How to Desqueeze Anamorphic Footage in Adobe Premiere Pro
You shot on an anamorphic lens, imported the footage into Premiere Pro, and now every subject looks unnaturally tall and thin. This is not a camera error. Anamorphic lenses optically compress the horizontal field of view, and Premiere Pro does not correct that compression automatically on import. This guide walks through three reliable methods to desqueeze your footage, explains which one to use for a full project, and covers the most common mistakes that keep footage looking wrong even after applying a fix.
Why Anamorphic Footage Looks Stretched in Premiere
Anamorphic lenses use a cylindrical optical element to capture a wider horizontal field of view than the sensor would normally record. To fit that wider image onto a standard sensor, the lens squeezes the horizontal axis by a fixed ratio. When you play that footage back without correcting for the squeeze, Premiere displays the raw pixel data as-is, making everything appear vertically stretched.
Premiere Pro does not read squeeze metadata on import. Unlike some camera-native applications, Premiere has no built-in detection for anamorphic ratios, so the correction always has to be applied manually.
Before fixing the footage, you need to know your squeeze ratio. The two most common values are 1.33x and 2x, though some lenses use 1.5x.
Lens / Adapter
Squeeze Ratio
Moment Anamorphic Lens
1.33x
Sirui 1.33x Anamorphic
1.33x
Sirui Full-Frame Anamorphic
1.5x
Laowa Nanomorph
1.5x
Lomo/Kowa Vintage Anamorphics
2x
SLR Magic 2x Anamorphot
2x
If you are unsure of your ratio, check the lens documentation or look up the specific product on the manufacturer’s website before proceeding.
Method 1 — Interpret Footage (Recommended)
Interpret Footage is Premiere Pro’s native, non-destructive method for correcting pixel aspect ratio at the source clip level. Because the change is applied to the source clip in the Project panel, it propagates automatically to every instance of that clip across the entire timeline. This makes it the most reliable approach for a complete project.
Steps:
  1. Open the Project panel and locate the anamorphic clip.
  2. Right-click the clip and select Modify > Interpret Footage.
  1. In the dialog box, go to the Pixel Aspect Ratio section.
  2. Select Conform to and choose Custom from the dropdown menu.
  3. Enter the PAR value that matches your squeeze ratio (see the table below).
  1. Click OK.
  2. Drag the clip into your sequence and confirm the image displays at the correct width.
Note: If you have already placed the clip in a timeline before interpreting, the correction will apply retroactively to all existing instances of that clip.
What Pixel Aspect Ratio Value to Enter
The PAR value you enter maps directly to your lens’s squeeze ratio. A 2x squeeze means the lens compressed the horizontal axis by a factor of 2, so Premiere needs to expand it by the same factor during playback.
Squeeze Ratio
PAR Value to Enter
Resulting Display Resolution (from 1920×1080)
1.33x
1.33
~2554×1080 (crop or letterbox to 2.39:1)
1.5x
1.50
2880×1080
2x
2.00
3840×1080
For 4K capture (3840×2160 native sensor), the desqueezed output at 2x would be 7680×2160 equivalent, which you then crop or export at your target delivery resolution such as 4096×1716 for a 2.39:1 CinemaScope frame.
Method 2 — Adjust Sequence Pixel Aspect Ratio
Instead of modifying the source clip, you can configure the sequence itself to display footage using an anamorphic pixel aspect ratio. This approach works well when you need a clean sequence-level solution or are managing a mixed timeline with both anamorphic and spherical clips.
Steps:
  1. Go to File > New > Sequence, or open an existing sequence and go to Sequence > Sequence Settings.
  2. Set Editing Mode to Custom.
  3. Enter your target Frame Size (for example, 4096×1716 for a 2.39:1 delivery).
  4. Set the Pixel Aspect Ratio to match your squeeze ratio. For a 2x lens, select Anamorphic 2:1 if available, or enter a custom value.
  5. Click OK and confirm the sequence preview shows the corrected image.
The key distinction between this method and Method 1 is scope. Sequence settings affect how the entire sequence renders and previews. Interpret Footage affects only the source clip’s interpretation. For most single-lens projects, Method 1 is simpler and less prone to error. Use Method 2 when you need consistent rendering behavior across a complex, multi-source timeline.
Method 3 — Manual Horizontal Scale (Quick Workaround)
This method is useful for a quick visual check or when working on an older version of Premiere Pro where Interpret Footage options are limited. It does not change any clip metadata, so it is not suitable for final delivery without additional sequence setup.
Steps:
  1. Select the anamorphic clip in the timeline.
  2. Open Effect Controls.
  3. Under Motion, click the link icon between Scale Height and Scale Width to unlink them.
  4. Increase Scale Width to match your squeeze factor:
  • For 1.33x squeeze: set Scale Width to 133
  • For 1.5x squeeze: set Scale Width to 150
  • For 2x squeeze: set Scale Width to 200
  1. Confirm the image looks correct in the Program Monitor.
Callout: This method expands the visible pixels but does not update the clip’s pixel aspect ratio metadata. If you export with the sequence set to the squeezed source dimensions, the exported file will still appear compressed on other players. Always pair this workaround with a correctly configured sequence frame size, or switch to Method 1 before final export.
How to Export Correctly After Desqueezing
After applying your desqueeze correction, confirm that your export settings reflect the desqueezed dimensions rather than the raw squeezed source resolution.
If you used Interpret Footage correctly, Premiere will treat the expanded resolution as the clip’s native size. Export using H.264 or H.265 at your intended delivery resolution. Common targets include 1920×816 or 2048×858 for a 2.39:1 CinemaScope frame from a 1080p 2x anamorphic source, and 3840×1606 or 4096×1716 from a 4K 2x source.
Source + Lens
Desqueezed Size
Typical Delivery Frame
1920×1080 + 1.33x
2554×1080
1920×810 (2.39:1 crop)
1920×1080 + 2x
3840×1080
1920×540 or upscale to 1920×816
3840×2160 + 1.33x
5107×2160
4096×1724
3840×2160 + 2x
7680×2160
4096×1716
Avoid exporting at the raw squeezed resolution. If the exported file looks compressed when played back outside Premiere, the sequence or export frame size was not updated to reflect the corrected dimensions.
Q: Does Premiere Pro automatically desqueeze anamorphic footage?
No. Premiere Pro does not natively detect anamorphic squeeze on import. Regardless of the lens or camera used, you must manually apply the pixel aspect ratio correction using Interpret Footage or sequence settings. There is no automatic detection feature in any current version of Premiere Pro.
Q: What’s the difference between 1.33x and 2x anamorphic desqueeze?
The squeeze ratio tells you how much the lens compressed the horizontal axis during capture. A 1.33x lens requires 33% horizontal expansion to restore the correct image proportions. A 2x lens requires 100% expansion. Entering the wrong ratio in Interpret Footage will leave the image visibly distorted, either still too narrow or now too wide.
Q: Why does my footage still look squeezed after changing sequence settings?
Sequence settings control playback display at the timeline level, not at the source clip level. If the source clip has not been interpreted correctly, it will still play back squeezed within the sequence. Apply Interpret Footage to the source clip in the Project panel to ensure consistent correction throughout the timeline.
Q: Can I desqueeze 4K anamorphic in Premiere without losing quality?
Yes. Interpret Footage is a metadata-level instruction and does not alter or re-encode the original pixel data. The image quality remains fully intact. Only the display ratio changes. This is one of the main reasons Method 1 is preferred over the manual scale workaround for final project delivery.
For most projects, Interpret Footage is the right tool: it is non-destructive, applies project-wide, and keeps your source files clean. Sequence pixel aspect ratio adjustment works well for complex timelines or specific delivery setups. Manual horizontal scaling is a fast visual check but should not be used as a final export solution without additional configuration. Before opening Premiere, confirm your lens’s squeeze ratio in the manufacturer documentation so you enter the correct value from the start.
For your next step, see the related guide on anamorphic color grading in Premiere Pro to continue building out your workflow after the desqueeze is set.
