Getting your audio and video to line up cleanly is one of the most common hurdles in CapCut. Whether you’re snapping cuts to a music beat, nudging a voice recording into place, or replacing the built-in mic audio with a cleaner track, the fix depends on which scenario you’re dealing with. This guide walks through all three methods for both CapCut Mobile and CapCut PC so you can follow along on whatever device you’re using.
How to Sync Audio to Video in CapCut (3 Methods for Mobile & PC)
Why Audio Goes Out of Sync in CapCut (and What to Expect)
Audio sync issues in CapCut usually fall into one of three buckets: music that doesn’t cut in rhythm with your clips, a separately recorded audio file that drifts from the visuals, or original camera audio that slips out of time after editing. Each scenario has a different fix. The three methods below cover all of them, with notes on where Mobile and PC steps diverge.
Method 1 — Use Auto Beat Sync for Music-to-Video Sync
Auto Beat Sync is CapCut’s built-in feature that automatically adjusts your video clip cuts to match the rhythm of a music track. It’s the fastest approach for montages, TikTok edits, and any project where you want the visuals to feel locked to the beat.
Import your video clips into a new CapCut project.
Add your music track. Tap Audio and select a track from CapCut’s library or import one from your device.
Select the video or audio clip (or select all clips) you want to sync.
Tap Beats, then select Auto Generate Beats. CapCut will analyze the music and create beat markers along the track.
Review the generated beat markers and use them as guides when editing. .
Move the playhead to a beat marker, select the video clip, and tap Split to create cuts at important beat points.
Repeat throughout the timeline, aligning major actions, transitions, and scene changes with the generated beat markers.
Preview the edit and make any necessary adjustments until the cuts feel synchronized with the music.
When to use it: Social media reels, highlight montages, TikTok videos with trending audio, or any edit where the visual pacing should follow the music.
How to Set Custom Beat Points Manually Within Beat Sync
If Auto Beat Sync places cuts in the wrong spots, you can override the auto-detected points and set your own.
Enter the Beat panel (Audio > Beat) and turn off Auto Beat Sync if it’s active.
Play your audio from the beginning by pressing the play button in the timeline.
Tap “Add Beat Point” at each moment in the song where you want a cut to happen.
Delete any auto-placed points you don’t want by tapping and selecting “Remove.”
Apply the sync and preview to confirm the cuts land where you marked them.
Method 2 — Manually Sync Audio to Video on the Timeline
When Auto Beat Sync is too rigid or you’re working with dialogue, voiceover, or sound effects, manual timeline alignment gives you precise control. This method works for any audio type.
Import your audio file. Tap the “+” in the audio section and locate your file. On PC, you can drag the file directly from your file explorer into the audio track lane.
Zoom into the timeline. On Mobile, pinch outward with two fingers to expand the timeline. On PC, use the zoom slider at the bottom right of the timeline panel. A zoomed-in view makes small adjustments far more accurate.
Enable waveform view if it’s not already visible. The waveform shows the audio’s volume peaks and valleys, which helps you identify where dialogue starts or where a specific sound falls.
Long-press and drag the audio clip left or right on the timeline (Mobile) or click and drag it (PC) until the waveform peaks align with the corresponding moments in the video.
If additional adjustments are needed, zoom further into the timeline and manually drag the audio clip until it aligns correctly with the video.
Play back the full section at 1x speed to confirm the sync before moving on.
Note: On Mobile, long-pressing the audio clip activates the drag mode. On PC, a single click selects the clip and you can drag it immediately. The PC timeline also snaps to frame boundaries, which can help when precise frame-level alignment matters.
Method 3 — Add or Replace External Audio and Sync It
This method applies when you recorded audio separately from your video, such as with an external microphone, a phone voice memo app, or a standalone recorder, and now need to replace the camera audio with the cleaner external track.
Mute or extract the original audio. In CapCut, tap the video clip and look for “Extract Audio” or simply use the volume slider to bring the original audio track to zero. This prevents the camera audio from conflicting with your import.
Import the external audio file. Tap the audio “+” button and navigate to your recorded file. On PC, drag it into the audio lane below the video track.
Create a sync reference point. If you used a hand clap, a slate, or any sharp visual-and-audio cue at the start of your recording, locate that moment in both the video and the audio waveform. Align those two points first.
Drag the audio clip so the sync cue lines up with its matching frame in the video. Zoom in to the maximum timeline level to get frame-accurate alignment.
Play back the synced section and listen for any remaining drift. Use the offset adjustment to correct slight timing gaps without re-dragging the whole clip.
Lock the audio clip if CapCut offers that option, so trimming other clips doesn’t accidentally shift the audio position.
Starting with clean, isolated audio from a compact wireless mic like the Hollyland LARK M2 makes this step noticeably faster, since there’s no background noise or room bleed in the waveform to confuse the sync reference cue.
CapCut Mobile vs. CapCut PC — Key Differences for Audio Sync
Feature |
Mobile (iOS / Android) |
PC / Desktop |
Audio track access |
Bottom toolbar > Audio |
Left panel audio lane, visible by default |
Timeline zoom |
Pinch with two fingers |
Zoom slider (bottom right of timeline) |
Clip dragging |
Long-press, then drag |
Single click and drag |
Beat Sync availability |
Yes |
Yes |
Audio offset adjustment |
Available via clip settings |
Available via clip settings panel |
Waveform visibility |
Tap clip to toggle |
Visible in timeline lane by default |
Drag precision |
Frame-level (zoomed in) |
Frame-level with optional snapping |
Quick Tips to Get a Tighter Sync Every Time
Start every recording with a hand clap. The sharp spike in the audio waveform gives you an instant visual reference point to match against the video frame where your hands meet.
Zoom in before you drag. Even a small timeline drag at low zoom can skip several frames. Max zoom gives you control down to individual frames.
Mute the original camera audio before importing your external track. Hearing both at once during alignment makes it impossible to tell which one is drifting.
Re-sync after trimming. If you cut or resize a video clip after you’ve set the audio position, check the alignment again. Clip trims can shift the relative position of audio.
Preview on your intended output device. Some phones and Bluetooth speakers add a slight audio delay on playback. A sync that looks perfect in the CapCut preview may sound off elsewhere.
How do I fix audio that’s slightly ahead of or behind the video in CapCut?
Open the audio clip settings and look for the offset or delay adjustment. This lets you nudge the audio forward or backward in milliseconds without dragging the whole clip. If the offset isn’t precise enough, zoom the timeline to maximum and manually drag the clip one frame at a time until the audio and video line up on playback.
Does CapCut have an automatic audio sync feature?
Yes. Beat Sync automatically cuts and aligns video clips to the rhythm of a music track. However, this only works for music-to-video sync. If you’re working with dialogue, voiceover, or a separately recorded audio file, CapCut does not auto-sync speech to video, so manual timeline alignment is required for those scenarios.
Can I sync audio to video in CapCut on PC the same way as on mobile?
The core process is the same on both platforms, but the interface behaves differently. On PC, you drag audio clips directly in the timeline lane with a standard click-and-drag, and the waveform is always visible. On mobile, you need to long-press a clip to activate drag mode. The PC version also offers slightly easier precision due to the larger screen and snap-to-frame behavior.
Why is my audio still out of sync after editing in CapCut?
The most common cause is trimming a video clip after the audio was already aligned, which shifts the relative timing. Other causes include export settings that alter frame timing, or a playback device adding its own audio delay. Always re-check sync after any clip edits, and preview the exported file on the device your audience will use before publishing.
For music-based edits, start with Auto Beat Sync and customize beat points where needed. For dialogue, voiceovers, or precise alignment, the manual timeline drag with a zoomed-in waveform view is your most reliable tool. When working with externally recorded audio, mute the original track first, align on a clear sync cue, and fine-tune with the offset setting. Run a quick test on a 15-second clip before committing to a full project sync.
