Your iPhone can record excellent videos without extra equipment. The Camera app gives you plenty of recording options. You can film family moments, social media content, or short films. Many of these options are easy to miss. This guide covers the main steps for recording video. You will learn about modes, quality settings, and recording techniques.
How to Start Recording Video on iPhone
Opening the Camera app and pressing Record is simple, but a few small details make the difference between clean footage and a re-shoot. Follow these steps the first time, and they will quickly become automatic.
Open the Camera app. Tap the Camera icon on your Home Screen or App Library. The app opens in Photo mode by default.
Switch to Video mode. Tap on the “Video” option at the bottom of the screen.
Frame your shot. Point your iPhone at the subject. Tap the screen to set focus and exposure where you want them.
Lock focus and exposure (recommended). Tap and hold your subject until the AF/AE Lock banner appears at the top of the screen. This prevents the camera from readjusting mid-recording.
Start recording. Tap the red Record button at the bottom of the screen. A recording timer will start, confirming that the recording is in progress.
Pause if needed (iOS 18 and later). A Pause button appears alongside the Record button on supported models. Tap to pause, tap again to resume. When you stop, all segments from that session merge into one video file.
Stop and save. Tap the Stop button to end the recording. Your video saves automatically to the Camera Roll.
Find your clip. Open the Photos app, tap Albums, and select the Videos album. You can also scroll through Recents to locate it.
Quick-Launch Shortcuts for Faster Access
Lock Screen swipe: From the Lock Screen, swipe left to launch the Camera app. You do not need to enter your passcode first. The app normally opens with Photo mode selected. Switch to Video mode before you start recording. You can change this swipe option through Camera settings.
Control Center shortcut: Swipe down from the top-right corner to open Control Center. Press and hold to start editing the controls. Add Camera if its control is not already there. Then tap Camera whenever you need quick access.
iPhone Video Modes Explained
Swiping through Camera modes without understanding their differences leads to missed shots and wrong-format footage. Here is what each built-in video mode does and when to reach for it.
Mode |
Best For |
Minimum iPhone Required |
Video |
Everyday recording, social media, events, and travel |
All iPhone models |
Cinematic |
Storytelling with automatic, film-like focus transitions and shallow depth of field |
iPhone 13 |
Slo-Mo |
Sports, fast action, or detail captured at 120fps or 240fps for slow-motion playback |
iPhone 5s (120fps) / iPhone 6 (240fps) |
Time-Lapse |
Sunsets, cityscapes, crowds, or any long-duration scene compressed into seconds |
All iPhone models |
Action Mode |
High-motion shooting such as running, cycling, or sports that demands maximum stabilization |
iPhone 14 |
Video is the right starting point for nearly all recordings. Swipe to it by default unless you have a specific reason to use another mode.
Cinematic Mode records up to 4K at 30fps and applies rack focus automatically, shifting focus between subjects the way a professional camera operator would. You can adjust or override focus decisions during and after recording.
Slo-Mo captures at a higher frame rate than normal playback speed, so the Camera app stretches the footage into slow motion. At 120fps, motion plays back at one-quarter speed; at 240fps, it drops to one-eighth speed. Best used for anything fast and fleeting.
Time-Lapse captures frames at intervals and compresses them into a short clip. Mount your iPhone on a stable surface, select Time-Lapse, and let it run for the duration of the event you want to document.
Action Mode (iPhone 14 and later) applies aggressive electronic image stabilization to footage recorded while you move. Expect a modest crop, but a significantly steadier result.
Note: ProRes is a high-quality recording format for certain iPhone models. Apple introduced it with the iPhone 13 Pro and Pro Max. You can find it as an option inside Video mode. It does not appear as a separate camera mode. ProRes files take up much more storage than HEVC files. They are mainly useful for advanced video editing software.
How to Adjust iPhone Video Quality Settings
Resolution and frame rate defaults are not set in the Camera app itself. These controls live in the Settings app, and adjusting them takes under a minute.
Navigation path:
Open the Settings app.
Scroll down and tap Camera.
Tap Record Video.
Select your preferred resolution and frame rate combination from the list.
Options available (choices may vary by model):
720p HD at 30fps
1080p HD at 30fps
1080p HD at 60fps
4K at 24fps
4K at 30fps
4K at 60fps
Choosing your resolution:
Resolution determines how many pixels make up each frame. 4K produces the sharpest image and provides flexibility to crop or reframe during editing without visible quality loss. 1080p results in smaller file sizes and plays back smoothly on virtually all screens and platforms. For most casual recordings, the difference between 4K and 1080p is subtle unless you are viewing on a large 4K television or monitor.
Choosing your frame rate:
Frame rate affects how motion looks and how large your files become. 24fps carries a cinematic, film-like quality associated with professional productions. 30fps is common for social media, news, and everyday videos. It keeps movement smooth and natural on most screens. 60fps delivers noticeably fluid motion and is particularly useful when shooting fast-moving subjects or when you want to slow footage down in editing without introducing a choppy look.
Practical recommendation: For most users, 1080p at 30fps is a reliable default that balances image quality with storage efficiency. If you plan to edit, reframe, or display footage on a large screen, upgrade to 4K at 30fps for added flexibility.
Two additional toggles worth reviewing:
Auto Low Light FPS: When active, the camera automatically drops to 24fps in dim environments to allow more light per frame. Leave this on unless you require a consistent 30fps regardless of lighting conditions.
HDR Video: Captures a wider range of highlights and shadows simultaneously. Useful for high-contrast outdoor shooting. Available on iPhone 12 and later.
In-Camera Settings You Can Change While Recording
Zoom: Pinch two fingers outward on the viewfinder to zoom in during an active recording. Depending on your model, optical zoom steps at 1x, 2x, and 5x are available before the camera shifts to digital zoom.
Focus and exposure lock: Tap and hold on your subject before or during recording until the AF/AE Lock banner appears. This prevents the camera from hunting focus when something passes between you and the subject.
Flip the camera: Tap the camera-flip icon to switch between rear and front-facing cameras at any point during recording. The recording continues without interruption.
Tips to Get Better iPhone Video Quality
These shooting habits make an immediate difference to your footage without requiring any additional gear:
Face your subject toward the light: Natural light from a window or the sun produces clean, well-exposed video. Shooting with light directly behind the subject creates silhouettes and forces the camera to underexpose the scene.
Hold your phone in landscape orientation: A horizontal frame suits most platforms, television screens, and wider displays. Portrait orientation is appropriate for Reels and Stories, but landscape gives you more flexibility during editing.
Stabilize your shot: Keep your elbows pressed against your body to reduce hand movement. A small tripod, a grip handle, or resting the phone on a flat surface removes the micro-tremors that reveal unsteady handheld footage.
Clean the lens before you start: The lens collects fingerprints and pocket lint throughout the day. A quick wipe with a soft cloth before recording removes smears that cause blurring and lens flare.
Lock focus and exposure before pressing Record: Tap and hold on your subject until AF/AE Lock confirms. This stops the camera from readjusting when the scene or available light shifts slightly mid-shot.
Leave buffer space at the frame edges: Keep your main subject slightly inset from the edges of the frame. Stabilization processing and any cropping in editing both consume the outer edges, and a little breathing room protects your intended composition.
How to Improve Audio Quality When Recording iPhone Video
Clear video is only part of a viewer's overall experience. Bad audio can quickly make good footage seem unprofessional. Muffled voices, wind noise, and room echoes can ruin recordings. Audio problems can also be harder to fix later.
The iPhone’s built-in microphone sits on the bottom edge of the device. In quiet, close-range conditions, it performs reasonably well. In practice, most real-world recording situations introduce one or more of these common problems:
Distance: A subject standing more than a few feet from the phone will sound thin and faraway in the recording.
Wind noise: Even mild outdoor breezes generate a persistent low rumble that overwhelms dialogue when picked up by a bottom-mounted microphone.
Room echo: Bare walls, hard floors, and large spaces reflect sound back into the microphone, producing a reverberant, hollow quality.
Background noise: Crowds, traffic, and ambient environment blend into the recording and compete directly with your subject’s voice.
The most effective fix for all of these issues is an external microphone that captures audio close to the source, regardless of where the phone is positioned.
The Hollyland LARK A1 is a wireless microphone system built for this exact use case. Its compact receiver plugs directly into the iPhone’s Lightning or USB-C port. No dongle, no Bluetooth pairing, and no app required. The transmitter clips to the speaker’s clothing and captures audio at the source. Three-Level Intelligent Noise Cancellation filters wind and background interference automatically. Getting started takes four steps:
Plug the LARK A1 receiver into your iPhone’s Lightning or USB-C port.
Clip the transmitter onto the speaker’s collar or lapel.
Open the Camera app and navigate to Video mode.
Tap Record. The microphone activates immediately and begins capturing clean, close-up audio.
For vloggers and solo creators who prefer a more minimal setup, the Hollyland LARK M2 is a fully wireless clip-on microphone weighing just 9 grams with extended battery life. It is a compact alternative well suited to run-and-gun shooting where simplicity matters.
Can I record 4K video on all iPhone models?
4K recording was introduced with the iPhone 6s, but not every frame rate is available on every model. 60fps recording at 4K requires an iPhone 8 or newer. Cinematic Mode in 4K starts with the iPhone 14 series. To confirm exactly what your device supports, open Settings > Camera > Record Video and review the options listed for your specific phone.
Why is my iPhone video blurry or shaky?
Blurry footage is most often caused by a smudged lens, low light, or the camera searching for focus mid-recording. Wipe the lens, improve your light source, and lock focus before pressing Record. Shaky footage usually comes from hand movement during recording. Brace your arms against your body, use a tripod, or enable Action Mode on iPhone 14 and later for stronger electronic stabilization.
How do I record video on iPhone without the shutter sound?
Put your iPhone into silent mode before recording video. Older models have a Ring/Silent switch for this. Newer models may use the Action button instead. Some countries require camera sounds by local regulations. Japan and South Korea are examples of such regions. Those sounds cannot be turned off through settings.
Does recording in 4K use more storage?
Yes, the difference in storage consumption can be quite large. One minute of 4K video can take around 350MB. By comparison, 1080p footage may need 60MB to 130MB. The exact amount depends on your codec and recording settings. If storage is limited, 1080p at 30fps makes sense. iCloud Photos can also help free up device storage. Choose Optimize Storage to keep smaller copies locally.
Why does my iPhone video sound muffled or echoey?
The built-in microphone struggles with distance, wind, and room reflections. Recording in smaller spaces filled with soft furnishings such as rugs and curtains helps absorb echo. For consistently clean audio in any environment, an external clip-on microphone like the Hollyland LARK A1 captures audio from the source and filters background noise automatically, solving the problem at the point of capture rather than in post-production.
Start by opening the Camera app and selecting Video mode. Then choose your preferred resolution and frame rate. Record in good lighting while keeping your phone steady. These simple steps can improve your videos considerably. If audio still sounds weak, consider an external microphone. The Hollyland LARK A1 can make a noticeable difference.
