If you are unheard on the other side of the FaceTime call, chances are your mic is the one to blame. The fact that you can still hear them confirms your speakers or connection are fine. But did you know that most mic issues on an iPad can be fixed within a few minutes? Follow these seven fixes below in order. Each one is quick to try and targets a common cause first.
Why Your iPad Microphone Stops Working on FaceTime?
Five root causes cover the vast majority of cases. Identifying which one applies to you helps you skip ahead to the right fix.
Blocked or dirty microphone grille: Dust, lint, a case lip, or adhesive from a screen protector physically muffles the mic opening.
Revoked app permission: FaceTime was denied microphone access, either at first launch or through a later settings change.
Audio routed to a Bluetooth device: When a Bluetooth headset or speaker is connected, iOS sends mic input through that device, not through the iPad’s built-in mic.
iPadOS software bug: Certain iPadOS versions carry known audio session bugs that break microphone input in FaceTime specifically.
Hardware damage: The microphone itself is physically damaged or failed. This is less common, but it is the likely diagnosis if every software fix below fails.
Before You Troubleshoot — Check These Two Things First
These two checks take under 60 seconds each and resolve more FaceTime microphone problems than any software fix.
Is the Microphone Grille Physically Blocked?
iPad models place microphone openings in different locations depending on the generation. On most modern iPads, there is a mic at the top edge of the device. Some models also have one at the bottom edge near the charging port. Check both locations.
Remove your iPad case completely.
Hold the iPad under a bright light and look closely at the small pinhole openings along the top and bottom edges.
Check for lint, debris, adhesive residue from a screen protector, or a case lip that overhangs the mic opening.
If you spot a blockage, use a clean, dry soft-bristle brush (a clean toothbrush works well) to gently clear the grille. Avoid blowing compressed air directly into the opening at close range, as this can push debris deeper.
Reattach your case and test with a FaceTime call before moving on.
Are You Muted During the FaceTime Call?
The mute button inside a FaceTime call is easy to tap accidentally, especially when holding the iPad with two hands.
Start or rejoin a FaceTime call, then tap the screen once to bring up the call controls overlay.
Look for the microphone icon. If it shows a line through it, you are muted. Tap it once to unmute.
If you were not muted and the other party still cannot hear you, move to Fix 1 below.
Fix 1 — Disconnect Bluetooth Headphones or Speakers
When any Bluetooth audio device is connected to your iPad, iOS automatically routes both audio output and microphone input through that device. If your Bluetooth headset is in a bag across the room, has a low battery, or has a faulty built-in mic, FaceTime effectively has no working microphone input, even though the iPad’s built-in mic is perfectly fine.
Swipe down from the top-right corner of your iPad to open Control Center.
Press and hold the audio card (the block in the top-right cluster showing the app name or track name).
Tap the AirPlay icon and select iPad as the audio source.
Alternatively, go to Settings → Bluetooth and toggle Bluetooth off completely.
Or, tap the i icon next to the connected device and choose Disconnect.
Re-test FaceTime immediately after disconnecting.
If disconnecting the Bluetooth device restores your microphone, the issue is with that Bluetooth device, not the iPad. You can continue using FaceTime with the built-in mic or switch to a different audio device.
Fix 2 — Restart Your iPad
A simple restart can fix leftover audio conflicts from other apps. It also resets how the system assigns the microphone. This usually takes about thirty seconds.
If your iPad has a Home button:
1. Press and hold the Top button until the power slider appears.
2. Drag the “slide to power off” slider to the right to shut down.
3. After the screen goes dark, press the Top button again to turn the iPad back on.
If your iPad has Face ID (no Home button):
1. Press and hold the Top button and either Volume button simultaneously until the power slider appears. 2. Drag the slider to shut down.
3. After the screen goes dark, press the Top button to restart.
Once the iPad finishes restarting, open FaceTime and test before moving to the next fix.
Fix 3 — Check Screen Time Microphone Restrictions
Screen Time can restrict microphone access at the operating system level, which overrides the per-app permission you set in Privacy & Security. This is a common scenario on iPads shared between family members or set up by a parent for a child.
Open Settings and tap Screen Time.
Tap Content & Privacy Restrictions.
If the toggle is on, confirm FaceTime is listed under Allowed Apps and is enabled.
Look for any microphone-related restriction under Privacy & Security Changes and set it to Allow.
Note: If Screen Time is protected by a passcode set by another person, you will need that passcode to make any changes. Contact whoever set up Screen Time on the device.
Fix 4 — Update iPadOS
Apple regularly releases software updates that address audio and microphone bugs present in specific iPadOS builds. If you are running an older version, a pending update may already contain the fix you need.
Connect your iPad to Wi-Fi and plug it into power.
Open Settings → General → Software Update.
If an update is available, tap Update Now.
Consider backing up first via Settings → [Your Name] → iCloud → iCloud Backup → Back Up Now before the update begins.
Once the update installs and the iPad restarts, test FaceTime before opening any other apps.
Fix 5 — Toggle Airplane Mode On and Off
This resets network settings and rebuilds the connection system. It can fix FaceTime connection errors that sometimes look like microphone problems.
Swipe down from the top-right corner to open Control Center and tap the Airplane Mode icon. It will turn orange.
Wait 15 seconds.
Tap the Airplane Mode icon again to turn it off, then wait for your Wi-Fi or cellular connection to restore before making a test call.
Fix 6 — Reset All Settings
This is the last software step before assuming a hardware problem. Resetting all settings restores system preferences to default values. Your photos, apps, and personal files are not removed.
What gets reset: Wi-Fi passwords, Bluetooth pairings, display brightness, notification settings, privacy permissions, keyboard shortcuts, and VPN configurations.
What does not get erased: Photos, videos, apps, app data, contacts, messages, and downloaded content.
Open Settings → General.
Tap Transfer or Reset iPad.
Tap Reset, then select Reset All Settings.
Enter your iPad passcode if prompted, then confirm.
The iPad will restart and return to default settings. Re-enter your Wi-Fi password, open FaceTime, and test.
Use this step only after Fix 5 has failed. It rules out any remaining software configuration as the cause, but it cannot fix a physically damaged microphone.
Fix 7 — Test With an External Microphone and When to Call Apple Support
If all previous fixes do not work, the iPad microphone may be damaged. At this stage, the hardware is likely failing and needs inspection. Schedule a repair appointment as soon as possible. At the same time, use an external microphone to continue FaceTime calls.
To book a repair, visit apple.com/support or use the Apple Support app to schedule a Genius Bar appointment. Microphone repairs are covered under a flat out-of-warranty service fee, and manufacturing defects may still fall within warranty coverage.
How to Use an External Wireless Mic With Your iPad for FaceTime
The Hollyland LARK A1 is a wireless clip-on microphone system that connects to iPads through a direct wired receiver. There is no Bluetooth pairing, no app installation, and no manual audio input selection required. iPadOS detects the receiver as a microphone input the moment you plug it in.
Choose the right receiver for your iPad:
USB-C receiver: For iPad Pro (all M-series models), iPad Air (4th generation and later), and iPad mini (6th generation and later).
Lightning receiver: For older iPad models with a Lightning port.
Setup steps:
Plug the LARK A1 receiver into your iPad’s USB-C or Lightning port. iPadOS immediately detects it as an audio input with no additional configuration.
Clip the LARK A1 transmitter to your collar or shirt. Keep it within 200 meters of the iPad for a stable connection.
Check the LED on the transmitter. A solid blue light means it is connected and active. A flashing light means it is still in pairing mode. In that case, turn off the transmitter and press the button on it for 6 seconds to begin the pairing process. Throughout this process, make sure the receiver is already turned on and ready to be paired.
Set the noise cancellation level through the HollyAudio app (LarkSound app) on your iPad. The LARK A1 offers three levels of intelligent noise cancellation (Low, Medium, and High). For indoor FaceTime calls, Medium is the recommended starting point. Contrarily, you can press the yellow button once on the TX or RX to activate noise cancellation. But to set different levels, you will need the app.
Open FaceTime and start a call. The in-call microphone icon should appear unmuted, and the other party will hear you clearly through the transmitter. No additional input selection step is needed on the iPad.
Pro Tip: Even if your built-in mic works but sounds muffled or echoey, switching to the LARK A1 at noise cancellation Level 2 will noticeably improve your call quality, especially in rooms with hard floors or background noise.
Why can people not hear me on FaceTime but I can hear them?
This shows the issue is only with the microphone input. Your speaker and internet connection are working normally. Since you can hear the other person, FaceTime audio output is fine. The problem is only with what your iPad records and sends. Clean the microphone openings and remove any case blockage first. Then check Bluetooth routing and microphone permissions carefully.
Does FaceTime use a different microphone than other apps?
No. FaceTime relies on the same built-in mic used by other iPad apps. Unlike downloaded apps, it is part of the operating system itself. Because of this, it does not show up as a separate switch in microphone privacy settings. If your mic works elsewhere but not in FaceTime, the issue is usually a system glitch. It can also come from blocked microphone openings or certain audio modes like Voice Isolation.
My FaceTime mic works on iPhone but not iPad. Why?
Microphone permissions and hardware are completely independent on each device. Approval on iPhone does not affect iPad settings. Check microphone permission directly in iPad settings. Also inspect the iPad mic grille for blockage. The iPhone working does not guarantee the iPad is fine. Confirm that the iPad is signed into your Apple Account. Plus, ensure FaceTime is enabled in system settings on the iPad.
Will a Bluetooth microphone work with FaceTime on iPad?
Yes, but with one condition. iOS must be routing audio input through the correct device. If routing is set incorrectly, the Bluetooth mic will not capture input even while connected (see Fix 1 for how to correct this). A wired receiver like the one included with the Hollyland LARK A1 avoids this issue entirely, since plugging into the port causes iOS to route input automatically, with no manual selection required.
Start by disconnecting Bluetooth devices completely. If the problem continues, restart the iPad next. Then check Screen Time restrictions carefully. After that, install any system updates available. Try toggling Airplane Mode and test again. Then reset all settings if needed. Follow these steps in sequence for best results. If all fails, book a Genius Bar appointment for repair. Use an external microphone, like the Hollyland LARK A1. It offers a simple plug-and-play wireless mic for everyday use.
