Premiere Pro’s Speech to Text feature is supposed to save you hours, but when it stalls, returns blank output, or grays out entirely, the cause is rarely obvious. No useful error message, no clear next step – just a workflow stopped cold. This guide walks through the seven most common reasons transcription fails and gives you a direct fix for each, ordered from quickest to check to most involved.
Why Premiere Pro’s Transcription Feature Fails
Before jumping into fixes, here are the most common root causes. If one of these matches your situation, skip directly to the corresponding fix.
No internet connection or Adobe server outage: Speech to Text runs on Adobe’s cloud servers, so any network disruption silently breaks the feature.
Unsupported Premiere Pro version: Speech to Text requires version 22.0 (2022) or later; older installs won’t show the option at all.
No detectable audio track: Transcription needs a linked, active audio track with audible speech – muted or empty tracks produce no output.
Language setting mismatch: If the selected transcription language doesn’t match the spoken language in your clip, you’ll get blank or garbled results.
Corrupted media cache: Damaged cache files can prevent transcription from starting or completing, even when everything else is configured correctly.
Corrupted preferences file: A broken Premiere Pro preferences file can silently disable features, including Speech to Text.
GPU driver conflict: Hardware acceleration can occasionally interfere with cloud-based processing, causing transcription to fail without any error message.
Fix 1 – Confirm Internet Connection and Adobe Server Status
Premiere Pro does not process transcription locally. Audio is sent to Adobe’s cloud servers, which means a dropped connection or a service-side outage will stop transcription with no meaningful error. Always check this first.
Verify your internet connection by loading a webpage in your browser.
Open the Creative Cloud desktop app and confirm you are signed in. If your session has expired, sign out and sign back in with your Adobe ID.
Visit status.adobe.com and check for any reported incidents affecting Premiere Pro or Adobe’s cloud services.
If an outage is listed, wait for Adobe to resolve it – no local fix will override a service-side failure.
Once connectivity is confirmed and servers show normal status, relaunch Premiere Pro and attempt transcription again.
Fix 2 – Update Premiere Pro to a Supported Version
Speech to Text was introduced in Premiere Pro 22.0, released in January 2022. If you’re on an older version, the Transcribe Sequence option either won’t appear in the Text panel or will fail without explanation. Several early v22 releases also shipped with transcription bugs that were patched in subsequent updates, so running the latest version matters beyond just meeting the minimum requirement.
Open the Creative Cloud desktop app on your computer.
Click “Apps” in the left sidebar.
Find Premiere Pro in your installed apps list and check for an available update.
Install any pending updates and relaunch Premiere Pro.
Open the Text panel (Window > Text), click “Transcribe Sequence,” and test the feature again.
Fix 3 – Verify Your Audio Track Is Detectable
Premiere Pro’s transcription engine needs a linked audio track with actual speech to process. If the track is missing, muted, or running at near-zero levels, the engine has nothing to work with and will either return no output or report “No speech detected.”
Click your clip in the timeline and check the Source panel. Confirm the clip has a visible audio waveform – a video-only file will have no waveform and cannot be transcribed.
Check the timeline and confirm the audio track is not muted. The “M” button on the track header should not be active.
Open the Audio Clip Mixer (Window > Audio Clip Mixer) and play your clip. Watch the level meters and confirm audio is registering above silence – levels consistently near zero will prevent detection.
If audio levels are low, adjust the clip volume or apply audio normalization before running transcription.
How Poor Audio Quality Affects Transcription Accuracy
Even when your audio track is present and technically audible, heavy background noise or a poor signal-to-noise ratio can overwhelm the speech detection engine and produce incomplete or empty output. This is a source recording problem, not a software bug, and it won’t be resolved by any of the settings-level fixes in this guide. Capturing clean audio at the recording stage – for example, using a wireless microphone system like the Hollyland LARK MAX 2, which features AI Noise Cancellation and 48 kHz / 32-bit Float recording – eliminates this category of transcription failure entirely before the footage ever reaches Premiere Pro.
Fix 4 – Correct the Language Setting in the Text Panel
The transcription engine matches audio against a specific language model. If the spoken language in your clip doesn’t match the language selected in the Text panel, output will be blank, full of errors, or missing large sections. This is one of the most common and easily overlooked causes of a failed transcription.
Go to Window > Text to open the Text panel.
Click “Transcribe Sequence.”
In the dialog, open the “Language” dropdown and confirm it matches the language spoken in your clip.
If it was set incorrectly, select the correct language.
If a previous transcription attempt was made, check the “Overwrite existing transcript” box.
Click “Transcribe” and allow the process to complete.
Adobe’s Speech to Text engine currently supports English, Spanish, French, German, Italian, Japanese, Korean, Mandarin Chinese, Portuguese, Danish, Norwegian, and Swedish, among others. Check Adobe’s official documentation for the current complete and updated list.
Fix 5 – Clear Premiere Pro’s Media Cache
Corrupted cache files are a frequent, invisible source of feature failures in Premiere Pro. Clearing the media cache is completely non-destructive – it does not affect project files, sequences, or exported media. Premiere Pro will rebuild the cache automatically the next time it needs it.
In Premiere Pro, go to Edit > Preferences > Media Cache (on Mac: Premiere Pro > Preferences > Media Cache).
Click “Delete” next to “Remove Media Cache Files.”
Select “Delete all media cache files” and confirm the action.
Close Premiere Pro completely and reopen it.
Load your project and attempt transcription again.
Fix 6 – Reset Premiere Pro Preferences
A corrupted preferences file can quietly disable Speech to Text and other Premiere Pro features. Resetting preferences restores all settings to factory defaults. This will reset your workspace layouts and any custom keyboard shortcuts, so export your keyboard shortcut profile before proceeding if you have a customized setup (Edit > Keyboard Shortcuts > Export).
Close Premiere Pro completely.
Hold the Alt key (Windows) or Option key (Mac) and click the Premiere Pro icon to launch the application.
A dialog will appear asking whether you want to reset preferences – click “Yes.”
Allow Premiere Pro to fully relaunch with default settings.
Open your project and test transcription again.
Fix 7 – Disable Hardware Acceleration
GPU driver conflicts can occasionally block cloud-processing features like Speech to Text. Switching to software-only rendering is a diagnostic step, not a permanent fix. If transcription works after making this change, update your GPU driver and then switch the renderer back.
Go to File > Project Settings > General.
Under “Video Rendering and Playback,” locate the “Renderer” dropdown.
Switch from “GPU Acceleration (CUDA / Metal / OpenCL)” to “Software Only.”
Click OK and restart Premiere Pro.
Attempt transcription again. If it succeeds, update your graphics card driver through your GPU manufacturer’s software, then return the renderer to GPU Acceleration.
Why does Premiere Pro say “No speech detected” even though my clip has audio?
This message typically means audio levels are too low for the engine to process, the wrong language is selected in the transcription dialog, or the audio contains no speech – only music or ambient sound. Check your track levels in the Audio Clip Mixer and confirm the language setting matches your clip before re-running transcription.
Does Premiere Pro transcription work offline?
No. Speech to Text requires an active internet connection because audio is processed on Adobe’s cloud servers. If you are working offline or on a restricted network, transcription will not run. Check your connection and visit status.adobe.com to rule out a service outage before troubleshooting further.
What Premiere Pro version supports Speech to Text?
Speech to Text is available in Premiere Pro version 22.0 (January 2022) and later. A valid Adobe Creative Cloud subscription is required. If you are on an older version, update through the Creative Cloud desktop app to access the feature and receive ongoing bug fixes.
How do I re-transcribe a clip after changing the language setting?
Open the Text panel (Window > Text), click “Transcribe Sequence,” and select the correct language from the dropdown. Check the “Overwrite existing transcript” box before clicking Transcribe. This replaces the previous output with a new transcription using the updated language model.
Transcription was working before – why did it stop?
The most common causes of a sudden failure are an Adobe server outage, an expired Creative Cloud login session, or a regression introduced by a recent software update. Check status.adobe.com first, then sign out of Creative Cloud and sign back in. If a recent update is the suspected cause, check Adobe’s Premiere Pro community forums for reported regressions.
Next Steps
Work through these fixes in order: start with your internet connection and Premiere Pro version, then verify your audio track and language setting, and move to cache clearing and preference resets only if earlier steps don’t resolve the issue. If none of the fixes work, post in Adobe’s official Premiere Pro community forum or submit a bug report through Adobe’s feedback tool. And for recurring transcription problems tied to audio quality, clean capture at the recording stage is the single most reliable long-term fix.
