CapCut is widely used as a free video editing app. Many people choose it because it is simple to learn. It includes advanced editing tools inside a clean interface. New users can still navigate it without confusion. You can create content for TikTok, Reels, or Shorts. This article shows each stage from start to export. It also covers turning raw clips into finished videos. No editing background is needed to begin using it.
What Is CapCut and What Can You Make With It?
CapCut is a free, all-in-one video editing app developed by ByteDance, the company behind TikTok. Available on iOS, Android, and desktop, it handles everything from basic trimming to AI-generated captions, background removal, and multi-track audio editing. Creators use it primarily for TikTok, Instagram Reels, YouTube Shorts, and short-form vlog content. Its combination of powerful tools, a user-friendly layout, and a zero-cost barrier makes it the go-to choice for casual creators, students, and small business owners who want polished video without a dedicated editor or expensive software.
How to Download and Open CapCut
iOS: Search “CapCut” in the App Store and tap Get.
Android: Search “CapCut” in the Google Play Store and tap Install.
Desktop: Visit capcut.com and download the Windows or Mac application.
Open the app. Account login is optional — you can start editing immediately without signing in.
Note: The free version of CapCut includes every feature covered in this guide. A CapCut Pro subscription unlocks additional premium effects and AI tools but is not required to follow along.
Understanding the CapCut Interface
Before you edit a single frame, it pays to know where everything lives. Here is a labeled breakdown of the main screen elements you will use on every project.
1. Projects Panel: The home screen that displays all your saved projects. Tap any project tile to reopen it where you left off.
2. + New Video Tile: The entry point for every new video. Tapping it opens your camera roll, allowing you to select footage.
3. Timeline: The horizontal strip at the bottom of the editing screen where your clips, audio tracks, and text overlays appear as color-coded blocks. All editing actions happen here.
4. Preview Window: The large display above the timeline showing exactly how your video looks at the current playhead position.
5. Playhead: The thin vertical line in the timeline. Drag it left or right to scrub through your footage and land on a specific frame.
6. Bottom Toolbar: A context-sensitive row of buttons that changes based on what is selected. With no clip selected, you see tabs for Text, Audio, Effects, Transitions, Ratio, and more.
7. Clip Selection Bar: When you tap a clip in the timeline, a secondary toolbar appears with clip-specific options including Speed, Trim, Volume, Filters, and Adjust.
8. Export Button: Located in the top-right corner of the editing screen. Tap it when your project is ready to render and save.
Spending five minutes tapping through these areas before you start your first real project will save you significant frustration later.
How to Start a New Project and Import Your Footage
On the home screen, tap + New video.
Your camera roll opens. Tap each clip or photo you want to use. A numbered badge appears on each selected item showing the import order.
Tap Add in the bottom-right corner to bring the selected clips into the timeline.
CapCut arranges the clips in the order you selected them. The editing canvas opens with your footage loaded and the first frame visible in the preview window.
You are now inside an active project and ready to edit.
Pro Tip: Select your clips in the order you want them to appear in the final video. CapCut uses that numbered selection sequence as the initial timeline order, which saves you from manually rearranging everything afterward.
Choosing the Right Aspect Ratio From the Start
Set your aspect ratio before making any edits. Changing it later can shift text overlays and graphic elements off-screen, requiring you to reposition everything. Tap the Aspect ratio icon in the bottom toolbar while the canvas has no clip selected to open the ratio panel.
Platform |
Recommended Ratio |
Why |
TikTok |
9:16 |
Fills the full vertical smartphone screen |
Instagram Reels |
9:16 |
Native Reels player format |
Instagram Feed Post |
4:5 or 1:1 |
Maximizes feed real estate |
YouTube / Long-form |
16:9 |
Standard widescreen format |
YouTube Shorts |
9:16 |
Matches the Shorts viewer |
Basic Editing: How to Trim, Cut, and Split Clips
Trimming, splitting, and deleting are the three actions you will use on every single project. Mastering these first makes everything else feel manageable.
How to Trim a Clip
Trimming shortens a clip by moving its start or end point without affecting any other clip in the timeline.
Tap a clip in the timeline to select it. White handles appear on both ends.
Press and hold the left handle and drag it right to remove footage from the beginning of the clip.
Press and hold the right handle and drag it left to remove footage from the end.
The preview window updates in real time so you can see the exact frame where the clip will begin or end.
Note: Trimming in CapCut is non-destructive. You can drag a handle back outward at any time to restore footage you previously trimmed.
How to Split and Delete a Clip
Splitting cuts a clip into two independent pieces at the exact playhead position. This is the right tool for removing a section from the middle of a clip.
Drag the playhead to the point where you want the cut to occur.
Tap the clip to select it, then tap Split in the toolbar beneath the timeline.
The clip divides into two separate clips at the playhead.
Tap the unwanted segment and tap Delete (or the trash icon) to remove it.
To cut out a section from the middle of a clip, split at the start of the unwanted section, split again at the end, then delete the segment between the two cuts.
How to Reorder Clips in the Timeline
Long-press on any clip in the timeline until it lifts slightly and enlarges.
Drag it left or right to the new position in the sequence.
Release to drop it in place. The surrounding clips shift automatically to close any gap.
How to Add Text and Captions in CapCut
Text overlays and auto-generated captions are two of CapCut’s most-used features, especially on TikTok and Reels where on-screen text drives both engagement and accessibility.
Adding Manual Text Overlays
Use manual text when you want full control over what is written, how it looks, and when it appears.
Tap Text in the bottom toolbar, then tap Add Text.
Type your text in the input field and tap the checkmark to confirm.
The text block appears in the timeline as a separate layer beneath your video clips.
Tap the Style tab to change the font, color, size, and background fill.
Tap the Animations tab to add entrance and exit animations such as a fade-in or a pop effect.
In the timeline, drag the edges of the text layer to control how long it stays visible on screen.
In the preview window, drag the text block to reposition it anywhere on the canvas.
Using CapCut’s Auto Captions Feature
Auto Captions transcribes your spoken audio and places each phrase as a timed caption directly on the video, which is a significant time-saver for dialogue-heavy content.
Tap Text in the bottom toolbar, then tap Auto Captions.
Select your spoken language from the dropdown menu.
Tap Generate. CapCut processes the audio track, which typically takes 10 to 30 seconds depending on clip length.
The generated captions appear in the timeline as a series of individual text segments.
Tap any caption segment to review the text. Tap again to manually correct any transcription errors.
Use the Style tab to customize the font, size, and background box color to ensure readability over any background.
Position captions in the lower third of the frame, clear of faces and key visual elements.
Note: Auto Captions performs best with clean audio recorded in a quiet space. Background noise, fast speech, and strong accents can reduce accuracy and require more manual corrections. Always review the full transcript before publishing.
Adding Music, Sound Effects, and Voiceovers
CapCut supports three independent audio layers that run simultaneously: background music, voiceover, and sound effects. You can adjust the volume balance between all three.
Adding Background Music
Tap Audio in the bottom toolbar, then tap Sounds.
Browse the CapCut tab for royalty-free tracks organized by genre and mood.
To use a file from your device, tap the Folder icon and choose Device.
Tap any track title to preview it. Tap the + icon to add it to the timeline.
The music track appears beneath your video clips.
Tap the audio track and drag its edges to trim the music to match your video length, or drag the bar left or right to shift where the track starts.
Tap the music bar and use the Volume slider to balance the music level against any voiceover or dialogue.
Note on copyright: Tracks in CapCut’s library are cleared for use in TikTok content. For YouTube uploads or monetized videos, verify each track’s license individually, as some are restricted to CapCut and TikTok platform use only.
Recording a Voiceover
Tap Audio in the bottom toolbar, then tap the Record icon (it's the voiceover feature).
Position the playhead at the point where you want the recording to start.
Press and hold the Record button and speak clearly into the microphone.
Release the button to stop recording. The voiceover clip appears in the timeline automatically.
Trim or reposition the clip as needed, then adjust its volume relative to the background music.
Microphone quality has a direct impact on voiceover clarity. A wireless clip-on mic such as the Hollyland LARK M2 captures clean broadcast-quality audio at the source, which means far less noise correction is needed inside the app. For beginners looking for the simplest setup, the plug-and-play Hollyland LARK A1 connects directly via USB-C or Lightning with no configuration required.
Using Sound Effects
Tap Audio in the bottom toolbar, then tap Sound FX (sound effects). Browse by category (Transitions, Cinematic, Funny, and others), tap any sound to preview it, and tap + to add it to the timeline. Tap the sound clip to adjust its volume independently from the other audio layers.
How to Add Transitions and Effects
Transitions connect two clips together; effects alter the look of a clip itself. Both are worth using selectively.
Adding Transitions Between Clips
A small white square icon sits between every pair of clips in the timeline. That is the transition slot.
Tap the white square between two clips.
The transitions panel opens with categories including Basic, Trendy, and MG transitions.
Tap any transition style to instantly preview it in the preview window.
Use the Duration slider to set how long the transition lasts. Between 0.1 and 0.5 seconds tends to feel clean; longer durations can feel sluggish.
Tap the checkmark to confirm and apply.
Repeat for any other clip boundary where a transition is appropriate.
Pro Tip: Limit yourself to one or two transition styles across the entire video. Mixing five different transitions reads as cluttered and pulls attention away from the content.
Applying Effects to Clips
Tap a clip to select it, then tap Effects in the clip toolbar. Alternatively, tap the Effects tab in the main bottom toolbar to apply an effect across the full project.
Two main categories appear: Video Effects (grain, glitch, blur, light leak, and others) and Body Effects (motion-tracking effects tied to people in the frame).
Tap any effect to preview it. If it fits the tone, tap the checkmark to apply.
Trim the effect layer in the timeline to limit it to a specific portion of the video rather than the entire clip.
Choose effects that reinforce the mood of the video. A subtle film grain adds warmth to travel footage; heavy glitch effects lose their impact quickly if repeated throughout.
Adjusting Speed, Filters, and Color
These three tools help you polish how your footage looks and moves. Apply them after your structural edit is locked.
Speed control: Tap a clip, then tap Speed in the clip toolbar. Use Normal mode to set a precise speed multiplier from 0.1x (very slow motion) to 100x (extreme time-lapse). Use Curve mode to create smooth speed ramps that accelerate or decelerate at specific points within a clip.
Filters: Tap a clip, then tap Filter. Choose from preset color grades grouped by style (Film, Food, Vintage, Summer, and others). Use the intensity slider to reduce the filter strength for a more natural look.
Adjust (manual color grading): Tap a clip, then tap Adjust. Individual sliders for Brightness, Contrast, Saturation, Sharpness, Highlights, and Shadows give you granular control. Small adjustments in the range of 10 to 20 points on any slider are usually enough; large swings tend to look over-processed.
How to Use CapCut Templates (Optional Shortcut)
Templates drop your clips into a pre-built edit with timing, transitions, music, and effects already in place. They are useful when speed matters more than creative control.
Tap the Templates tab at the bottom of the CapCut home screen.
Browse by category or search by keyword such as “travel,” “product,” or “birthday.”
Tap a template to watch a full preview of the edit style.
Tap Use Template to open it in the editor.
Tap each placeholder clip slot and select your own footage or photo from the camera roll.
Tap Preview to review the result, then tap Export to save.
Keep in mind that templates lock most of the creative structure, including font choices, transition timing, and effects. If you need the flexibility to change anything, building from scratch gives you full control.
How to Export and Share Your Video
The export step is where many beginners make costly mistakes, including the wrong resolution, wrong frame rate, or an accidental watermark on a finished video.
When your edit is complete, tap the Resolution menu (AI UHD) next to the Export button in the top-right corner of the editing screen.
For Resolution, select at minimum 1080p. For YouTube uploads or any platform where maximum sharpness matters, choose 4K if your source footage supports it.
For Frame Rate, select 30fps for standard content. Choose 60fps for action footage, sports, or gaming where motion clarity is a priority.
Tap the Export button. CapCut begins rendering and shows a progress bar.
Once rendering finishes, choose to save to your camera roll or share directly to TikTok, Instagram, YouTube, or another platform from the share screen that appears.
Note: Projects made from scratch in newer CapCut versions usually stay free of watermarks during playback. But a short ending clip with the CapCut logo is often added automatically. You need to move to the end of the timeline and remove that clip before exporting. You can also disable this ending card inside the settings menu. Template-based projects may still include branding from the original template. Starting a fresh project is the safest way to avoid unwanted marks for professional uploads.
Q: Is CapCut free to use?
Yes. CapCut’s main editing tools are free on mobile and desktop. Some fonts, effects, and AI tools require a Pro plan. But everything shown in this guide can be used without paying.
Q: Why are my auto captions inaccurate?
Auto Captions performs best with clear, steady speech recorded in a quiet environment. Background noise, fast delivery, and strong accents all reduce transcription accuracy. Always review the full caption transcript after generating it, and correct errors manually before you publish the video.
Q: Can I use CapCut on a desktop or PC?
Yes. CapCut has a dedicated desktop application for both Windows and Mac. CapCut desktop offers nearly the same tools as the mobile version. It also gives a larger workspace for editing videos. Mouse and keyboard controls make detailed edits faster.
Q: What’s the best export setting for TikTok?
Export at 1080p resolution, 30fps frame rate, MP4 format, with a 9:16 aspect ratio. These settings match TikTok’s recommended specifications and produce a sharp upload without overly large file sizes that could slow down the upload process.
Q: Can I use my own music in CapCut?
Yes. Navigate to Audio, then Sounds, then tap the Folder icon and select the Device tile to add any audio file saved to your device. Be aware that uploading videos with copyrighted music to TikTok or YouTube can trigger content ID claims or takedowns. For monetized content, use royalty-free tracks or music you own the rights to.
Editing a complete video in CapCut becomes easier after learning the basics. Bring your footage into the project before making any changes. Remove unwanted sections and place every clip in the correct order. Add titles, music, or sound only where they improve the video. Export everything using settings that match your intended platform.
Practice is the quickest way to build confidence with any editing software. Create a small project and experiment with different editing tools. Every finished video helps you understand the workflow much better. Regular interaction with CapCut gradually makes each editing step faster and more natural.
