Premiere Pro has no built-in TikTok preset, which means every creator has to configure the vertical format manually. Get it wrong and you will spend time troubleshooting black bars, cropped footage, and choppy playback after upload. This guide gives you every value you need to set up a correct 9:16 sequence, choose the right frame rate, and export a TikTok-ready file—without guesswork.
Why TikTok Needs a Custom Sequence in Premiere Pro
Premiere Pro ships with presets for broadcast formats, cameras, and common social ratios, but TikTok is not among them. That gap matters because TikTok’s native format—1080×1920 pixels in a 9:16 vertical orientation—is the inverse of the 1920×1080 horizontal frame that most presets assume. If you open a default sequence and start editing, the program monitor will be landscape, and your vertical footage will either be pillarboxed with black bars on both sides or cropped unpredictably when TikTok reprocesses the file after upload.
A custom sequence tells Premiere Pro the canvas dimensions, frame rate, and pixel behavior that match TikTok’s requirements before a single clip lands on the timeline. That alignment means what you see in the program monitor is exactly what viewers will see on their phones—no surprises at delivery.
Setting up the sequence correctly also protects your export. Export settings that do not match the sequence can introduce scaling artifacts or force the encoder to compensate in ways that reduce quality. Building the project right from the start eliminates those downstream problems entirely.
The Correct Sequence Settings for TikTok at a Glance
The table below contains every value you need. Keep this open while following the step-by-step section.
Setting |
Value |
Editing Mode |
Custom |
Frame Size |
1080 × 1920 |
Pixel Aspect Ratio |
Square Pixels (1.0) |
Frame Rate |
30 fps (standard) or 60 fps (smooth motion) |
Fields |
No Fields (Progressive) |
Audio Sample Rate |
48000 Hz |
Display Format |
Frames |
Why these values matter: - 1080×1920 is TikTok’s recommended Full HD vertical resolution. Width comes first, height second—this is where most mistakes happen. - Square Pixels (1.0) ensures no geometric distortion. Non-square pixel ratios are a legacy broadcast setting and will stretch or squeeze your footage. - No Fields (Progressive) matches every modern camera sensor. Interlaced footage shot with modern gear will comb on fast motion. - 48000 Hz is the broadcast-standard audio sample rate and is what TikTok’s encoder expects for clean audio sync.
How to Create the Custom Sequence (Step-by-Step)
Open your project in Premiere Pro.
Go to File → New → Sequence.
In the New Sequence dialog, click the Settings tab at the top (not a preset category).
Set Editing Mode to Custom.
Set Timebase to 30.00 fps (or 60.00 if your source footage is 60 fps).
Enter 1080 in the horizontal field and 1920 in the vertical field under Frame Size.
Set Pixel Aspect Ratio to Square Pixels (1.0).
Under Fields, select No Fields (Progressive Scan).
Set Display Format to Frames.
Confirm Audio Sample Rate is set to 48000 Hz.
Name your sequence something identifiable, such as “TikTok_1080x1920_30fps.”
Click OK.
Your program monitor should now display a tall vertical canvas. If it still looks horizontal, double-check that you entered the frame size with 1080 as width and 1920 as height—not the other way around.
Using a Clip to Auto-Generate Sequence Settings
If your camera or phone already shot footage in vertical 9:16 format, Premiere Pro can build a matching sequence automatically. Drag the clip directly onto the New Item icon at the bottom of the Project panel, or drag it onto an empty area of the Timeline panel. Premiere Pro will create a sequence that matches the clip’s properties. This shortcut works well when all your source footage was captured vertically at a consistent frame rate, but use the manual method above when you are repurposing horizontal footage or mixing clips from multiple sources.
Choosing the Right Frame Rate for TikTok
TikTok accepts video up to 60fps, so you have three realistic options. Choose based on your source footage and the aesthetic you want.
24fps: Gives a cinematic film look. Use it only if your source was shot at 24fps. TikTok accepts it, but it is less common for short-form content and can look slightly choppy on trending fast-cut edits.
30fps: The standard recommendation for TikTok. Smooth enough for most content types, universally compatible, and the safest choice if you are mixing clips from different devices.
60fps: Best for dance videos, action content, sports, or the high-frame-rate aesthetic that performs well on certain TikTok trends. Only choose 60fps if your source footage was also captured at 60fps; applying a 60fps sequence to 30fps footage does not add frames—it just duplicates them.
Pro Tip: Always match your sequence frame rate to your source footage frame rate. A mismatch causes Premiere Pro to drop or duplicate frames, which produces choppy playback both in the timeline and after upload.
Export Settings for TikTok in Adobe Premiere Pro
When your edit is complete, go to File → Export → Media (or press Ctrl+M / Cmd+M). Use the following values:
Export Setting |
Value |
Format |
H.264 |
Preset |
Match Source – High Bitrate (as a starting point) |
Frame Size |
1080 × 1920 (confirm it has not reverted) |
Frame Rate |
Match sequence (30 or 60 fps) |
Bitrate Encoding |
VBR, 2 Pass |
Target Bitrate |
8 Mbps |
Maximum Bitrate |
16 Mbps |
Audio Format |
AAC |
Audio Bitrate |
320 kbps (or 192 kbps minimum) |
File Extension |
.mp4 |
On bitrate: TikTok re-encodes every video after upload, so uploading an astronomically high bitrate file does not improve the final result—it only increases upload time. A VBR 2-pass encode targeting 8 Mbps with a ceiling of 16 Mbps gives the encoder enough data to preserve detail in motion without pushing toward TikTok’s 287.6 MB file size limit for standard uploads. For a typical 60-second TikTok at 30fps, this range keeps your file well within that limit.
After confirming all settings, click Export to render directly, or click Queue to send the job to Adobe Media Encoder.
Using Adobe Media Encoder for Batch Export
If you are cutting multiple TikTok versions from a single project—different aspect ratios, durations, or caption variants—click Queue instead of Export. Adobe Media Encoder opens in the background and handles the render while you continue editing in Premiere Pro. It also saves your export presets, which speeds up delivery on future projects.
Common Mistakes and How to Fix Them
Black bars or pillarboxing on the sides: The sequence or export frame size was set to 1920×1080 instead of 1080×1920. Open Sequence Settings (Sequence menu → Sequence Settings), correct the frame size, and re-export. If the export dialog shows the correct size but the video still has bars, check whether a nested sequence with the wrong dimensions is inside your timeline.
Footage appears zoomed in or heavily cropped: Your source footage is horizontal (16:9) and Premiere Pro is scaling it to fill the vertical frame. Apply the Auto Reframe effect (Effects panel → search “Auto Reframe”) to let the AI track your subject automatically, or use the clip’s Position and Scale properties in the Effect Controls panel to manually reposition and crop the frame to a composition you prefer.
Choppy or stuttered playback after upload: The sequence frame rate and the export frame rate do not match, or the source footage frame rate differs from both. Go back and confirm all three values are consistent. If the source footage is a different frame rate, use Premiere Pro’s Interpret Footage option (right-click the clip in the Project panel → Modify → Interpret Footage) to set the correct native frame rate before editing.
Capture Better Audio Before You Edit
Sequence settings determine how your picture looks, but audio quality is locked in at the moment of recording—no amount of post-processing fully repairs audio captured with poor equipment. For TikTok creators shooting on the go, a compact wireless microphone eliminates wind noise, room tone, and the hollow sound of a phone’s built-in mic before the footage ever reaches Premiere Pro. The Hollyland LARK M2 weighs 9 grams, runs for up to 40 hours on a single charge, and clips on without being visible on camera. It sends clean audio directly to your camera or phone, so the file you import into Premiere Pro is already production-ready.
Q: Does Adobe Premiere Pro have a built-in TikTok preset?
No. Premiere Pro does not include a native TikTok sequence preset. You must create a custom sequence using 1080×1920 at 30fps with square pixels. Once you build it and save it, you can export that configuration as a custom preset for future projects so you do not have to re-enter the values manually.
Q: Can I edit a horizontal video and export it for TikTok in Premiere Pro?
Yes. Create a 1080×1920 sequence, import your horizontal footage, and use the Auto Reframe effect or manually reposition the clip to fill the vertical frame. Auto Reframe uses AI to keep the subject centered, while manual repositioning gives you full creative control over what part of the frame is shown.
Q: Should I use 30fps or 60fps for TikTok?
30fps works well for most content and is universally accepted by TikTok. Use 60fps only if your source footage was shot at 60fps and you want the high-frame-rate look. Choosing 60fps for footage shot at 30fps does not improve motion smoothness—it only duplicates frames and increases file size.
Q: What resolution does TikTok recommend for uploads?
TikTok recommends 1080×1920 pixels for vertical Full HD video. The platform can accept up to 4K, but 1080p is the standard that balances visual quality and file size for most creators, and it stays well within TikTok’s upload limits.
Q: Why does my TikTok video have black bars after upload?
Black bars almost always mean the sequence or export frame size was set to 1920×1080 (horizontal) instead of 1080×1920 (vertical). Correct the sequence settings, confirm the export frame size matches, and re-export the file. Double-check any nested sequences inside your timeline as well.
Next Steps
The three values that matter most are straightforward: 1080×1920 frame size, 30fps frame rate, and H.264 export. Get those right and every other setting falls into place. For more advanced workflows, explore how color grading in Premiere Pro can sharpen your TikTok visuals, or learn how the Auto Reframe tool handles horizontal-to-vertical conversions automatically—both are natural next steps once your sequence setup is solid.
