Premiere Pro handles YouTube Shorts well once you know the right settings. The challenge most creators face is not the editing itself but getting the vertical sequence configured correctly, keeping the cut tight enough for short-form pacing, and exporting with the right codec for YouTube to recognize the video as a Short. This guide walks you through every step, from project setup to final upload.
Before opening Premiere Pro, confirm you have everything in place:
Premiere Pro version: 2022 or later is recommended for full Speech-to-Text caption support and the Auto Reframe tool
Footage: Vertical (9:16) clips are ideal, but horizontal (16:9) footage can be adapted
Separate audio files: If you recorded dialogue or voiceover separately, have those files ready to sync
Length awareness: Standard YouTube Shorts must be under 60 seconds; YouTube now also supports Shorts up to 3 minutes, but sub-60-second content still gets priority in the Shorts feed
A YouTube account ready for upload once editing is complete
Setting Up the Right Sequence for YouTube Shorts
Getting sequence settings wrong is the single most common mistake when editing Shorts in Premiere Pro. Building your edit in a standard 1920x1080 timeline and exporting vertically produces pillarboxing, cropping problems, or degraded upload quality.
Follow these steps to create the correct vertical sequence:
Open your project and go to File > New > Sequence, or press Ctrl+N (Windows) / Cmd+N (Mac).
Navigate to the Settings tab in the New Sequence dialog instead of selecting a preset. No default preset includes a 9:16 vertical configuration.
Enter the following settings manually:
Setting |
Value |
Frame Rate |
29.97 fps or 60 fps |
Frame Width |
1080 |
Frame Height |
1920 |
Pixel Aspect Ratio |
Square Pixels (1.0) |
Fields |
No Fields (Progressive Scan) |
Audio Sample Rate |
48000 Hz |
Name your sequence something descriptive, such as “Shorts_Final_v1,” and click OK.
Confirm the sequence by checking the Program Monitor. It should display a tall vertical canvas, not a wide horizontal one.
Pro Tip: If you realize mid-edit that your sequence settings are wrong, do not try to patch it with scaling adjustments. Create a new sequence with the correct dimensions and move your timeline clips into it. Trying to fix incorrect settings late in an edit wastes more time than starting fresh.
Using Auto Reframe for Horizontal Footage
If your source footage is 16:9 and you need to fit it into a 9:16 frame, the Auto Reframe tool can automate most of the repositioning work.
Place the horizontal clip on your Shorts timeline.
Go to Sequence > Auto Reframe Sequence, or right-click the clip and choose Auto Reframe.
Set the target aspect ratio to Vertical 9:16.
Select a motion tracking preset: Slower Motion, Default, or Faster Motion, based on how much camera movement your clip contains.
Review the result in the Program Monitor and scrub through the full clip.
Override manually when needed: Select the clip, open Effect Controls, and adjust Position and Scale keyframes to keep your subject centered through any sections Auto Reframe misses.
Pro Tip: Auto Reframe is a reliable starting point for talking-head content but often struggles with wide-angle shots or fast movement. Always scrub the entire clip after applying it before moving on in the edit.
Importing and Organizing Your Footage
With your sequence ready, bring your clips into the project in an organized way:
Open the Media Browser panel (Window > Media Browser) and navigate to your footage folder. Importing from within Premiere rather than dragging files from your desktop reduces link errors.
Select all relevant clips and click Import, or drag them into the Project panel.
Create bins to keep the project organized. Right-click in the Project panel, select New Bin, and label them clearly: “Raw Footage,” “Music,” “Graphics,” “SFX.”
If you recorded audio separately, import those files and use Clip > Synchronize (matching by audio waveform) to align them with your video clips.
Preview each clip in the Source Monitor before adding it to the timeline. Use this step to confirm which sections are usable and whether any single clip will push your total duration past the 60-second limit.
Cutting and Trimming Your Short on the Timeline
Short-form content lives and dies by pacing. A slow opening loses viewers within two seconds. Every clip on your timeline should earn its place.
Set In and Out points in the Source Monitor before placing clips on the timeline. Press I to mark In and O to mark Out, then drag or insert the clip. This prevents cluttering the timeline with footage you do not need.
Use the Razor tool (C) to make precise cuts directly on the timeline, then select and delete the unwanted segments.
Ripple Delete gaps immediately. Right-click any gap in the timeline and select Ripple Delete, or press Shift+Delete. Leaving gaps creates silence and black frames in the final export.
Mark the 60-second boundary. Move the playhead to the 01:00:00;00 timecode mark and press M to drop a sequence marker. This visible flag keeps you from accidentally letting the edit run long.
Lean into jump cuts. On Shorts, jump cuts are not a flaw but a convention. Cutting out pauses, filler words, and dead air keeps energy high and viewer retention strong.
Enable snapping (S key) so clips snap cleanly to adjacent clips and markers. This prevents micro-gaps between cuts that cause audio pops or a flash of black on export.
Review the full edit in real time. If the first one to two seconds do not communicate a clear hook, trim the opening or reorder the clips. The algorithm rewards high audience retention from the very first frame.
Adding Text, Titles, and Captions
Captions and on-screen text are not optional for Shorts. A significant portion of viewers watch on mobile with sound off, and readable captions directly affect how long people stay in the video.
Open the Essential Graphics panel via Window > Essential Graphics. Click New Layer > Text to create a text element, or browse the panel for pre-built social media templates.
Respect mobile safe zones. The top of the screen is partially covered by the subscribe button, and the bottom is covered by the video title, sound bar, and action buttons. Keep important text between approximately 15% and 75% of the vertical canvas height to avoid overlap.
Style text for readability. Use a bold font at a minimum of 60–80pt on a 1080x1920 canvas. Add a drop shadow or semi-transparent background bar behind the text to create contrast against any background.
Generate auto-captions using Speech to Text. Go to Text > Captions > Create captions from transcript. Premiere Pro analyzes the audio track and produces a caption file automatically. Review and correct errors in the Captions panel before styling.
Style captions consistently. With your caption track selected, open the Essential Graphics panel and set a uniform font, size, color, and background fill. Consistency helps captions feel like part of the design rather than an afterthought.
Use animated text templates sparingly. Browse the Essential Graphics panel for short-form-friendly motion templates. Keep individual animations under 0.5 seconds per word reveal to stay in line with Shorts pacing.
Pro Tip: Shrink the Program Monitor down to roughly phone-screen size to test caption readability at real viewing scale. If text becomes hard to read at that size, increase the font size or add more background contrast before you lock the cut.
Editing Audio for Your Short
Poor audio breaks viewer attention even in a video that is under 60 seconds. Clean, balanced sound keeps people watching.
Set dialogue levels to -6 to -3 dB. Select the dialogue or voiceover clip and adjust audio volume in Effect Controls. Alternatively, use the Audio Track Mixer (Shift+9) for fader-based mixing. Avoid peaks above 0 dB.
Apply noise reduction to raw audio. In the Essential Sound panel (Window > Essential Sound), tag your dialogue clip as “Dialogue,” then enable Reduce Noise under the Repair section. The built-in DeNoise audio effect (available in the Effects panel) gives additional manual control for problem recordings.
Add background music. Import a royalty-free track from YouTube Audio Library, Epidemic Sound, or Artlist. Place it on a separate audio track beneath your dialogue track.
Duck the music under dialogue. In the Essential Sound panel, select the music clip, tag it as “Music,” and enable Ducking. Adjust the sensitivity so the music lowers automatically when dialogue is present and returns when dialogue stops.
Test your final mix on multiple playback sources. Listen through headphones first, then through phone speakers. Audio that sounds balanced on monitors can sound thin or muddy through a mobile device.
Note: Starting with clean source audio significantly reduces correction work in post. For creators shooting Shorts on location or on the move, a compact wireless mic like the Hollyland LARK M2 (9g, 40-hour battery, designed for vlogging and short-form content) captures broadcast-quality audio that needs minimal cleanup in Premiere Pro. Good source audio is always faster to work with than damaged audio that needs heavy repair.
Adding Transitions and Effects (Keep It Simple)
Shorts audiences expect clean, fast edits. Heavy transition effects slow pacing and can make content feel dated.
The default approach for Shorts should be the straight cut. Use a transition only when it serves a clear editorial purpose. Practical options include:
Cross Dissolve: Suitable for time jumps or scene transitions
Dip to Black: Works well for an intro fade or a closing beat
Zoom or push effect (keyframed scale): Adds energy to a cut without distracting from the content
Avoid: Wipe transitions, page turns, iris effects, and anything from the “3D Motion” transitions folder. They read as low-quality on mobile screens and slow down the visual rhythm.
To apply a transition, drag it from the Effects panel onto the cut point between two clips. For Shorts, keep transition duration to 10–15 frames maximum.
Quick Color Grading with Lumetri Color
A full cinematic grade is not necessary for Shorts, but a basic correction makes footage look intentional and polished.
Open Lumetri Color via Window > Lumetri Color or switch to the Color workspace. Work through these adjustments quickly:
Auto correction: Click the “Auto” button in Basic Correction to get a histogram-based starting point
Exposure and Contrast: Bring exposure to a neutral level and add slight contrast for depth
Saturation: A small boost between 105–115 makes colors register well on mobile screens
Match across clips: Select all clips, then use Color > Apply Match to create a consistent look across the entire Short without grading each clip individually
Avoid over-processing. Oversaturated, over-sharpened footage is a common short-form mistake that reads as amateurish on mobile.
Exporting Your Short from Premiere Pro
Export settings determine whether your Short uploads at full quality or gets compressed into a degraded file. Use these exact settings.
Go to File > Export > Media (Ctrl+M / Cmd+M), or send to Adobe Media Encoder for background export while you continue working.
Setting |
Recommended Value |
Format |
H.264 |
Output File |
MP4 |
Resolution |
1080 x 1920 |
Frame Rate |
29.97 fps (or 60 fps if shot at 60fps) |
Bitrate Encoding |
VBR, 2 Pass |
Target Bitrate |
10–12 Mbps |
Maximum Bitrate |
15 Mbps |
Audio Codec |
AAC |
Audio Sample Rate |
48000 Hz |
Audio Channels |
Stereo |
Audio Bitrate |
320 kbps |
Additional notes before you export:
Check “Use Maximum Render Quality” in the export dialog when source footage and sequence resolution differ, as this produces smoother downscale or upscale results.
Confirm your timeline duration is under 60 seconds (or under 3 minutes for a long Short) before rendering. The export dialog displays the total duration in the output summary.
For Shorts feed recognition: YouTube routes videos to the Shorts feed primarily based on vertical aspect ratio and duration, but adding #Shorts to your title or description reinforces this classification and helps the algorithm assign it correctly.
After uploading, allow 24–48 hours for YouTube to fully process the Short. If it initially appears as a standard video in your channel, the classification typically corrects itself within a day.
Q: What sequence settings should I use for YouTube Shorts in Premiere Pro?
Use 1080x1920 resolution, 9:16 aspect ratio, square pixels (1.0), and either 29.97 fps or 60 fps depending on your footage. Set the audio sample rate to 48 kHz. These settings match YouTube’s recommended Shorts specifications and ensure your vertical frame is correct from the start, preventing cropping or pillarboxing issues on export.
Q: Can I edit horizontal footage as a Short in Premiere Pro?
Yes. Create a 1080x1920 sequence first, then use the Auto Reframe tool (Sequence > Auto Reframe Sequence) to automatically reposition your horizontal clip within the vertical frame, or manually adjust Scale and Position values in Effect Controls. Auto Reframe works reliably for talking-head content; manual keyframing gives more precise control over action-heavy or wide-angle shots.
Q: How do I keep my Short under 60 seconds in Premiere Pro?
Press M at the 01:00:00;00 timecode mark on your timeline to place a sequence marker as a visible boundary. You can also monitor total duration in the timeline header. Trim clips and ripple-delete gaps throughout your edit to stay within the limit well before you reach the export stage.
Q: What is the best export format for YouTube Shorts in Premiere Pro?
Export as H.264 (MP4) at 1080x1920, with VBR 2-pass encoding, a target bitrate of 10–12 Mbps, and a maximum bitrate of 15 Mbps. For audio, use AAC at 320 kbps and 48 kHz stereo. This combination delivers high visual quality within a manageable file size and is fully compatible with YouTube’s upload and processing pipeline.
Q: Does Premiere Pro have auto-captions for Shorts?
Yes. Go to Text > Captions > Transcribe Sequence to activate Speech to Text. Premiere Pro analyzes your sequence audio and generates a caption track automatically. Review the output for transcription errors in the Captions panel, then style the captions inside the Essential Graphics panel to match your content’s visual design.
Start Editing and Build From There
Editing YouTube Shorts in Premiere Pro follows a clear, repeatable workflow: set up the correct 1080x1920 sequence first, edit for tight pacing, add readable captions, balance your audio, and export with H.264 at the right bitrate. Sequence settings are the step most creators skip or misconfigure, so treat that as step zero before anything else goes on the timeline.
Once this workflow feels natural, explore Shorts thumbnail optimization and channel analytics to understand what is driving watch time. For deeper editing skills, Premiere Pro’s motion graphics templates and keyframe animation for short-form content are strong next areas to develop.
