Recording a piano at home does not require a professional studio, but mic placement makes or breaks the result. Positioning a microphone above the instrument is one of the most reliable approaches for home recordists because it captures the piano’s full tonal range without amplifying key noise or hammer thud. This guide shows where to place your mic and adjust levels. It also explains how grand and upright piano setups differ.
Why Recording Above a Piano Captures Its Best Sound
A piano does not spread its sound evenly in every direction. On a grand piano, sound travels upward through the open lid and reflects off its angled surface into the room. Positioning a microphone above the string plane puts the capsule directly in the path of the instrument’s most balanced projection, where bass body, midrange clarity, and high-end harmonic detail are all available from a single capture point.
Upright pianos project differently. The soundboard faces the wall behind the instrument, but a significant portion of sound exits through the open top board. Placing a mic above that opening captures upward sound cleanly. It also avoids mechanical noise from the cabinet's front.
Close-miking inside the piano body isolates string and hammer sound but also amplifies key click, hammer thud, and pedal mechanism. Above-piano placement provides natural distance averaging, producing a balanced tone that needs less corrective work before use.
What You Need to Record Above a Piano
Condenser microphone. A large-diaphragm condenser is the preferred choice. A piano produces fast transients across a wide frequency range, and condenser capsules resolve them accurately. Budget clip-on mics and most dynamic microphones will compress or color that transient detail.
High SPL tolerance. An acoustic piano at full forte can exceed 95 dB at close range. Your microphone needs a maximum SPL rating above 120 dB to handle forte and fortissimo passages without distortion.
Boom arm mic stand. A fixed-height stand cannot reach the correct position above a grand piano lid or an upright’s top board. A boom arm provides both vertical reach and horizontal angle adjustment.
Recording interface or integrated recorder. Use a clean preamp connection from your mic to the recorder. Choose USB-C or XLR, depending on your recording gear.
Monitoring earbuds or headphones. Essential for finding the tonal sweet spot without needing a second person to move the stand while you play.
For this guide, the demonstration microphone is the Hollyland MELO P1. Its 1-inch large-diaphragm condenser capsule handles the piano’s full-frequency output, and its 132 dB Max SPL rating means it will not distort on even the loudest chord voicings. The MELO P1 includes wireless monitoring earbuds that are used directly in the positioning steps below. Its companion HollyAudio App provides real-time volume control and level metering from your phone. Mount the MELO P1 on a standard boom stand using its compatible mount so it can be positioned above the instrument.
How to Position a Microphone Above a Grand Piano
Open the grand piano lid fully. Full-open produces the most balanced frequency capture. Half-stick is a valid option for a slightly warmer, more contained tone because it allows some low-frequency buildup inside the lid. Avoid recording with the lid fully closed. Above-placement loses most of the instrument’s projection if the lid is down.
Set up the boom stand beside the piano body. Extend the boom arm over the open lid. Hang the mic capsule 8 to 18 inches above the string plane. Start at 12 to 14 inches for your first test.
Center the capsule over the midrange strings. The midrange area (roughly middle C and the two octaves above and below) produces the most balanced blend of bass warmth and treble clarity. Avoid centering directly over the bass strings, which will bias the capture toward a muddy low end.
Angle the capsule slightly toward the bass strings. Bass strings generate lower acoustic output than treble strings at equal key velocity. A tilt of roughly 15 to 20 degrees toward the bass side compensates for this imbalance and produces a flatter overall frequency response.
For stereo, use an XY pair above the string midpoint. Place two cardioid capsules angled at 90 degrees to each other, spaced 20 to 30 cm apart above the midpoint of the strings.ORTF offers another setup, with 17 cm between capsules. Their axes form a 110-degree angle. Stereo above-placement preserves the instrument’s natural spread from bass on the left to treble on the right.
Plug in the MELO P1’s bundled monitoring earbuds. With the earbuds connected, play a wide dynamic range passage from pianissimo through forte. Slowly adjust the boom arm height and horizontal position while listening. The tonal balance shifts noticeably as the capsule moves across the string plane. Stop at the position where the low end feels full without obscuring midrange definition.
Open the HollyAudio App and check input levels. Navigate to Input Volume and play a forte passage while watching the real-time level meter. Your peak should land between -12 and -18 dBFS. This headroom protects the recording when a passage unexpectedly climbs to fortissimo. If peaks are hitting above -6 dBFS consistently, reduce the gain slider.
Enable 32-bit Float recording in the HollyAudio App. Even if your gain setting is imperfect, 32-bit Float preserves the complete dynamic range in the recorded file, including transient peaks that exceeded the analog gain ceiling. This is your safety net against unpredictable SPL spikes during a live performance take.
How to Position a Microphone Above an Upright Piano
Confirm the top board is fully open. The top lid of the upright must be open for above-placement to work. If the pianist normally keeps it closed, use a foam wedge, small book, or rubber block to hold it open during the session.
Position the mic stand directly behind the upright or slightly to one side, above the top opening. The capsule should sit 12 to 24 inches above the opening. Start at 15 inches for your initial test.
Angle the capsule downward and slightly toward the strings, not toward the front of the instrument. Pointing toward the pianist’s side picks up breath noise, room reflections from the front wall, and pedal mechanism sounds. Angling the capsule down toward the strings keeps it oriented at the primary sound source.
Test two positions: farther over the opening versus held just at the edge. Moving the capsule higher inside captures more string and hammer detail. Placing it near the top board's edge captures richer cabinet resonance. Neither approach is always better for every recording situation. Your choice depends on the music and recording style.
Plug in the MELO P1’s monitoring earbuds and walk the position. Upright pianos have a narrower projection zone than grand pianos, so small horizontal adjustments make a larger tonal difference. With the earphones in, play the piano and slowly move the capsule from the far edge above the cabinet to directly over the strings. Stop at the point that produces the most balanced tone between bass weight and treble clarity.
If the room is acoustically live, engage AI Noise Cancellation in the HollyAudio App. A mic positioned high above an upright is farther from the direct sound source than a close-mic setup, so it picks up ambient noise more readily. Open the HollyAudio App, locate the AI Noise Cancellation toggle, and enable it at the lowest effective setting that removes HVAC and ambient noise without softening piano attack transients.
Dialing In Your Recording Settings
Gain staging for piano recording requires setting levels based on the loudest passage you expect to play, then leaving additional headroom for the unexpected. Piano dynamic range is wide. A pianissimo passage might peak at -30 dBFS while a forte chord on the same recording hits -8 dBFS. Setting gain for average levels can cause clipping during louder moments.
Step-by-step gain setup using the HollyAudio App:
Open the HollyAudio App and select the MELO P1 from the connected device list.
Under the Volume tab, locate the Mic option in the Input section (represented by “In”).
Play the loudest passage or chord you expect to record, with full pedal sustain.
Reduce the gain slider until peak levels sit between -12 and -18 dBFS on the meter.
Watch the MELO P1’s onboard peak indicator LED. Green indicates a safe operating level.
The LED shifts to red as the signal approaches the clipping threshold. Use this as a visual confirmation alongside the app meter.
Recording format recommendations:
Set sample rate to 48 kHz minimum. 96 kHz is a reasonable choice for acoustic piano if your storage and interface support it.
Enable 32-bit Float in the HollyAudio App settings. This eliminates the risk of permanent clipping. If a fortissimo passage exceeds your gain setting, the 32-bit Float file retains the full dynamic information for recovery during editing.
Noise reduction guidance:
Turn off AI Noise Cancellation in quiet or treated rooms. Heavy processing can soften piano attacks and transients. Quiet recording spaces usually do not need this processing anyway.
Enable it at the lowest effective strength level in untreated rooms with HVAC or ambient noise. Start at the minimum setting in the HollyAudio App and increase only if remaining noise is clearly audible on playback.
How to Turn On / Off Noise Cancellation in Hollyland Melo P1?
You can activate or deactivate the noise reduction feature in two simple ways.
Connect the MELO P1 to the HollyAudio app.
Go to Settings and locate the Noise Cancellation toggle, then tap to enable or disable it.
Or, you can press the physical Noise Cancellation button at the bottom of the Melo P1 microphone.
In both use cases, when the noise cancellation is active, the LED indicator on the mic will turn solid green. When disabled, the light will turn solid blue.
To adjust the noise cancellation levels, tap the Noise Cancellation Settings toggle.
Move the bar left or right until you find the right NC Level that matches your requirements.
Tips for Better Above-Piano Recordings
Treat parallel reflective surfaces before the session. Hardwood floors, windows, and bare walls can create flutter echo nearby. A high mic placement can capture this echo more clearly. Add a rug beneath the piano bench for better control. Curtains over nearby windows can also reduce unwanted reflections.
Use mic height to control tone. Closer positions (8 to 10 inches) emphasize string attack, hammer detail, and presence. Farther positions (18 to 24 inches) introduce more room bloom and natural reverb. Match your choice to the genre and the recording's destination.
Adjust the grand piano lid angle to shape low-frequency weight. Full-open produces the most balanced capture. Half-stick allows some low-frequency buildup inside the body for a warmer result.
Record 10 seconds of room tone before the session. A silence recording in the same mic position captures the ambient noise floor, which helps with noise profiling in post-production if needed.
Always record a short test take first. Play 30 to 60 seconds across the full dynamic range of the piece, then listen back through headphones before committing to the full session. Use the MELO P1’s wireless monitoring earphones for immediate in-ear playback directly from the unit to catch resonance buildup, proximity coloration, or ambient noise before it affects the complete recording.
Common Mistakes to Avoid
Mic positioned too low inside the grand piano lid. This captures hammer mechanism noise and restricts the pianist’s movement during the performance.
Capsule aimed toward the open side of the piano rather than above the strings. The mic picks up room reflections instead of direct string output.
Gain set for average dynamics. Clipping during forte passages destroys transients and is not recoverable without 32-bit Float recording enabled.
Boom arm extended without a counterweight. A long, unbalanced boom arm can tip a mic stand mid-session. Use a counterweight or a sandbag on the stand base.
Stereo pair mics misaligned in angle or too close together. Two cardioid mics placed too close without correct angular alignment will cancel frequencies and hollow out the center image of the stereo field.
How high should a microphone be above a piano?
For grand pianos, place the mic 8 to 18 inches above the strings. Closer placement gives more detail and a stronger piano attack. Greater distance gives a more natural room sound. For uprights, start 12 to 24 inches above the top board. Try 12 to 14 inches first, then adjust by ear. Test the sound before recording the entire session.
Should I use a condenser or dynamic microphone to record above a piano?
A condenser mic is usually the top pick for piano recording. Pianos create quick transients across a broad frequency range. Fundamentals range from 27.5 Hz to 4,186 Hz. Harmonics also reach far into the higher frequencies. Their volume can shift dramatically from soft to very loud passages. Most dynamic mics may miss some of these finer details. A high-SPL condenser can capture both gentle and powerful piano parts. Small and large-diaphragm models rated at 120 dB or higher can work nicely.
Can I get a usable stereo recording above the piano with a single microphone?
A single mono mic above the piano captures a balanced, full-range signal that works well for most applications, including demos, YouTube content, and social media. True stereo requires at least two capsules in an XY or ORTF configuration. Some large-diaphragm condensers with switchable polar patterns support mid-side technique, but the side channel still requires a second microphone.
Above-piano mic placement can change with every recording setup. Your piano, room, and music can all affect placement choices. Use this guide's positions as a starting point first. Record a short test covering the piece's dynamics. Then adjust placement while monitoring through your headphones carefully. Once everything sounds right, record the complete session. You can also explore room treatment basics for home recording. Stereo miking techniques can also help shape your piano recordings.
