How to Normalize Audio in DaVinci Resolve (3 Methods Explained)
Inconsistent audio levels are one of the most common problems in a video timeline. One clip is too quiet, the next is too loud, and your exported video fails to meet platform loudness requirements. DaVinci Resolve offers three distinct ways to fix this: a fast clip-level tool in the Edit page, a precise LUFS-based workflow in Fairlight, and manual gain adjustment for granular control. This guide walks through each method so you can choose the right one for your project.
What Does Audio Normalization Do in DaVinci Resolve?
Audio normalization is the process of adjusting a clip’s level to hit a specific loudness target. It solves two related problems: clips that vary wildly in volume across a timeline, and audio that is too loud or too quiet for a specific delivery platform like YouTube or broadcast television.
There are two fundamentally different types of normalization, and understanding the difference helps you decide which method to use. Peak normalization raises or lowers a clip’s gain until its loudest single sample reaches a defined ceiling, expressed in dBFS (decibels relative to full scale). It is fast and prevents clipping, but it does not account for how loud the audio actually sounds to a listener.
Loudness normalization targets an integrated LUFS value (Loudness Units Full Scale), which measures perceived loudness averaged across a clip or timeline. This is the standard that platforms like YouTube and broadcast networks use to evaluate audio. For anything destined for public distribution, loudness normalization gives you a more accurate result.
Method 1 — Normalize Audio Clips in the Edit Page (Quick Right-Click Method)
This is the fastest normalization path in DaVinci Resolve. It applies peak normalization to one or more selected clips directly from the Edit page timeline, with no need to switch pages.
Steps:
  1. Open your project in the Edit page.
  1. Click a clip in the timeline to select it. To normalize multiple clips at once, hold Ctrl (Windows) or Cmd (Mac) and click each additional clip, or drag to select a range.
  2. Right-click any selected clip and choose Normalize Audio Levels from the context menu.
  1. In the dialog that appears, set your target level. A common choice is -6 dBFS for headroom during mixing, or -1 dBTP (True Peak) if you are preparing a near-final mix.
  1. Click OK. DaVinci Resolve calculates and applies the gain adjustment to each selected clip.
This method performs peak normalization only. It does not analyze integrated loudness, so clips normalized to the same peak target can still sound uneven if they were recorded in different acoustic environments or with different dynamics.
When to Use This Method
  • Best for quickly leveling dialogue clips that were recorded at inconsistent volumes before you begin mixing.
  • Useful as a starting point when working with raw field recordings that vary significantly in level.
  • Not recommended as the final step for export loudness compliance — use the Fairlight LUFS method for that.
Method 2 — Loudness Normalization in the Fairlight Page (LUFS-Based)
For accurate, platform-compliant audio, the Fairlight page is where you want to work. This method measures integrated loudness across your full timeline and lets you adjust to a specific LUFS target.
Steps:
  1. Switch to the Fairlight page by clicking the waveform icon at the bottom of the screen.
  1. Open the Loudness Meter by going to Meters > Loudness. The meter panel will appear on the top right side of the interface.
  1. Press Play to play back the entire timeline (or a representative section). Watch the Integrated Loudness reading in the meter — this is the value you will compare against your target platform standard.
  2. Once playback is complete, note the Integrated Loudness reading. For example, if your timeline measures at -18 LUFS and your target is -14 LUFS, you need to raise the overall level by 4 LUFS.
  1. To apply the adjustment, select the clip or bus you want to normalize. Right-click the clip and choose Normalize Audio Levels, or adjust the Bus Fader on your master bus to bring the integrated measurement to your target.
  2. Re-play the timeline to confirm the new Integrated Loudness reading matches your target.
  3. Check the True Peak reading as well, and ensure it does not exceed -1 dBTP for most platforms.
Note: DaVinci Resolve Studio includes additional Loudness tools and analysis features in Fairlight. The free version of DaVinci Resolve still provides the Loudness Meter and manual gain adjustment, but some automated loudness analysis functions may be limited to Studio users.
How to Read the Fairlight Loudness Meter
The Loudness Meter displays several different readings simultaneously. Here is what each one means and when you should act on it:
Meter Type
What It Measures
When to Use It
Integrated
Average loudness across the entire timeline or selection
Primary target for platform compliance (e.g., -14 LUFS for YouTube)
Short-Term
Loudness averaged over a rolling 3-second window
Useful for monitoring louder sections like music drops or sound effects
Momentary
Loudness averaged over a rolling 400ms window
Identifies brief spikes; helpful during dialogue review
True Peak
Highest reconstructed sample peak in the signal
Must not exceed -1 dBTP for most streaming and broadcast platforms
For most normalization decisions, focus on Integrated for your target level and True Peak as your ceiling. Momentary and Short-Term readings are useful for monitoring during the mixing process, but are not the values you match to platform specs.
Method 3 — Manual Normalization Using Clip Gain and Volume Overlay
When the automatic normalization tools over-adjust or under-adjust a specific clip, manual gain control gives you the precision to correct it. DaVinci Resolve provides two non-destructive tools for this: Clip Gain and the Volume Overlay.
Steps:
  1. In the Edit page, locate the clip you want to adjust.
  2. To use the Volume Overlay, hover over the clip until you see a thin white horizontal line running across the middle of the audio waveform. Click and drag this line up or down to raise or lower the clip’s volume. The dB change is displayed as you drag.
  1. To use Clip Gain, select the clip and open the Inspector panel (top-right of the Edit page). Under the Audio tab, you will find the Volume slider and a separate Clip Gain field. Adjust Clip Gain to set the level before any effects in the signal chain.
  1. Alternatively, right-click the clip and select Clip Attributes to enter a precise gain value.
Clip Gain vs. Volume: These two controls behave differently in the signal chain, and the distinction matters. Clip Gain is applied before any audio effects on that clip, so it affects how plugins like EQ or compression receive the signal. Volume (the overlay line) is applied after effects and is fully automatable with keyframes. For normalization purposes, Clip Gain is generally the better choice because it adjusts the input level without interfering with automation data.
Use this method when a specific clip sounds noticeably off after running the automatic normalization tool, or when you need to fine-tune a single clip without affecting the rest of the timeline.
Loudness Targets by Platform — What Level Should You Normalize To?
One of the most common points of confusion is knowing which loudness number to target. The table below covers the major platforms and broadcast standards so you can enter the correct value with confidence.
Platform
Integrated Loudness Target
True Peak Limit
YouTube
-14 LUFS
-1 dBTP
Podcast (Apple / Spotify)
-16 LUFS
-1 dBTP
Broadcast (EBU R128)
-23 LUFS
-1 dBTP
Broadcast (ATSC A/85)
-24 LUFS
-2 dBTP
General Online Video
-14 to -16 LUFS
-1 dBTP
Note: YouTube applies its own loudness normalization on playback, turning down audio that exceeds -14 LUFS. Normalizing above that target does not make your content louder for viewers; it only reduces your headroom and risks distortion. Targeting -14 LUFS integrated and staying below -1 dBTP is the correct approach for YouTube delivery.
Pro Tip: Start with Better Source Audio to Minimize Normalization Work
Normalization corrects level problems after the fact, but it cannot recover audio that was clipped or distorted at the recording stage. Capturing audio with a wide dynamic range from the start reduces how much correction you need in post. Wireless microphones that support 32-bit float internal recording, like the Hollyland LARK MAX 2, preserve significantly more headroom in the original file, which means normalization in DaVinci Resolve produces cleaner results with less risk of artifacts.
Why is my audio still inconsistent after normalizing clips in DaVinci Resolve?
Clip normalization in the Edit page raises each clip to the same peak level, but clips recorded with different dynamic ranges will still sound uneven to the listener. Peak normalization does not account for perceived loudness. Switch to the Fairlight page and use LUFS-based loudness normalization for consistent results across your timeline.
Is there a difference between normalizing audio in the Edit page vs. Fairlight?
Yes, and the difference is significant. The Edit page right-click method applies peak normalization, which targets the highest sample value in the clip. Fairlight provides loudness normalization based on integrated LUFS, which reflects perceived volume. For platform delivery, Fairlight’s LUFS-based approach is the more accurate and appropriate method.
Can I normalize multiple clips at once in DaVinci Resolve?
Yes. In the Edit page, select all the clips you want to normalize by holding Ctrl (Windows) or Cmd (Mac) and clicking each one. Then right-click any selected clip and choose Normalize Audio Levels. DaVinci Resolve applies the same peak target to all selected clips in a single operation.
Does normalizing audio reduce quality in DaVinci Resolve?
No. DaVinci Resolve’s normalization adjusts gain metadata rather than rewriting or reprocessing the source audio file. The original file remains unchanged on your drive. This makes the process fully non-destructive, and you can reset or re-adjust levels at any point in your edit.
What is the best normalization level for YouTube?
Target -14 LUFS integrated loudness with a True Peak maximum of -1 dBTP. YouTube’s playback system automatically turns down audio that exceeds this level, so delivering above -14 LUFS does not increase perceived volume. It only reduces your headroom and increases the chance of distortion.
DaVinci Resolve gives you a normalization method for every situation. Use the right-click Normalize Audio Levels tool in the Edit page for a fast peak-based fix on inconsistent clips. Switch to the Fairlight Loudness Meter for LUFS-based normalization when platform compliance is the goal. Use Clip Gain or the Volume Overlay when you need precise manual control over a specific clip.
