Syscom 1000T
Syscom 1000T
Syscom 1000T
Syscom 1000T
Syscom 1000T
Syscom 1000T
Syscom 1000T
1 / 7
Syscom 1000T
1,000ft Full-Duplex Intercom System with Wireless Tally Support
$4,299.00
Add to Wishlist
  • 1000ft Broad Coverage
  • High-Quality Audio
  • Full-Duplex Calls
  • Easy Setup
  • Maximum 10 Users
  • Wireless Tally Function
  • Wide Range Compatibility
  • Tally Signal on the Screen
  • Long Running-time
  • Smudge-Proof Matte Finish
Syscom 1000T-4B
Syscom 1000T-4B
$4,299.00
Syscom 1000T-8B
Syscom 1000T-8B
$5,999.00
Syscom 1000T
$4,299.00
SYSCOM 1000T
1000FT Full-Duplex Intercom System Supports Wireless Tally
Hands-Free Full-Duplex Communication
With this full-duplex intercom system, audio transmission starts once you speak, and there is no need to press a button before talking (as is the case for a walkie-talkie). Its full-duplex feature allows communication in both directions, which guarantees efficient and agile team collaboration.
High Quality Audio
You can toggle between dynamic and electret modes by pressing a single button on the base station when needed to clearly convey the director's requirements. Each beltpack comes standard with a circumaural dynamic headset, which effectively reduces the ambient noise to ensure you won't miss any instructions.
FULL-Duplex Calls for Efficient Communication
The full-duplex intercom system can support simultaneous calls with 1 main station and up to 8 beltpacks. Say goodbye to the annoying problems of traditional walkie-talkies such as crosstalk and competing for the chance to speak and enjoy a quicker and smoother calling experience.
Plug and Play-Easy Setup
Just like any other Hollyland product this system works straight out of the box. Simply open the package and plug it in. Once your turn on the base station and the beltpacks,they will beautomatically paired. No learning is need. Just buy it and use it.
Maximum 10 Users
As single base station can enable simultaneous calls involving up to 10 parties.
Indicator Status
Red: Selected, the camera's signal is being used
Green: To be selected, the camera's signal will beused soon
Colorless: Unselected, you can check the device status and perform other operations.
Various Accessorriess for Easy Expansion
The base station not only supports calls with a gooseneck microphone and a speaker but also provides a LEMO headset jack and a 4-segment 3.5mmheadset jack for more flexible operation.
Empowered to Last All Day
The built-in lithium battery allows easier charging and eliminates the need to remove and reinstall batteries. The battery can keep each device working for up to 10 hours. Longer battery life means higher productivity.
