Premiere Pro’s built-in Speech to Text feature lets you generate a full transcript directly from your timeline without a third-party plugin. Whether you need captions for YouTube, subtitles for a documentary, or a plain-text transcript for show notes, the entire workflow runs inside Premiere Pro. This guide covers every step — from opening the correct panel to exporting a finished SRT file — along with practical tips for getting the most accurate results.
Does Premiere Pro Have Built-In Audio Transcription?
Yes. Adobe added native Speech to Text functionality in Premiere Pro 2021 (version 15.4), powered by Adobe Sensei, Adobe’s AI and machine learning engine. The feature lives inside the Text panel and requires no additional plugins, third-party subscriptions, or manual caption entry to use.
Before running Speech to Text, confirm you have the following in place:
Premiere Pro version 15.4 or later. The Speech to Text feature is exclusive to the 2021 release and newer. Update through the Creative Cloud desktop app if you’re on an older version.
A sequence with audio or video clips loaded. Transcription works at the sequence level or on individual clips. Have your footage assembled on the timeline before starting.
A supported language selected. Premiere Pro supports a growing list of languages. English delivers the highest accuracy, but you can select your target language in the transcription dialog.
Adequate system memory. Adobe recommends at least 16 GB of RAM for smooth processing; 32 GB is preferable for longer sequences.
Clean source audio. Audio quality directly affects transcript accuracy. Noisy or inconsistent recordings increase correction time (covered in detail in the accuracy tips section below).
How to Transcribe Audio in Premiere Pro Using Speech to Text
The full workflow runs through Premiere Pro’s Text panel. Here are the steps from start to finish.
Step 1 — Open the Text Panel
Go to Window > Text in the top menu bar to open the Text panel, then click the Transcript tab at the top. If no transcription has been run yet, the tab will prompt you to begin one.
Note: The Text panel may already be docked in your workspace. If you cannot find it, go to Window > Text to bring it forward.
Step 2 — Select Your Sequence
Premiere Pro can transcribe either the active sequence or individual clips from the project panel. For most editing workflows — interviews, podcasts, documentary cuts — transcribing the full sequence is the better choice, since it captures all audio in timeline order and reflects any edit decisions you’ve already made. Confirm the correct sequence is open and active in the Timeline panel before moving forward.
Step 3 — Run Transcription
With the Transcript tab open, click the Transcribe Sequence button. A dialog box will appear with these options:
Language — Select the spoken language from the dropdown.
Audio Track — Choose which audio track to analyze if your sequence has more than one.
Identify Speakers — Enable this if your recording contains multiple speakers. Premiere Pro will label distinct voices as Speaker 1, Speaker 2, and so on.
Improve Audio — Check this box to apply Adobe’s Enhance Speech pre-processing before transcription, which can recover intelligibility from recordings with mild noise.
Click Transcribe. Processing time depends on sequence length and your hardware. A 30-minute interview may take several minutes to complete.
Step 4 — Review and Edit the Transcript
Once transcription finishes, the full text appears in the Transcript tab with each word linked to its timecode. Clicking any word jumps the playhead to that point in the timeline.
To correct errors:
Double-click a word to select and edit it inline.
Use the search bar at the top of the panel to find and replace repeated mistakes across the entire transcript.
If speaker labels are active, click any label to rename it (for example, change “Speaker 1” to “Sarah”).
Edits made in the Transcript tab carry through automatically when you generate captions, so cleaning up the transcript now saves time later.
How to Create Captions from Your Premiere Pro Transcript
Once the transcript is reviewed, converting it to a caption track takes only a few clicks.
In the Transcript tab, click the Create Captions button. A dialog box will open.
Choose your caption format:
SRT — a plain-text subtitle format compatible with YouTube, Vimeo, and most streaming platforms.
CEA-608 — the broadcast closed-caption standard for television delivery.
Subtitle — a general open-caption format for web and streaming use.
Set your maximum line length and duration to control how much text appears on screen per caption block.
Click Create to apply.
Premiere Pro adds a captions track to your timeline. Each caption block appears as its own clip, synced to the corresponding audio. You can trim, extend, or drag caption clips just like any other clip on the timeline.
To adjust styling — font, size, color, position — select the captions track and open the Essential Graphics panel (Window > Essential Graphics). Style changes apply to the entire captions track at once.
Captions track vs. burned-in subtitles: A Premiere Pro captions track is a data layer, not visual text baked into the video image. You can export it as a separate SRT file and let a platform like YouTube handle display, or you can choose to render it directly into the video by enabling that option in the Export Settings dialog during final export.
How to Export a Transcript or Captions File from Premiere Pro
Premiere Pro offers two export paths depending on how you plan to use the text.
Path 1: Export as SRT (or another captions format)
Go to File > Export > Captions.
Select your preferred format from the dialog (SRT is the most widely compatible option).
Choose a destination folder and click Export.
Use this path when uploading subtitles to YouTube, Vimeo, or any platform that accepts a separate captions file.
Path 2: Export as plain text from the Transcript panel
In the Transcript tab, click the three-dot menu in the panel’s top-right corner.
Select Export Transcript to Text File.
Save the file to your preferred location.
Use this path when you need a readable document for show notes, blog posts, editorial review, or client delivery. The plain-text file contains spoken words without timecodes, making it easy to paste into any document editor.
Tips to Improve Transcription Accuracy in Premiere Pro
The quality of Premiere Pro’s transcript is directly tied to the quality of your source audio. These steps reduce manual correction time:
Record in a quiet environment. Background noise and room reflections are the most common cause of transcription errors.
Keep the microphone close to the subject. A higher signal-to-noise ratio in the recording gives the AI engine more to work with.
Avoid overlapping speakers. Speaker identification works best when voices are distinct and non-simultaneous. In interviews, encourage guests to wait for a pause before responding.
Maintain consistent audio levels. Aim for levels in the -12 to -6 dBFS range. Sudden volume drops or spikes cause missed words.
Use the Improve Audio checkbox. Enabling this option in the Transcribe Sequence dialog applies Adobe’s Enhance Speech pre-processing to help compensate for imperfect recordings.
Starting with cleaner recorded audio is the single most effective variable you can control. A wireless lavalier microphone with built-in AI noise cancellation — such as the Hollyland LARK MAX 2, which records at 48 kHz / 32-bit Float and applies noise reduction at the source before the signal ever reaches Premiere Pro — delivers the kind of clean input that Adobe Sensei’s Speech to Text engine processes most reliably, and can meaningfully cut the number of edits you need to make in the Transcript panel.
Alternative Tools for Transcribing Audio Before or After Premiere Pro
Premiere Pro’s built-in Speech to Text handles the majority of standard production needs, but it can fall short with heavy accents, multiple overlapping speakers, or degraded archival recordings. In those cases, a dedicated transcription service will often deliver higher accuracy. All of the tools below export SRT files that can be imported directly into Premiere Pro via File > Import.
Simon Says — A professional-grade service that integrates directly with Adobe Premiere Pro and supports a broad range of languages.
Descript — An audio and video editing platform with strong transcription accuracy and straightforward SRT export.
Sonix — An automated transcription service well-suited for interview and podcast content, with clean SRT output.
What version of Premiere Pro supports Speech to Text transcription?
Speech to Text was introduced in Premiere Pro 2021 (version 15.4). If you’re running an older version, update through the Creative Cloud desktop app. Users who cannot update can use a third-party tool such as Descript or Simon Says and import the resulting SRT file into Premiere Pro.
How accurate is Premiere Pro’s auto-transcription?
Accuracy typically ranges from 85 to 95 percent with clean, well-recorded audio in a supported language. Background noise, overlapping speakers, strong accents, and low recording quality all reduce accuracy and increase the number of manual corrections needed in the Transcript panel.
Can I transcribe audio from multiple speakers and label them separately?
Yes. Enable the “Identify Speakers” option in the Transcribe Sequence dialog before running the transcription. Premiere Pro will assign labels such as Speaker 1 and Speaker 2 to distinct voices. You can then rename each label in the Transcript panel to reflect the actual speaker names.
Can Premiere Pro transcribe audio in languages other than English?
Yes. Premiere Pro’s Speech to Text supports a growing list of languages. Select the correct language from the dropdown in the Transcribe Sequence dialog before starting. English currently delivers the strongest accuracy, but other supported languages produce usable results with clean source audio.
The workflow reduces to two core steps: use the Text panel to generate a transcript via Speech to Text, then click Create Captions to convert it into a timeline track you can style and export. Clean source audio is the most controllable factor determining how much correction work that transcript requires. Once your captions track is ready, explore the styling options in the Essential Graphics panel or follow a dedicated guide on exporting SRT files for YouTube to complete your workflow.
