Jumping between clips with different audio levels can sound really off. One clip feels loud and clear, while the next feels weak. Mismatched audio levels are a common issue when clips come from different sources. But Adobe Premiere Pro gives you a few ways to fix this problem. First, you can rely on the automatic tweak, which is fine in many cases. Or, you can opt for manual and detailed control. But whatever your choice is, our guide will show you the workaround for each option. You can try both to see which works best for you.
What Does “Matching Audio Tracks” Mean in Premiere Pro?
“Matching audio tracks” can refer to two different problems. The first is loudness matching — making two tracks consistent in volume so they sit comfortably in the same mix. The second is time-sync matching — aligning a camera’s built-in mic track with audio recorded on a separate external recorder. This article covers loudness matching only. If you need to sync dual-system audio, that workflow uses Premiere’s Merge Clips or Synchronize tools and is covered in a separate guide.
Key terms used in this article:
LUFS (Loudness Units relative to Full Scale): a standardized measure of perceived loudness
dBFS (decibels relative to Full Scale): a measure of peak signal level
Audio Gain: a clip-level adjustment that changes how Premiere reads the source file’s amplitude
Method 1 — Match Loudness Using the Essential Sound Panel (Recommended)
The Essential Sound panel is Premiere Pro’s built-in loudness-matching tool. It analyzes the integrated loudness of each clip and applies a gain correction to hit a target LUFS value. For most editors working with dialogue or interviews, this is the fastest and most reliable starting point.
Steps:
Open the Essential Sound panel. Go to Window > Essential Sound. If you don’t see it, make sure you’re in the Audio workspace.
Select both audio clips on the timeline. Click one clip, then Shift-click the other. You can also select multiple clips at once if you’re normalizing a larger group.
Assign an audio type tag. In the Essential Sound panel, click “Dialogue” (for spoken word) or “Music” (for background tracks). Premiere needs this tag to activate the Match Loudness controls. Apply the same tag to both clips.
Click “Auto-Match.” Premiere analyzes each selected clip and adjusts its gain so the integrated loudness hits the target. The process takes only a few seconds.
What Premiere is doing behind the scenes: It measures the average perceived loudness across the entire clip and applies a static gain offset to bring it to the target level. It does not compress or limit the audio dynamically.
When this method works best: Dialogue-to-dialogue matching, music bed leveling, and any situation where two clips of the same type need to coexist at a consistent level.
Limitation: Match Loudness applies one flat correction to the whole clip. If one clip has a section that is dramatically quieter or louder than the rest, you may still need keyframes to smooth out those inconsistencies after auto-matching.
Method 2 — Manually Match Levels with Audio Gain
Audio Gain gives you direct numerical control over a clip’s level. This method is useful when you already know the target level one clip needs to hit, or when you want precise control that the automated tool doesn’t give you.
Steps:
Open the Audio Gain dialog. Right-click the clip on the timeline and select “Audio Gain,” or click the clip and press the keyboard shortcut G.
Choose your adjustment method. The dialog offers two useful options:
Normalize Max Peak to: raises or lowers the clip so its loudest peak hits a specific dBFS value. A common safe target is -3 dBFS to leave headroom.
Adjust Gain by: enters a manual dB value to add or subtract from the clip’s current level.
Apply, then compare both clips. Use the Audio Track Mixer (Window > Audio Track Mixer) or simply watch the waveforms on the timeline to see whether both clips now sit at a similar visual level.
Apply gain to the second clip as needed. Repeat the process on the other clip, adjusting until both read similarly in the Audio Track Mixer meters during playback.
Check for clipping. After adjusting, play the clips back and watch the track meters. If the clip header turns red in the timeline or the meter hits 0 dBFS, reduce the gain to bring the peak down.
When to use this method over Match Loudness: Use Audio Gain when you need a specific dBFS peak target, when you’re working with sound effects that need to hit a precise level, or when you want to match one clip’s level to another without relying on Premiere’s automated analysis.
Method 3 — Use Volume Keyframes for Dynamic Matching
Sometimes a single clip does not stay at one level. A speaker may fade out near the end of a line. A music track can rise suddenly and upset the mix. In these cases, one fixed adjustment is not enough. Volume keyframes let you control levels at exact points in time. This way, you adjust only what needs to change inside the clip.
Steps:
Expand the audio track on the timeline. Click the small arrow or drag the track height up until you can see the white rubber band (the volume line) running through the clip.
Add keyframes at problem points. Hold Ctrl (Windows) or Command (Mac) and click directly on the rubber band to place a keyframe. Place keyframes just before and just after the section you need to adjust.
Drag keyframes up or down. Click and drag a keyframe to raise or lower the volume at that specific moment. Premiere creates a smooth ramp between keyframes.
Start with a global offset first. Before using keyframes, use Audio Gain (Method 2) or Match Loudness (Method 1) to get the clip’s overall level in the right range. Keyframes are a refinement layer, not a replacement for the baseline correction.
Pro Tips for Cleaner Audio Matching Results
Always check matched clips at reference loudness before export. After normalizing, listen to your edit at a consistent playback volume. What sounds balanced on a loudspeaker may still feel uneven at low volume.
If tracks refuse to match cleanly, send them to Adobe Audition. Use Edit > Edit Clip in Adobe Audition for access to more granular EQ, noise reduction, and multi-band dynamics tools that go beyond what Premiere’s Essential Sound panel offers.
Match the same audio types to each other. Applying Auto-Match to a dialogue clip and a music clip at the same time will produce odd results because the LUFS targets for each type differ. Tag and match dialogue to dialogue, music to music.
Capturing consistent levels at the source reduces how much correction you need in post. A wireless mic system like the Hollyland LARK MAX 2 records internally in 32-bit Float on both transmitters, preserving the full dynamic range of each channel so that gain corrections in Premiere are minor adjustments rather than heavy rescues.
Q: Why do my audio tracks still sound different after using Match Loudness?
Match Loudness corrects integrated loudness but does not address tonal differences, EQ, or dynamic range inconsistencies. If one track carries more room noise, low-end rumble, or harshness, the volume will match, but the character will not. Apply Premiere’s built-in Noise Reduction or EQ effects in the Essential Sound panel after matching levels to close that gap.
Q: Can I match more than two audio tracks at once in Premiere Pro?
Yes. Select all the clips you want to normalize on the timeline, assign them the same audio type tag in the Essential Sound panel, then click Auto-Match. Premiere calculates and applies individual gain corrections to each selected clip simultaneously, targeting the same LUFS value across all of them.
Q: What is the difference between Audio Gain and Volume in Premiere Pro?
Audio Gain is a clip-level adjustment applied directly to the file reference; it affects how Premiere reads the clip everywhere it appears in the timeline. Volume is a timeline-level adjustment that uses keyframes and does not alter the source clip. Best practice: use Gain to correct level inconsistencies at the source, and use Volume for mix decisions and creative automation.
For most editors, Method 1 (Essential Sound > Auto-Match) is the right starting point. It handles the majority of loudness mismatches quickly and accurately. When you need more control over a specific target level, Audio Gain gives you that precision. For clips with internal volume variation, layer volume keyframes on top of either method.
