How to Reverse Audio in CapCut PC (Step-by-Step)
Reversing audio in CapCut PC is straightforward once you know where to look. The feature is not labeled “audio reverse” anywhere in the interface, which is why so many users get stuck. This guide covers two methods: reversing a full clip so both video and audio play backward, and reversing only the audio while keeping the video playing forward. Both approaches are built into CapCut PC with no extra plugins required.
What Does “Reverse Audio” Do in CapCut PC?
CapCut PC does not have a standalone audio-only reverse button. Its built-in Reverse function applies to the entire selected clip, flipping both the video and audio playback direction at once.
Depending on what you need, there are two paths:
  • Reverse video and audio together – use the Reverse option directly on your clip in the timeline.
  • Reverse audio only – detach the audio from the video first, then apply Reverse to the isolated audio track.
Method 1 – How to Reverse Video and Audio Together in CapCut PC
This is the quickest route and covers the most common use case: you want the entire clip, sound and picture, to play in reverse.
Step-by-Step Instructions
  1. Open CapCut PC and start a new project or open an existing one.
  2. Import your video clip using the Media panel (click Import and locate your file).
  3. Drag the clip from the media panel down onto the timeline.
  4. Click the clip on the timeline to select it. A highlight border will appear around it.
  5. In the Top Toolbar, click the Video Tool Menu tab.
  6. Select the Reverse option from the Top Toolbar menu.
  7. Wait for CapCut to process the reversal. A progress indicator will appear on the clip.
  8. Once processing is complete, press the spacebar or click Play to preview and confirm the clip now plays backward.
  9. Continue editing or export your project when ready.
What to Expect During Processing
Processing time depends on clip length. A short clip under 30 seconds usually finishes within a few seconds, while longer clips may take half a minute or more. The clip thumbnail in the timeline will refresh once the reversal is applied. If it appears to freeze briefly, let it finish rather than clicking elsewhere.
Method 2 – How to Reverse Only the Audio in CapCut PC (Audio-Only Method)
If you want the video to play forward while the audio plays backward, you need to separate the two tracks first. This is the step most users miss.
  1. Import your video clip and drag it onto the main timeline.
  2. Right-click the clip directly on the timeline.
  3. From the context menu, select Extract Audio. CapCut will split the audio into a separate track that appears below the video track.
  4. Click on the audio track only to select it. Make sure the video track above it is not selected.
  5. In the right-hand editing panel, open the Edit tab and click Reverse.
  6. Wait for the processing to complete.
  7. Press play to verify: the video should play forward while the audio plays backward.
  8. Trim or reposition the audio track if needed to keep it in sync, then export when finished.
Quick Note on Audio-Video Sync After Reversal
After reversing the detached audio, the track may shift slightly on the timeline. If the audio no longer lines up with the start of the video, click and drag the audio track to realign it with the beginning of the video clip before exporting.
Tips for Getting the Best Results with Reversed Audio
  • Start with clean, isolated audio. Music tracks or single sound effects produce the most noticeable reversal effect. Audio recorded with heavy background noise tends to sound muddy when reversed.
  • Keep it short for dialogue. Reversed speech works best with brief phrases or single words. Long reversed sentences are usually unintelligible and lose impact.
  • Adjust speed if the timing feels off. Use CapCut’s speed controls on the audio track to tighten or loosen the reversed audio until it sits where you want it in the edit.
  • Preview at full volume before you export. Subtle reversal artifacts that are easy to miss in the editor can sound obvious in the final file, especially on the first and last frames of the reversed segment.
Q1: Does CapCut PC have a reverse button for audio only?
There is no dedicated one-click audio reverse button in CapCut PC. To reverse only the audio, right-click your clip on the timeline, select Detach Audio, then click the audio track and use the Reverse option in the Edit panel. The full walkthrough is covered in Method 2 above.
Q2: Why is the Reverse option greyed out in CapCut PC?
The Reverse option becomes unavailable when no clip is actively selected on the timeline, when the selected layer is a text box or sticker, or when the clip is still being processed. Click directly on a video or audio clip in the timeline to activate the full set of Edit panel options, including Reverse.
Q3: Can I reverse audio without reversing video in CapCut PC?
Yes. Right-click the clip on the timeline and choose Detach Audio to separate the audio into its own track. Then select only the audio track and apply Reverse from the Edit panel. The video track stays unaffected and continues to play forward.
Wrapping Up
Both methods covered here are built directly into CapCut PC and require no third-party tools or plugins. If you want to take your reversed audio further, explore the speed and volume controls in the same Edit panel to fine-tune the effect, or check out CapCut’s other audio editing options such as pitch adjustment and noise reduction for even more creative control.
