How to Record a Podcast Remotely: Tools, Setup, and Step-by-Step Workflow
Recording with guests in another city is now pretty normal. Independent creators do this, and production teams do too. Distance itself isn’t the main problem during remote podcast sessions. Platform choices and gear can affect your final audio quality. Your recording habits also play a major role here. Bad choices can leave you with compressed, unusable call audio. This guide covers platforms, gear, workflows, and backup plans. The goal is to avoid lost recordings and poor-quality audio.
What Remote Podcast Recording Actually Involves
Remote podcast recording captures audio from people in different locations. Two or more participants can join from separate physical spaces. Your recording quality depends heavily on the recording method. The same method also affects your overall recording risks.
Two models exist. In platform-only recording, the service captures audio through its servers. You get convenience, but your recording quality is constrained by the weakest internet connection in the session and the platform’s compression settings.
In double-ender recording, each participant records their own audio locally on their own device, and the isolated tracks are merged in post-production. This method removes each audio track from internet instability entirely, which raises the quality ceiling and nearly eliminates session-loss risk from a dropped connection. For any recording where audio quality matters, a double-ender is the professional standard.
What You Need to Record a Podcast Remotely
Below are the five equipment and environment requirements for remote podcast recording, each with a short note on why it matters specifically for the remote context.
  • Microphone: One of the biggest factors you can control. Your guest’s audio quality mostly stays outside your control. Your own microphone quality depends on your equipment and setup. Weak microphone signals are hard to fix during post-production. Heavy editing can also add noticeable artifacts to the final audio.
  • Closed-back headphones: Required to prevent guest audio from bleeding out of your ear cups and back into your microphone, which causes the echo and double-voice artifacts that are extremely difficult to clean in editing. Open-back headphones and laptop speakers are not suitable alternatives.
  • Stable internet connection: Even with double-ender recording, a reliable connection is required for real-time communication with your guest and for uploading local tracks after the session. A wired Ethernet connection is preferable to Wi-Fi for both stability and consistent upload speed.
  • Computer (Mac or PC): Runs the recording platform, manages audio device routing, and handles post-session track export. A mid-range laptop from the last four years is more than sufficient.
  • Acoustic environment: A small, soft-furnished room reduces room reflections. Hard walls and bare floors produce reverb that no noise-removal plugin fully eliminates. A bedroom with carpet, bookshelves, or a closet nearby is a practical starting point.
Choosing the Right Microphone
Your microphone sets the highest possible quality for recordings. No platform upgrade can fix poor microphone audio. Strong editing skills can’t fully repair bad source audio. This hardware choice affects every episode you publish later.
For this guide, the demonstration microphone is the Hollyland LARK MAX 2, a two-piece wireless system consisting of a transmitter worn or placed near the speaker and a receiver that connects to the host’s computer via USB-C. It is built for broadcast-quality audio capture in real-world, uncontrolled recording environments.
Two features make the LARK MAX 2 specifically well-suited for remote podcast recording:
32-bit Float Internal Recording is available directly on the transmitter and provides onboard backup recording to the device’s internal storage. If the recording platform experiences a server failure, your internet drops mid-session, or the browser crashes, a complete local audio file exists on the transmitter itself. No re-recording required. This is session insurance built into the hardware, not an add-on feature you configure inside the platform.
AI Noise Cancellation processes your audio signal before it reaches the platform, removing background noise at the source rather than applying a filter after the fact. For a host recording from a home office with HVAC noise, street traffic, or ambient hum, this is a structural fix rather than a post-processing patch. The result is a clean host track regardless of your recording environment.
Full setup steps for the LARK MAX 2 appear in the dedicated section below.
Headphones and Real-Time Monitoring
Closed-back headphones are non-negotiable for remote recording. They seal around the ear and block guest audio from leaking out of the ear cup and into your microphone, which is the primary cause of the echo artifacts that derail remote recordings.
The LARK MAX 2 includes OWS wireless earphones that connect directly to the receiver and provide real-time, low-latency monitoring during live sessions. If you are already using the LARK MAX 2 as your primary microphone, the OWS earphones give you an integrated monitoring solution, eliminating the need for a separate headphone device in your setup.
Best Platforms for Remote Podcast Recording
The feature that separates professional remote recording tools from call-recording workarounds is local track recording: the ability to capture each participant’s audio directly on their own device, independent of internet connection quality. Without it, every quality and reliability problem becomes the platform’s problem and ends up in your final mix.
Use the table below to match a platform to your use case. Zoom is included for completeness because many podcasters default to it out of familiarity, but it belongs in the fallback category rather than the primary workflow.
Platform
Local Recording
Audio Quality Ceiling
Video
Best For
Free Tier
Riverside
Yes
48 kHz / 32-bit WAV
Yes, up to 4K
Hosts who need professional-grade isolated tracks with video capability
Yes, limited to 2 hours/month
Zencastr
Yes
44.1 kHz / 16-bit WAV
Yes
Beginner hosts on a budget who want automated post-production tools
Yes, limited features
Squadcast
Yes
48 kHz / 32-bit WAV
Yes
Production teams and high-volume interview shows
No, paid plans only
Zoom
No (by default)
Compressed M4A
Yes
Fallback option when guests cannot access a dedicated platform
Yes, 40-minute session limit
Riverside (also known as Riverside.fm)is the recommended starting point for most independent podcasters. It records uncompressed local tracks from every participant, requires no guest download or account creation, and provides the widest quality ceiling at a free or low-cost entry point.
Zencastr is the stronger choice when budget is the primary constraint and video capability is not a priority for the show.
Squadcast suits podcast production teams or hosts running a high-volume interview schedule who need reliable session management and professional-grade audio across every recording.
Zoom is adequate as a fallback when a guest is unwilling or unable to join a dedicated platform. Pair it with a double-ender workflow where both participants record locally using Audacity, GarageBand, or similar software, then share audio files after the session to recover the quality that Zoom’s compression removes.
How to Set Up the Hollyland LARK MAX 2 for Remote Podcast Recording
These steps configure the LARK MAX 2 as your primary microphone input for a remote recording session. The platform example used throughout is Riverside. Complete all steps before your guest joins.
  1. Power on and pair the transmitter and receiver. Once the transmitter and receiver units are out of the charging case, they pair automatically. If they are not paired, then you will need to manually do it.
  • Turn off both units by pressing the power button for 3 seconds.
  • When the LARK MAX 2 mic / transmitter (TX) is powered off, press and hold the power button on the TX for 6 seconds until the LED activates. This means that the TX unit has entered the pairing mode.
  • Next, while in the powered-off state, press and hold the Camera RX power button for 6 seconds to let this unit enter pairing mode.
  • Once the pairing is complete, the Camera RX touchscreen display will show the successful pairing status.
  • Whereas the TX unit will show a solid blue light, confirming that it is successfully paired with the RX unit.
  1. Connect the receiver to your computer. Use the included USB-C cable to connect the LARK MAX 2 receiver to an available USB-C port on your Mac or PC. Your operating system will register it automatically as an audio input device.
  • On macOS, confirm by opening System Settings, then Sound, then Input, and verifying that the LARK MAX 2 (or its USB device name) appears and shows an active signal.
  • On Windows, check Settings, then System, then Sound, then Input.
  1. Enable AI Noise Cancellation. Press the power button once on the LARK MAX 2 transmitter to activate or deactivate Noise Cancellation. The LED indicator will change state to solid green, confirming that AI Noise Cancellation is now active. With this enabled, the LARK MAX 2 processes your audio signal in real time before it reaches the platform, removing ambient background noise at the hardware level.
  1. Activate 32-bit Float onboard backup recording on the transmitter. On the transmitter, press and hold the recording button (REC) until the LED turns red.
By default, the internal recording is captured in 32-bit Float, but there is also an option to switch the format to 24-bit. So, to ensure the recording format is set to 32-bit:
  • Open the HollyAudio app and make sure LARK MAX 2 is connected.
  • Scroll to the Bit-Depth section and select 32-bit Float.
The 32-bit Float format captures the full dynamic range of your voice without clipping or distortion, regardless of input level fluctuations during the session. You can easily record up to 10 hours of 48kHz / 32-bit Float internal audio.
  1. Connect the OWS earphones for real-time monitoring.
  • Make sure the LARK MAX 2's transmitter and Camera RX are powered on and paired.
  • Remove the OWS earphones from the charging case so they can automatically be connected to the Camera RX.
  • Open the Camera RX menu, navigate to Monitoring, and tap on the Wireless option.
  • Next, tap Monitoring Source, and select RX.
This lets the OWS earphones pick up the audio feed directly from the receiver hardware.
  1. Select the LARK MAX 2 as your audio input inside Riverside.fm.
  • Sign in to your Riverside (formerly Riverside.fm) account.
  • Click the Open Studio option on the left side of the screen.
  • Click on the Default Microphone dropdown menu and select LARK MAX 2 or the USB device name that matches your receiver.
  • Click the Test button and observe the volume input meters. If they are green, click Stop, and then you can join the studio.
How to Record a Remote Podcast: Step-by-Step
This workflow assumes you are the host, your equipment is fully set up and tested, and your guest will join via a platform invite link.
  1. Send your guest the platform invite link at least 24 hours in advance. Riverside generates a unique guest link from the studio dashboard. Send it via direct email rather than relying on the guest to locate it inside a calendar invite. Include two to three sentences of pre-session guidance: find a quiet room, use headphones, and connect via Ethernet if possible.
  2. Run a solo audio check 30 minutes before the session. Enter the studio alone and record a 30-second test of your own voice. Confirm the LARK MAX 2 is the active input device, AI Noise Cancellation is running, and the backup recording LED on the transmitter is flashing. Resolve equipment problems now. Troubleshooting on a live call with a guest already present is inefficient and unprofessional.
  3. Confirm local recording is enabled in the platform settings. In Riverside, local track recording is enabled by default. Verify it under Studio Settings before the session begins. This is the step most podcasters skip and the one that determines whether you have clean isolated tracks in post-production or a single mixed-down file.
  4. Greet your guest and run a live 30-second test together. Ask your guest to speak for 30 seconds while you listen for echo, background noise, low volume, or compression artifacts. Address problems before the interview starts. A guest recording on a laptop microphone should be asked to move closer to the screen or hold the device at chin level to improve pickup quality.
  5. Start the official recording. Click Record in the platform interface. Verify that the LARK MAX 2 transmitter LED is on, which confirms onboard backup recording remains active. Confirm the platform shows local track recording running for both participants before beginning the interview.
  6. What not to do during an active session. Do not refresh the browser tab or navigate away from the recording platform. Do not mute yourself inside the platform, as muting stops your local track from recording. Do not switch audio input devices mid-session. Do not close the browser to address a minor audio glitch. Losing a local track carries a far higher cost than a brief audio imperfection that can be addressed in editing.
  7. End the session and wait for local tracks to upload. When the interview is complete, click Stop Recording but do not close the browser. Riverside uploads local track files to the cloud after the session ends. Closing the browser before upload completes can result in partial or missing track files. Wait for the on-screen upload confirmation before closing the tab.
  8. Retrieve the onboard backup from the LARK MAX 2 transmitter. After the session, connect the transmitter to your computer via USB-C. The internal storage will mount as a drive. Copy the 32-bit Float audio file to your project folder before clearing the transmitter storage. This file is your master backup and exists completely independent of the platform.
How to Get Better Audio from Your Remote Guests
Your gear controls the quality of your own podcast audio. Guest audio creates a separate challenge during remote recording sessions. You can’t install their microphone or improve their recording space. Still, some early preparation can improve their final audio quality. A quick setup check can prevent many avoidable recording problems.
  • Send a one-page pre-interview audio checklist. Include four items: use a dedicated microphone rather than the built-in laptop mic, wear closed-back headphones or wired earbuds, find a small, soft-furnished room, and close windows and fans before the session. Guests follow specific written instructions reliably; vague verbal requests before a call do not.
  • Ask guests to use a dedicated microphone. Any USB microphone is a meaningful improvement over a built-in laptop mic. A basic USB microphone under $60 produces audio substantially easier to work with in post-production.
  • Require closed-back headphones or wired earbuds. Guests monitoring through laptop speakers or open-back headphones create echo on their recording track. This is one of the most common causes of unusable remote interview audio and is entirely preventable with one instruction.
  • Recommend a small, soft-furnished room. Bedrooms with carpet, bookshelves, or nearby clothing closets are ideal. Large, bare rooms produce reverb that degrades the voice signal when removed in post.
  • Close windows, fans, and HVAC vents five minutes before recording. These are the most common sources of persistent background noise on guest tracks. Eliminating them before the session starts costs nothing.
  • Test the guest’s audio before beginning the interview. A 30-second pre-roll check takes less time than re-recording. If guest audio is unusable after preparation has been applied, reschedule rather than publish a degraded track.
Note: Your own environment is fully within your control. The Hollyland LARK MAX 2’s AI Noise Cancellation handles residual ambient noise on the host’s side, including HVAC hum, low-level street noise, and room reflections, so that your track stays broadcast-ready even in an untreated home recording space.
Common Remote Recording Problems and Quick Fixes
Problem
Likely Cause
Fix
Echo or double voice on one track
Guest monitoring audio through laptop speakers instead of headphones
Ask guest to switch to closed-back headphones or wired earbuds; restart guest’s local recording slot in the platform if the option is available
One participant has no audio in the final tracks
Wrong input device selected in platform settings, or local recording failed for that participant
Check platform audio input settings for each participant; confirm correct microphone is selected; have the affected party re-enter the studio if needed
Choppy or garbled audio during the call
Unstable internet connection on host or guest side
Switch to wired Ethernet if possible; ask guest to close bandwidth-heavy applications; note that with local recording enabled, the final track files may still be clean even if the live communication sounds degraded
Audio delay or latency between participants
Network latency or high server load
Latency affects the live conversation but does not affect the quality of local track recordings; reduce live streaming quality in settings while keeping local recording quality at maximum
Background noise on host audio track
Ambient HVAC, street noise, or untreated room
Toggle AI Noise Cancellation on the LARK MAX 2 by pressing the NC button on the receiver; verify the LED indicator confirms AI NC is active; confirm the transmitter is positioned close to the host’s mouth for optimal signal capture
What is the best free platform to record a podcast remotely?
Riverside offers local track recording for remote podcast sessions. That’s important when basic video calls aren’t enough. Its free plan limits separate-track recording to two hours. Exported files also include watermarks under the free plan. So, it feels more like a trial than forever. Zencastr also gives creators options for recording guests remotely. Regular shows with multiple guests may need paid plans. Creators can also explore other workflows after free limits end.
Can I record a remote podcast on my phone?
Yes, but there are some limitations worth knowing about first. Riverside and Zencastr require mobile users to download apps. Their apps provide a steadier recording experience than mobile browsers. Still, phones aren’t ideal as primary podcast recording devices. Their microphones can produce inconsistent audio quality during longer sessions. Phones also provide limited acoustic isolation and recording controls. External professional gear can improve those limitations quite a bit. So, use your phone as backup recording gear. It can also serve as a useful secondary device.
Do both the host and guest need to use the same recording software?
No, guests usually don’t need an account to join. With Riverside, hosts enter through the browser-based studio. Guests join using a unique invitation link from the host. Computer guests can join through browsers without accounts or apps. Mobile guests need the dedicated app to open invitations. Both participants record local tracks on their own devices. Those tracks upload to the host account after recording ends.
What internet speed is required for remote podcast recording?
At least 5 Mbps upload and download speeds support basic remote recording. For high-definition sessions, 10 Mbps or higher is recommended. Connection stability matters more than having extremely high speeds. A steady wired Ethernet connection usually beats unstable high-speed Wi-Fi. Local-track recording also helps protect your final audio files. Minor connection drops can affect calls and live feeds temporarily. They won’t affect locally saved audio tracks on computers.
What is a double-ender and when should I use it?
A double-ender records each person’s audio locally on their device. The separate tracks are combined later during post-production. Use this method when clean audio quality matters most. It also gives you more control over individual tracks. Network problems won’t ruin locally recorded audio quality. Cloud-based double-ender tools still need working internet connections. They need internet access for calls and file uploads. Fully offline setups can avoid those internet requirements entirely.
Can I use a wireless microphone for remote podcast recording?
Yes. A wireless microphone like the Hollyland LARK MAX 2 works reliably for remote recording because the receiver connects to the host’s computer via USB-C, and the operating system’s audio driver routes the signal to the platform as a wired USB microphone would. The LARK MAX 2 adds a distinct advantage: its onboard 32-bit Float backup recording on the transmitter provides a full-session audio file that exists completely independent of the platform.
Three things can determine your remote podcast audio quality. First, choose a platform that records isolated local tracks. Next, use a microphone with onboard backup recording. It should also reduce environmental noise directly at the source. Finally, run an audio check before every recording session. These steps help prevent common recording problems from reaching editing.
