How to Add Another Audio Track in Premiere Pro (3 Fast Methods)
Adding an audio track in Premiere Pro is a quick task once you know where to look. The timeline interface isn’t always obvious for first-time track managers, and choosing the wrong track type can cause frustrating clip rejection errors. This guide covers three working methods — from the fastest one-click option to the most flexible dialog-based approach.
Quick Answer
Right-click anywhere in the track header area (the left-side column of the Timeline panel, below your last audio track label, such as A1 or A2) and select “Add Track.” A new audio track appears instantly. This works in all versions of Premiere Pro CC 2019, Premiere Pro 2022, and later. If you need more control over track type or placement, use the Sequence menu method covered in Method 2.
Method 1 — Right-Click in the Timeline Track Header (Quickest)
This is the fastest way to add a single audio track. Make sure you right-click in the track header column on the left side of the Timeline — not on a clip itself.
  1. Open your sequence in the Timeline panel.
  1. Locate the track header area on the left side — this is where your track labels (A1, A2, etc.) appear.
  1. Right-click in an empty gray area below your last audio track label. If you right-click on a clip or on the video track header, you will get a different context menu.
  2. Select “Add Track” from the context menu.
  1. A new audio track (labeled A2, A3, etc.) appears immediately below your existing tracks.
  1. Drag your audio clip onto the new track to begin using it.
Note: If “Add Track” does not appear in the context menu, you right-clicked in the wrong area. Click on an empty space in the track header column, not on a clip or a track name label.
Method 2 — Sequence Menu → Add Tracks (Most Control)
Use this method when you need to add multiple tracks at once, specify placement, or choose a specific track type.
  1. With your sequence open, click Sequence in the top menu bar.
  1. Select “Add Tracks” from the dropdown. The option is usually at the bottom of the menu. Therefore, you will need to click the “downward” arrow to expand the menu.
  1. The Add Tracks dialog box opens.
  2. Under the Audio Tracks section, set the number of tracks you want to add in the “Add” field.
  1. Use the Placement dropdown to choose where the new track should appear — before or after a specific existing track.
  1. Select your desired Track Type from the dropdown (see the table below).
  1. Click OK. Your new track or tracks appear in the Timeline immediately.
Note: The Add Tracks dialog also lets you add video tracks and audio submix tracks in the same step. Ignore those sections if you only need an audio track.
Choosing the Right Audio Track Type
Selecting the wrong track type is the most common reason a clip won’t snap to a new track. Use this table to match the track to your clip.
Track Type
Best For
Accepts
Standard
Most editing workflows
Mono, stereo, and adaptive clips
Mono
Voiceovers, isolated mic channels
Mono clips only
5.1
Surround sound audio
5.1 surround clips only
Adaptive
Multi-channel broadcast and advanced routing
Adaptive clips
For the majority of YouTube videos, short films, and podcast edits, Standard is the correct choice.
Method 3 — Drag a Clip Below Existing Tracks (Auto-Create)
Premiere Pro will automatically generate a new audio track if you drag an audio clip below the last existing audio track in the Timeline. You may have already discovered this by accident. Drop the clip in the empty gray space beneath your lowest audio track, and Premiere Pro creates a new track and places the clip on it in one move.
The limitation here is that you cannot choose the track type — Premiere Pro assigns it automatically based on the clip’s channel format. If you need a specific track type, use Method 2 instead.
Pro Tip: This drag-to-create behavior is useful for quickly dropping in a music bed or extra sound effect layer without interrupting your editing flow, as long as you are not particular about track organization or naming.
Troubleshooting — Audio Track Not Showing or Clip Won’t Snap
Problem: I added a track, but I cannot see it in the Timeline.
Fix: Scroll down inside the Timeline panel — the new track may be below the visible area. You can also hover over the track header border and drag downward to reduce the height of existing tracks and reveal the new one.
Problem: My clip won’t drop onto the new audio track.
Fix: The clip’s channel format does not match the track type. For example, a stereo clip cannot be placed on a Mono track. Right-click the track header, select “Delete Track,” then re-add it using Method 2 and choose “Standard” as the track type.
Problem: The “Add Track” option is grayed out or missing.
Fix: Confirm a sequence is open and active in the Timeline. If no sequence is open, the Sequence menu options and right-click options will be unavailable.
Problem: I accidentally deleted an audio track with clips on it.
Fix: Press Ctrl+Z (Windows) or Cmd+Z (Mac) immediately to undo. Deleting a track also removes all clips on it, so undo as quickly as possible.
Q: Can I add multiple audio tracks at once in Premiere Pro?
Yes. Go to Sequence > Add Tracks and enter the number of tracks you want in the “Add” field under the Audio Tracks section. Premiere Pro will create all of them in one step, and you can set placement and track type for the entire batch at the same time.
Q: How do I delete an audio track I added by mistake?
Right-click the track header on the left side of the Timeline and select “Delete Track.” Be aware that deleting a track also permanently removes any clips sitting on it, so move clips to another track first if you need to keep them.
Q: What is the maximum number of audio tracks in a Premiere Pro sequence?
Premiere Pro supports up to 99 audio tracks per sequence. For nearly all standard editing projects, you will never come close to that limit, but it provides enough room for complex multi-track audio productions and sound design workflows. New versions of Premiere Pro, including v26, no longer limit you to 99 tracks. You can add hundreds of audio tracks to one sequence. The only limit comes from your system's power and available memory.
Adding an audio track in Adobe Premiere Pro is no pain. Right-click inside the Sequence panel to add one track. You can also add multiple tracks from the top Sequence menu. Once your tracks are ready, open the Mixer to adjust audio. You can also add effects and manage audio roles.
