How to Use the Parametric Equalizer in Premiere Pro: A Step-by-Step Guide
Muddy dialogue, a boomy room, or harsh sibilance can derail an otherwise solid video edit. The Parametric Equalizer in Premiere Pro gives you the precision to fix these problems at the frequency level, without needing to export audio to a separate application. This guide covers everything you need: where to find the effect, how every control works, and practical EQ settings for dialogue, music beds, and ambience tracks.
What Is the Parametric Equalizer in Premiere Pro?
The Parametric Equalizer is a multi-band audio effect in Premiere Pro that lets you boost or cut specific frequency ranges in any audio clip or track. Unlike a graphic EQ with fixed frequency bands, a parametric EQ gives you full control over frequency, gain, and bandwidth for each band individually. That flexibility makes it one of the most capable native audio tools the software offers.
Premiere Pro also includes an EQ option inside the Essential Sound panel, which is faster to apply but far more limited. The Essential Sound EQ is preset-driven and suited for basic cleanup. The Parametric Equalizer, by contrast, lets you place bands exactly where you need them and dial in precise, surgical corrections.
When to use which: Reach for the Essential Sound panel when you need a quick, consistent fix across similar clips. Use the Parametric Equalizer when you are solving a specific audio problem, such as resonant hum, a boxy room sound, or sibilance that requires precise targeting.
How to Find and Apply the Parametric Equalizer
  1. Open the Effects panel. Go to Window > Effects, or press Shift+7.
  2. Navigate to Audio Effects. Expand the Audio Effects folder in the Effects panel browser.
  3. Open the Filter and EQ subfolder. Scroll down until you find Filter and EQ, then click to expand it.
  4. Locate Parametric Equalizer. It is listed alphabetically within that folder.
  5. Drag it onto your clip. Drop the effect directly onto an audio clip in your timeline. Alternatively, drag it onto an audio track header in the Timeline panel to apply it to every clip on that track.
  6. Open the full interface. Select the clip, open the Effect Controls panel (Window > Effect Controls), and click the Edit button next to Parametric Equalizer to launch the EQ editor.
Pro Tip: Applying the Parametric Equalizer to an audio track rather than individual clips saves time when you want consistent EQ across all clips in the same location, such as every interview shot in the same room.
Understanding the Parametric Equalizer Interface
Once the editor is open, you will see a frequency graph, a row of band controls, and a master gain slider. Here is what each element does.
The Frequency Graph
The horizontal X-axis represents frequency, running from 20 Hz on the left to 20 kHz on the right. The vertical Y-axis represents gain, with 0 dB sitting at the center line. Boosts appear above it; cuts fall below. The curve displayed on the graph is the combined result of all active bands. As you adjust any parameter, the curve updates in real time, giving you a visual reference for how your changes affect the audio signal.
The Five Band Types Explained
Each of the five bands can be independently set to a different type. The table below summarizes each one:
Band Type
Function
Common Use Case
High Pass (HP)
Rolls off all frequencies below the set cutoff
Remove low-end rumble, handling noise, and HVAC hum from dialogue
Low Shelf (LS)
Boosts or cuts all frequencies below the set point
Reduce muddiness across a full track or add warmth to thin audio
Parametric (Bell)
Precise boost or cut centered on one frequency
Target a specific problem frequency, such as a resonant room mode
High Shelf (HS)
Boosts or cuts all frequencies above the set point
Reduce harsh brightness or add presence and air to a voice
Low Pass (LP)
Rolls off all frequencies above the set cutoff
Remove high-frequency hiss or restrict a track’s upper range
Frequency, Gain, and Q Controls
Each active band has three adjustable parameters:
  • Frequency (Hz/kHz): Sets the center point for Parametric (Bell) bands, or the cutoff point for High Pass, Low Pass, High Shelf, and Low Shelf bands. Drag the band handle directly on the graph or type a value into the field.
  • Gain (dB): Determines how much the selected frequency range is boosted or cut. Positive values boost; negative values cut. For corrective EQ work, you will typically be making cuts in the range of -2 to -6 dB.
  • Q Factor: Controls the width of the affected frequency range. A high Q value (such as 8 to 10) produces a narrow, surgical band that targets one specific frequency while leaving neighboring ones largely untouched. A low Q value (such as 0.5 to 1) creates a broad, smooth curve that affects a wider range of frequencies, making it better suited for general tonal shaping.
Master Gain
The Master Gain control adjusts the overall output level of the EQ after all band processing has been applied. It is not a volume fader. If several cuts have noticeably reduced the loudness of a clip, a small positive Master Gain adjustment compensates for that loss, keeping your processed clip consistent in level with the rest of the timeline.
Step-by-Step Workflow: EQing Audio in Premiere Pro
Follow this sequence to apply corrective EQ in a controlled, repeatable way.
  1. Apply the Parametric Equalizer and open its editor. Use the navigation steps from the previous section to add the effect and open the full interface in Effect Controls.
  2. Set Band 1 as a High Pass filter. Start with a cutoff frequency around 80 Hz for dialogue. This immediately removes low-end noise that most microphones capture but human speech does not require.
  3. Listen before adjusting further. Play back the audio and identify the actual problem. Is the voice boxy, muddy, harsh, or thin? Know what you are trying to fix before reaching for another band.
  4. Sweep to find problem frequencies. Set a Parametric (Bell) band to a high gain boost, around +10 dB, with a high Q of roughly 8. Slowly drag the frequency handle across the range where you suspect the issue. When the problem becomes noticeably worse, you have found the offending frequency.
  1. Flip the boost to a cut. Once you locate the problem frequency, pull the gain down to a cut, typically -3 to -6 dB. Slightly lower the Q if you want a more natural-sounding result.
  2. Add a presence adjustment if needed. If the voice sounds clear but lacks intelligibility, add a gentle boost of 2 to 3 dB with a low Q in the 2 to 5 kHz range.
  1. A/B check with bypass. Toggle the effect on and off using the fx button in Effect Controls. Compare the processed and unprocessed audio. If the processed version is genuinely better, your adjustments are working. If it sounds over-processed, scale the cuts back.
  2. Adjust Master Gain if needed. If your cuts have pulled the perceived level down, use a small Master Gain increase to restore consistency with neighboring clips.
Practical EQ Settings for Common Audio Types
These are starting-point settings, not fixed recipes. Every recording environment is different, so use these as a guide and trust what you hear.
EQing Dialogue and Voice-Over
  • High-pass filter at 80 to 100 Hz: Eliminates low-end rumble, mic handling noise, and air conditioning interference.
  • Cut at 200 to 400 Hz: If the voice sounds boxy or muddy, a narrow cut here often clears it up. Start at -3 dB and adjust by ear.
  • Gentle boost at 2 to 5 kHz: A 2 to 3 dB boost with a low Q in this presence range improves intelligibility and helps dialogue cut through a music bed.
  • De-essing at 6 to 10 kHz: If “S” and “T” sounds are harsh or piercing, apply a narrow cut centered on the offending frequency. A cut of -3 to -4 dB is usually sufficient.
EQing Music Beds and Background Tracks
  • High-pass more aggressively at 120 to 200 Hz: This clears low-end space for dialogue and reduces muddiness in the overall mix.
  • Low shelf cut below 300 to 400 Hz: Reduce this range by 2 to 4 dB to stop the music from competing with the fundamental tones of the voice.
  • Gentle high-shelf roll-off above 10 to 12 kHz: A soft cut here reduces brightness and keeps the music bed from clashing with the presence range of the dialogue track.
Cleaning Up Room Tone and Ambience
  • High-pass filter to remove low rumble: Interior spaces almost always carry low-end noise in ambience recordings that a high-pass filter can cleanly address.
  • Notch cuts on resonant frequencies: Use a narrow, high-Q Bell band to cut tonal hum from HVAC systems (often near 60 Hz or its harmonics) or buzzing fluorescent lights (around 120 Hz).
  • Preserve the natural character: Ambience tracks should feel transparent. The goal is removing unwanted artifacts, not reshaping the tone. Less adjustment is almost always better.
Key EQ Techniques Every Premiere Pro Editor Should Know
  • Sweep-and-cut method: Boost a Bell band to +10 dB with a high Q, drag across the frequency range until the problem sound becomes exaggerated, then flip it to a cut. This locates problem frequencies far faster than guessing.
  • Subtractive before additive: Always cut problem frequencies before reaching for a boost. Stacking multiple boosts inflates output levels and creates a higher risk of clipping and distortion.
  • Use bypass to A/B your work: Toggle the effect on and off regularly. Your ears adapt quickly to what you are hearing, and a fresh comparison reveals whether you are genuinely improving the audio or simply changing it.
  • EQ in context, not in isolation: Always check how your adjusted track sounds against the full mix, including music beds, sound effects, and other dialogue. What works in isolation can still feel wrong in the complete sequence.
  • Avoid over-processing: Most corrective cuts only need to be -2 to -4 dB. Using a wider Q for general tonal shaping sounds more natural than applying narrow, deep cuts aggressively across multiple bands.
Start With Clean Source Audio to Minimize EQ Work
No amount of post-production EQ can fully recover audio that was poorly captured at the source. The most efficient EQ workflow starts before you open Premiere Pro. For on-location interviews or run-and-gun production, recording with a high-quality wireless microphone significantly reduces the corrective work needed in post. The Hollyland LARK MAX 2, for example, features 32-bit Float Internal Recording and AI Noise Cancellation, which captures cleaner dialogue with a wider dynamic range and less background noise at the recording stage. That means less time sweeping for problem frequencies in the EQ editor and more time making genuine refinements.
Parametric Equalizer vs. Premiere’s Essential Sound Panel
Both tools shape audio, but they serve different purposes in a real editing workflow.
Feature
Control precision
Low (preset-based)
High (fully manual)
Speed
Fast
Slower; requires more setup
Best for
Quick, consistent cleanup across clips
Solving specific audio problems
Skill level needed
Beginner-friendly
Intermediate to advanced
The Essential Sound panel applies automatic EQ curves based on audio type (Dialogue, Music, SFX, Ambience), which is efficient for projects with clean, consistent source audio. The Parametric Equalizer is the right choice when you need to track down a resonance, tame sibilance, or precisely shape the tonal balance of a specific recording. Many editors use both in the same project: Essential Sound for broad initial passes, and the Parametric Equalizer for targeted corrections on problem clips.
Q: Where is the Parametric Equalizer in Premiere Pro?
Go to the Effects panel (Window > Effects) and navigate to Audio Effects > Filter and EQ > Parametric Equalizer. Drag it onto an audio clip in the timeline, or onto an audio track header to apply it to every clip on that track. Select the clip, open Effect Controls, and click the Edit button next to the effect to open the full EQ interface.
Q: How many bands does the Premiere Pro Parametric Equalizer have?
The Premiere Pro Parametric Equalizer offers up to five fully configurable bands. Each band is independently adjustable for band type, frequency, gain, and Q factor. You do not need to activate all five. Enable only the bands your specific audio problem requires to keep the processing clean and controlled.
Q: What is Q in the Parametric Equalizer?
Q controls the width of the frequency band affected by a boost or cut. A high Q value, such as 8 to 10, creates a narrow, surgical adjustment that targets one specific frequency without affecting neighboring ones. A low Q value, such as 0.5 to 1, produces a broad, gradual curve that affects a wider frequency range, which is more suitable for gentle tonal shaping.
Q: Should I boost or cut with EQ in Premiere Pro?
Start by cutting problem frequencies before adding any boosts. Subtractive EQ is less likely to cause clipping, tends to sound more natural, and forces you to identify what is actually wrong with the recording. Once you have addressed problem areas, small targeted boosts of 2 to 3 dB can add presence or warmth where needed.
Q: Is the Parametric Equalizer better than the Essential Sound EQ?
Neither is universally better; they serve different purposes. The Essential Sound panel is faster for applying broad, consistent fixes across multiple clips. The Parametric Equalizer provides precise manual control, making it better suited for diagnosing and correcting specific audio problems like resonant hum, boomy room tone, or harsh sibilance on individual recordings.
The core workflow is simple to repeat: apply the effect, set a high-pass filter to clean the low end, sweep for problem frequencies and cut them, refine presence if needed, and use bypass to A/B check your work. Practice this sequence on a single dialogue clip before applying changes across a full project. Once it feels natural, the logical next steps are learning audio compression in Premiere Pro and mixing dialogue with music beds to complete your audio post-production workflow.
Related reading: How to Use Audio Compression in Premiere Pro | Mixing Dialogue and Music Beds in Premiere Pro
