How to Sync Audio and Video in Premiere Pro (4 Methods That Actually Work)
Audio sync problems are one of the most common headaches in post-production, whether you recorded dialogue on a dedicated audio recorder, used a wireless lav mic, or found that your camera’s audio simply drifted over time. Adobe Premiere Pro has four native methods to fix sync issues, each suited to a different shooting scenario. This guide walks through all four in order of simplicity, so you can get back to editing fast.
Why Audio and Video Fall Out of Sync in Premiere
Sync problems typically come from one of two root causes.
The first is dual-system recording, where audio and video were captured on separate devices. A videographer might record picture on a mirrorless camera while simultaneously recording clean audio on an external recorder or wireless mic system. When using a wireless mic system that stores internal backup audio, such as the Hollyland LARK MAX 2 (which records 48 kHz / 32-bit Float audio internally), you end up with a dedicated high-quality audio file that needs to be aligned with your camera footage in post. That separation is intentional and worth it for audio quality, but it creates a sync task every time you edit.
The second cause is sample rate mismatch. If your camera records audio at 44.1 kHz but your sequence is set to 48 kHz (or vice versa), Premiere may play the audio at the wrong speed relative to the video. The clip looks in sync at the start but gradually drifts further off as it plays. This is a quieter problem than dual-system recording, but it catches editors off guard.
Understanding which cause you are dealing with points you directly to the right fix below.
Method 1 — Auto-Sync Using Audio Waveform (Fastest)
Priority: Primary
Auto-Sync is the right starting point for most editors. Premiere compares the waveforms from two clips (for example, camera scratch audio and an external mic recording) and aligns them automatically. Both clips must share some overlapping audio content, such as ambient room sound, dialogue, or a clap, for the algorithm to find a match point.
Steps:
  1. Import both your video clip and your external audio file into the Project panel.
  2. Place the video clip on one timeline track (e.g., V1/A1) and the external audio file on a separate audio track directly below or above it. Keep the clips roughly aligned by eye first.
  3. Select both clips on the timeline by clicking one, then Shift-clicking the other.
  4. Right-click either selected clip and choose Synchronize from the context menu.
  1. In the Synchronize dialog, select Audio as the sync point.
  2. Click OK. Premiere analyzes both waveforms and snaps the audio clip into alignment.
  1. Once synced, right-click the video clip and select Unlink to separate the original camera audio, then delete the scratch audio track. Your external audio is now the active track.
Troubleshooting note: If Premiere returns an error or the sync looks wrong, the most likely cause is that the camera’s scratch audio is too quiet, too distorted, or contains no usable transient for matching. In that case, skip to Method 3 (manual waveform alignment).
Pro Tip: Before running Auto-Sync, boost the waveform display height in the timeline by dragging the track header taller. A taller waveform view makes it easier to visually confirm the alignment after Premiere finishes processing.
Method 2 — Merge Clips for Dual-System Audio
Priority: Primary
Merge Clips is the preferred method when you are working with dual-system audio and want to lock that sync permanently before you begin editing. Rather than syncing clips on the timeline, Merge Clips creates a brand-new merged asset directly in your Project panel bin. That merged clip behaves exactly like a single camera clip and can be dropped onto the timeline without worrying about the tracks drifting apart later.
Steps:
  1. In the Project panel (not the timeline), select your video clip and your external audio clip at the same time. Hold Ctrl (Windows) or Command (Mac) to select multiple items.
  2. Right-click either selected clip and choose Merge Clips.
  1. In the Merge Clips dialog, choose your sync method:
  • Audio (recommended if no timecode) – Premiere matches waveforms automatically.
  • Timecode – use this if both devices recorded matching timecode.
  • In Point or Out Point – use these if you manually set matching markers beforehand (e.g., using a clapperboard).
  1. Optionally rename the merged clip in the Name field so it is easy to identify in the bin.
  2. Decide whether to keep or remove the camera audio from the merged clip using the checkbox provided.
  3. Click OK. The merged clip appears in your Project panel and is ready to edit with.
Merge Clips vs. Synchronize – Key Difference:
Feature
Merge Clips
Synchronize
Where it works
Project panel (before editing)
Timeline (during editing)
Output
Creates a new merged asset in the bin
Aligns existing timeline clips in place
Best for
Dual-system audio setup before a rough cut
Fixing sync after clips are already on timeline
Permanent?
Yes, creates a new project item
No, clips remain separate assets
Use Merge Clips when you are setting up a project. Use Synchronize when you discover a sync issue mid-edit.
Method 3 — Manual Waveform Alignment
Priority: Secondary
When auto-sync fails (no clean audio overlap, corrupted scratch track, or a very short clip), manual alignment is the universal fallback. It takes a little more patience but works in any situation.
Steps:
  1. Place your video clip and external audio file on separate tracks in the timeline. Stack them vertically so you can see both waveforms at once.
  2. Press the + key on your keyboard (or use the zoom slider) to zoom into the timeline until individual waveform peaks are clearly visible.
  3. Look for a sharp transient that appears in both waveforms: a clap, a door slam, a spoken consonant, or ideally the “crack” of a clapperboard slate.
  4. Click and drag the external audio clip left or right until that transient aligns directly under the same transient in the camera audio track.
  5. For fine-tuning, use the comma (,) and period (.) keys to nudge a selected clip one frame at a time, or hold Alt and press the Left/Right arrow keys to nudge by sub-frame increments.
  6. Play back the aligned section to confirm lip sync looks correct.
  7. Once satisfied, unlink and delete the camera scratch audio.
Tips: - A clapperboard slate is the single most reliable sync anchor. The sharp visual frame of the clap closing matches directly with the sharp audio spike in both recordings. - If the clip is long and you still notice drift after aligning the start, see the “How to Fix Audio Drift After Syncing” section below before applying Rate Stretch.
Method 4 — Sync via Multicam Sequence (Multi-Camera Shoots)
Priority: Secondary
When you are editing footage from two or more camera angles alongside a single audio source, syncing each clip one by one is impractical. The Multicam Sequence feature handles sync across all angles simultaneously and places them inside a nested sequence that you can switch between during editing.
Steps:
  1. In the Project panel, select all the clips you want to include (both camera angles and the audio file).
  2. Right-click the selected clips and choose Create Multi-Camera Source Sequence.
  1. In the dialog, set the Synchronize Point to Audio (most reliable option when timecode is not available). If your devices shared timecode, choose Timecode for a faster and more precise result.
  1. Choose your clip overlap settings and whether to move the source clips to a new bin.
  2. Click OK. Premiere creates a nested multicam sequence with all clips synced inside it.
  3. Double-click the multicam sequence to open it, then begin editing. Use the Multi-Camera Monitor (Window > Multi-Camera Monitor) to switch between angles in real time.
When to use this method: Interview setups with a wide and a close shot, event coverage with multiple cameras, or any A/B roll workflow where you need to cut between angles. If you are editing a single camera angle with one external audio file, Methods 1 or 2 are simpler choices.
Note: Multicam sequences add a layer of nesting to your project structure. If you are new to Premiere, it is worth getting comfortable with Methods 1 and 2 before introducing multicam workflows.
Priority: Brief
If the audio and video are aligned at the beginning of a clip but gradually fall out of sync over time, the problem is almost always a sample rate mismatch rather than an initial alignment error.
  • Cause: Mismatched sample rates (e.g., audio at 44.1 kHz, sequence at 48 kHz) Fix: Right-click the audio file in the Project panel, select Modify > Audio Channels, and confirm the sample rate. Then transcode the audio file to match your sequence sample rate using Adobe Media Encoder before re-importing.
  • Cause: Camera recorded at a slightly different rate (e.g., 23.976 vs. 24 fps) Fix: Check your sequence settings and confirm your camera’s actual frame rate. Adjust the clip’s interpreted frame rate via Modify > Interpret Footage.
  • Cause: Long recording with gradual drift that cannot be fixed by transcoding Fix: Use the Rate Stretch Tool (R) to stretch the audio clip so its end point aligns with the video’s end point. This compensates for the drift across the full clip duration.
What is the difference between Merge Clips and Synchronize in Premiere Pro?
Merge Clips creates a new combined asset in your Project panel bin before editing begins. Synchronize aligns clips that are already placed on the timeline without creating any new project item. Use Merge Clips during project setup when you have dual-system audio to organize. Use Synchronize to correct a sync problem you discover while already deep into an edit.
Can Premiere Pro sync audio automatically?
Yes. Both the Synchronize command (right-click a timeline selection and choose Synchronize, then select Audio) and the Merge Clips feature (set to Audio sync point) use automatic waveform matching. Both methods require that the video clip’s scratch audio and the external audio file share some overlapping sound content for the algorithm to find a match.
Why did my auto-sync fail in Premiere?
The three most common causes are: (1) the camera’s built-in microphone recorded audio that is too quiet or silent, giving Premiere no waveform to match against; (2) the two clips do not share overlapping audio content from the same moment; or (3) the scratch audio is too distorted or noisy for reliable waveform matching. When any of these apply, fall back to Method 3 (manual waveform alignment).
Does Premiere Pro support timecode-based sync?
Yes. If your camera and audio recorder both captured matching timecode during the shoot, the Synchronize dialog and the Merge Clips dialog each include a Timecode option. Timecode sync is faster and more precise than waveform matching and is the standard approach for professional multicam productions and broadcast workflows.
Choosing the right sync method saves significant editing time. Use Auto-Sync (Method 1) for most single-camera situations where both recordings share ambient audio. Use Merge Clips (Method 2) when working with dual-system audio and you want a clean, permanently merged asset before your rough cut. Fall back to Manual Waveform Alignment (Method 3) whenever automation fails. Use Multicam Sequence (Method 4) for any multi-angle production.
Scenario
Recommended Method
Single camera, external mic, some overlap audio
Dual-system audio, starting a new edit
No usable scratch audio, or auto-sync failed
Multiple camera angles, one audio source
Once sync is handled, a clean external audio workflow (using a wireless mic system with onboard backup recording) means less troubleshooting on every future project.
