How to Edit Speaker Names in Premiere Pro (Step-by-Step)
When Premiere Pro transcribes a multi-speaker recording, it auto-labels each voice as “Speaker 1,” “Speaker 2,” and so on. Those generic labels are fine as placeholders, but before you publish captions or share a transcript, replacing them with real names makes your deliverables look polished and professional. This guide walks you through the exact steps to rename speaker labels inside the Transcript panel and covers the most common issues you might run into.
What Are Speaker Names in Premiere Pro?
Speaker names are auto-generated labels that Premiere Pro’s Speech to Text engine assigns to each detected voice in your sequence. They appear in the Transcript tab inside the Text panel, sitting above each block of dialogue attributed to that voice. Editing them matters because those labels feed directly into your captions track and exported transcripts, so inaccurate names create confusion for viewers, editors, and anyone reviewing the export downstream.
How to Edit Speaker Names in the Transcript Panel
Step-by-Step Instructions
  1. Open your sequence in Premiere Pro, then go to Window > Text to open the Text panel.
  2. Click the Transcript tab at the top of the Text panel to view your auto-generated transcript.
  3. Locate a speaker label – for example, “Speaker 1” – sitting above one of the transcript blocks.
  4. Right-click the speaker label and select Edit Speaker Name from the context menu. Alternatively, double-click the label to enter edit mode directly, depending on your Premiere Pro version.
  5. Type the new name in the editable field.
  6. Press Enter to confirm the change. When prompted, select Rename all instances to apply the new name globally across every segment attributed to that speaker in the transcript.
Note: In Premiere Pro 2023 and later, you can also click the speaker label once to enter inline edit mode without right-clicking. If you are on an older build and the inline click does not respond, use the right-click method instead.
How Editing Speaker Names Affects Your Captions
Renaming a speaker in the Transcript tab does not always update an existing captions track automatically, so the timing of your edits matters.
  • If you rename before creating captions: The new names carry through immediately when you generate a captions track from the transcript. This is the cleanest workflow.
  • If captions already exist: The existing caption segments will not update retroactively. You will need to either regenerate the captions track from the corrected transcript or manually edit the affected caption segments in the Captions track.
For SRT and VTT exports, speaker names are not included as standard labeled fields in the output file. If you need speaker-attributed output for review or accessibility documentation, use Premiere Pro’s built-in transcript export (plain text or DOCX format) instead of SRT, as that format preserves speaker name metadata.
Tips for Keeping Speaker Names Consistent Across Multi-Speaker Projects
Managing three or more speakers adds room for error. These habits help keep things clean:
  • Rename immediately after transcription and before you create any captions track. Doing it early prevents the extra step of regenerating captions later.
  • Pick a naming convention and stick to it. First name only (“Maria”) works well for captions readability; full names (“Maria Chen”) are better for formal transcripts or legal work. Mixing both creates inconsistency in exports.
  • Use speaker color assignments alongside name edits. Premiere Pro lets you assign a unique color to each speaker in the Transcript panel, which makes it easier to visually scan multi-speaker timelines and catch any segments still tagged to the wrong label.
  • Run a quick speaker filter after renaming to confirm no stray segments are still labeled with the old auto-assigned name.
Q1: Why does Premiere Pro show “Unknown Speaker” instead of a speaker number?
Premiere Pro assigns “Unknown Speaker” when its engine cannot confidently distinguish a unique voice during transcription – this often happens with overlapping dialogue, low audio quality, or very short speaking segments. To fix it, right-click the “Unknown Speaker” label in the Transcript tab, select Edit Speaker Name, and assign the correct name manually.
Q2: Can I edit speaker names after I’ve already created captions?
Yes, but there is an extra step. Edit the names in the Transcript tab first, then either regenerate the captions track from the updated transcript for a clean result, or manually update individual caption segments in the Captions track if you want to preserve other edits you have already made there.
Q3: Do speaker names appear in exported SRT or VTT files?
Not in standard SRT output. SRT files do not have a native field for speaker labels, so those names are stripped during export. If you need speaker-attributed output, export the transcript as plain text or DOCX from the Transcript tab instead, which does retain speaker name metadata.
Q4: Can I merge two speaker labels that were auto-assigned to the same person?
Yes. Simply rename both labels to the same name and Premiere Pro will treat all associated segments as belonging to one speaker. After merging, use the speaker filter in the Transcript tab to review all combined segments at once and confirm nothing was misattributed.
Next Steps
Once your speaker names are accurate, head back to the Text panel and either generate a new captions track from the corrected transcript or export the transcript directly for review. Clean speaker labels now mean less cleanup work during caption review and a more professional final deliverable for your audience.
