COSMO C1
COSMO C1
COSMO C1
COSMO C1
COSMO C1
COSMO C1
COSMO C1
COSMO C1
transmitter and receiver
hollyland wireless video
transmitter
wireless video transmitter
wireless hdmi transmitter and receiver
1 / 13
COSMO C1
Stable, You Get It
$549.00 $899.00
  • HDMI & SDI connections on both the transmitter and receiver, plus an SDI loopout on the transmitter
  • Transmit up to 1000ft LOS range with ultra-low latency down to 40ms
  • Embedded UVC for direct 2160x1080/60p HD video feed to computer via USB-C
  • Superior anti-interference in the 5.1GHz-5.8GHz frequency
  • HDMI & SDI input plus SDI loopout on transmitter, and two SDI outputs and one HDMI output on receiver
  • Easy-to-read OLED display showing status and configuration
-38%
COSMO C1
COSMO C1
$549.00 $899.00
Accessories Options
Mushroom Antenna
Mushroom Antenna
$9.00
Compatibility MARS 4K MARS 400S PRO MARS 300 PRO COSMO C1 Features 5 dBi Double High-Gain 90 to 360° Rotating Anti-Pressure 5.8 GHz Transmission Rate Anti-Pressure Material Technology Gold-Pla...
Soft Antenna
Soft Antenna
$17.00
With its flexible stem design, the Hollyland soft antenna can be easily adjusted to different angles, allowing for optimal placement and improved signal strength. Compatibility COS...
D-TAP to DC 2.1 Power Supply Cable
$23.99
Usage: Connect the V-mount battery to power Hollyland video transmission products Weight: 27.5g length: 65 cm
Crab Clamp
Crab Clamp
$17.00
Features Rod diameter: 54mm (2.1") Material: Aluminium Color: Black Compatibility MARS 4K MARS 400S PRO MARS 300 PRO COSMO C1 MARS 400S PRO ll What's in the Box Crab Clamp*1
COSMO C1
$549.00
$899.00
Saved $350.00
