How to Make a YouTube Intro on CapCut (Step-by-Step)
A polished YouTube intro signals professionalism from the first frame. CapCut makes this achievable for any creator, whether you want to customize a ready-made template in minutes or build a branded animation from scratch. This guide covers both methods, plus everything you need to know about customization, export settings, and dropping the final intro into your videos.
Before opening CapCut, gather a few things so the process runs smoothly:
  • Your channel logo or image (PNG with a transparent background works best)
  • Brand colors (hex codes if possible)
  • Your channel name and tagline, finalized and ready to type
  • Intended intro length (5–8 seconds is the recommended range)
CapCut is available on iOS, Android, and PC (Windows and Mac). The steps in this guide apply to all platforms; any UI differences between mobile and desktop are flagged at the relevant step.
How to Make a YouTube Intro Using CapCut Templates (Fastest Method)
Templates are the quickest path to a professional-looking YouTube intro without designing from scratch. Here is the full walkthrough:
  1. Open CapCut and tap “Templates.” On mobile, find the Templates tab at the bottom of the screen. On PC, select “Templates” in the left sidebar.
  2. Search “YouTube intro” in the template search bar. Scroll through results and filter by style (minimal, gaming, vlog, cinematic) to find one that fits your channel. Tap any template to preview it before committing.
  3. Tap “Use Template.” CapCut loads the template into the editor and prompts you to replace the placeholder media.
  4. Replace placeholder clips or images with your logo or channel art. Tap each placeholder slot, select your image from your gallery, then resize and position it within the frame.
  5. Edit the placeholder text. Tap any text layer, delete the sample copy, and type your channel name or tagline. Change the font to match your brand using CapCut’s font library in the text editing panel.
  6. Adjust colors to match your brand palette. Tap a background or text element, then use the color picker to enter your exact hex code.
  7. Mute the default music. Tap the audio track in the timeline and either delete it or replace it with a track from CapCut’s audio library or your own device.
  8. Preview the full sequence. Tap play and watch from start to finish. Confirm that all text is readable and that the timing feels natural before moving to export.
Note: CapCut may add its watermark to exported videos by default. At the export screen, look for a “Remove watermark” toggle. On the free plan, this option is available in most regions — tap it before exporting.
How to Create a YouTube Intro from Scratch in CapCut
Building from scratch gives you complete control over every element. Follow these steps:
  1. Open CapCut and tap “New Video.” Do not select any media yet — you will configure the canvas first.
  2. Set the aspect ratio to 16:9. On mobile, tap the aspect ratio icon and select 16:9. On PC, set the canvas to 1920x1080 under project settings. This matches YouTube’s standard display format.
  3. Add a background. Tap “background” and choose either a solid color layer (go to “Canvas” then “Color”) or a short background video clip. Keep it simple so it does not compete visually with your logo.
  4. Import your logo or image. Tap “Add Clip,” select your logo from your gallery, and place it on the timeline. Drag the clip edges to match your intended 5–8 second total duration. On mobile: pinch to resize the logo directly on the preview screen. On PC: drag the corner handles in the preview window.
  5. Apply an entrance animation. With the logo layer selected, tap “Animate” (mobile) or the “Animation” panel (PC). Under “In,” choose an effect such as Fade In, Zoom In, or Slide Up. Set the animation duration to 0.5–1 second for a clean, controlled feel.
  6. Add your channel name as a text layer. Tap “Text” then “Add Text.” Type your channel name and adjust the font, size, color, and any shadow or outline using the styling panel. Position the text below or beside your logo.
  7. Animate the text with keyframes (optional). Tap the text layer, then tap the diamond icon on the timeline to set a keyframe at the starting position. Move the playhead forward slightly, reposition the text, and add a second keyframe. CapCut will smoothly interpolate the motion between them.
  8. Add audio. Tap “Audio” then “Sounds” to browse CapCut’s built-in library. Choose a short audio sting or rising tone that suits your brand, then trim it to match the intro length.
  9. Confirm total clip duration is 5–8 seconds. Drag the timeline end point to trim or extend the project. Play back the full intro to verify everything is in sync.
Customizing Your YouTube Intro — Text, Animations, and Music
Text
Font choice affects how professional your intro reads at a glance. Stick to one or two complementary fonts — a bold display font for your channel name and a clean sans-serif for any tagline. Avoid decorative fonts that become unreadable at small sizes, and always use manual text boxes rather than CapCut’s auto-caption tool so you retain full control over placement and timing.
  • Pair a bold header font with a simpler secondary font
  • Use a color that contrasts clearly with the background
  • Keep text on screen for at least 2 seconds so viewers can read it comfortably
Animations
CapCut gives you two animation options: preset in/out animations (quick to apply, great for most intros) and keyframe animation (manual, frame-level control for custom motion paths). For the majority of YouTube intros, presets applied with restraint are all you need.
  • Apply both an “In” and an “Out” animation to your logo and text layers
  • Use the same animation style across all elements for visual consistency
  • Avoid layering multiple effects on a single element — one clean motion reads better than three competing ones
  • Keyframes work best for subtle floating effects or custom movement paths
Music and Audio
CapCut’s audio library includes royalty-free tracks and sound effects suitable for intros. To add audio: tap “Audio,” choose “Sounds” from the CapCut library (or “Extracted” to pull audio from a video on your device), preview tracks, and select a short musical sting. Trim the audio to match your intro length exactly, and apply a brief fade-out at the end so it does not cut abruptly.
Note: Before publishing to a monetized YouTube channel, verify the license status of each CapCut track. Tracks labeled “for commercial use” are safe; others may trigger Content ID claims on your video.
Export Settings for Your YouTube Intro in CapCut
Getting the export right is just as important as the design itself. Here is the correct sequence:
  1. Tap the AI UHD button in the top-right corner (mobile or PC).
  2. Set the resolution to 1080p. This is the minimum recommended quality for YouTube. Use 4K only if your channel publishes in 4K and your device can produce that file size comfortably.
  3. Set the frame rate to match your main video content — typically 24fps or 30fps. A mismatched frame rate between your intro and main footage can cause stuttering in the final edit.
  4. Toggle off the CapCut watermark if that option appears on the export screen.
  5. Tap Export. The file saves to your camera roll (mobile) or downloads folder (PC). A 5–8 second 1080p intro should be well under 50MB.
Resolution
Best For
File Size
1080p / 30fps
Most YouTube channels
Moderate
4K / 30fps
High-production channels
Large
720p / 24fps
Fast uploads, small channels
Small
How to Add Your CapCut Intro to YouTube Videos
Once exported, dropping the intro into any video project takes two steps:
  1. Open your main video project in CapCut. Tap “Add Clip” at the very start of the timeline and select your exported intro file from your gallery.
  2. Drag the intro clip to the first position on the timeline. Check the cut point between the intro and the main footage and add a short crossfade or clean cut transition for a smooth handoff.
As an alternative, you can save your intro as a template in your CapCut personal library and reuse it at the start of future projects without re-importing each time.
Tips for Making Your YouTube Intro Look Professional
  • Keep it under 8 seconds. Viewer retention drops sharply in the opening moments. A tight, punchy intro performs better than a long, elaborate one.
  • Match your thumbnail style. Use the same fonts and colors as your channel thumbnails so the intro looks like part of a cohesive brand.
  • Limit your palette to 2–3 colors. A restricted color scheme looks intentional; too many colors create visual noise.
  • Pick one animation style and commit to it. Mixing fade, bounce, and glitch effects on the same five-second clip looks unfocused.
  • Use a consistent audio sting. A recognizable sound builds brand recall across videos — even a simple rising tone works if it appears in every upload.
  • Preview on a small screen before finalizing. Most viewers watch on mobile. Text and animations that look great on your monitor may be hard to read on a phone.
What size should a YouTube intro be in CapCut? Set the canvas to 16:9 at 1920x1080 pixels. When starting a new project, select the “YouTube” preset and CapCut applies this ratio automatically. This ensures your intro fills the player on all devices without black bars or unwanted cropping on any screen size.
How long should a YouTube intro be? 5–8 seconds is the recommended range for most channels. Longer intros risk early drop-off before your content even begins. For fast-paced or short-form content, a 3–5 second intro keeps the energy high and viewers engaged from the very first frame.
Does CapCut have free YouTube intro templates? Yes. CapCut offers a large library of free intro templates searchable directly inside the app. Some premium templates and select audio tracks require a CapCut Pro subscription to unlock, but there are plenty of polished free options to get started without spending anything.
Will CapCut add a watermark to my YouTube intro? CapCut may add its watermark by default on export. You can remove it by toggling off the watermark option on the export screen. On the free plan, this toggle is available in most regions with no subscription required — just disable it before tapping the final export button.
Can I use music from CapCut in my YouTube intro without copyright issues? Many tracks in CapCut’s library are approved for commercial use, but not all of them. Before publishing to a monetized channel, check the license label on the specific track you choose. Tracks marked as “commercial use available” are safe; others may generate Content ID claims on your video.
Whether you use a template for speed or build from scratch for full creative control, CapCut gives you everything needed to create a sharp, on-brand YouTube intro without expensive software. Keep it short, stay visually consistent with your channel, and always export at 1080p. If you are just starting out, try the template method first — it takes minutes and gives you a strong foundation to refine over time.
