How to Fix “Audio Recording Not Available” on iPhone (Step-by-Step)
Few things are more frustrating than opening Voice Memos or the Camera app at the exact moment you need to record, only to see the “Audio Recording Not Available” error staring back at you. The good news: this error is almost always a software issue, not a broken microphone. Work through the fixes below in order, and you will most likely resolve it within five minutes.
What “Audio Recording Not Available” Means on iPhone
This error appears when iOS blocks microphone access for the app trying to record. It shows up in Voice Memos, the Camera app during video recording, and any third-party recording app. The root cause falls into one of three buckets: a permission or settings block, a resource conflict with another app, or a hardware problem. The vast majority of cases land in the first two buckets, so start with software fixes before suspecting your hardware.
Fix 1 — Check Microphone Permissions for the App
This is the single most common cause of the error. iOS asks for microphone permission the first time an app needs it. If you tapped “Don’t Allow,” iOS silently blocks access without giving any follow-up notice.
  1. Open the Settings app.
  2. Scroll down and tap Privacy & Security.
  3. Tap Microphone.
  1. Find the app that triggered the error (Voice Memos, Camera, or a third-party app).
  2. Toggle the switch to the on (green) position.
  3. Return to the app and test recording.
Note: If the toggle is grayed out and you cannot change it, Screen Time restrictions are overriding the setting. Skip ahead to Fix 4 for instructions on disabling those restrictions.
For the Camera app specifically, also check Settings > Camera and confirm that microphone access is not restricted there.
Fix 2 — Close Apps Conflicting With the Microphone
iOS allows only one app to use the microphone at a time. An active phone call, an ongoing FaceTime session, or another recording app running in the background will lock the microphone and trigger the error in any other app that tries to use it.
  1. Check the status bar at the top of your screen for a green or orange indicator dot, which signals an active call or mic use.
  2. If a call is active, end it before attempting to record.
  3. Open the App Switcher by swiping up from the bottom of the screen (Face ID models) or double-pressing the Home button (Touch ID models).
  4. Swipe up to close FaceTime, other recorder apps, or any app that recently accessed your microphone.
  5. Return to your recording app and test again.
Fix 3 — Free Up iPhone Storage
Voice Memos and video recording both require free storage to buffer audio data. When your iPhone storage drops below roughly 500 MB, iOS will block new recordings to protect system stability.
  1. Go to Settings > General > About.
  2. Wait for the list to load and check how much space is available.
  1. If storage is critically low, scroll through the app list and look for large items to remove.
  2. Tap any app to see its size and offload or delete it. Use Offload App to remove the app while keeping its documents and data.
  3. Also delete duplicate photos, old downloaded videos, or large podcast files.
  4. Once you have freed several hundred megabytes, retest recording.
Pro Tip: Tap Recommendations near the top of the iPhone Storage screen. iOS will often suggest specific items to remove that will recover the most space with the least disruption.
Fix 4 — Disable Screen Time Microphone Restrictions
Screen Time’s Content and Privacy Restrictions can block microphone access across all apps simultaneously. When this restriction is active, the per-app toggles in Privacy and Security will appear correct, yet the error persists — which makes this one of the more confusing causes to diagnose.
  1. Go to Settings > Screen Time.
  2. Tap Content & Privacy Restrictions.
  1. If the toggle is on, tap Allowed Apps or look for a Microphone option within the restrictions list.
  2. Make sure the microphone is set to Allow.
  3. Exit Settings and retest the recording app.
Family Sharing note: If Screen Time is managed by a parent or administrator through Family Sharing, you will need the Screen Time passcode to make this change. Contact whoever set up the restriction to have it adjusted.
Fix 5 — Update iOS and the Recording App
Known bugs in older versions of iOS or a specific app can produce phantom “not available” errors that disappear entirely after an update.
To update iOS: 1. Go to Settings > General > Software Update. 2. If an update is available, tap Download and Install. 3. Updating iOS will not delete your recordings or personal files.
To update the recording app: 1. Open the App Store. 2. Tap your profile icon in the top-right corner. 3. Scroll down to Pending Updates and update any relevant apps.
After installing updates, restart your iPhone before retesting to give iOS a clean start.
Fix 6 — Restart iPhone and Reset All Settings (Last Resort)
Force restart your iPhone first — this clears temporary system states that can lock the microphone without requiring any settings changes.
  • Face ID iPhones: Press and release Volume Up, press and release Volume Down, then press and hold the Side button until the Apple logo appears.
  • Touch ID iPhones (with Home button): Press and hold the Home button and the Side (or Top) button together until the Apple logo appears.
If a force restart does not fix the error, the next step is to reset all settings:
  1. Go to Settings > General > Transfer or Reset iPhone.
  2. Tap Reset, then tap Reset All Settings.
  3. Enter your passcode if prompted and confirm.
Important: Reset All Settings does NOT delete your apps, photos, voice recordings, or personal data. It only clears system preferences such as Wi-Fi passwords, display settings, and accessibility configurations. Your recordings remain fully intact.
If the error still appears after this step, the problem is unlikely to be software-based.
When to Suspect a Hardware Problem
If every software fix above has failed, a microphone hardware fault may be the cause. Look for these signs before heading to Apple Support:
  • No audio is captured in any app whatsoever
  • Recordings sound muffled, staticky, or distorted even when the “not available” error is not present
  • The iPhone was recently dropped in water or exposed to moisture
  • The microphone grille at the bottom of the device is visibly blocked or damaged
If any of these apply, take your device to an Apple Store or Apple Authorized Service Provider for a hardware diagnostic. Avoid DIY microphone repair, as it carries a risk of further damage.
Want Better Audio After Fixing the Issue?
Once your iPhone microphone is working again, you may notice that the built-in mic is the next bottleneck for clear recordings. If you create content, conduct interviews, or record lectures regularly, the Hollyland LARK A1 connects via Lightning or USB-C with no app or adapter required and delivers 3-Level Intelligent Noise Cancellation that noticeably lifts voice clarity above what the built-in mic can produce. It is a straightforward upgrade for anyone recording directly to iPhone.
Why does Voice Memos say “Audio Recording Not Available”?
Most commonly, Voice Memos has been denied microphone permission in Settings, or another app is actively using the microphone at the same time. Go to Settings > Privacy & Security > Microphone and confirm that Voice Memos is toggled on. If the toggle is grayed out, a Screen Time restriction is blocking access and must be disabled first.
Why can’t I record audio on my iPhone Camera app?
The Camera app requires microphone permission to capture audio in video recordings. Check Settings > Privacy & Security > Microphone and make sure Camera is enabled. Also confirm that no active phone call or FaceTime session is running in the background, since these will lock the microphone and prevent Camera from accessing it.
Does low storage cause the “audio recording not available” error?
Yes. When available storage drops below a critical threshold, iOS blocks new recordings to prevent system instability. Open Settings > General > iPhone Storage to check your available space and delete or offload large files before attempting to record again. Aim to keep at least 1 GB free for reliable recording.
Will resetting all settings delete my voice recordings?
No. Reset All Settings only wipes system-level preferences such as network settings, display brightness, and accessibility options. Your voice memos, photos, apps, and all personal data remain completely untouched after this reset.
Start with microphone permissions, rule out app conflicts and low storage, then move on to iOS updates and Reset All Settings if the error persists. Following that order handles the vast majority of cases without touching hardware. If the error survives every software fix above, Apple Support or an Apple Store is the right next step for a hardware diagnostic. For more related help, see our guides on fixing an iPhone microphone that is not working and choosing the best external microphones for iPhone recording.
