Turning a 16:9 video into vertical content once took a lot of work. Editors had to crop each frame manually for TikTok, Instagram Reels, and YouTube Shorts. But now Auto Reframe in Premiere Pro removes most of that work by using Adobe Sensei AI to detect motion and intelligently reposition the crop for any target aspect ratio. Whether you need a single clip converted or an entire timeline reformatted at once, this guide walks through both methods, all three motion tracking presets, and how to correct tracking errors when the AI misses the mark.
What Is Auto Reframe in Premiere Pro?
Auto Reframe is an AI-powered feature built into Adobe Premiere Pro that detects the primary subject or motion in your footage and repositions the crop frame when you switch to a new aspect ratio. Rather than manually keyframing a pan across hundreds of clips, the tool analyzes each frame and generates position keyframes to keep the action centered. It is powered by Adobe Sensei, Adobe’s machine learning engine.
The main reason people use Auto Reframe is social media editing. Many creators film and edit videos in the standard 16:9 landscape format first. Later, they also need vertical or square versions for different platforms. Auto Reframe quickly converts videos into formats like 9:16, 1:1, or 4:5. These formats fit TikTok, Instagram Reels, square posts, and portrait feeds better. Your original clip or sequence stays unchanged during the process. Premiere Pro creates a separate adjusted version that you can review and edit further.
There are two ways to access the feature. The Auto Reframe Sequence method processes your entire timeline at once from the Sequence menu. The Auto Reframe Effect applies the reframe to individual clips via the Effects panel. Both methods are covered in detail below.
Auto Reframe Sequence vs. Auto Reframe Effect: Which Should You Use?
Both methods produce similar results but serve different use cases. The table below summarizes the key differences so you can pick the right approach before you start.
Method |
Where to Find |
Best For |
Limitations |
Auto Reframe Sequence |
Sequence menu > Auto Reframe Sequence |
Reformatting a complete, finished edit for a new platform in one pass |
Processes the whole timeline; less granular per-clip control |
Auto Reframe Effect |
Effects panel > search “Auto Reframe” |
Single clips or mixed-format timelines requiring clip-by-clip adjustments |
Must be applied and configured clip by clip |
How to Use Auto Reframe Sequence (Full Timeline Method)
The Sequence method is the fastest way to reformat an entire finished edit. Premiere Pro creates a duplicate sequence at the new aspect ratio, leaving your original sequence completely intact.
Step 1: Open Your Sequence and Navigate to Sequence > Auto Reframe Sequence
Make sure the sequence you want to reframe is open, and files are selected in the Timeline panel.
Click Sequence in the top menu bar.
Select Auto Reframe Sequence from the dropdown. If this option appears grayed out, confirm you have an active sequence selected and that you are running the latest Premiere Pro version.
Step 2: Set Your Target Aspect Ratio
In the Auto Reframe Sequence dialog, open the Aspect Ratio dropdown.
Select the ratio that matches your target platform: 9:16 for TikTok, Instagram Reels, and YouTube Shorts; 1:1 for Instagram square posts; or 4:5 for portrait-style feed content.
The dialog will display the new sequence dimensions below your selection so you can confirm before proceeding.
Step 3: Choose a Motion Tracking Preset
Use the Motion Tracking dropdown to select a preset: Slower Motion, Default, or Faster Motion.
Match the preset to your footage type. A full breakdown of each option appears in the next section.
If you are unsure which to use, start with Default and adjust after reviewing the output.
Step 4: Let Premiere Process and Open the New Sequence
Click Create to begin processing. Processing time depends on sequence length and your system’s hardware.
Premiere Pro generates a new sequence with a reframed suffix added to the name (for example, “Sequence 01 - 1x1 ”).
Open the new sequence from the Project panel and scrub through it to review the tracking results before you export.
Pro Tip: Run Auto Reframe Sequence on a finalized or near-finalized edit. Processing a rough cut means regenerating the reframed sequence every time you revise the original, which adds up quickly on longer projects.
How to Apply the Auto Reframe Effect to Individual Clips
The Auto Reframe Effect gives you per-clip control and is the better choice when you are working with a mixed-format timeline or need to reframe only one or two clips without restructuring an entire sequence.
Open the Effects panel (Window > Effects if it is not already visible).
In the search bar, type Auto Reframe.
Drag the Auto Reframe effect onto the target clip in your timeline.
Select the clip and open the Effect Controls panel.
Set the Motion Tracking preset to match the movement in the clip.
Click Analyze to let Premiere process the clip and generate position keyframes.
Scrub through the clip in the Program Monitor to check the framing, and adjust any keyframes that look off (see the section on keyframe correction below).
Understanding the Motion Tracking Presets
Choosing the wrong Motion Tracking preset is the most common reason Auto Reframe produces a poor result. Each preset tells Adobe Sensei how aggressively to move the reframed crop in response to motion detected in the clip.
Slower Motion: Best for content with little or no camera or subject movement. Use this for talking-head interviews, seated presenters, controlled product shots, or any footage where the subject holds a fairly fixed position throughout the clip.
Default: A balanced setting for general mixed content with moderate movement. Use this for footage that includes walking, light gestures, or moderate camera pans, and when you are not certain which preset fits best. It is a reliable starting point for most social media content.
Faster Motion: Designed for high-energy content such as sports footage, action sequences, fast pans, handheld run-and-gun shooting, or any clip where the subject crosses the frame quickly. This preset reacts more aggressively to keep fast-moving subjects centered.
If your first result does not look right, switch presets and re-analyze the clip rather than spending time correcting dozens of bad keyframes manually.
How to Review and Correct Auto Reframe Keyframes?
After Premiere Pro processes a clip or sequence, it generates a series of position keyframes that control where the reframed crop sits at each moment in time. These keyframes are fully editable, so you can fix tracking errors without rerunning the entire analysis from scratch.
Open the reframed sequence (Sequence method) or select the clip with the Auto Reframe effect applied.
Scrub slowly through the timeline in the Program Monitor. Look for moments where the frame jumps suddenly, cuts to the wrong area, or loses the subject entirely.
Note the timecode of each problem area.
Expand the Adjust Position section. Check the “Overwrite generated path” option to see keyframes plotted on the mini timeline.
Position the playhead on the mini timeline on the scene that needs reframing.
Now, go to the Adjust Position option. And adjust the values. You will notice that the specific keyframe will be reframed.
To add a new keyframe at a specific point, place the playhead at that timecode and click the Add/Remove Keyframe button next to the Position property.
To remove a rogue keyframe causing a sudden jump, click it in the Effect Controls timeline and press Delete.
After editing, scrub through the corrected section again to confirm the adjustment plays back smoothly.
Pro Tip: If a large portion of a clip has bad tracking, it is often faster to delete all Auto Reframe keyframes and manually set three to five keyframes at key moments rather than correcting each flawed keyframe one by one.
Target Aspect Ratios by Platform (Quick Reference)
Use this table to confirm the correct aspect ratio setting before running Auto Reframe.
Platform |
Aspect Ratio |
Recommended Preset Starting Point |
TikTok |
9:16 |
Default or Faster Motion |
Instagram Reels |
9:16 |
Instagram Feed (Square) |
1:1 |
Default |
Instagram Feed (Portrait) |
4:5 |
Default |
YouTube Shorts |
9:16 |
Facebook Stories |
9:16 |
Default |
Common Auto Reframe Mistakes and How to Fix Them
Even with the right settings, Auto Reframe does not always produce a perfect result on the first pass. Here are the most frequent problems and how to address each one.
AI tracks the background instead of the subject: Switch to a different Motion Tracking preset (Faster Motion often helps when the subject is moving) and re-analyze. If the problem continues, manually override the keyframes at the affected moments in Effect Controls.
Output looks overly cropped or zoomed in: This is a resolution issue, not an Auto Reframe bug. Shoot or source in 4K and output at 1080p. The extra pixel headroom gives Premiere room to reframe without a visible quality hit.
Sequence settings mismatch after reframe: After the Sequence method generates a new sequence, go to Sequence > Sequence Settings and confirm the dimensions match your target platform specifications.
Auto Reframe Sequence option is grayed out: The most common causes are that no sequence is currently active in the Timeline panel, your Premiere Pro version is older, or the project file is in a read-only state.
Does Auto Reframe in Premiere Pro reduce video quality?
Auto Reframe itself does not degrade video quality, but reframing inherently zooms into the frame, which can reduce sharpness if your source resolution is too close to your output resolution. Shooting or sourcing in 4K and outputting at 1080p gives the algorithm enough pixel headroom to reframe without a noticeable loss in clarity.
Can I undo or reset Auto Reframe after applying it?
Yes. For the Effect method, select the clip, open Effect Controls, and either disable or delete the Auto Reframe effect entirely. In some cases, pressing Ctrl + Z (undo) also works and removes the recent change back to the previous or original state. For the Sequence method, your original sequence is always preserved unchanged. Simply delete or discard the generated reframed sequence if you want to start over with different settings.
What versions of Premiere Pro support Auto Reframe?
Auto Reframe was introduced in Premiere Pro 14.0 as part of the Adobe Creative Cloud subscription. Any version from 14.0 onward supports the feature. If your version is older, update through the Creative Cloud desktop application. But we do recommend installing the most recent version of Adobe Premiere Pro to enjoy the newest features.
Does Auto Reframe work with multicamera sequences or nested clips?
Auto Reframe performs best on flattened, non-nested timelines. If the project has a multicamera sequence or nested clips, unwrap first. For multicam edit, duplicate the sequence first, then. Right-click multicam clips, choose Multicam Flatten Multi-Camera option. Then use the Auto Reframe Sequence method on the flattened copy.
Why is my Auto Reframe Sequence option grayed out?
Three common reasons can cause this issue in Premiere Pro. No sequence is active or selected in the Timeline panel. An older Premiere Pro version may also cause it. A project opened in read-only mode creates this problem. Check all conditions, then try the menu option again.
Auto Reframe provides two main ways to work in Premiere Pro. One option processes an entire sequence at once, while the other allows adjustments on each clip separately. Before working on longer edits, try it on a short 30-second clip first. This helps fine-tune the motion tracking settings. Also, it helps spot any keyframes that need manual fixes. For creators focused on social content, using a small wireless microphone can also help. The Hollyland LARK M2 is often chosen to keep audio clear across different platforms.
