Inconsistent audio is one of the most common problems in video editing. One clip is too quiet, the next is too loud, and the overall mix sounds unprofessional. Premiere Pro includes three useful tools for fixing audio levels properly. The Audio Gain window fixes volume problems on single clips quickly. The Essential Sound panel adjusts loudness based on LUFS standards before export. Normalize Mix Track targets the volume of your complete mix at once. This guide explains all three methods in simple, clear steps. It also shows when each option makes the most sense. The guide also covers important loudness targets worth paying attention to.
What Audio Normalization Does in Premiere Pro?
Normalization adjusts a clip’s gain so its audio hits a specific target level. There are two types, and knowing the difference saves a lot of confusion.
Peak normalization sets the loudest sample in a clip to a defined ceiling, measured in dBFS. It is fast and reliable for preventing clipping, but it does not account for how loud something sounds to human ears.
Loudness normalization measures integrated loudness across the full clip, expressed in LUFS (Loudness Units relative to Full Scale). This approach is perceptually consistent, meaning clips that measure the same LUFS will feel roughly the same volume to a listener.
Editors reach for normalization when clips were recorded at different gain levels, when dialogue sounds buried under a music track, or when preparing a finished edit to meet platform specifications for YouTube, podcasts, or broadcast delivery.
Method 1 — Normalize Audio Using the Audio Gain Dialog
The Audio Gain dialog is the quickest way to correct clip levels directly in the timeline. It works on single clips or multiple clips selected at once, making it useful for batch cleanup early in an edit.
Steps:
Select one or more clips in the Timeline or Project panel. To select multiple clips, hold Shift and click each one.
Right-click on any selected clip and choose Audio Gain from the context menu. Alternatively, use the keyboard shortcut G.
The Audio Gain dialog box opens. Locate the normalization options near the bottom.
Choose either Normalize All Peaks To or Normalize Max Peak To (see the explanation below).
Enter your target value. For dialogue during a mid-edit cleanup, -6 dBFS is a safe starting point that leaves headroom for mixing.
Click OK. Premiere Pro applies the gain adjustment immediately, and a gain indicator appears on each clip in the timeline.
The Audio Gain dialog shows the current peak value of the selected clip, which is useful for checking how far the adjustment will push the level before committing.
Normalize All Peaks vs. Normalize Max Peak — Which to Choose
These two options behave differently when multiple clips are selected, and choosing the wrong one produces unintended results.
Normalize All Peaks To adjusts every selected clip independently so each one hits the same peak ceiling. If Clip A peaks at -12 dBFS and Clip B peaks at -18 dBFS, both will be raised to your target. Use this when clips have no intentional level relationship, and each one needs to stand on its own.
Normalize Max Peak To finds the single loudest peak across all selected clips and calculates one proportional gain adjustment applied to the entire group. This preserves the relative level differences between clips. Use this when clips were recorded in the same session, such as multiple takes of the same interview, where maintaining the natural dynamics between clips matters.
Method 2 — Normalize Audio Using the Essential Sound Panel (LUFS Auto-Match)
The Essential Sound panel uses integrated LUFS measurement rather than peak dBFS, which makes it the right tool when you need your output to meet actual platform loudness standards. It is best used on a finished or near-finished edit, not during early clip cleanup.
Steps:
Open the Essential Sound panel by going to Window > Essential Sound.
Select the clip or clips in the timeline that you want to normalize.
In the Essential Sound panel, assign a clip type by clicking one of the four buttons: Dialogue, Music, SFX, or Ambience. The panel must have a type assigned before the Loudness section becomes available.
To make the concept clear, we have selected the Music tag as an audio type. You can choose other tags, depending on the nature of your audio.
Scroll down to the Loudness section within the panel.
Click Auto-Match. Premiere Pro analyzes the integrated loudness of the clip and applies a gain adjustment to match its internal target.
By default, Adobe’s Auto-Match targets -23 LUFS for Dialogue clips, which aligns with EBU R128 broadcast standards. This value is not displayed as an editable field in the panel itself, but it reflects Adobe’s built-in standard. If you are delivering for YouTube (-14 LUFS) or a podcast (-16 LUFS), use Auto-Match as a reference starting point and then use a loudness meter to verify before export.
The Essential Sound panel approach is ideal for preparing a final mix for export. It accounts for the full duration of a clip rather than a single peak moment, so the result sounds more consistent across an entire program.
Method 3 - Normalize the Whole Mix Track Audio
The “Normalize Mix Track” setting in the Premiere Pro 2026 Sequence menu raises or lowers your project’s total volume automatically. It sets the final mix near 0 dB without changing audio balance. This keeps your exported video loud enough without causing distorted sound. It also helps mixed audio sources sound more even and polished.
Assuming you already have the sequence with the audio track you want to normalize, click the Sequence tab from the top menu, and choose Normalize Mix Track.
When the dialog box pops up, enter the targeted dB and click OK.
Which Loudness Target Should You Use?
Choosing the correct target value is the question that trips up most editors. The table below covers the main platform standards and a practical working target for mid-edit peak normalization.
Platform / Use Case |
Integrated Loudness |
True Peak Max |
YouTube |
-14 LUFS |
-1 dBTP |
Podcast (general) |
-16 LUFS |
-1 dBTP |
Broadcast (EBU R128) |
-23 LUFS |
-1 dBTP |
Broadcast (ATSC A/85, US) |
-24 LUFS |
-2 dBTP |
Mid-edit cleanup (working target) |
-6 dBFS |
A few practical notes on reading this table:
Integrated LUFS reflects the average perceived loudness across the entire piece of content. Platforms like YouTube automatically turn down audio that exceeds their target, so delivering louder than -14 LUFS just results in the platform reducing your levels, not a louder result for the viewer.
True Peak is the maximum peak level after digital-to-analog conversion, which can exceed the dBFS peak shown in Premiere Pro’s meters. Staying at -1 dBTP gives the converter enough headroom to avoid distortion.
-6 dBFS as a mid-edit working target for peak normalization is not a delivery spec. It is simply a safe ceiling that keeps dialogue readable and leaves room to add music, sound effects, and final processing without clipping.
Common Normalization Mistakes to Avoid
Normalization is a straightforward process, but a few consistent errors can create more problems than they solve.
Normalizing clipped or distorted source audio: If a clip was recorded too hot and the waveform is already flattened at the top, normalization cannot recover those lost peaks. Raising the gain on distorted audio only makes the distortion louder. There is no software fix for a recording that clipped at the source.
Over-normalizing music or ambient tracks: Boosting a music bed to the same peak ceiling as dialogue raises the noise floor and surfaces compression artifacts. Music tracks are already mastered; they usually need attenuation, not normalization upward.
Normalizing individual clips before completing the mix: If you normalize clips early and then add a music track, sound effects, or additional dialogue, every new element changes the overall mix level. Apply LUFS-based normalization as one of the final steps before export, not at the start of the edit.
Confusing peak normalization with LUFS normalization and applying the wrong one: Using Audio Gain to hit -6 dBFS peak does not mean your output meets -14 LUFS for YouTube. These are different measurements. Always verify integrated loudness with a meter before final export.
Pro Tip: The quality of your source recording has a direct impact on how cleanly normalization works in post. Recordings captured with 32-bit float, such as the internal backup recordings supported by the Hollyland LARK MAX 2, retain the full dynamic range of the original audio without clipping, which means Premiere Pro has clean material to work with and normalization produces accurate results without amplifying noise or distortion artifacts.
Does normalizing audio in Premiere Pro affect the original file?
No. Audio Gain adjustments in Premiere Pro are non-destructive. The values are stored as metadata within the project file, and the original source media on your drive is never modified. If you need to undo a normalization, reopen the Audio Gain dialog and set the value back to 0 dB, or use Ctrl+Z / Cmd+Z immediately after applying.
Why does my audio still sound uneven after normalizing?
Peak normalization matches only the loudest audio point in every clip. It does not measure how loud the audio actually feels overall. Two clips may show matching peaks, but still sound very different. One clip may stay consistently loud while another changes constantly. For more balanced loudness, use the Essential Sound panel’s Auto-Match tool. It adjusts audio based on integrated LUFS instead of peak levels.
Can I normalize multiple clips at once in Premiere Pro?
Yes. Select multiple clips in the Timeline or Project panel using Shift-click or Ctrl/Cmd-click, then right-click any selected clip and choose Audio Gain. The normalization you apply will process all selected clips in a single step. Use “Normalize All Peaks To” for independent adjustments or “Normalize Max Peak To” to preserve relative level differences between clips.
For mid-edit cleanup, use the Audio Gain dialog with a -6 dBFS peak target to bring clips to a consistent working level. For final delivery, use the Essential Sound panel’s Auto-Match to hit the correct LUFS target for your platform, then verify with a loudness meter before export. Contrarily, you apply the Normalize Mix Track option from the Sequence menu to normalize the audio of the entire mix.
