Undoubtedly, MP3 is one of the most common audio formats. Nevertheless, saving audio recordings as MP3 requires a bit of effort. For example, iPhones save audio as M4A by default. Audacity also needs an extra export step for MP3 files. This guide shows the easiest way to record or save audio as MP3 on every major device.
What You Need to Know Before You Start
You can get an MP3 file in two different ways. Record directly as MP3 from the beginning. You can also record in WAV, M4A, or AAC first. Then, convert the file to MP3 later. Both approaches work, and this article covers each one. MP3 is the standard choice because it pairs broad device compatibility with manageable file sizes. For most uses, 192 kbps is the recommended default bitrate, balancing audio quality with practical storage requirements.
How to Record Audio to MP3 on Your Smartphone
iPhone (iOS)
Apple’s built-in Voice Memos app saves all recordings as M4A by default, and there is no in-app setting to change this. Your two practical options are to record in Voice Memos and convert the file afterward, or to use a third-party app that exports directly to MP3, such as Voice Record Pro.
Steps to record as MP3 using Voice Record Pro on iPhone:
Download Voice Record Pro from the App Store. The free version supports MP3 recording.
Open the app and click the REC button at the bottom of the screen. Once done, you will be taken to the Preset settings of the New Recording.
Select the Quality of your recording by tapping Low, Medium, or High (recommended). Each quality option shows the default settings, such as format and bit rate, in which the audio will be recorded.
Now, tap on the Advanced tab next to the Preset tab at the top.
Set your Recording Format to MP3. You can also change sample rate, bit depth, and bit rate.
After that, tap the Start button on the top-right corner of the screen to begin recording.
To end the audio recording, click the Stop button at the bottom of the screen. And choose the location where you want to save the audio file.
Note: The free version of the Voice Record Pro app displays ads.
Android
Most Android voice recorder apps, including Samsung Voice Recorder and Google Recorder, do not offer MP3 as a selectable output format. For direct MP3 recording, two apps stand out: Hi-Q MP3 Voice Recorder and Easy Voice Recorder Pro.
Steps to record as MP3 using Hi-Q MP3 Voice Recorder:
Install Hi-Q MP3 Voice Recorder from the Google Play Store.
Open the app and tap the Settings icon.
Tap the GRANT PERMISSIONS button and allow microphone access.
Tap Recording, select Format, and confirm it is set to MP3.
Then, tap Bit rate and set it to your preferred value (192 kbps is recommended for voice).
Tap the red record button to start your session.
Tap stop when finished. The file saves directly to your device storage as an MP3.
Hi-Q MP3 Voice Recorder encodes in real time during the recording session, so no conversion step is needed after the fact. But the free version only allows 10 minutes of recording per clip.
How to Record Audio to MP3 on Windows
Audacity is the most widely used free audio recorder and editor on Windows. One source of confusion for new users is that older Audacity versions required a separate LAME encoder download. Audacity version 2.3.2 and newer already include the LAME encoder. You do not need to install anything else.
Steps to record and export as MP3 in Audacity:
Download and install Audacity from audacityteam.org and open the application.
Go to Edit and select Preferences.
On the Preferences dialog box, select Audio Settings in the left sidebar. Look for the Project Sample Rate option and set the value to 41000 Hz.
In the same Audio Settings, go to the Recording section. Click the dropdown menu next to Device, and select your microphone as an input device.
Press the red Record button and begin your session.
Press the black Stop button when finished.
Go to File → Export Audio to open basic export settings.
In the export dialog, set Format to MP3.
Set the Bit Rate Mode to Constant and Quality to 192 kbps. Name the file and click Export.
Bitrate at a Glance: 128 kbps produces smaller files but introduces audible compression artifacts, especially in music. For most voice recordings and podcasts, 192 kbps is a solid choice. 320 kbps delivers the highest MP3 quality and is best reserved for music recordings.
Quick alternative: You can record audio as an MP3 with the Sound Recorder app in Windows 11. Open the app, go to Settings, and choose MP3 as the output format. Then start your recording. It is a simple choice when you need a quick voice recording without installing another program.
How to Record Audio to MP3 on Mac
Mac users can record audio for free with GarageBand or Audacity. GarageBand already comes with every Mac. Audacity follows the same recording process as it does on Windows.
Steps to record and export as MP3 using GarageBand:
Open GarageBand from your Applications folder and select Empty Project.
When prompted to choose a track type, select Audio and click Create.
Go to Settings > Audio/MIDI, and select your Input Device.
Press the red Record button in the transport bar to begin.
Press Stop when your recording is complete.
Go to Share → Export Song to Disk.
Select MP3 from the format dropdown and use the quality slider to choose your preferred bitrate. High Quality corresponds to approximately 192 kbps.
Choose a save location and click Export.
If Audacity is already installed, the export process is identical to the Windows steps: File → Export → Export as MP3.
Note: QuickTime Player is a common first guess for audio recording on Mac, but it does not support MP3 export. QuickTime saves audio as M4A only, so use GarageBand or Audacity instead.
How to Convert an Existing Audio Recording to MP3
If you already have a recording saved as WAV, M4A, FLAC, or AAC and only need it in MP3 format, no re-recording is required. Below are the fastest options split by method.
Desktop Software (Fastest, No Upload Limits)
Desktop tools are the better choice for large files or recordings you prefer not to send to a third-party server.
Audacity: File → Import → Audio (select your file) → File → Export → Export as MP3. This reuses the same steps from the Windows recording section and supports nearly every major audio format.
VLC Media Player: Media → Convert/Save → Add your file → click Convert/Save → set the Profile to Audio - MP3 → choose a destination → click Start. VLC is free, widely installed, and handles the task reliably.
Online Converters (No Software Install)
Online converters work best for quick, one-off conversions on files under 100 MB.
CloudConvert (cloudconvert.com): Wide format support; lets you set a custom MP3 bitrate before converting.
Online Audio Converter (online-audio-converter.com): Straightforward interface; no account required for basic use.
FreeConvert (freeconvert.com): Drag-and-drop interface similar to CloudConvert with a clean layout.
Privacy note: Avoid uploading sensitive recordings such as confidential interviews, legal discussions, or private conversations to free online tools. Use Audacity or VLC locally for those files.
Tips for Getting Better MP3 Quality Before and After Recording
Bitrate settings only go so far. These practical steps make a larger difference than any format toggle.
Start with a better microphone: Recording a low-quality source at 320 kbps still produces a poor result. An external mic is the single highest-leverage upgrade available. For smartphone users, the Hollyland LARK A1 connects via USB-C or Lightning with no adapter required and includes 3-Level Intelligent Noise Cancellation that cleans up background noise before the signal reaches MP3 compression. For creators recording on location, the Hollyland LARK M2 weighs just 9g and runs for up to 40 hours on a charge, delivering wireless audio capture without compromising fidelity.
Use 192 kbps or higher: At 128 kbps, MP3 compression artifacts become noticeable, particularly during quiet pauses in speech or in music recordings. 192 kbps is the practical baseline for anything you plan to publish or share.
Record in a quiet space: Close doors, turn off fans or air conditioning when possible, and avoid rooms with hard, parallel walls that produce echo. A lower noise floor makes a significant difference, as MP3 compression tends to amplify background noise.
Normalize levels after recording: In Audacity, select your track and go to Effect → Volume and Compression → Normalize. Set the peak amplitude to -1.0 dB. This step prevents clipping and ensures your final MP3 is not too quiet on playback.
Can I record audio directly to MP3 without converting it afterward?
Yes. Some recording apps can create MP3 files without extra steps. Hi-Q MP3 Voice Recorder is one example for Android users. Audacity saves recordings in WAV before converting them to MP3. iPhones and many Android phones save audio in other formats instead. If you want MP3 right away, install an app that supports it.
What is the best MP3 bitrate for voice recording?
192 kbps is the standard recommendation for voice content, including podcasts, interviews, and lectures. 320 kbps is best for music recordings where you want the highest possible MP3 quality. 128 kbps is technically usable for low-bandwidth uploads but produces audible compression artifacts compared to higher bitrate settings.
Does converting WAV to MP3 reduce quality?
Yes. MP3 uses lossy compression, which permanently discards some audio data to reduce file size. The quality loss is subtle at 192 kbps or higher but is irreversible. Keep the original WAV file for backup and future editing, and export only the final version to MP3 for distribution or upload.
Is there a free app to record phone calls as MP3?
Android users can record calls with apps like Cube Call Recorder ACR. Some phones also need a helper app and Accessibility permission. Support depends on your Android version and phone model. On iPhone, the Phone app now includes call recording and transcription. Many third-party iPhone apps record calls by connecting them through their own servers with three-way calling.
The right method depends on your starting point. On a phone, use Hi-Q MP3 Voice Recorder on Android, Voice Record Pro on iPhone, or a third-party app with MP3 export on iOS. On a computer, Audacity is the free cross-platform standard for both recording and converting. Already have an audio file? Use VLC or Audacity on your desktop, or CloudConvert for a fast online job.
Before a long session, take two minutes to record a 30-second test clip and confirm that the output file carries an .mp3 extension. That one check saves a lot of re-recording.
