Removing audio in Premiere Pro is straightforward once you know which method fits your situation. Whether you need to strip the audio from a single clip, wipe an entire track, or cut out a few seconds of bad sound in the middle of a clip, there is a clean way to do each. This guide walks through all three methods step by step, plus a quick look at when muting is a better choice than deleting.
Ways to Delete Audio in Premiere Pro (Quick Overview)
Premiere Pro gives you several ways to remove audio depending on your goal. You might need to delete camera audio from one clip, remove a complete audio track from the timeline, or cut out only a few seconds of unwanted sound from inside a clip. The three methods below cover each scenario without risking your video footage.
Method |
When to Use |
Difficulty |
Unlink and Delete |
Remove audio from one or more clips while keeping the video |
Beginner |
Delete an Entire Track |
Remove all clips on a specific audio track |
Beginner |
Razor Tool Split and Delete |
Remove audio from only part of a clip |
Intermediate |
Method 1 — Unlink and Delete Audio from a Video Clip
This is the most common path. When you import footage, the audio and video are linked together. To delete just the audio, you need to either unlink them first or use the Alt/Option shortcut to select only the audio portion.
Steps using right-click Unlink:
In the timeline, right-click the clip containing the audio you want to remove.
Select Unlink from the context menu. The audio and video will now be independent selections.
Click once on the audio clip (the waveform portion) to select only that clip.
Press Delete (Windows) or Delete/Backspace (Mac) to remove it.
If a gap remains in the timeline, right-click the gap and select Ripple Delete to close it, or leave it if you want to preserve timing.
Pro Tip: Skip the right-click Unlink step entirely by holding Alt (Windows) or Option (Mac) and clicking directly on the audio portion of a linked clip. This selects only the audio without permanently unlinking the clip. Press Delete and you are done in two steps.
How to Delete Audio Without Creating a Gap (Ripple Delete)
When you delete an audio clip, Premiere Pro leaves an empty gap in the timeline where the clip used to be. To remove that gap automatically, right-click the empty space and choose Ripple Delete. On Windows, you can also select the audio clip and press Shift+Delete to perform a ripple delete in one action (Mac: Shift+Forward Delete). This pulls downstream clips forward to close the space.
Method 2 — Delete an Entire Audio Track from the Timeline
If you want to remove every clip on a specific audio track at once (for example, all camera audio recorded across an entire sequence), deleting the track itself is the fastest approach.
Locate the track header on the left side of the timeline. This is the labeled panel showing A1, A2, etc.
Right-click on the track header of the audio track you want to remove.
Select Delete Tracks from the context menu.
In the dialog box that appears, confirm which track(s) you want to delete and click OK.
Note: Deleting a track removes the track and all clips sitting on it. Before proceeding, make sure no clips you want to keep are using that track. Check each track carefully if your timeline has multiple audio sources sharing the same track.
Method 3 — Remove Audio from Only Part of a Clip
Sometimes you only need to remove a few seconds of audio from the middle or end of a clip while keeping the rest intact. The Razor tool lets you split the audio at precise points so you can delete only the unwanted segment.
Press C to activate the Razor tool.
Hold Alt (Windows) or Option (Mac) while clicking on the audio waveform at the point where the unwanted audio begins. Holding Alt/Option restricts the cut to the audio track only, leaving the video untouched.
Make a second Razor cut at the point where the unwanted audio ends.
Press V to switch back to the Selection tool.
Hold Alt/Option and click the isolated audio segment to select only that portion.
Press Delete to remove it.
Right-click the resulting gap and choose Ripple Delete if you want to close it, or leave the gap if the silence serves your edit.
Muting Audio vs. Deleting It — Which One Should You Use?
If you are unsure whether to mute or delete, this quick comparison covers the key differences.
Mute |
Delete |
Reversible |
Yes, toggle back on anytime |
Yes, but only via Undo (Ctrl+Z / Cmd+Z) |
Affects source file |
No |
No |
Best for |
Temporarily silencing a clip while you decide |
Permanently removing audio from the sequence |
How to do it |
Click the M button on the track header or clip |
Unlink and press Delete (see Method 1) |
Muting is a non-destructive option that keeps the audio data in your timeline but silences playback. Deleting removes the clip from the sequence entirely, though the original source file in your Project panel is never affected either way.
Keyboard Shortcuts for Deleting Audio in Premiere Pro
Action |
Windows Shortcut |
Mac Shortcut |
Select audio only (linked clip) |
Alt + Click audio clip |
Option + Click audio clip |
Delete selected clip |
Delete |
Delete or Backspace |
Ripple Delete selected clip |
Shift + Delete |
Shift + Forward Delete |
Activate Razor tool |
C |
C |
Switch back to Selection tool |
V |
V |
Undo last action |
Ctrl + Z |
Cmd + Z |
Ctrl + L |
Cmd + L |
Can I delete audio without deleting the video in Premiere Pro?
Yes. Hold Alt (Windows) or Option (Mac) and click the audio portion of a linked clip to select only the audio. Press Delete and only the audio is removed. The video clip stays in place on the timeline, fully intact, without needing to unlink the two first.
How do I delete audio from multiple clips at once?
Select all target clips by holding Shift and clicking each one, or drag a selection box across them. Then hold Alt/Option and click the audio portion of any one of the selected clips. This isolates the audio selection across all highlighted clips. Press Delete to remove audio from all of them in one action.
Will deleting audio from the timeline remove the original file?
No. Premiere Pro is non-destructive by design. Removing audio from your sequence only affects that sequence. The original source file remains untouched in your Project panel and on your hard drive. You can always re-drag the original clip back to the timeline to recover the audio.
How do I recover audio I accidentally deleted?
Press Ctrl+Z (Windows) or Cmd+Z (Mac) immediately after deleting to undo the action. For edits made in a previous session, go to File > Open Recent or check the Auto Save folder inside your project directory to find an earlier version of your project.
Next Steps
You now have three reliable ways to remove audio in Premiere Pro: unlink and delete for single clips, track deletion for a full audio track, and the Razor tool for segment-level removal. From here, the natural next step is replacing the deleted audio with a music track, voiceover, or clean location audio. If poor recording quality is what keeps sending you back to delete and re-record, capturing cleaner audio at the source with a wireless mic like the Hollyland LARK MAX 2 (48 kHz / 32-bit Float, AI Noise Cancellation) can significantly cut down on post-production cleanup time.
