How to Use Enhance Speech in Premiere Pro (Step-by-Step Guide)
Dialogue that sounds unclear or noisy can ruin a well-edited video. Premiere Pro’s Enhance Speech tool uses Adobe AI to clean voice audio in one step. You do not need any external plugin or app for this. This guide shows where to find it and how to use it. It also explains what to do if the results are not good enough.
What Is Enhance Speech in Premiere Pro?
Enhance Speech is an AI-powered audio cleanup tool built into Premiere Pro’s Essential Sound panel. It is designed specifically for spoken dialogue — interviews, voiceovers, talking-head footage, narration — and its primary job is to reduce background noise and improve speech clarity in one automated pass. Adobe’s AI engine analyzes the audio signal and applies targeted correction without requiring manual frequency adjustments or noise sampling.
The feature is available to all active Adobe Creative Cloud subscribers running Premiere Pro version 22 and 23.0 (released late 2022) or later. But AI Enhance Speech is available starting with version 24.2. Nevertheless, if you have previous versions, you can still find this tool, though it won't be backed by Artificial Intelligence, as it was under development at the time. If you are on an older version, you will need to update through the Creative Cloud desktop app to access it.
Also,  Enhance Speech is a repair tool, not a substitute for recording well. It works best on audio that is already reasonably clean but needs refinement. The worse the source recording, the more limited the results.
How to Access and Use Enhance Speech in Premiere Pro
Step 1 — Open the Essential Sound Panel
Go to Window > Essential Sound in the top menu bar to open the Essential Sound panel. It will appear as a docked panel on the right side of your workspace by default, though your layout may vary.
Before you open the panel, make sure the audio clip you want to process is already on your timeline. Enhance Speech only works on clips placed in a sequence — it cannot be applied to clips in the Project panel directly.
Step 2 — Tag the Clip as “Dialogue”
Click on the audio clip in your timeline to select it. In the Essential Sound panel, you will see a row of clip type buttons: Dialogue, Music, SFX, and Ambience. Click Dialogue.
This step is not optional. Enhance Speech is exclusive to the Dialogue clip type. If you select a clip and the Essential Sound panel shows no Enhance Speech option, the most common reason is that the clip has not been tagged as Dialogue, or it has been tagged as a different type. Re-tagging it as Dialogue will unlock the full set of speech-specific controls.
Step 3 — Enable Enhance Speech and Set the Amount
Once the clip is tagged as Dialogue, scroll down in the Essential Sound panel until you see the Enhance Speech checkbox. Check the box to enable it.
Below the checkbox, you will find the Amount slider, which runs from 0 to 10. This controls how aggressively the AI correction is applied. A good starting point for most dialogue clips is somewhere between 4 and 6. This range improves clarity without introducing the processed, artificial sound that can appear at higher values.
To preview the effect before committing, use Premiere Pro’s standard playback. Scrub through the clip with the feature enabled, then temporarily uncheck the Enhance Speech box to A/B compare the original and processed versions. This comparison is one of the most useful steps in the workflow.
Note:Once you set the Amount, Premiere Pro starts processing the clip. It runs on your system locally. You will see a progress bar in the timeline or panel. But the time depends on clip length and your system speed. What's good? Well, you can keep editing while the changes are being processed.
Enhance Speech Settings Explained
The settings inside the Enhance Speech section are minimal by design, but understanding how they interact with other Essential Sound controls helps you get the most out of the feature without causing new problems.
Setting
What It Does
Recommended Range
Enhance Speech (checkbox)
Enables or disables the AI speech enhancement on the selected clip
On/Off as needed
Amount
Controls the intensity of AI correction; higher values apply stronger processing
40–60 for most clips; up to 80 for heavily degraded audio
Reduce Noise (separate control)
Applies a secondary noise reduction layer independent of Enhance Speech
Use sparingly; 20–40 if used alongside Enhance Speech
Reduce Rumble (separate control)
Rolls off low-frequency rumble below the speech range
Useful for HVAC or traffic noise; 20–50 range
There’s a simple rule when applying these controls. Always apply Enhance Speech first. Then add small extra corrections if needed.
Using strong Enhance Speech together with heavy noise reduction can cause problems. It often creates a hollow or robotic sound. You may also hear odd warbling in the audio. This happens when the processing becomes too intense.
Start with a moderate Amount in Enhance Speech. Play back the result and listen carefully. Only adjust other sliders if the audio still needs improvement.
Tips for Getting the Best Results
  • Apply Enhance Speech to isolated dialogue clips only: Do not apply it to a mixed stem, a group clip that includes music, or any track where speech and non-speech audio have already been combined.
  • Never use it on music or ambient tracks: The feature is trained on speech patterns. Applying it to music, room tone, or sound effects will produce unpredictable artifacts and degraded audio quality.
  • Split clips with different noise profiles before applying: If one part of a clip was recorded in a quiet room and another part was recorded near a fan or outdoors, split the clip at the transition point and apply different Amount values to each segment separately.
  • Use a conservative Amount on mildly noisy audio: If the original recording is only slightly noisy, a lower Amount (30–50) will clean it up without making it sound processed. Reserve values above 70 for audio that is genuinely difficult.
  • Always A/B compare before finalizing: Toggle the Enhance Speech checkbox on and off during playback to verify the enhancement is actually an improvement for that specific clip.
  • Check the result on different playback systems before final export: What sounds clean on studio monitors may still sound thin or unnatural through laptop speakers or earbuds. Build the final export check into your workflow.
Limitations of Enhance Speech And What to Do When It’s Not Enough
Enhance Speech is effective for common dialogue problems — light-to-moderate background noise, room presence, mild HVAC hum — but it has a clear ceiling. There are specific situations where it will not produce usable results, regardless of the Amount setting:
  • Severely clipped or distorted audio: If the original recording peaked and distorted during capture, the waveform data needed for reconstruction is gone. AI cannot recover it.
  • Heavy reverb or echo: Audio recorded in large, reflective rooms (parking garages, gymnasiums, bare concrete spaces) has reverb baked in. Enhance Speech is not a de-reverb tool.
  • Outdoor wind noise: Strong winds introduce broadband noise that directly competes with the speech signal, confusing the AI model.
  • Overlapping voices: The feature is built around a single primary speaker. Multiple overlapping voices in the same clip produce inconsistent and often poor results.
When Enhance Speech hits its limit, the real issue is the recording itself. The original audio is the main factor here. AI tools in editing always work better with cleaner input.
Getting better sound at the source reduces later fixing work. A good microphone setup makes a big difference right from the beginning. A wireless mic with 32-bit Float recording and built-in AI Noise Cancellation helps a lot. And guess what? The Hollyland LARK MAX 2 comes pack with all these brilliant features, and much more! Plus, it records 48kHz audio. The mic also includes onboard noise cancellation. This gives editing tools cleaner audio to work with. It also reduces how much Enhance Speech needs to fix later.
Q1: Is Enhance Speech free in Premiere Pro?
Enhance Speech is included with an active Adobe Creative Cloud subscription at no additional cost. There is no separate purchase or add-on required. You will need to be running Premiere Pro version 23.0 or later. If you do not see the feature in the Essential Sound panel, check that your Premiere Pro installation is fully up to date through the Creative Cloud desktop app.
Q2: Why is Enhance Speech greyed out?
This usually happens when the clip is not set correctly. The feature only works on Dialogue in Essential Sound. If the clip is marked as Music or SFX, it stays inactive. No category selection also keeps it disabled in the panel. So make it functional, select the audio clip, and open the Essential Sound panel. Click the Dialogue tag to reassign the audio type. After that, Enhance Speech becomes active again for use.
Q3: Does Enhance Speech work on audio recorded from a phone or camera?
Yes, it will process audio from any source. However, results vary considerably depending on recording quality. Phone or built-in camera audio with moderate background noise can show meaningful improvement. Heavily degraded recordings — low bitrate, heavily compressed, or recorded in noisy environments — may still show artifacts, particularly at higher Amount values.
Q4: Does Enhance Speech affect video quality or file size?
No. Enhance Speech processes only the audio track associated with the clip. It writes a new audio render without modifying the video data. Your video quality is unaffected, and any file size change at export will be negligible and audio-related only.
Q5: Can I use Enhance Speech on multiple clips at once?
Yes. Select multiple clips on the timeline that are already tagged as Dialogue, then enable Enhance Speech and set your Amount value in the Essential Sound panel. The setting applies across all selected clips simultaneously, which makes batch processing a sequence of interview clips or voiceover takes significantly faster.
Enhance Speech is one of the easiest ways to clean up dialogue in Premiere Pro. Once you know where it is, the whole process feels pretty straightforward. Just tag your clip as Dialogue, switch on Enhance Speech, and start with a moderate Amount. Give it a quick preview before locking anything in. Most rough voice recordings get noticeably clearer after that. Try it on a problem clip in your project and listen to the change yourself.
