Soft Antenna
Soft Antenna
1 / 2
Soft Antenna
$17.00
With its flexible stem design, the Hollyland soft antenna can be easily adjusted to different angles, allowing for optimal placement and improved signal strength.
Compatibility
  • COSMO C1 / COSMO C2
Features:
  • Frequency range: 4.9GHz–5.9GHz
  • Gain: 4dBi
  • Impedance: 50Ω
  • SWR: 2.5 (max)
  • Color: Black
Weight:
  • Gross Weight: 29.5g
  • Net Weight: 19.0g
Included:
  • Soft Antenna*1
Soft Antenna
Soft Antenna
$17.00
Soft Antenna
$17.00
