How to Fade Out Audio in Premiere Pro: 3 Methods That Actually Work
An abrupt audio cut is one of the fastest ways to make a polished video feel unfinished. Whether you’re wrapping a music bed, softening the end of a dialogue clip, or smoothing a scene transition, knowing how to fade out audio in Premiere Pro is a fundamental skill. This guide covers three distinct methods, from the quickest drag-and-drop option to precise manual control, so you can choose the right approach for any project situation.
What an Audio Fade-Out Does (and When You Need One)
A fade-out is a gradual reduction in a clip’s volume from its current level down to silence. Common use cases include ending a music track under narration, softening ambient sound at a scene cut, or preventing a hard stop at the end of a sequence. Knowing more than one method matters because each one trades off speed against precision, and the right choice depends on how much control your project requires.
Method 1 — Apply an Audio Transition (Fastest)
Premiere Pro includes built-in audio crossfade transitions that apply a fade with a single drag. This is the fastest method and works well for most standard fade-outs.
  1. Open the Effects panel (Window > Effects).
  2. Navigate to Audio Transitions > Crossfade.
  3. Choose your transition type (see the comparison below).
  4. Drag the transition to the end of the audio clip on the timeline.
  5. Release it directly onto the clip’s out point. A colored transition block will appear.
  1. To adjust the duration, hover over the edge of the transition block and drag to lengthen or shorten it. Alternatively, double-click the transition block and enter a specific duration in the dialog that opens.
  1. To set a transition as your default, right-click it in the Effects panel and select Set Selected as Default Transition. You can then apply it with the keyboard shortcut Shift + D.
Note: The transition must be applied to the end of the clip, not the beginning. If the clip has no room for a handle (extra footage beyond the cut point), Premiere will warn you or center the transition at the cut, which may not produce the result you want.
Exponential Fade vs. Constant Power vs. Constant Gain — Which to Choose
Each transition type uses a different volume curve, which produces a noticeably different fade feel.
Transition Type
Best For
Behavior
Exponential Fade
Music tracks
Mimics a natural-sounding fade; volume drops slowly at first, then faster toward silence
Constant Power
Dialogue and speech cuts
Maintains perceived loudness through a crossfade; the standard choice for cuts between two clips
Constant Gain
Rarely recommended
Decreases volume at a fixed linear rate; often sounds abrupt or unnatural compared to the other two
Default recommendation: Use Exponential Fade when fading out a standalone music clip. Use Constant Power when crossfading between two audio clips. Avoid Constant Gain unless you have a specific reason to need a strictly linear curve.
Method 2 — Manual Volume Keyframes (Most Control)
Manual keyframing takes more steps but gives you exact control over where the fade starts, where it ends, and how the volume curve behaves between those two points. This is the preferred method when timing is critical or when a transition block does not produce the right feel.
  1. On the timeline, locate your audio clip and expand the audio track by clicking the small arrow to the left of the track name.
  2. Make sure the clip is displaying the volume rubber band (the thin horizontal line running through the clip). If you see waveform only, right-click the clip, go to Show Clip Keyframes > Volume > Level.
  3. Using the Pen tool (P), click on the rubber band at the point where you want the fade to begin. This creates the first keyframe.
  4. Click again at the point where you want the audio to reach silence. This creates the second keyframe.
  5. Drag the second keyframe downward until it reaches the bottom of the clip, which corresponds to -∞ dB (silence).
  6. Switch back to the Selection tool (V) and play the clip to review the fade.
Alternative via Effects Controls: Select the clip, open the Effects Controls panel (Window > Effect Controls), and expand the Volume property. Click the stopwatch icon to enable keyframing, then move the playhead to your start and end points, adjusting the Level value at each position. This approach is useful if you prefer numerical dB input over visual dragging.
Adjusting Keyframe Curves for a Smoother Fade
By default, Premiere Pro sets keyframes to a linear interpolation, which produces a straight-line volume drop. For a more natural fade, right-click the second keyframe on the rubber band and select Ease In. This applies a Bezier curve that slows the rate of volume change as it approaches silence, resulting in a smoother, more gradual fade tail. You can also select Bezier and manually adjust the curve handles for custom shaping.
Method 3 — Use the Essential Sound Panel (Beginner-Friendly)
The Essential Sound panel is designed for editors who want audio adjustments without deep technical knowledge. It is particularly useful for fading music tracks that sit underneath dialogue.
  1. Open the panel via Window > Essential Sound.
  2. Select the audio clip on the timeline you want to fade.
  3. In the Essential Sound panel, click a clip type tag: Music, Dialogue, SFX, or Ambience. Choose the tag that matches your clip.
  4. For music clips, scroll down to the Loudness or Creative section. Look for the Fade Out duration field and enter a value in seconds.
  5. Premiere applies a fade automatically based on that duration. Play back the clip to confirm the result.
  6. If you are using Ducking (lowering a music track under dialogue), enable the Ducking toggle and set the sensitivity and target level. The panel will auto-generate volume keyframes, which you can later adjust manually if needed.
The Essential Sound panel is the fastest option for simple music fades, but it offers less precision than manual keyframing. If you need a fade that hits a specific frame, use Method 2 instead. NOT WORKING
Which Method Should You Use?
Scenario
Recommended Method
Reason
Quick fade on a single clip with a tight deadline
Method 1 (Audio Transition)
Drag-and-drop speed; no keyframe setup required
Fade needs to hit a precise frame or follow a custom curve
Method 2 (Manual Keyframes)
Full control over start point, end point, and curve shape
Fading a music bed under dialogue across multiple clips
Method 3 (Essential Sound Panel)
Ducking and fade controls designed specifically for this use case
Crossfading between two overlapping audio clips
Method 1 (Constant Power)
Built for transitions between two clips, not just a single clip end
All three methods produce a clean result when your source audio is in good shape. If you are also capturing original audio for your projects, starting with a clean signal makes a measurable difference. Recording with a quality wireless microphone like the Hollyland LARK MAX 2, which features 32-bit float internal recording and AI noise cancellation, reduces the low-level noise that tends to become audible during the quiet tail of a fade.
Why is my audio fade not smooth in Premiere Pro?
The most common cause is using the Constant Gain transition instead of Exponential Fade, or having keyframe interpolation set to linear. Constant Gain drops volume at a fixed rate that the human ear perceives as abrupt. Switch to Exponential Fade for transitions, or right-click your end keyframe and apply Ease In to soften a manual keyframe fade.
How do I fade out multiple audio tracks at once?
Select all target clips on the timeline, then use the Shift + D shortcut to apply the default audio transition to all selected clip endpoints simultaneously. For track-level automation, open the Audio Track Mixer (Shift + 9), enable write automation, and draw a volume fade across the entire track rather than individual clips.
Can I fade audio in Premiere without affecting the video clip?
Yes. Right-click the clip on the timeline and select Unlink. This separates the audio and video into independent clips. You can then apply any fade method to the audio clip only, without touching the video track. Re-linking is not necessary unless you need the clips to move together again.
How do I make a fade-out last exactly 2 seconds?
For the transition method, double-click the transition block after applying it and type 00;00;02;00 in the duration field. For the keyframe method, place your first keyframe at a specific timecode, then type the playhead position exactly 2 seconds later using the timecode entry field above the timeline before placing the second keyframe.
Audio fade-outs in Premiere Pro come down to three core methods: audio transitions for speed, manual keyframes for precision, and the Essential Sound panel for music-under-dialogue work. If you are in a rush, drag on an Exponential Fade transition. If the timing needs to be exact, use rubber band keyframes with Ease In curves. For music ducking, the Essential Sound panel handles it with minimal setup. For more on shaping audio in Premiere, see the related guides on adjusting audio levels and syncing audio to video.
