Uploading a well-edited Short only to watch it look blurry or stretched on YouTube is frustrating, and it almost always traces back to the export stage, not the editing. CapCut Desktop gives you full control over every setting that matters, but the default choices aren’t always optimized for Shorts. The steps below show each setting to choose from and where to find it. You will also see how each choice affects video quality.
Best CapCut Desktop Export Settings for YouTube Shorts: Quick Reference
If you need the numbers fast, start here. Every setting in the table below is covered in detail in the sections that follow.
Setting |
Recommended Value |
Why It Matters |
Resolution |
1080×1920 |
Native vertical format for YouTube Shorts |
Aspect Ratio |
9:16 |
Prevents black bars on mobile screens |
Frame Rate |
30fps (60fps for fast motion) |
Matches standard Shorts playback |
Format |
MP4 |
Most compatible container for YouTube |
Codec |
H.264 |
Universal compatibility, smooth processing |
Bitrate |
High (approx. 10–20 Mbps) |
Preserves quality through YouTube re-encoding |
Color Space |
SDR / Rec.709 |
Avoids HDR conversion issues on standard displays |
Audio Codec |
AAC |
YouTube’s preferred audio format |
Audio Bitrate |
320 kbps (192 kbps minimum) |
Reduces degradation from YouTube compression |
How to Access Export Settings in CapCut Desktop
Many users think that they can adjust all the vital settings related to exporting their videos by simply clicking the "Export" button on the CapCut PC application. Well, those thoughts are real! But some essential baseline parameters, such as aspect ratio, color space, and more, can only be changed through the Modify button, which is right on the interface and appears when none of the files are selected on the timeline.
So before we jump to the steps, keep in mind that the Export button is the final stage for rendering a video with a few settings to tweak. Modify button changes base project settings during editing. And most importantly, whatever changes you make through the Modify option reflect in your Export settings.
So let's explore where each setting exists.
Phase 1:
1. Open the CapCut editor on your computer. Before you import and edit clips, click the Modify button to open project settings.
2. Since you are working on YouTube Shorts, make sure the aspect ratio is correct. To do that, look for the "Aspect ratio" dropdown menu under the Timeline settings. Click the menu and choose 9:16.
3. Next, set a custom Resolution by clicking the dropdown menu.
4. Click the Frame rate dropdown and select your preferred fps.
5. Also ensure that the correct Color space is selected.
6. You can also rename the project or change it when you actually interact with the Export options.
Once you are done with all of this, click Save, import your clips, bring them to the timeline, and edit.
Phase 2:
Video Settings
1. After the editing work is done, click the "Export" button on the top-right corner of the interface.
2. Reconfirm Resolution.
3. Click the Bit rate dropdown menu and choose from Lower, Recommended, Higher, and Custom.
4. Then, from the Codec dropdown menu, select H.264 or HEVC (H.265).
5. Pick the video format for your exported Shorts from the available options, such as MP4 and MOV.
Audio Settings
6. Scroll down to the audio section, open the Format dropdown menu, and choose from MP3, WAV, and AAC.
Lastly, double-check your choices and hit Export.
Note: These settings match CapCut PC Desktop version 8.5.0. Other versions may show different menu names. Some buttons or navigation steps can also appear slightly different.
Video Resolution and Aspect Ratio for YouTube Shorts
The correct export resolution for YouTube Shorts is 1080×1920 pixels at a 9:16 aspect ratio. This is the native vertical format YouTube uses to display Shorts on mobile screens, and it ensures your video fills the frame without black bars or cropping on either side.
As discussed in detail in the previous section, resolution and aspect ratio are largely determined at the project setup stage, not just at export. If you created your CapCut project using the default 16:9 landscape canvas, exporting at 1080×1920 will produce a vertical file, but your footage will likely appear pillarboxed or distorted inside it. The correct fix is to set up a 9:16 canvas before you begin editing on your next project.
Note: If your current project is already in 16:9, you can go to Project Settings in CapCut Desktop and switch the canvas ratio before exporting. CapCut will reframe your clips automatically, but you may need to manually reposition footage afterward.
720×1280 uploads without issues and is technically within YouTube’s accepted range, but 1080p is the standard for competitive Shorts quality. On most modern phone screens, the difference is noticeable.
Frame Rate: 30fps or 60fps for Shorts?
YouTube Shorts supports multiple frame rates, and CapCut Desktop lets you choose from 24, 25, 30, 50, and 60fps at export.
30fps is the standard choice for most Shorts content. Talking-head videos, vlogs, lifestyle clips, and commentary formats all look natural at 30fps, and it keeps file sizes smaller than 60fps with no visual trade-off for those styles.
60fps is worth selecting when your content involves fast movement, such as dance videos, sports highlights, gaming footage, or any scene where motion blur at 30fps would reduce clarity.
Remember, match your export frame rate to your project frame rate. If your timeline is set to 30fps and you export at 60fps, CapCut will duplicate frames to fill the gap. The result is a slightly juddering or unnatural-looking video. Always verify your project settings before you hit export.
Best Video Format and Codec Settings
For YouTube Shorts, always export as MP4. It is the most universally supported container format and the one YouTube processes most reliably. MOV files also work with YouTube Shorts, but they provide no real benefit. In some cases, they can take slightly longer for YouTube to process after upload.
For codec, H.264 is the recommended default for most creators. It is compatible with every major browser, operating system, and YouTube’s upload pipeline. Processing is fast, playback is reliable, and you are unlikely to encounter any downstream compatibility issues.
H.265 (HEVC) produces files roughly 30 to 40 percent smaller than H.264 at comparable quality, which makes it appealing for high-volume uploaders managing storage. The downside is that YouTube may need more time to process H.265 videos. Older computers and some editing programs may also have trouble opening or playing HEVC files if you want to edit them again later.
Use H.264 as your main export format. Only move to H.265 when file size becomes a repeated problem in your editing workflow.
Bitrate and Quality Slider: What Setting to Use?
CapCut Desktop does not offer a direct Mbps input by default. Instead, it uses a quality slider with three labeled tiers:
Recommended: A compressed output suited for quick sharing or draft review. Not appropriate for final Shorts uploads.
High: The right choice for most creators. This produces output in the 10–20 Mbps range for 1080p content, which falls within YouTube’s recommended bitrate window for standard dynamic range uploads. Quality is strong, and file sizes stay manageable.
Higher: Maximum output quality, typically above 20 Mbps. Best reserved for archival copies or situations where you plan to re-edit the exported file in another application. For direct Shorts uploads, most of the extra quality is lost regardless of whether YouTube re-encodes the video.
Select High for your standard Shorts uploads. Because YouTube re-encodes every video it receives, there is a ceiling to how much benefit additional bitrate provides. The goal is to give YouTube’s encoder enough image detail during processing. The High setting does this without creating a larger file than necessary.
Audio Export Settings for YouTube Shorts
Clean audio export settings protect quality that would otherwise be lost to YouTube’s compression. Use the following:
Codec: AAC YouTube’s preferred audio format; MP3 adds no benefit in this context
Keep in mind that YouTube applies its own audio compression on top of whatever you export. If your audio still sounds thin or noisy after applying these settings, the problem is typically at the capture stage rather than the export stage. Compact wireless mics like the Hollyland LARK M2 (9g, 40-hour battery life) are built for Shorts creators who need clean source audio before it ever reaches CapCut, because no export setting can recover quality that was never captured in the first place.
Common Export Mistakes That Hurt YouTube Shorts Quality
These are the errors most likely to cause quality problems after upload:
Exporting in 16:9 instead of 9:16: YouTube adds black bars on both sides, and the video will not display as a Short correctly. Fix: Set the canvas to 9:16 before starting your project.
Mismatched project and export frame rates: Creates judder and duplicated frames that visually degrade playback. Fix: Confirm both project settings and export settings use the same frame rate.
Using the Recommended quality preset for final uploads: This is a compressed output not suited for competitive Shorts quality. Fix: Always use High or Higher for anything you intend to publish.
Exporting to H.265 without verifying compatibility: Can result in slow YouTube processing or playback failures on older systems. Fix: Default to H.264 unless you have a confirmed reason to use HEVC.
Exporting an HDR project to an SDR platform without converting: Colors appear washed out or blown out on standard displays. Fix: Confirm your CapCut project is set to SDR/Rec.709 before exporting for Shorts.
What resolution should I export from CapCut Desktop for YouTube Shorts?
Export at 1080×1920 pixels with a 9:16 aspect ratio. This is the native format for YouTube Shorts and ensures your video displays correctly on mobile screens without cropping, stretching, or black bars. 720×1280 is technically accepted but produces noticeably lower quality on modern devices.
Should I use H.264 or H.265 when exporting Shorts from CapCut Desktop?
Default to H.264. It is fully compatible with YouTube’s upload and processing pipeline and works on virtually every device and system. Use H.265 only if storage management is a priority and you have confirmed your full workflow handles HEVC without issues. For most creators, H.264 is the safer and simpler choice.
Does YouTube Shorts re-encode my video after upload?
YouTube re-encodes every video after upload. Because of that, a higher bitrate matters during export. It gives YouTube a better source quality to process. CapCut’s High preset for 1080p offers around 10 to 20 Mbps. This range is suitable for most Shorts exports. Pushing far above 20 Mbps usually does not improve the final upload.
Why do my Shorts look blurry after uploading even with high export quality?
Two common causes account for most cases. First, YouTube may still be processing your video when you view it. So wait 10 to 15 minutes after upload for the highest-quality version to finish rendering. Second, a frame rate mismatch between your CapCut project settings and your export settings can produce softness and judder that reads visually as blur.
For better Shorts results on YouTube when editing in the CapCut Desktop app, set the correct aspect ratio and resolution first. Make sure your project frame rate and export frame rate match. Use AAC audio for clear sound output. Choose the proper video format and codec before exporting. Also, set the bitrate within the recommended range for stable quality.
