How to Edit Audio in Premiere Pro: Step-by-Step Guide for Cleaner Sound
Even great visuals lose viewers fast when sound quality feels poor. Inside Premiere Pro, you can fix levels, clean noise, and shape tone. You can also control volume changes without leaving the timeline. This guide walks through each essential technique in order, from setting up your workspace to exporting at the right loudness standard. Whether your recording came out too quiet, too noisy, or just uneven, the steps below will help you clean it up and deliver a polished sound.
Setting Up Your Audio Workspace in Premiere Pro
Before adjusting a single clip, switch to the dedicated audio workspace so all the tools you need are visible and accessible. Go to Window > Workspaces > Audio. This rearranges your panels to prioritize audio-related controls.
The four panels you will use most are:
  • Timeline — where your audio tracks live, displayed as waveforms beneath video tracks
  • Essential Sound Panel — a simplified, tag-based toolkit for common audio tasks (open via Window > Essential Sound)
  • Audio Track Mixer — controls levels, panning, and effects at the track level rather than per clip
  • Effects Panel — where you find and apply individual audio effects such as EQ, compression, and noise reduction
Pro Tip: Editing efficiency starts before you open Premiere Pro. Source footage recorded with 32-bit float and built-in AI Noise Cancellation, such as audio captured on the Hollyland LARK MAX 2, significantly reduces noise with minimal effort. Cleaner input means less time fixing problems in post.
How to Adjust Audio Levels and Gain in Premiere Pro?
Adjusting levels is the first practical step in any audio edit. Premiere Pro gives you two distinct tools for this: Clip Gain and Volume. Knowing when to use each saves time and prevents mixing problems later.
Method 1: Adjusting Clip Gain
Clip Gain sets the signal level of a clip before any effects are applied. Use it when a recording is universally too quiet or too loud — a problem with the capture itself, not the mix.
  1. In the Timeline, right-click the audio clip you want to adjust.
  2. Select Audio Gain from the context menu.
  1. In the Audio Gain dialog, choose one of the following:
  • Set Gain to: Enter a specific dB value (e.g., +6 dB to make a quiet clip louder).
  • Adjust Gain by: Apply a relative change to the current level.
  • Normalize Max Peak to: Automatically raises or lowers the clip so its loudest point hits a target value (e.g., -3 dB).
  • Normalize All Peaks to: Applies the same normalization logic to multiple selected clips at once — useful for batch-correcting an interview with inconsistent levels.
  1. Click OK. The waveform display in your timeline will visually reflect the change.
Method 2: Adjusting Volume via the Timeline Rubber Band
The rubber band is the thin white horizontal line running across each audio clip in the timeline. It represents the clip’s volume and can be manipulated directly.
  1. Make sure your timeline tracks are tall enough to see the white line. Drag the bottom edge of a track header downward to expand it.
  1. Hover over the white rubber band line. Your cursor will change to a finger pointer with an arrow.
  2. Click and drag the line up or down to raise or lower the volume for that clip.
  3. For a precise value, right-click the rubber band and choose a specific level in dB.
Gain vs. Volume: What’s the Difference and When to Use Each
Gain
Volume
Where it acts
Pre-fader (before effects chain)
Post-fader (after effects are applied)
Best use
Correcting a poorly recorded clip
Fine-tuning levels within the mix
Automation support
No
Yes, via keyframes
The practical rule: fix a bad recording level with Gain first, then use Volume for mix adjustments and automation. Applying EQ or compression to a clip that is too quiet at the gain stage will amplify the noise along with the signal. Getting it right first makes every subsequent step cleaner.
Using the Essential Sound Panel for Fast Audio Editing
The Essential Sound Panel is Premiere Pro’s built-in, non-destructive audio workflow tool. It organizes controls around the type of sound you are editing, rather than requiring you to know which specific effect to reach for. For most video projects, this panel handles most of the audio work.
Step 1: Tag Your Clip
  1. Select one or more audio clips in the Timeline.
  1. Open the Essential Sound Panel (Window > Essential Sound).
  1. Click the appropriate audio type tag for your selection:
  • Dialogue — spoken word, interviews, voiceover
  • Music — background tracks, score, licensed music
  • SFX — sound effects
  • Ambience — room tone, environmental audio
Tagging is not just for simple organization. It loads controls tuned for that specific audio type. It also guides Premiere Pro during auto ducking and loudness tasks.
Step 2: Work the Dialogue Tab
Once a clip is tagged as Dialogue, you will see four main control groups:
  1. Loudness: Click Auto-Match to automatically normalize the clip to a broadcast or streaming loudness target. This is the fastest way to fix uneven levels across an interview.
  1. Repair:
  • Reduce Noise — drag the slider right to attenuate background hiss, HVAC rumble, or general room noise. Start around 5–6 and increase only as needed to avoid artifacts.
  • Reduce Reverb — lowers the wet, roomy quality of audio recorded in untreated spaces.
  • DeHum — removes electrical hum at 50 Hz or 60 Hz depending on your region.
  1. Clarity: Enhances the intelligibility of speech. The Enhance Speech toggle uses AI processing to sharpen vocal presence.
  2. Creative: Panning controls for dialogue placement.
Step 3: Use the Music Tab for Ducking
Ducking automatically lowers music volume whenever a Dialogue clip is detected. This avoids adding many manual keyframes during editing.
  1. Tag your music clip as Music in the Essential Sound Panel.
  1. Enable the Ducking toggle.
  1. Set Duck Against to Dialogue clips.
  1. Adjust the Sensitivity, Reduce By / Duck Amount (how much the music drops), and Fades sliders to taste.
  2. Click Generate Keyframes. Premiere Pro writes volume keyframes on the music clip automatically.
The Essential Sound Panel covers roughly 80% of common audio problems without requiring any work in the Effects Panel.
How to Remove Background Noise in Premiere Pro?
Background noise is one of the most common complaints about self-recorded video audio. Premiere Pro offers two native approaches depending on severity.
Method 1: Essential Sound Panel Sliders (Fastest Approach)
For mild-to-moderate noise in dialogue clips:
  1. Select the clip in the Timeline.
  2. In the Essential Sound Panel, tag it as Dialogue.
  3. Under the Repair section, drag the Reduce Noise slider to the right.
  4. Play the clip in real time while adjusting. Stop increasing the value when you hear the speech beginning to sound unnatural or hollow — a common artifact of over-processing.
  5. If the room sounds echoey, also increase the Reduce Reverb slider.
Method 2: DeNoise and DeReverb Effects (More Control)
For recordings with persistent or broadband noise that the Essential Sound sliders cannot fully tame:
  1. Open the Effects Panel (Window > Effects).
  1. In the search bar, type DeNoise or DeReverb.
  1. Both effects appear under Audio Effects > Noise Reduction/Restoration.
  2. Drag the effect onto your clip in the Timeline.
  3. Open the Effect Controls Panel (Window > Effect Controls).
  4. Click Edit or Custom Setup next to the effect to open its full interface.
  1. In the DeNoise interface, adjust the Amount slider. Use the Output Noise Only toggle to preview exactly what the plugin is removing — if you hear speech in that output, back off the amount.
Note: For severe noise problems, recordings damaged by wind, or audio that requires spectral repair, right-click the clip in the Timeline and choose Edit in Adobe Audition. Audition’s Spectral Frequency Display and Adaptive Noise Reduction tools are better suited for those cases. This guide does not cover Audition workflows in depth.
How to Use Audio Keyframes for Volume Automation?
Keyframes let you change volume over time within a single clip. They are essential for smooth fades, music-under-dialogue ducking, and any transition where audio needs to ramp up or down.
Adding Keyframes Manually
  1. In the Timeline, expand your audio track by dragging the bottom edge of the track header downward until the rubber band line is clearly visible.
  2. To enable keyframe view on the clip, right-click the clip’s volume rubber band line, then choose Show Clip Keyframes > Volume > Level.
  1. Select the Pen tool (P) from the toolbar, or hold Ctrl (Windows) / Cmd (Mac) while hovering over the rubber band line with the Selection tool.
  1. Click on the rubber band to place a keyframe. The keyframe appears as a small diamond or circle shape, depending on the software version.
  1. Place a second keyframe at a different point on the clip.
  2. Drag one keyframe up or down to create a volume ramp between the two points.
Creating Smooth Fades with Ease Handles
Linear keyframe ramps sound abrupt. For natural-sounding fades:
  1. Right-click a keyframe.
  2. Choose Ease In, Ease Out, or Bezier from the context menu.
  1. Bezier keyframes give you drag handles you can curve to shape an S-curve, which sounds smoother than a straight linear fade.
Practical Example: Fading Music Under Dialogue
  1. Place four keyframes on your music clip: two before the speaker begins and two after the speaker finishes.
  2. Keep the first and last keyframes at your normal music level.
  3. Drag the two inner keyframes down to your desired ducked level (typically -12 to -18 dB below full volume).
  4. Apply Ease In to the downward keyframe and Ease Out to the recovery keyframe for a smooth dip and return.
Shortcut: With the Selection tool active, hold Ctrl (Windows) or Cmd (Mac) and click directly on the rubber band line to add a keyframe without switching to the Pen tool.
Applying Audio Effects: EQ and Compression
Once levels and noise are addressed, EQ and compression are the two effects most likely to improve the perceived quality of dialogue and music in a video project.
Parametric EQ
Parametric EQ lets you boost or cut specific frequency ranges. For dialogue, two corrections do most of the work:
  1. In the Effects Panel, search for Parametric Equalizer and drag it onto your clip.
  1. Open Effect Controls and click Edit to open the EQ graph.
  2. Apply a high-pass filter at around 80 Hz to remove low-end rumble, handling noise, and HVAC hum below the vocal range.
  1. If dialogue sounds muddy, try a small cut (2–4 dB) around 200–400 Hz.
  2. For added clarity and presence, try a gentle boost (2–3 dB) in the 2–4 kHz range, where speech intelligibility lives.
  3. A slightly high-frequency shelf cut above 10–12 kHz can tame harshness in certain microphones.
Dynamics (Compressor)
Compression reduces the volume difference between the loudest and quietest parts of a recording, resulting in more consistent, controlled audio.
  1. In the Effects Panel, search for Dynamics and apply it to a dialogue clip.
  1. Open the Effect Controls and click Edit.
  2. Set the Threshold to the level above which compression kicks in (start around -20 dB for dialogue).
  3. Set the Ratio to control how aggressively it compresses (3:1 to 4:1 is a common starting point for speech).
  4. Adjust Attack and Release to control how quickly compression engages and disengages. Slower attacks preserve natural transients; faster attacks clamp down harder.
  5. Use the Makeup Gain to restore overall level after compression reduces it.
Using the Audio Track Mixer for Multi-Track Control
When your project includes three or more simultaneous audio tracks (dialogue, music, and ambient sound, for example), the Audio Track Mixer is more efficient than adjusting each clip individually.
  • Open it via Window > Audio Track Mixer.
  • Each column represents one audio track in your Timeline.
  • Use the faders to set a master level per track rather than adjusting clip-by-clip.
  • Use the track effect slots at the top of each channel strip to apply an effect (like EQ) to every clip on that track at once.
  • The panning knobs control stereo placement per track.
The Audio Track Mixer is most useful during final mix balancing, after clip-level corrections are already in place.
Exporting Your Project with the Right Audio Settings
Audio quality can be lost at export if the settings do not match the intended delivery platform.
  1. Go to File > Export > Media (or press Ctrl+M / Cmd+M).
  1. In the Export Settings dialog, click the Audio tab.
  1. Select the appropriate codec and settings for your destination:
Destination
Recommended Format
Codec
Sample Rate
YouTube / Web streaming
H.264 / MP4
AAC, 320 kbps
48 kHz
Podcast / Audio-only
MP3 or AAC
AAC, 192–320 kbps
44.1 or 48 kHz
Broadcast / Linear TV
MXF or MOV
PCM (WAV), 24-bit
48 kHz
Archiving / Further editing
MOV or MXF
PCM (WAV), 24-bit
48 kHz
  1. For loudness, use the Loudness Radar or reference your Essential Sound Panel normalization target:
  • YouTube and most streaming platforms: -14 LUFS integrated
  • Broadcast (EBU R128 standard): -23 LUFS integrated
  • Podcasts: -16 LUFS is a widely accepted target
  1. Leave Channels set to Stereo for most deliverables unless the client specifies mono or 5.1.
  2. Click Export or add to the Media Encoder queue for background processing.
How do I normalize audio in Premiere Pro?
Right-click a clip in the Timeline and select Audio Gain. Choose Normalize Max Peak to and enter a target value such as -3 dB. Alternatively, open the Essential Sound Panel, tag the clip as Dialogue, and click Auto-Match under the Loudness section to automatically hit a target LUFS value based on your chosen standard.
What is the difference between Gain and Volume in Premiere Pro?
Gain adjusts the signal level before any effects in the chain (pre-fader). Volume adjusts the final output level after all effects have been applied. The correct workflow is to fix a poorly recorded clip with Gain first, then use Volume and keyframes to automate level changes within the mix.
How do I remove echo or reverb from audio in Premiere Pro?
Apply the DeReverb effect from the Effects Panel (search “DeReverb” under Noise Reduction/Restoration) or use the Reduce Reverb slider in the Essential Sound Panel with the clip tagged as Dialogue. For heavy or severe reverb that cannot be fixed natively, right-click the clip and choose Edit in Adobe Audition for spectral repair tools.
How do I sync external audio to video in Premiere Pro?
Select both your video clip and the external audio recording in the Timeline or Project panel. Right-click and choose Merge Clips, then select Audio as the sync point. Premiere Pro analyzes the waveforms and aligns them automatically. After merging, mute or delete the original camera audio track to avoid a double-audio conflict.
But apart from this method, there's another process that professionals usually adopt. So, instead of Merge Clips, editors now use multi-camera sequences. Select your video and audio files in the Project panel. Right-click and choose Create Multi Camera Source Sequence. Set audio as the sync point before creating the sequence. This approach lines up the audio and builds a clean virtual clip. It keeps the original file data safe for later editing stages. It also reduces risks during the final steps of post-production.
What LUFS target should I use for YouTube?
YouTube normalizes uploaded content to approximately -14 LUFS integrated loudness. Exporting at -14 LUFS ensures your audio plays back at its intended level without YouTube’s normalization reducing it. Going louder than -14 LUFS at upload will cause YouTube to turn your audio down, not up.
Audio editing in Premiere Pro follows a clear step-by-step process. Start by adjusting the clip gain to correct recording levels first. Then use Essential Sound to set loudness and reduce noise. Apply EQ and compression to shape tone and control dynamics. Add keyframes to manage volume changes across your timeline. Export using the right codec and proper loudness settings. These steps can help fix the most common audio issues in your videos.
