Screw Fitting 02
Screw Fitting 02
$9.90
Add to Wishlist
The Screw Fitting 02 is for the use of mounting the Mars 4K or Cosmo C1 horizontally in necessary senarios. It comes a 1/4"-20 mounting thread to mount on to your cage or other gears that come with standard 1/4"-20 screw.
Compatibility
  • MARS 4K
  • COSMO C1
Material: ADC12 aluminum alloy
Color: Black blue
Weight: 16g (0.6oz)
Size: 45.5x18.38x12mm (1.8"x0.7"x0.5")
Included: Screw Fitting *1
Screw Fitting 02
Screw Fitting 02
$9.90
Screw Fitting 02
$9.90
