How to Export Captions in Premiere Pro (Step-by-Step)
Getting captions out of Premiere Pro is straightforward once you know which export method matches your destination. The process differs depending on whether you need a standalone caption file, permanently visible text in the video frame, or captions encoded inside the video container for broadcast. This guide covers all three paths with step-by-step instructions, format selection guidance, and fixes for the most common export failures.
Sidecar File vs. Burned-In Captions — Which Export Method Do You Need?
Before you touch the export dialog, decide how your captions will travel with the video. Premiere Pro offers two fundamentally different output types, and choosing the wrong one means a full re-export.
Method
What It Produces
When to Use It
Sidecar file (SRT / WebVTT)
A separate caption file delivered alongside the video
YouTube, Vimeo, streaming platforms, clients who need editable captions
Burned-in / open captions
Captions rendered permanently into the video frame
Instagram Reels, TikTok, Facebook autoplay, social media, clients without caption management
Embedded closed captions (CEA-608/708)
Captions encoded inside the video container
Broadcast delivery, OTT platforms, MXF/MOV network handoffs
Sidecar files keep captions toggleable so viewers can turn them on or off. Burned-in captions are always visible and cannot be removed downstream. If your destination platform supports caption file uploads, a sidecar file is almost always the better choice because it preserves flexibility for future edits.
How to Export Captions as a Sidecar File (SRT / WebVTT)
This is the most common export path for YouTube creators, social media managers, and editors delivering web content. The dedicated caption export route lives in the File menu, not inside the Export Media dialog, which is where most editors get stuck.
Important: A caption track must already exist on your timeline for this option to appear. If you have not added or imported a caption track, the File > Export > Captions option will be grayed out.
Step-by-Step Instructions
  1. Open the sequence containing your caption track in the Timeline panel.
  2. Go to File > Export > Captions.
  3. In the Export Captions dialog, select your Caption File Format (SRT, WebVTT, or another supported format depending on your Premiere Pro version).
  4. Set the Frame Rate to match your sequence frame rate exactly to prevent timestamp drift.
  5. Adjust the Start Time if your sequence does not begin at 00:00:00;00, as a non-zero start timecode will offset every caption timestamp in the exported file.
  6. Click OK and choose a destination folder for the file.
  7. Open the exported caption file in a text editor to confirm it contains content and timestamps before delivering it.
Pro Tip: In Premiere Pro 2022 and later, the Captions workspace (Window > Workspaces > Captions and Graphics) gives you a clear view of your caption track. Confirm the track labeled “Captions” is present and populated in the timeline before you export.
Choosing the Right Caption File Format
Match the format to your destination to avoid upload errors or unsupported file warnings.
Format
Best For
SRT
YouTube, Vimeo, most video platforms
WebVTT
Web embeds, HTML5 video players
CEA-608 / CEA-708
Broadcast, cable, OTT delivery
STL
European broadcast (EBU standard)
When in doubt, SRT is the most universally accepted format for online platforms and rarely causes compatibility problems.
How to Burn Captions into the Video (Open Captions)
Burning captions into the video frame makes them permanently visible with no separate file and no viewer toggle. This method is the standard approach for social media content where autoplay runs without sound, and for deliverables where you cannot guarantee the receiving platform will handle a sidecar file.
Note: Burned-in captions are irreversible in the exported file. If captions need to change later, you must return to the source sequence and re-export the entire video.
  1. Open your sequence in the Timeline panel and locate the caption track.
  2. Right-click the caption track header and select Convert to Open Captions. This converts the track from a closed-caption format to a visible open caption layer that renders into the video frame. (This option is available in Premiere Pro 2022 and later.)
  3. Scrub through the sequence in the Program Monitor to confirm captions appear correctly and are positioned as intended.
  4. Open the Export Media dialog with File > Export > Media or press Ctrl+M (Windows) / Cmd+M (Mac).
  5. Choose your output format and preset. H.264 is appropriate for most web and social media uses.
  6. Click the Captions tab in the Export Media dialog and confirm the setting is Burn In.
  7. Set your output file name and destination, then click Export or queue the job in Adobe Media Encoder.
After the export finishes, scrub through the video file to verify captions are visible and correctly positioned before delivery.
Exporting a Video File with Embedded Closed Captions (CEA-608/708)
Embedded closed captions are required for broadcast television, cable networks, and some OTT platforms. Unlike a sidecar SRT, the captions are encoded directly into the video container so everything travels as a single file.
To export with embedded captions:
  1. Open the Export Media dialog via File > Export > Media.
  2. Select a compatible output format such as MXF, MOV, or H.264 with a broadcast preset.
  3. Click the Captions tab in the Export Media dialog.
  4. Set Export Options to Embed in Output File.
  5. Select the appropriate standard: CEA-608 for standard definition or legacy broadcast, or CEA-708 for HD broadcast and digital delivery.
  6. Confirm the caption track type in your sequence matches the standard you selected, then export.
Your sequence caption track type must match the embedded standard you choose. A CEA-608 track will not export correctly as CEA-708 without first converting the track in the Text or Captions panel.
Troubleshooting Caption Export Issues in Premiere Pro
  • “Export Captions” is grayed out in the File menuCause: No caption track exists on the active sequence, or the sequence with captions is not currently open in the Timeline panel. Fix: Click into the correct sequence tab in the Timeline. Confirm a caption track is present, not just text layers or Essential Graphics clips. If no caption track exists, you need to add or import one before exporting.
  • Captions are visible in the timeline but absent from the exported videoCause: You used the Export Media path without configuring the Captions tab, or the caption track type is set to closed captions, which requires a sidecar file rather than rendering into the frame. Fix: For sidecar output, use File > Export > Captions. For burned-in output, convert the track to open captions first, then export via Export Media with Burn In selected in the Captions tab.
  • SRT file timestamps are misaligned or offsetCause: The sequence start timecode is not 00:00:00;00, or there is a frame rate mismatch between the export settings and the sequence. Fix: In the Export Captions dialog, manually set Start Time to 00:00:00;00 and verify the frame rate in the dialog matches your sequence frame rate exactly.
Can I export both the video and SRT file at the same time in Premiere Pro?
Not in a single export operation. You need to export the video through File > Export > Media and the SRT file separately through File > Export > Captions. Adobe Media Encoder does not combine both into one queued output, so plan for two separate export steps in your delivery workflow.
Why is my SRT file blank after exporting?
A blank SRT usually means the caption track was empty or the wrong track type was targeted. Open the Text panel (Window > Text) and confirm your caption track contains actual caption clips. If the timeline only has Essential Graphics text layers, those are not caption tracks and will not export as an SRT file.
What caption format does YouTube require?
YouTube accepts SRT, WebVTT, SBV, and several additional formats. SRT is the most reliable choice when exporting from Premiere Pro. Uploading your own SRT file gives you full control over timing and phrasing, which is generally more accurate than relying on YouTube’s auto-generated captions.
Does exporting captions in Premiere Pro require Adobe Media Encoder?
No. The dedicated caption export path (File > Export > Captions) runs directly inside Premiere Pro without launching Media Encoder. Media Encoder is only involved if you are queuing the video file export or batch-processing multiple sequences through the AME queue.
How do I export captions for Instagram Reels or TikTok?
Both platforms have limited and inconsistent support for uploaded caption files. The reliable approach is to burn captions directly into the video by converting your caption track to open captions and exporting with the Burn In setting in Export Media. This ensures captions display on every device and feed placement without relying on platform caption support.
For most online delivery, the choice comes down to one question: does your platform support a caption file upload? If yes, export a sidecar SRT. If not, or if reliable visibility matters more than flexibility, burn the captions into the video. For broadcast or OTT work, embed CEA-608 or CEA-708 directly in the container through the Export Media Captions tab.
Related reading: - How to Add Captions in Premiere Pro - Best Caption Formats for YouTube and Social Media - How to Use the Captions Workspace in Premiere Pro 2024
