How to Fade Out Audio in CapCut (Mobile and PC): Step-by-Step Guide
Sudden audio cuts can make a video feel unfinished. CapCut includes a fade out tool that removes this problem quickly on both mobile and desktop. The steps below show how to apply it on each platform and also how to add a fade in. You will learn how to finish audio in a clean and controlled way.
How to Fade Out Audio in CapCut (Mobile & PC): Step-by-Step Guide
What the CapCut Fade Out Feature Does
CapCut’s fade out gradually reduces the volume of an audio clip to silence at the end, preventing a jarring cutoff. The feature works across all audio types in the timeline, including background music, voiceover recordings, and imported sound effects. No manual volume keyframing is required.
How to Fade Out Audio in CapCut on Mobile (iOS and Android)
This is the most common workflow for CapCut users. The steps below apply to both iOS and Android.
  1. Open your project in CapCut and confirm your audio clip is already placed on the timeline.
  2. Tap the audio clip on the timeline to select it. A toolbar appears at the bottom of the screen.
  3. Scroll through the bottom toolbar and tap Fade.
  1. You will see two sliders: Fade In and Fade Out. Drag the Fade Out slider to the right to set the fade duration in seconds.
  1. Tap the play button to preview how the fade sounds at the end of the clip.
  2. Tap the checkmark to confirm and apply.
Note: If the Fade option does not appear, you may have tapped the video clip rather than the audio clip. Tap directly on the colored audio waveform strip on the timeline to select the right layer.
How to Fade Out Background Music in CapCut
Background music added through CapCut’s music library uses a slightly different entry point, but the fade controls are in the same place once the clip is selected.
  1. Tap Audio at the bottom of the editing screen, then tap Sounds to add a track if you have not already done so.
  1. Tap the “+” button next to the music clip to add it to the timeline.
  1. Once it's there, tap the clip on the timeline to select it.
  2. Tap Fade in the bottom toolbar.
  3. Drag the Fade Out slider to your preferred duration.
  4. Tap the checkmark to confirm.
How to Fade Out a Voiceover in CapCut
Voiceover recordings appear in their own dedicated lane on the timeline, separate from music and background audio clips.
  1. Locate your voiceover clip on the timeline. It typically appears as a colored bar below the main video track.
  2. Tap the voiceover clip to select it.
  1. Tap Fade in the bottom toolbar.
  2. Drag the Fade Out slider to your desired duration.
  3. Tap the checkmark to apply.
How to Fade Out Audio in CapCut on PC (Desktop)
The desktop version of CapCut organizes controls in a right-side panel rather than a bottom toolbar, and it allows you to type an exact duration for more precise control.
  1. Open your project in CapCut for PC and ensure the audio file is imported and placed on the timeline.
  2. Click the audio clip on the timeline to select it.
  3. In the right-side panel, look into the Basic tab
  4. Locate the Fade In and Fade Out fields within that panel.
  1. Type your preferred duration in seconds into the Fade Out field or adjust the slider.
You will notice that the tail of the audio clip on the timeline will be shadowed. The more you increase the fade out value, the more the shadow will expand, confirming that the effect is being applied to the audio file.
  1. Press the spacebar or click Play to preview the fade.
  1. Export once the fade sounds correct.
How to Add a Fade In to Audio in CapCut
Fade in is found in the same panel as fade out.
  1. Select the audio clip on the timeline.
  2. Tap or click Fade.
  3. Drag or enter a value in the Fade In slider or field.
A fade in works well when background music feels too abrupt at the start of a clip or when you want a voiceover to ease in smoothly rather than begin at full volume.
Tips for Getting the Most Out of Audio Fades in CapCut
  • Keep fade outs short for short-form content: A 1 to 2 second fade works well for TikTok, Instagram Reels, and YouTube Shorts. Longer fades can make brief clips feel sluggish.
  • Pair fade out with a slight volume reduction: Lowering the clip’s overall volume before the fade creates a more gradual, natural-sounding ending on background music.
  • Avoid fading very short clips aggressively: On a 2 or 3-second clip, a 2-second fade out means the audio is barely audible for most of its duration. Use a shorter value or skip the fade.
  • Start with clean source audio: For creators who record on the go, starting with clean source audio captured with a compact wireless mic like the Hollyland LARK M2 makes the fade feel smoother and more natural in post.
Why can’t I see the Fade option in CapCut?
The most common reason is that you have tapped the video clip instead of the audio clip on the timeline. Tap directly on the colored audio waveform strip to select it, and the Fade option will appear. On very short clips, the option still appears, but the slider range will be limited by the clip length.
Can I fade out individual sound effect clips in CapCut?
Yes. The fade out process works on every audio layer in CapCut, including sound effects. Tap the sound effect clip on the timeline, select Fade from the toolbar, and adjust the Fade Out slider as you would for music or a voiceover.
How long should a fade out be in CapCut?
For short-form content like Reels or Shorts, 1 to 2 seconds is the right range. For longer YouTube videos or cinematic clips, a 3 to 5 second fade out tends to feel more natural. Adjust based on how quickly the scene or content changes after the audio ends.
Does fading out audio affect the video track?
No. Audio and video are independent in CapCut. Applying a fade out only affects the volume of the selected audio clip and has no impact on your video visuals, transitions, or timing.
Can I fade out music on CapCut for free?
Yes. The fade in and fade out features are available on CapCut’s free plan. You do not need a CapCut Pro subscription to access or use these audio controls.
Fading out audio in CapCut takes just a few taps on mobile or a quick field entry on desktop. Before you export, play through the end of your clip to confirm the fade sounds natural and does not cut off too early.
