Subject Matter Expert Interview Template: The Complete Question Framework to Capture Expert Knowledge
Whether you are making an e-learning course or writing technical content, expert input matters. Even recorded interviews need solid questions to get useful answers. This template gives you a ready-to-copy framework for SME interviews. It keeps each interview phase organized and packed with useful questions. You will get clear answers you can actually use later.
What Is a Subject Matter Expert Interview (and When Do You Need a Template)?
An SME interview is basically a focused chat with an industry expert. The goal is to turn their knowledge into something useful. That could become a course, training module, article, or video. You’re also trying to uncover how they apply their knowledge. That includes tricky parts and lessons learned through years. Those details often come from experience, not just basic knowledge.
The two most common use cases are instructional design (capturing expertise to build e-learning or training content) and content production (developing thought leadership articles, white papers, or podcast episodes grounded in genuine expert insight).
Without a template, these interviews can easily go off track. Busy experts may give short answers without knowing your needs. Important topics can get missed along the way. Detailed insights might never make it into the conversation. A structured template keeps both sides on the same page.
Before the Interview: Preparation Checklist
The interview is only as good as the setup. Complete each of these steps before you start recording.
Before the Interview — Preparation Checklist
  1. Define the interview objective. Know what you need to produce, such as course module, article, or video script, before scheduling the session.
  2. Scope the topic boundaries. Agree with stakeholders on what is in and out of scope so the SME knows exactly where to focus.
  3. Research the SME’s background. Review their bio, published work, or any existing materials to avoid redundant questions and signal preparation.
  4. Customize the template. Replace placeholder terms like “[domain]” and “[topic]” with the specific subject area before the session.
  5. Send the pre-interview brief. Give the SME enough advance context to prepare thoughtful, specific answers (see the section below).
  6. Set up recording or assign a notetaker. Do not rely on memory alone. Confirm your recording setup works before the session begins.
  7. Build in buffer time. Schedule 15 extra minutes beyond your target length to accommodate overruns and follow-up questions.
What to Send the SME Before the Call
A brief one-page document sent before the session measurably improves answer quality. Include the following:
  • The session goal: One sentence explaining the final deliverable and how the SME’s input will be used.
  • Topic scope: A short list of areas you plan to cover so nothing comes as a surprise.
  • Estimated session length: Be specific, for example, “45 minutes, with 10 minutes for follow-up if needed.”
  • 3 to 4 anchor questions: A preview of your most important questions helps the SME recall relevant examples in advance.
  • Format and recording details: Whether the session will be recorded, how it will be used, and any consent requirements.
Do not send every question on the template. Over-scripting leads to rehearsed answers that lack the spontaneous depth you need.
The Subject Matter Expert Interview Template
Use this template as your working interview guide. Each phase builds on the last, moving from context and rapport into deep knowledge extraction before closing with forward-looking insights. Replace all bracketed placeholders with terms specific to your subject area.
Phase 1: Opening and Context (Rapport and Framing)
Purpose: Establish the SME’s experience level, define how they frame the subject area, and surface the misconceptions that shape your audience’s starting point. These opening questions ease the SME into the conversation and set the foundation for everything that follows.
  1. How long have you been working in [domain], and what does your current role involve day to day?
  2. How would you describe [topic] to someone who has absolutely no background in this area?
  3. What is the most common misconception people have about [topic] when they first encounter it?
  4. How has your understanding of [topic] changed over the course of your career?
  5. If you had to name the single concept most central to understanding [domain] at a deep level, what would it be?
Follow-up prompt: “You mentioned [concept or term] — can you say a bit more about what that looks like in practice?”
Phase 2: Core Knowledge Extraction
Purpose: This section is where the most valuable expert insights come out. These questions reveal knowledge experts often apply without thinking. They also cover things experienced people rarely write down. Focus on their process, choices, and reasons behind those decisions. Don’t just ask about the final results or outcomes.
  1. Walk me through how you would approach [core task or process] from start to finish.
  2. When you’re making decisions about [key decision point], what factors are you weighing?
  3. What does a good [output or result] look like in practice? How do you know when you’ve gotten it right?
  4. What mental shortcuts or rules of thumb have you developed over the years that guide your work in this area?
  5. When two experienced people in [domain] disagree, what is it usually about?
  6. How do you handle [common variable or constraint] when it changes the standard approach?
  7. If you were teaching this to someone starting from scratch, what would you make sure they understood in the first week?
  8. What do most training programs or published resources get wrong about [topic]?
Follow-up prompt: “Can you give me a specific example of a time you applied that approach?”
Follow-up prompt: “What would happen if someone skipped that step or ignored that factor?”
Phase 3: Challenges, Errors, and Edge Cases
Purpose: This phase consistently produces the most instructionally rich content in the entire interview. Errors and edge cases reveal the full shape of a skill in ways that ideal-scenario descriptions never do. These answers are also the most quotable for articles and the most memorable for learners.
  1. What is the most frequent mistake you see people make in [domain]?
  2. Tell me about a time a standard approach failed. What happened and how did you respond?
  3. What is a problem that looks simple from the outside but is significantly harder once you are actually dealing with it?
  4. What do people typically underestimate about [topic] until they have real hands-on experience?
  5. When something goes wrong in [domain], what are the early warning signs that an experienced practitioner notices first?
  6. Are there situations where the widely accepted approach in [domain] actually makes things worse? What do you do instead?
  7. What failure modes do you watch for most closely in your own work?
Follow-up prompt: “What would you tell a less experienced colleague to do differently if they could go back?”
Phase 4: Nuance, Exceptions, and Expert Judgment
Purpose: These questions move beyond documented process into the judgment calls that only experience creates. Use this phase for advanced L&D content where learners need to operate independently, or for thought leadership articles that take a credible, differentiated position on a contested topic.
  1. In what situations does the standard approach to [topic] not apply?
  2. How do you adjust your thinking when the context changes significantly — for example, [describe a relevant contextual variable]?
  3. What is something that is technically correct but frequently applied in the wrong situations?
  4. What advice do you see repeated in this field that you believe is outdated or oversimplified?
  5. Where is there genuine expert disagreement in [domain] right now, and where do you personally stand?
Follow-up prompt: “How long did it take you to develop that judgment, and what experiences shaped it most?”
Phase 5: Closing and Future-Facing
Purpose: Wrap-up questions that add editorial richness, surface recommended resources, and invite the SME to share what matters most to them. These questions also provide natural transitions for article conclusions and course summaries.
  1. What resources, such as books, communities, people, and tools, would you recommend to someone who wants to go deeper in [domain]?
  2. What trends or shifts in [domain] are you watching most closely right now?
  3. What do you wish more people understood about [topic] that rarely gets discussed?
  4. Is there anything we have not covered that you think is important?
Note: Before ending the session, confirm whether the SME is available for a brief follow-up by email or a second session if gaps emerge during content production. Most will agree if you ask clearly and define the scope.
How to Adapt This Template for Different Use Cases
The full five-phase template works best for 45- to 60-minute sessions. For shorter or more focused sessions, use the table below to identify which phases to prioritize and which to compress.
Use Case
Phases to Prioritize
Phases to Compress
L&D / Instructional Design
Phase 2 (Core Knowledge), Phase 3 (Errors and Edge Cases)
Phase 1 (reduce to 2 questions), Phase 5 (skip trends)
Content Marketing / Thought Leadership
Phase 1 (quotable framing), Phase 4 (expert opinion), Phase 5 (trends and resources)
Phase 3 (limit to 2 to 3 key mistakes)
Recorded Video / Podcast Interview
Phase 1 (narrative intro), Phase 2 (story-driven process), Phase 5 (closing insight)
Phase 3 and Phase 4 (select 1 to 2 questions each)
For content marketing, add a question about the expert’s unpopular opinion. Ask what they believe differently from most people. These answers often create the most shareable and engaging content.
Tips for Getting Better Answers During the Interview
Use silence as a tool. When an SME finishes a short answer, resist the impulse to move immediately to the next question. A two- to three-second pause signals that you are expecting more, and most people will fill that silence with a deeper, more considered response than what they gave you first.
Ask for concrete examples after abstract answers. If an SME says “you have to be very careful at that stage,” follow with “Can you describe a specific situation where that played out?” Concrete examples are what learners remember and what readers share. Abstract principles provide scaffolding; stories carry the actual content.
Use the explain-it-simply redirect. When an SME slips into dense jargon or highly technical language, try: “How would you explain that to someone who has never worked in this field?” This almost always produces cleaner, more transferable answers without making the expert feel corrected or talked down to.
Break complex topics into sub-questions. If a question produces an overwhelming or scattered answer, pause and chunk it down. “Let’s take that piece by piece — starting just with [first sub-component], what does that involve?” Chunking keeps the session manageable and makes your transcript far easier to organize afterward.
Recognize when an SME is in presentation mode. Some experts switch to polished answers once recording starts. If they sound rehearsed, change up your questions. Ask about a failure, unpopular opinion, or recent change of mind. That can bring the conversation back to honest reflection. Those moments often reveal the most useful insights.
Recording, Transcription, and Documentation
Even the best interview template produces limited value if the capture workflow is weak. Record every session with the SME’s explicit consent, and run the audio through transcription software to create a searchable, editable text document your team can work from directly.
Good audio can make your transcript way cleaner and easier. Poor audio can confuse transcription tools and create tons of corrections. Important details can also get lost when recordings sound messy. That’s why a wireless lav mic can be a smart upgrade. The Hollyland LARK MAX 2 makes a strong choice here. It records at 48 kHz/32-bit Float for clear, broadcast-ready audio. AI Noise Cancellation helps reduce unwanted sounds around busy recording spaces. Real-time OWS wireless monitoring also lets you spot audio problems right away. That means fewer surprises when you review the final recording.
Assign a dedicated notetaker if the session is not being recorded, or designate a team member to drop timestamp markers during the recording at key answers, quotable moments, and topic transitions. These markers reduce post-session processing time significantly.
How long should a subject matter expert interview be?
The full five-phase template works well in a 45- to 60-minute session. For a focused, single-topic session, 30 minutes is achievable if you limit the interview to Phases 2 and 3. Avoid scheduling longer than 60 minutes unless the SME specifically allows for it; answer quality and attention tend to drop off after that point.
Should I send all questions to the SME in advance?
Give the expert some context before the interview begins. Share three or four main questions before the session. Keep your remaining questions private until the conversation starts. Giving everything away can make responses sound overly rehearsed. You want thoughtful answers based on real experience instead. Leave room for unexpected stories, opinions, and useful insights.
How many SME interviews do I need for one course or article?
For a single-topic e-learning module, one well-structured interview is typically sufficient. For larger courses, consider interviewing several experts across separate sessions. Two to three sessions can reveal different professional opinions. This gives your content more perspectives from experienced specialists. It also keeps one expert from dominating your entire project.
What is the difference between an SME interview and a stakeholder interview?
Stakeholder interviews capture project goals, constraints, audience needs, and organizational priorities. SME interviews capture technical knowledge, domain processes, and expert judgment. They serve different phases of a project and require different question structures. Most instructional designers run stakeholder interviews first, then use those outputs to scope their SME sessions.
How do I handle an SME who gives short or unhelpful answers?
Try asking for a real example from experience. You can also ask how someone might approach it incorrectly. Both questions encourage stories instead of simple statements. Stories often reveal details that basic answers leave out.
Think of this template as your starting point, not strict rules. Change the questions based on your subject and project needs. Spend more time on phases that matter most. Keep improving your approach after every expert conversation. Save this guide before your next SME interview session. For regular experts, keep a collection of useful questions. Better organization upfront can make later content creation easier.
