iPhone Audio Jack Not Working? 8 Fixes That Actually Work
Plug in your headphones and hear nothing. It’s one of the most frustrating iPhone problems, especially because the cause could be anything from a software glitch to a clogged port to a broken adapter. Before you book a Genius Bar appointment, work through these eight fixes in order. Most users resolve this issue in under five minutes without any tools or technical experience.
First, Does Your iPhone Even Have a Headphone Jack?
This matters more than you might think. Apple removed the 3.5mm headphone jack starting with the iPhone 7 in 2016. If you are trying to plug standard headphones directly into a newer iPhone, there is no jack to receive them — which is why you hear nothing.
Use the table below to identify your port type and what you need for wired audio.
iPhone Model
Port Type
Wired Audio Solution
iPhone 6 and earlier
Plug in directly
iPhone 7 – iPhone 14
Lightning
Lightning EarPods or Lightning-to-3.5mm adapter
iPhone 15 and later
USB-C
USB-C EarPods or USB-C-to-3.5mm adapter
If you have an iPhone 6 or earlier with a true 3.5mm jack, skip ahead to the port cleaning section. If you are on iPhone 7 or later, the adapter is a key part of the diagnosis and most of the steps below apply to your specific setup.
Quick Software Checks Before Anything Else
Run through these checks first. They take under two minutes total and fix a surprising number of cases.
  1. Check the volume level. Press the Volume Up button while headphones are connected. The on-screen volume bar should show “Headphones” — if it does not move or sits at zero, that is your issue.
  1. Check the mute/silent switch. On iPhones that have one (on the left edge), make sure the switch is not flipped to silent. A visible orange line means silent mode is on.
  2. Disconnect Bluetooth devices. If a Bluetooth speaker or AirPods are paired and active, your iPhone routes audio there instead of the wired headphones. Go to Settings → Bluetooth and disconnect or turn Bluetooth off temporarily.
  1. Check the audio output route. Swipe into Control Center and tap the AirPlay icon in the music widget. Confirm the output is set to “iPhone” rather than a wireless device.
  1. Try a different app. If audio fails in one app but works in another, the issue is app-specific — check that app’s in-app volume or notification settings.
Clean the Lightning Port (or 3.5mm Jack)
Lint and debris packed into the port are one of the most common causes of poor or absent audio connections. When the connector cannot make full contact, you get silence or distortion.
  1. Power off your iPhone first. Never clean a port while the device is on.
  1. Shine a flashlight into the port. Look for compacted lint or debris at the bottom before you do anything.
  2. Use a wooden or plastic toothpick. Gently run the tip along the bottom of the port, working out debris in short, careful strokes. Do not press hard or scrape the contacts.
  3. Use compressed air at an angle. Short bursts directed into the port can dislodge remaining particles. Hold the can at a slight angle rather than pointing it straight in.
  4. Power the iPhone back on and test your headphones or adapter.
Caution: Never use metal tools, cotton swabs (loose fibers can snag inside the port), or any liquid, including rubbing alcohol. These can damage the contacts or introduce moisture.
Test and Replace Your Adapter
For iPhone 7 and later, the Lightning-to-3.5mm adapter is a small, inexpensive accessory that fails more often than people expect. Before blaming the iPhone’s port, isolate the adapter.
  1. Test with a second adapter. Borrow or buy another Apple-certified Lightning-to-3.5mm (or USB-C-to-3.5mm) adapter and connect the same headphones. If audio works, your original adapter is defective.
  2. Test with Lightning EarPods (no adapter). If you have Apple’s wired EarPods with a Lightning connector, plug them in directly. If those work, the iPhone port is fine — you have an adapter problem.
  3. Test the headphones on another device. Plug the same headphones into a laptop, another phone, or a tablet using a standard jack. If they fail there too, the headphones are the problem, not the iPhone.
  4. Use only Apple-certified adapters. Third-party adapters without MFi certification frequently cause audio issues, even if they appear to fit correctly.
Fix a Stuck Headphone Mode
Sometimes the iPhone’s software incorrectly registers that headphones are still plugged in after you remove them. The result is that audio routes to a “headphone” output that does not exist, making the speakers go silent. You can spot this because the volume bar will read “Headphones” instead of “Ringer” or “Volume” even when nothing is connected.
  1. Plug headphones in and pull them out several times. This can reset the sensor state and cue the software to recognize that nothing is connected.
  2. Restart your iPhone. A restart clears the software state in most cases (see the next section for how to restart by model).
  3. Check for moisture. Stuck headphone mode is especially common after an iPhone has been exposed to water or humidity. If you suspect moisture, do not charge the device — let it dry in a well-ventilated area for several hours before retesting.
  4. Check third-party apps. Certain recording or audio apps can lock the audio route. Force-close all open apps and retest.
Restart Your iPhone and Update iOS
A basic restart clears temporary audio routing errors that accumulate during normal use.
  1. Restart your iPhone. On Face ID models, press and hold a volume button and the side button until the power slider appears. On Touch ID side-button models, hold the side button. On older models, hold the top button.
  2. Check for an iOS update. Go to Settings → General → Software Update. Apple periodically releases patches for known audio bugs, and running an outdated version may be the root cause.
  3. Install any available update and retest your headphones or adapter.
Reset All Settings
If software checks and physical fixes have not resolved the issue, a corrupted audio preference may be the culprit. Resetting all settings wipes configuration data without deleting your photos, apps, or personal files.
  1. Go to Settings → General → Transfer or Reset iPhone → Reset → Reset All Settings.
  1. Enter your passcode if prompted and confirm.
  1. Your iPhone will restart. Reconnect your headphones or adapter and test.
Warning: This step resets Wi-Fi passwords, Bluetooth pairings, display brightness, and notification preferences. You will need to re-enter Wi-Fi credentials after the reset.
When to Contact Apple Support
If every step above has failed, the port itself or the internal audio hardware is likely physically damaged. This is a repair-level issue that requires professional assessment.
  • Check your warranty status at appleid.apple.com. Devices under the one-year limited warranty or covered by AppleCare+ may qualify for a free or reduced-cost repair.
  • Book a Genius Bar appointment at apple.com/retail or through the Apple Support app.
  • Use Apple’s mail-in repair service if you do not have an Apple Store nearby.
  • Get a repair cost estimate. Out-of-warranty port repairs typically range from $79 to over $200 depending on the model. Apple will provide a quote before any work begins.
Do not attempt internal repairs yourself. Opening the iPhone voids your warranty and risks further damage.
Consider Going Wireless — Skip the Port Entirely
If your audio port issue affects microphone recording rather than headphone output — common for content creators, podcasters, or video interviewers — a wireless microphone that connects via Lightning or USB-C removes the adapter and jack from the equation entirely.
The Hollyland LARK A1 is a compact wireless microphone available with a Lightning receiver, making it a Plug & Play solution for iPhone recording. It features 3-Level Intelligent Noise Cancellation and requires no adapter, no jack, and no external interface.
Good fit for: Creators whose wired microphone is no longer recognized by the iPhone and who need a reliable recording solution while the port issue is diagnosed or repaired.
Q: Why does my iPhone show “Headphones” in the volume display when nothing is plugged in?
This is the stuck headphone mode bug, where the iPhone’s software incorrectly registers a connection. Try plugging in and removing headphones several times, then restart the device. If the label persists after a restart and Reset All Settings, the port may have moisture damage or a physical fault that requires Apple Support.
Q: Does the iPhone still have a 3.5mm headphone jack?
No. Apple removed the 3.5mm jack with the iPhone 7 in 2016. iPhone 7 through iPhone 14 use the Lightning port for wired audio. iPhone 15 and later use USB-C. For standard headphones, you need an Apple-certified adapter or headphones with the correct connector type for your model.
Q: Is it safe to clean the iPhone Lightning port myself?
Yes, with care. Power off the iPhone first, then use a dry wooden or plastic toothpick to gently dislodge lint from the bottom of the port. Avoid metal tools, cotton swabs, and any liquids. If you can see obvious debris under a flashlight, this step alone often restores a solid connection.
Next Steps
Work through the fixes in order: software checks, port cleaning, adapter testing, stuck headphone mode, restart and iOS update, then Reset All Settings. If nothing works, Apple Support is the right next call. Before trying adapter-specific steps, confirm your iPhone model so you know whether you need a Lightning or USB-C adapter. For ongoing port issues, check out our related guide on iPhone microphone not working for additional audio troubleshooting steps.
