How to Do Lip Sync in CapCut: Step-by-Step Guide for Any Video
Whether you are jumping on a trending TikTok sound or recreating a classic music video moment, getting your mouth movements to match the audio is what separates a polished clip from one that falls flat. CapCut provides three methods to match timing in videos. These include manual split and trim, Beat Sync, and Lip Sync effect. This guide walks you through all three so you can pick the right approach for your video.
What Does CapCut Lip Sync Actually Do?
Lip sync in CapCut involves matching the video mouth motion with separate audio placed on the timeline. It does not analyze faces or connect speech directly with lyrics automatically. Instead, the app gives editing tools for manual alignment or rhythm-based syncing assistance.
What CapCut Lip Sync Actually Does
The three methods available are:
  • Manual sync: Split and trim clips to match audio markers on the timeline waveform
  • Beat Sync: Let CapCut auto-cut your clips to the rhythm of your audio track
  • Lip Sync effect: Apply a visual effect from the Effects panel that stylizes mouth-movement sequences
Method 1: Manual Lip Sync in CapCut (Split, Trim, and Time)
Manual sync gives you the most control and works for any audio, including spoken dialogue, original songs, or trending sounds. Follow these steps:
  1. Import your video clip. Open CapCut, tap New video, and select the footage you recorded while mouthing the lyrics or dialogue.
  1. Add your audio track. Tap Audio at the bottom of the editing screen. Select Sounds and choose from CapCut’s sound library or import a file from your device. Position the audio so it starts where you want the sync to begin.
  1. Zoom into the timeline. Pinch outward on the timeline to expand it. This gives you frame-level precision when making cuts.
  1. Identify lyric or beat markers on the waveform. Look at the colored waveform bar beneath your audio clip. Peaks and visible changes in the waveform signal where words or beats land in the track.
  1. Split your video clip at key moments. Drag the playhead to a point where a word or syllable begins in the audio. Tap the video clip to select it, then tap Split in the toolbar below the timeline.
  1. Adjust clip timing. After splitting, move individual segments forward or backward on the timeline to align your mouth movements with the correct audio moment. Tap and hold a segment, then drag it into position.
  2. Fine-tune with speed adjustments. If a clip segment runs slightly too long or too short, select it and tap Speed. Use the Normal slider to nudge playback rate without drastically altering the look of the footage.
  1. Preview and repeat. Tap the play button and watch the edit in real time. Scrub slowly through any section where sync feels loose, then repeat the split-and-adjust process until the timing feels natural.
How to Read the Audio Waveform in CapCut for Accurate Sync?
The waveform is one of the most useful tools available for lip sync work in CapCut, and many beginners overlook it entirely.
To see it clearly, pinch outward on the timeline until the waveform is wide enough to identify individual peaks. Large waveform peaks usually mark louder sounds like syllables, drum beats, or sharp consonants. Smaller or flatter sections often represent quieter parts of the audio.
Place your video cuts near these waveform peaks when new words begin. Even without perfect frame matching, the lip sync will still look natural to most viewers.
Pro Tip: Switch to 0.5x playback speed in the preview player to catch any timing drift you might miss at normal speed. Small sync issues that look acceptable at 1x become obvious at half speed.
Method 2: Using CapCut’s Beat Sync Feature
Beat Sync is CapCut’s automated rhythm-matching tool. It works best for music-driven lip sync montages where you want cuts and transitions to feel locked to the beat, rather than achieving word-for-word syllable alignment.
  1. Add your clips and audio. Import all your footage and add the audio track to the timeline as described in Method 1.
  2. Select your audio clips. Tap the first audio clip in the timeline to highlight it.
  3. Open the Beats menu. In the bottom toolbar, scroll until you find Beats (sometimes labeled Auto Beat). Tap it.
  1. Enable Auto Beat. Toggle on the Auto generate switch. CapCut will analyze your audio and place rhythm markers at beat points throughout the track.
  1. Review the generated markers. CapCut will suggest or apply clip splits that align with rhythm peaks. Scrub past the marker that is in an awkward position, then select Delete to remove it.
  1. Adjust manually where needed. Play through the edit. If a cut feels misaligned, drag that clip boundary to the nearest beat marker by hand.
Note: Beat Sync aligns your video cuts to rhythmic peaks in the music. It does not detect or correct the position of your mouth movements within each clip. For syllable-level accuracy, use Beat Sync to handle the rough structure, then apply the manual adjustments from Method 1 within each individual segment.
When to use Beat Sync vs. manual sync: Choose Beat Sync for fast, energy-driven videos with lots of cuts. Choose the manual method when you have a single continuous clip and need precise word-for-word mouth alignment.
Method 3: Applying the CapCut Lip Sync Effect
The CapCut mobile app also includes an AI-powered Lip Sync tool. It is different from regular sync or beat-matching options. Rather than adding visual effects, it studies your audio or text. Then it adjusts your subject's mouth movement to match the spoken words more naturally.
  1. Select your clip on the timeline.
  2. Locate the Lip Sync feature in the bottom toolbar and tap it.
  1. Add your audio under the “Add audio” section, or type your script in the “Enter text” field.
  2. Tap Generate.
Note: The AI Lip Sync feature typically requires the Pro version.
Tips for Getting a Perfectly Timed Lip Sync Video in CapCut
  • Record at 60fps: Higher frame rates give you twice as many frames to work with during editing, making slow-motion review far more precise for catching sync drift.
  • Mute the original video audio first: Before adding your music track, tap the video clip, open Volume, and set it to zero. This prevents on-set ambient sound from clashing with your added track.
  • Use 0.5x playback speed during review: Slow-motion preview reveals drift that looks acceptable at normal speed but will irritate viewers watching on their phones.
  • Export at 1080p or higher: Exporting at a lower resolution may cause small audio and video timing changes after compression. Before saving your video, check the resolution and frame rate in the export settings.
  • Start your recording with a visible cue: Clap once or snap your fingers at the very beginning of filming while listening to the audio through earphones. This creates a sharp visual spike in the waveform that is easy to align during editing.
  • Clean up source audio before you edit: If you are recording an original voiceover or original song to use as a reference track before bringing footage into CapCut, clean audio makes waveform reading far easier. A compact wireless mic like the Hollyland LARK M2 eliminates background noise at the source. Its lightweight clip-on build suits quick recording sessions for TikTok and Reels creators who produce audio before editing.
Fixing Common CapCut Lip Sync Problems
Problem
Fix
Audio and video are out of sync after export
Check that your export frame rate matches your project frame rate in Export Settings before saving.
Beat markers disappear or reset
Re-enable Auto Beat in the Beat menu. Markers can reset if you close the project without saving first.
Speed adjustment breaks my sync
Avoid applying Speed changes after your sync cuts are already placed. Adjust clip speed before you begin splitting.
Audio volume is too low next to the lip sync track
Tap the audio clip, open Volume, and raise the level. Confirm the original video audio is fully muted as well.
Can CapCut automatically sync lips to audio?
CapCut includes an AI Lip Sync tool that matches mouth movements with voice recordings or song lyrics. This creates videos that look like the subject is speaking or singing naturally. Then comes the Beats tool, which has a different job. It places video cuts to match the music's rhythm, making it easier to edit several clips with a consistent pace.
Why is my CapCut lip sync off after export?
The most common cause is a frame rate mismatch between your project settings and your export settings. If footage was shot at 60fps but exported at 30fps, CapCut may drop frames unevenly during rendering. Also check whether an audio delay was accidentally applied to your sound clip in the timeline under the audio clip settings.
How do I lip sync to a trending TikTok sound in CapCut?
To lip sync with a popular TikTok sound, open the Audio menu and select Sounds to browse trending tracks. If you want a specific TikTok sound, save it to your TikTok favorites first. Then connect your TikTok account through the TikTok icon in CapCut to access your saved audio. Another option is to save the TikTok video to your device. After that, extract its audio with CapCut's Extract audio tool.
Does CapCut have a lip sync feature?
Yes. CapCut has d a dedicated Lip Sync visual effect located in the bottom toolbar menu of the CapCut mobile app.
CapCut includes three main methods for creating lip-sync videos. Manual splitting lets you adjust every clip with full control. Beat Sync matches your edits to the rhythm automatically. The Lip Sync feature animates mouth movements to fit the audio. Begin with a 15-second sample before editing the entire video. This helps you improve timing without redoing a longer project. After that, try speed ramping and layered audio mixing. These editing methods can make your videos feel more polished and engaging.
