five simple steps. First, choose your audio device in Preferences. Next, turn on the correct input channels. Then create an audio track and assign the proper input. Set Monitor to Auto and arm the track. Press Record when everything is ready. After your first recording, reduce latency for smoother monitoring and editing. You can also combine multiple takes into one polished performance. Begin with one clean recording before adding anything else.
