Lark Max
Lark Max
Lark Max
Lark Max
Lark Max
Lark Max
Lark Max
Lark Max
Lark Max
Lark Max
Lark Max
Lark Max
Lark Max
Lark Max
Lark Max
Lark Max
Lark Max
Lark Max
1 / 18
Lark Max
$139.00 $249.00
Add to Wishlist
Discover the Hollyland Lark Max, the ultimate flagship wireless microphone that delivers unparalleled studio-quality audio. With professional ENC, it guarantees pristine sound. With 14-hour on-board storage recording, it doubles as a standalone audio recorder. Enjoy an impressive 820ft (250m) line-of-sight range and a remarkable 22-hour long duration. Compatible with a wide range of devices and featuring magnetic attachment for convenience. Elevate your audio game with the Lark Max!
Key Features:
  1.  Studio-Quality Audio
  2.  Professional ENC
  3. 14-Hour Recording
  4. 820ft (250m) LOS Range
  5. 22-Hour Long Duration
  6. Wide Device Compatibility
  7. Magnetic Attachment
-44%
Lark Max Duo
Lark Max Duo
$139.00 $249.00
-43%
Lark Max Duo + 2 Lav Mics
$151.00 $269.00
-35%
Lark Max Solo
Lark Max Solo
$102.00 $159.00
Accessories Options
Magnetic Pendant
Magnetic Pendant
$29.90
Magnetic Pendant: Designed for the Hollyland Lark Max microphone, but also suitable for other microphones or small items with a magnetic component. Comfortable Material: This lanyard is made of so...
Lark Max Lavalier Microphone
$29.00
Lavalier Microphone: 1pcs 3.5mm jack lavalier microphone for lark max microphone system, compact and durable. 1.2m(4ft) Length: Long enough to hide it in your coats, and convenient for some offici...
Phone Holder
Phone Holder
$12.90
Compatibility LARK 150 LARK M1 Feature 1. Aluminum alloy with lightweight and strong protection2. Integrated cold shoe design for an external microphone or fill light3. Thick protective pad4. 65~...
Mini Tripod Stand with Universal Clip
$35.99
Multifunctional  Tripod:• Compact and lightweight with only 170g• Foldable design for both handheld and desktop use• 4-section extendable design to adapt different scenarios• Mini and portable with...
$19.00
Compatibility LARK 150 LARK M1 Feature1. Lightweight and portable with an excellent load-bearing structure2. 4-segment height adjustable3. Integrated cold shoe design for an external microphone o...
Universal Phone Kit
Universal Phone Kit
$49.00
Compatibility:LARK C1LARK M1LARK 150 Features:Universal phone kit for vlogging, live streaming, and video shootingIt features two cold shoe ports and multiple 1/4 threaded holes and can be connecte...
Lark Max
$139.00
$249.00
Saved $110.00
Studio-Quality Audio With MaxTimbre Technology
8GB On-Board Storage for 14-Hour Backup Recording
Magnetic Attachment
Professional Environmental Noise Cancellation (ENC)
The LARK MAX is an all-in-one wireless lavalier microphone system with industry-first MaxTimbre Mic technology and advanced ENC technology providing an unparalleled crystal-clear sound. The transmitter has 8GB of built-in memory and supports up to 14 hours of backup recording. It is perfect for interviewing, vlogging, podcasting, electronic field production, online teaching, and any audio recording applications requiring high-quality audio pickup and a peace-of-mind audio backup solution.
Studio-Quality Audio with MaxTimbre Mic Technology
Industry-First Mic Technology
MaxTimbre
MaxTimbre Mic technology is a multilayer membrane microphone design that optimizes voice recording for crisp, clear results. The multilayer acoustic structure effectively eliminates unwanted resonances. It enhances performance with a durable mesh of superior wind-proof and vibration-isolation features.
High-Sensitivity Omnidirectional Microphone
48kHz/24-bit
The LARK MAX high-sensitivity omnidirectional 48kHz/24-bit microphone records full-range audio with incredible precision, clarity, and rich detail.
High Signal-to-Noise Ratio
70 dB
The LARK MAX SNR is 70 dB, which is crucial for recording in quiet environments.
Max Sound Pressure Level (SPL)
128 dB
The LARK MAX stands up to 128 dB of SPL, and its 98-106 dB dynamic range significantly reduces audio distortion when recording in complex environments.
Note: The maximum SPL is based on laboratory testing results, with the transmitter input gain set to the lowest level. For optimal recording results, it is recommended to place the transmitter at a proper distance from the audio source.
Advanced Technology
DSP
The LARK MAX utilizes Digital Signal Processing (DSP) technology to significantly enhance audio signal quality and reduce unwanted noise and interference.
Professional ENC
The LARK MAX utilizes advanced ENC technology to detect and minimize surrounding noise, ensuring the audio quality remains crystal clear and distortion-free, even in loud recording environments. It is user-friendly, allowing you to easily turn the ENC mode on or off from the transmitter or receiver.
The LARK MAX transmitter also serves as a standalone recorder with built-in 8GB of storage. Record up to 14 hours of uncompressed and lossless WAV files. The internal recording files are stored in the transmitter. You can turn on the Auto Record mode on the receiver to activate the transmitter's internal recording feature for extra audio safety, ensuring that you won't miss any important moments.
14 Hours
Backup Recording
8GB
Memory
Ultra-long
22-Hour Battery Life
The LARK MAX is designed with a compact charging case, so you can enjoy virtually unlimited recording adventures without worrying about battery life. The transmitter's operation time is about 7.5 hours and can reach up to 22 hours with a fully charged charging case. The receiver can operate for up to 9 hours, and it can be charged and used at the same time.
Note:
1. The data provided above is based on laboratory testing results.
2. The charging case is not included in the solo version.
Enjoy teaming the LARK MAX with mobile devices, cameras, or computers.
The 3.5mm output interface makes it compatible with many camera types — DSLR cameras, mirrorless cameras, action cameras, camcorders, and others. To connect the receiver to a camera, just use the 3.5mm TRS to 3.5mm TRS cable.
820ft (250m)
Stable Transmission with AFH Technology
The LARK MAX provides an ultra-long wireless line-of-sight (LOS) range of up to 820ft (250m) with dual high-gain antennas. It also adapts advanced adaptive frequency hopping (AFH) technology to effectively prevent signal drops and ensure a seamless audio recording experience.
  Note: The LOS range of 820ft (250m) is measured in an unobstructed outdoor environment free of interference.
Convenient
Magnetic Design
Each transmitter comes with a convenient back clip and a clip magnet. The transmitter weighs approximately 33g (1.16oz) and can easily be attached to any garment and other objects via the integrated back clip or the clip magnet.
User-friendly Design
The LARK MAX works perfectly with various recording devices and is paired and ready for use out of its charging case. Addressing different audio recording preferences with its flexible gain control allows you to precisely tailor the audio volume for an outstanding user experience.
Color AMOLED Touchscreen
1.1"
The colorful and vivid AMOLED touchscreen on the receiver allows you to adjust transmitter settings and provides a real-time visual check.
Quick Control
Knob
You can customize different settings quickly with the control knob.
On-Screen
Home Button
A single tap easily accesses the quick settings interface or returns to the previous interface.
Skin-like
Comfortable Touch
The LARK MAX has a sleek and stylish appearance, giving it a warm, comfortable, and natural feeling when touched.
Professional Functions
Recording Modes
Select the most suitable audio recording mode: mono, stereo, or safety track for recording security and more flexibility in post-production.
Mono
Stereo
Safety Track
EQ Settings
Hi-Fi
The Hi-Fi function provides high-quality audio recording with utmost precision and accuracy.
