Audio bitrate often gets ignored until something sounds off. Go too low, and your audio comes across muffled. Go too high, and you're using extra bandwidth for little or no real benefit. Every platform recommends different bitrate settings for the best audio quality. Codec selection also affects which bitrate gives the best results. This guide explains the recommended settings for popular streaming platforms. It also shows how to adjust them correctly in OBS Studio.
What Is Audio Bitrate?
Audio bitrate measures how much data is transmitted per second of audio, expressed in kilobits per second (kbps). Higher bitrates preserve more audio detail during the encoding process. Lower bitrates remove more data, which may add distortion and reduce clarity. It is separate from video bitrate, which controls visual quality and is managed independently in your encoder. The two numbers are adjusted in different places and serve different purposes.
Why Audio Bitrate Matters for Streaming
Bitrate has a direct effect on your audience's audio quality. Your software translates raw audio captured by your microphone into a compressed stream, and the bitrate controls how much of the original signal survives that compression. Getting this wrong has consequences for your audience, and the problems look different depending on which direction you miss.
Setting your bitrate too low produces:
Muffled or thin voice audio: Speech intelligibility drops, and music loses presence and high-frequency detail, making your stream feel amateurish regardless of how good your content is.
Listener drop-off: Viewers usually accept lower video quality before poor audio quality. Distorted or hollow voices often make people leave sooner than choppy video.
Platform rejection or degraded output: Some platforms require a minimum bitrate for certain content types. Files below that limit may be rejected or compressed again during upload.
Setting your bitrate unnecessarily high creates a different set of problems:
Wasted upstream bandwidth during live streams, which can destabilize your connection and force your encoder to drop video quality to compensate.
Automatic re-encoding by platforms, like Spotify, Apple Music, and YouTube, all transcode incoming audio to their own delivery standards. Sending a 320 kbps file when the platform delivers at 128 kbps means the extra data is discarded by their pipeline, not passed to the listener.
Missed codec requirements: Some platforms accept only specific codecs at specific bitrates. An unsupported combination can cause upload failures or introduce unexpected quality loss during the platform’s re-encode.
Recommended Audio Bitrate by Platform
The table below consolidates the recommended bitrate, accepted codecs, and encoding mode for every major platform. Use this as your primary reference before opening your encoder.
Platform |
Recommended Bitrate |
Accepted Codec(s) |
CBR or VBR |
Twitch |
128 - 160 kbps |
AAC |
CBR |
YouTube Live |
128 (stereo)–320 kbps (5.1 Surround Sound) |
AAC |
CBR |
YouTube Upload |
320 kbps (stereo), 512 kbps (5.1 Surround Sound), and 128 kbps (Mono) |
AAC |
VBR |
Spotify |
96 kbps (Normal) - 320 kbps (Premium - submit lossless source) |
OGG Vorbis / AAC |
VBR |
Apple Music |
256 kbps |
AAC |
VBR |
Apple Podcasts |
128 kbps mono / 192 kbps stereo |
AAC, MP3 |
VBR |
General Podcast Hosting |
64 kbps mono / 128 kbps |
MP3, AAC |
VBR |
Note: Many platforms reprocess files that exceed their recommended bitrate limit. Uploading a higher bitrate does not always improve playback quality. The platform decides the final output, not the original file..
Live Streaming Platforms
For Twitch, 160 kbps AAC in CBR mode is the practical standard. Twitch’s ingest servers accept up to 192 kbps, but the platform transcodes streams for viewers on its end, so pushing above 160 kbps rarely produces an audible difference for your audience. The extra data primarily taxes your upload connection without returning a quality benefit on the listener side.
YouTube Live accepts AAC audio up to 320 kbps. A stable upload connection can easily support a 192 kbps audio bitrate. It keeps voices and music sounding clear while leaving enough bandwidth for your video stream. Both platforms transcode on their end, which means your ingest bitrate sets a ceiling, not a delivery guarantee.
On-Demand and Music Platforms
Spotify delivers audio at 320 kbps OGG Vorbis to Premium subscribers and 96 - 128 kbps to free-tier listeners. When submitting through a distributor, upload WAV or FLAC source files so Spotify encodes directly from a lossless master. Submitting a 320 kbps MP3 results in Spotify re-encoding an already-lossy file, which compounds compression artifacts through generation loss.
Apple Music delivers at 256 kbps AAC. Like Spotify, Apple handles all transcoding from your submitted master. Send the highest-quality source file your distributor accepts.
For Apple Podcasts and general podcast hosting, 64 kbps mono is the standard for voice-only content. If your show includes music, sound design, or stereo placement, step up to 128 kbps stereo. Unlike streaming, podcast episodes stay saved on listeners' devices after downloading. So no wonder that the file size becomes more important. A 1-hour mono episode at 128 kbps takes around 58 MB. And most podcast apps and hosting platforms can easily support that size.
Which Audio Codec Should You Use?
The codec determines how audio is compressed before bitrate even becomes relevant. At an equivalent bitrate, different codecs produce meaningfully different output quality. A 192 kbps AAC file sounds noticeably better than a 192 kbps MP3 because AAC’s compression algorithm is more efficient. It retains more perceptible audio information at the same data rate.
Codec |
Best Use Case |
Supported Platforms |
AAC |
Live streaming, YouTube, Apple platforms |
Twitch, YouTube Live, YouTube Upload, Apple Music, Apple Podcasts |
MP3 |
Podcast RSS feeds, broad legacy compatibility |
Podcast hosts, legacy players, SoundCloud |
Opus |
Low-latency communication, low-bitrate clarity |
Discord, WebRTC applications, select podcast apps |
FLAC |
Source file archiving, lossless masters |
Not suitable for live streaming due to bandwidth overhead |
For live streaming, default to AAC. OBS Studio uses it by default, and both Twitch and YouTube Live prefer it. If your podcast distributor or RSS host only accepts MP3, use 128 kbps mono for voice-only content. Reserve Opus for communication tools like Discord, where its efficiency at low bitrates is a genuine technical advantage.
CBR vs. VBR: Which to Use for Streaming?
Scenario |
Recommended Mode |
Reason |
Live Streaming |
CBR (Constant Bitrate) |
Ingest servers require a predictable, steady data stream; variable packet sizes cause buffer instability |
Pre-Recorded Upload |
VBR (Variable Bitrate) |
Allocates more data to complex audio passages and less to silence; better quality-to-file-size ratio |
Note: Use CBR for any live stream going to Twitch, YouTube Live, or a similar ingest server. Use VBR when exporting a podcast episode, rendering a YouTube upload, or submitting audio to a music distributor.
How to Set Audio Bitrate in OBS Studio?
OBS Studio is the most widely used streaming encoder, and its audio settings are straightforward once you know where to look. The steps below apply to OBS Studio 29 and later on Windows and macOS.
Open OBS Studio and click Settings in the bottom-right controls panel.
In the left sidebar, select Output.
At the top of the Output panel, change the Output Mode dropdown to Advanced if it is not already set there. Simple mode limits your available codec and bitrate options.
Select the Audio tab within the Output panel. This tab is separate from the main Audio entry in the left sidebar – make sure you are in the Output section.
Locate Track 1 (or whichever track your stream uses) and find the Audio Bitrate field on that row.
Enter your target bitrate value: 160 kbps for Twitch, 320 kbps for YouTube Live, or the platform-specific value from the table in Section 3.
To confirm your codec, navigate to the Streaming tab within Output and verify your encoder is set to an AAC-compatible option. OBS defaults to AAC for audio on most systems, so this is usually already correct.
If you use multi-track recording, for example, a separate mic track and game audio track, repeat the bitrate setting for each active track from Track 2 through Track 6.
Click Apply, then OK to save your changes.
Before your next live session, run a short local test recording at the new settings and review the audio output to confirm it sounds correct before going live.
Streamlabs users: The equivalent path is Settings (gear icon) → Output → Streaming. The Audio Bitrate field appears in the same area and accepts the same kbps values.
Does Improving Your Source Audio Change What Bitrate You Need?
Raising your bitrate setting cannot recover audio that was captured poorly at the source. If your mic picks up hiss, echo, or clipping, a 320 kbps bitrate will not fix them. Instead, it keeps those unwanted sounds in the recording. The file also becomes larger while keeping those flaws in greater detail instead of producing cleaner audio.
The bitrate controls how much detail the encoder retains from the incoming signal, not how clean that signal was before it arrived.
This is why clean source audio should come first, not later. For streamers where capturing a clean signal is the real bottleneck, a microphone that delivers high-quality audio from the start makes every downstream setting more effective. The Hollyland LARK MAX 2, for example, records at 48 kHz / 32-bit Float with onboard AI noise cancellation, giving the encoder clean, high-resolution audio to work with before any bitrate decision comes into play.
Q: What is the best audio bitrate for Twitch streaming?
AAC is the best choice for live streaming. It comes selected by default in OBS Studio. Twitch and YouTube Live also recommend this codec. If your podcast host only supports MP3, choose 128 kbps for stereo audio. For voice-only episodes, 64 to 96 kbps mono is usually enough.
Q: Is 128 kbps audio good enough for streaming?
A 128 kbps bitrate is enough when the recording mainly contains spoken voices. At this setting, people can hear speech clearly without noticeable audio distortion. For music, sound effects, or content where audio fidelity matters to the experience, 192 kbps to 320 kbps better preserves frequency range and dynamic detail.
Q: Should I use CBR or VBR for live streaming?
Choose CBR whenever you stream live to online platforms. Live streaming services expect a steady and consistent data rate. VBR can cause buffering or unstable connections during live broadcasts. Save VBR for recorded videos uploaded after editing is complete.
Q: Does higher bitrate always improve audio quality?
Not beyond a certain threshold. For AAC, most listeners cannot perceive a quality difference above 192 kbps under normal listening conditions. Gains above 256 kbps are effectively inaudible on consumer playback hardware. Choosing a bitrate above the platform's limit offers no real advantage. The platform re-encodes your file before viewers receive the final stream.
Begin by checking your platform's recommended audio settings instead of guessing. Then choose the codec that matches your type of content. Use CBR during live streams and VBR for uploaded recordings. Test everything in OBS before going live to catch audio problems early.
