Mars T1000
Mars T1000
Mars T1000
Mars T1000
Mars T1000
Mars T1000
Mars T1000
Mars T1000
Mars T1000
Mars T1000
Mars T1000
Mars T1000
1 / 12
Mars T1000
$1,799.00
Add to Wishlist
  • 1000FT(300m) Transmission Range
  • 4-Person Full-Duplex Communication
  • High Audio Quality
  • Built to Power A Long Workday
  • Intuitive HD Display
  • Easy Cascading and Expansion
  • Supports External Tally
Mars T1000
Mars T1000
$1,799.00
Mars T1000
$1,799.00
MARS T1000
1000FT(300M) FULL-DUPLEX WIRELESS INTERCOM SYSTEM
The maximum communication distance between the base station and beltpacks is 300 meters, which is greater than the combined length of two soccer fields. This will ensure smooth communication between team members over long distances and allow them to collaborate more effectively in the field.
Hands-Free Full-Duplex Communication
With this full-duplex intercom system, audio transmission starts once you speak, and there is no need to press a button before talking (as is the case for a walkie-talkie). Its full-duplex feature allows communication in both directions, which guarantees efficient and agile team collaboration.
Intuitive HD Display-All Info at A Glance
The base station and beltpacks all come with high-definition OLED display, which can display important information including signal strength, remaining battery power, and connection status in real time. So, you can clearly and intuitively understand whether the beltpacks are working properly.
The base station is fitted with a dual-battery plate, and can be powered by dual F970 batteries or from a DC power supply. One F970 battery can ensure more than 20 hours of ultra-long operating time. And dual batteries mean you can replace a battery without turning off the device.
Dynamic Microphone, Carrier-Grade Audio Quality
The product comes standard with a dynamic headset. This professional noise-canceling headset can effectively isolate the ambient noise to ensure carrier-grade audio quality, so that you can easily hear your instructions. The 3.5mm headset jack allows you to also use your everyday headsets and enjoy more choices and flexibility.
Clearer, Faster, Preciser
Each belt pack is equipped with a 3.5mm external tally light jack and supports wireless tally function, which allows the director to send work instructions precisely and quickly.
Convenient Beltpack Charging&Firmware Upgrade
The base station provides 1 USB Type-C and 4 USB Type-A ports. The USB Type-C port can be used for firmware upgrade. The USB Type-A ports can be used to charge 4 beltpacks at the same time. Each beltpack can be used for more than 8 hours when fully charged. So, just charge all your devices at atime and then rest assured that they will last many hours.
Crew-Friendly 1 to 4 Design
The mini base station has a simplified design and is easier to operate. It can work with up to 4 mini beltpacks. It is suitable for a wide range of activities including small and medium team livestreaming, stage shows, EFP, live webcasting, and film & television production.
