How to Add, Edit, and Export Captions in Premiere Pro (Step-by-Step Guide)
Adding captions in Premiere Pro is straightforward once you understand the two main methods and how the export paths differ. Whether you are generating captions automatically with Speech to Text, importing an existing SRT file, or burning text directly into a video for social media, this guide walks you through every stage — from the Captions workspace setup to the final export. Follow the sections in order or jump to the step that matches your current workflow.
Captions in Premiere Pro — What You Need to Know First
Before you start, it helps to know how Premiere Pro labels the three track types you will encounter.
Closed Captions are an accessibility standard (CEA-608 or CEA-708) that embed a separate data stream into the video. Viewers can toggle them on or off in a supported player.
Open Captions are text burned directly into the video frame. They are always visible and cannot be turned off by the viewer.
Subtitles in Premiere Pro’s context assume the viewer can hear the audio and are primarily used for language translation, not accessibility.
All three are managed inside the dedicated Captions workspace. Open it by going to Window > Workspaces > Captions and Graphics. The Text panel on the left and the timeline caption track are the two areas you will use most throughout this guide.
Method 1 — Using Auto Captions (Speech to Text)
This is the fastest path for most editors. Premiere Pro’s Speech to Text feature, powered by Adobe Sensei, transcribes spoken dialogue directly from your sequence audio and converts it into a caption track with a few clicks.
How to Generate Auto Captions
  1. Open the Captions and Graphics workspace via Window > Workspaces > Captions and Graphics.
  1. Make sure the sequence you want to caption is open and active in the Timeline panel.
  2. Under the Captions tab, click the Create captions from transcript button.
  3. In the dialog that appears, configure the format, layout, and character length.
  4. Click Create captions and wait for the process to be completed.
  1. Once completed, you can click the language button to translate the transcript.
Processing time depends on sequence length and your system. A five-minute sequence typically finishes in under two minutes on a modern machine. Premiere Pro will display progress in the Text panel. Do not close the panel or switch sequences while transcription is running.
Improve Transcription Accuracy Before You Caption
Auto-captions are only as accurate as the audio they are reading. Clean, intelligible dialogue with minimal background noise will produce a transcript close to publication-ready, while noisy or muffled recordings require significant manual correction afterward. Recording at 48 kHz with clean source audio makes a measurable difference — wireless microphones like the Hollyland LARK MAX 2, which captures at 48 kHz / 32-bit Float with AI Noise Cancellation, give Speech to Text a significantly cleaner signal to work with. If re-recording is not an option, consider noise reduction in Premiere Pro’s audio tools before running transcription.
Review and Correct the Transcript
Fixing errors at the transcript stage takes far less time than correcting individual caption clips on the timeline after conversion. Once the transcription is complete, work through it in the Text panel before creating any captions.
  1. Scroll through the transcript in the Text panel.
  2. Click directly on any word to highlight and edit it.
  3. Playback will jump to the corresponding timecode, so you can hear the audio while correcting text.
  4. Delete any false starts, filler words, or misheard phrases at this stage.
  5. Do not worry about caption breaks yet — those are set in the next step.
Pro Tip: Use Ctrl+F (Windows) or Cmd+F (Mac) inside the Text panel to find and replace recurring transcript errors, such as misheard proper nouns or brand names.
Convert Transcript to Caption Track
Once the transcript is accurate, convert it to a caption track using the following steps.
  1. In the Text panel, click “Create Captions from Sequence Transcript” (the button appears below the transcript once transcription is complete).
  2. A dialog box opens with the following settings to configure:
  • Maximum Duration (seconds): Controls the longest a single caption clip can run on screen. A setting of 3–4 seconds works for most spoken dialogue.
  • Minimum Duration (seconds): Sets the shortest a caption can appear. Keep this at 1 second to prevent flashing text.
  • Gap Between Captions: The silence between caption clips. 0 frames or a small gap of 3–5 frames reads cleanly.
  • Lines: Choose 1 or 2 lines per caption. Two lines work well for longer sentences; one line is standard for social media formats.
  • Format: Leave this as Subtitle unless you are producing broadcast content that requires a closed caption standard (CEA-608 or CEA-708).
  1. Click Create.
Premiere Pro will generate a caption track directly above your video track in the timeline. Each spoken segment becomes an individual caption clip that you can trim, move, and edit independently.
Method 2 — Adding Captions Manually
Manual captioning is the right choice when you already have a caption file from a client or transcription service, or when you need precise frame-level control over every caption clip.
Importing an SRT or VTT File
  1. Go to File > Import and navigate to your SRT or VTT file.
  2. Select the file and click Import. It will appear in your Project panel.
  3. Drag the caption file from the Project panel onto the timeline, placing it above your video track.
  4. Premiere Pro will automatically create a caption track and populate it with the text and timing from the file.
  5. Play back the sequence to confirm the captions are syncing correctly with the dialogue.
Timecode mismatch fix: If the captions appear early or late across the entire sequence, the most common cause is a sequence start timecode that is not set to 00:00:00:00. Go to Sequence > Sequence Settings and check the Start Timecode field. If it does not match the start time encoded in your SRT file, adjust either the sequence start timecode or offset the caption track on the timeline accordingly.
Creating Caption Clips Manually on the Timeline
This method works best for short videos or situations where you need full control over every caption’s timing.
  1. In the timeline, position the playhead where you want the first caption to appear.
  2. Under the Captions tab, select “Create new caption track”.
  1. Click the “+” button to create a blank text block.
  2. Type your caption in the block and do this until the whole video is captioned.
  3. Right-click and split if the text is too long or if you prefer single-line subtitles.
  4. There are a couple of ways to adjust the timing, but the easiest one is to drag and trim the text blocks in the timeline (usually located above the V1 track).
How to Edit and Style Captions in Premiere Pro
Editing Caption Text and Timing
  1. Double-click any caption clip in the timeline to open it for editing in the Text panel.
  2. Click into the text field and make your changes directly.
  3. To adjust timing, drag the left or right edge of the caption clip on the timeline to shorten or extend its duration.
  4. To move a caption to a different timecode, click and drag the clip body horizontally on the timeline.
  5. Use the Text panel to batch-edit multiple captions sequentially without switching back to the timeline between each one.
  6. Press Tab in the Text panel to jump to the next caption clip in sequence.
Pro Tip: To split one long caption into two shorter clips, position the playhead at the split point, select the caption clip, and press Ctrl+K (Windows) or Cmd+K (Mac) — the same razor cut shortcut used for video clips.
Styling Captions (Font, Color, Size, Position)
With the caption track selected, style controls appear in the Essential Graphics panel on the right side of the workspace.
  1. Select one or more caption clips on the timeline.
  2. In the Essential Graphics panel, open the Edit tab.
  3. Change the font family and font size using the text formatting controls. A font size of 40–60px (at 1080p) is a common starting point for readability.
  4. Adjust fill color for the text and optionally add a background box or text stroke for contrast against complex backgrounds.
  5. Reposition captions by adjusting the Vertical Position slider or dragging the text block in the Program Monitor.
  6. To save these settings as a reusable preset: click the menu icon in the Essential Graphics panel and select “Save Caption Style Preset”. Give it a descriptive name and it will be available in any future project.
Note: Platform-specific sizing matters. YouTube and Vimeo render captions at roughly standard proportions, but vertical formats like Instagram Reels and TikTok require a higher safe zone — keep text within the center 70% of the frame vertically to avoid overlap with UI elements.
How to Export Captions in Premiere Pro
This is the step editors most commonly get wrong. The export path depends entirely on how the captions will be delivered.
Export Captions as a Separate File (SRT / VTT)
Use this path when uploading to YouTube, Vimeo, LinkedIn, or any platform that accepts a separate caption file.
  1. Go to File > Export > Captions.
  2. In the Export Captions dialog, choose your Format from the dropdown (SRT, MCC, VTT, or others depending on your Premiere version).
  3. Choose a file destination and click Export.
  4. Upload the exported file to your video platform’s caption/subtitle manager separately from the video file.
Caption Format Comparison:
Format
Best For
Notes
SRT
Most universal; plain text with timecodes
VTT
Web video players (HTML5)
Supports basic inline styling
MCC
Broadcast / CEA-708
Closed caption standard for TV delivery
For the vast majority of online video workflows, SRT is the correct choice.
Export Captions Burned Into the Video
Use burned-in captions for platforms that do not support separate caption file uploads, such as TikTok, Instagram Stories, and Facebook Reels. Keep in mind that burned-in captions are permanently part of the video frame and cannot be removed or edited after export.
  1. In the timeline, make sure your caption track is visible and active.
  2. Open the Export dialog via File > Export > Media (or send to Adobe Media Encoder).
  3. In the Export Settings window, click the Captions tab.
  4. From the “Export Options” dropdown, select “Burn Captions into Video”.
  5. Confirm your other export settings (codec, resolution, frame rate) and click Export.
The rendered video file will contain the caption text baked directly into every applicable frame.
Troubleshooting Common Caption Issues in Premiere Pro
  • Auto Captions option is greyed out: This usually means the sequence has no active audio tracks, or you are not in the Captions and Graphics workspace. Confirm you have an audio track with content and that the Speech to Text panel is properly loaded.
  • Captions not showing on export: Open the Export Settings dialog and check the Captions tab. The setting may be on “Don’t Export” by default. Switch it to “Burn Captions into Video” or “Create Sidecar File” depending on your goal.
  • SRT import timecode not syncing: Check that your sequence start timecode matches the SRT file’s start time. Go to Sequence > Sequence Settings > Start Timecode and set it to 00:00:00:00 if the SRT file was authored from the beginning of the video.
  • Text spilling outside the safe zone: In the Essential Graphics panel, reduce the font size or adjust the vertical and horizontal position settings. Enable the safe margin guides in the Program Monitor via the wrench icon > Safe Margins to see the boundary zones.
Q1: What is the difference between captions and subtitles in Premiere Pro?
In Premiere Pro, captions (particularly closed captions) are designed for accessibility and are built to include non-speech audio cues like [applause] or [music]. Subtitles assume the viewer can hear the audio and are intended for language translation. Premiere Pro treats them as separate track types with different export options and compliance standards.
Q2: Does Premiere Pro auto-caption work in all languages?
Adobe Sensei supports a growing list of languages, which you can review in the Speech to Text settings dialog when setting up a transcription. Accuracy varies by language and is heavily dependent on audio quality. English currently has the strongest recognition performance, while support for other languages is updated with each major Premiere release.
Q3: Can I reuse caption styles across different Premiere Pro projects?
Yes. After styling your captions, click the menu icon in the Essential Graphics panel and choose “Save Caption Style Preset.” The preset is stored locally and can be loaded into any future Premiere Pro project, keeping your caption appearance consistent across a series or client deliverables.
Q4: How do I add captions to individual clips vs. the whole sequence?
Speech to Text transcription and the resulting caption track operate at the sequence level, not the clip level. For individual clips, you have two options: create a dedicated short sequence for that clip, or manually create caption clips only over the relevant portion of the timeline by using the Add Caption method described in Method 2.
Q5: Why are my exported captions out of sync?
The most common cause is a sequence start timecode that does not begin at 00:00:00:00, creating an offset between the video and the caption data. Go to Sequence > Sequence Settings > Start Timecode and set it to 00:00:00:00. For imported SRT files, confirm that the timecodes in the file itself match the sequence’s timeline position.
Next Steps
You now have two complete paths for adding captions — auto-generated or manual — and two export paths depending on your delivery platform. The logical next skill to build is styling captions for specific platform specs, since safe zone dimensions, font sizing, and contrast requirements differ between YouTube, Instagram Reels, and TikTok. From there, learning how to batch-export multiple caption files through Adobe Media Encoder will save significant time on multi-platform deliveries. For a broader look at output settings, see our guide to Premiere Pro export settings and format optimization.
