How to Remove Echo in Premiere Pro (Step-by-Step)
What's more painful than battling echo in the captured audio during post-production? While going through this kind of headache is a common challenge that many professional editors face in their routine, it is always a good thing to nip the evil in the bud. The issue is not always your mic or any other equipment, but the environment you record in.
Now, if we talk about the solution, then fortunately, Adobe Premiere Pro offers a powerful built-in tool that corrects echo to a great extent. So explore this guide to learn four different methods. We have discussed steps from the fastest native fix to more robust options for reluctant echoes.
Let's get it done!
Why Your Audio Has Echo And What You Can Actually Fix?
What many people call “echoey” audio is usually room reverb instead. It happens when sound reflects off walls, ceilings, and floors before finally reaching the microphone. Actual echo, where the same sound repeats with a clear delay, is far less common in normal recording setups. Premiere Pro mainly targets this room reverb issue. Light and medium reverb can often be reduced quite nicely, but heavily echoed audio from large empty spaces is much tougher to clean completely. Knowing this beforehand helps you avoid wasting editing time later.
Method 1 - Apply Reduce Reverb in the Essential Sound Panel to Mitigate Echo
Step-by-Step Instructions
  1. Open the Essential Sound panel by navigating to Window → Essential Sound.
  1. Select the audio clip on your timeline that contains the echo.
  1. In the Essential Sound panel, click Dialogue to tag the clip type. This unlocks the relevant repair options.
  1. Scroll down to the Repair section and expand it.
  1. Check the Reduce Reverb checkbox. A slider will appear.
  1. Start the slider at 2.0 and play back the clip in context. Increase the amount gradually until the room sound is reduced to an acceptable level.
Method 2 — Remove Echo Using DeReverb in the Effects Panel
The Essential Sound panel is the fastest and most accessible starting point for removing echo in Premiere Pro. Its built-in DeReverb tool requires no plugins, no manual frequency hunting, and works well for the majority of dialogue recorded in moderately reverberant rooms.
Step-by-Step Instructions:
  1. Click on the Window tab at the top and choose Effects from the list of options.
  1. Now, look at the bottom-left corner of the interface to make sure you’re in the Effects section. Type “DeReverb” in the search field, and the effect should appear under the Noise Reduction/Restoration tab.
  1. Drag and drop the DeReverb effect on the affected audio clip.
  2. Then, click the Window tab and select the Effect Controls option.
  1. Under the Effect Controls section, find the DeReverb effect (fxDeReverb) and click the Edit button.
  1. Once the DeReverb editor opens up, adjust the Amount slider (valued in %) until you get better results.
What to Watch Out For?
Pushing the Reduce Reverb slider too high is the most common mistake. Aggressive settings introduce a metallic, hollow artifact sometimes described as sounding “underwater.” If you hear that quality in the voice, pull the slider back. DeReverb also performs best on voice and dialogue tracks; results on music or ambient recordings are less predictable. Always monitor at the loudest setting you intend to use before committing.
Method 3 — Use Parametric EQ to Reduce Room Echo Frequencies
Parametric EQ does not remove reverb the way DeReverb does, but it targets the frequency ranges where room reflections build up and make audio sound boxy, muddy, or harsh. Used alongside DeReverb, it tightens the perceived result noticeably. It also works as a standalone option when the reverb is mild, and the voice mainly sounds thick or cloudy rather than obviously roomy.
  1. Apply the Parametric Equalizer effect via the Effect Controls panel.
  1. From the Effect Controls panel, locate the Parameter Equalizer effect, and click the Edit button.
Then make the following targeted cuts:
  • Apply a high-pass filter at 80–100 Hz to roll off the low-end room boom that adds muddiness without contributing to voice clarity.
  • Use a narrow notch cut around 200–400 Hz if the dialogue sounds boxy or congested. This range is where early reflections tend to accumulate in small rooms.
  • Apply a gentle shelf cut above 8–10 kHz if the audio sounds harsh or smeared, which can result from high-frequency room reflections.
Keep every cut subtle. EQ alone cannot eliminate echo, but a few precise reductions significantly clean up how the voice sits in the mix.
Method 4 — Use a Third-Party Plugin for Severe Echo
When Premiere Pro’s native tools reach their limit, third-party plugins extend what is possible. Two options are worth knowing about for serious echo problems.
  • iZotope RX – Dialogue De-reverb: The industry standard for heavy room reverb removal. It operates as a VST plugin inside Premiere Pro through the Audio Effects panel and provides far more granular control than the Essential Sound slider. If DeReverb at maximum settings still leaves audible echo, or introduces artifacts you cannot reduce, RX is the practical next step.
  • Adobe Audition: Premiere Pro users can route a clip directly to Audition via Edit → Edit in Adobe Audition. Audition’s noise reduction suite offers more tools for complex audio restoration cases.
These tools are worth reaching for specifically when DeReverb produces noticeable artifacts at high settings, signaling that the echo is more severe than the built-in effect can cleanly handle.
Pro Tip — Prevent Echo Before It Reaches the Edit
Even strong audio editing cannot fully remove heavy room echo. Recording in treated rooms cuts down on extra cleanup during editing later. A microphone with built-in noise and reverb control also helps greatly. For interviews and spoken camera shots, the Hollyland LARK MAX 2 records cleaner voice audio from the start. Its AI Noise Cancellation lowers unwanted background sound during recordings naturally. It also captures audio at 48 kHz / 32-bit Float. That leaves much less echo and room sound inside Adobe Premiere Pro.
Quick Comparison — Which Method Should You Use?
Echo Severity
Recommended Method
Skill Level
Light room reverb
DeReverb (Effects)
Beginner
Boxy or muddy dialogue
DeReverb + Parametric EQ
Beginner–Intermediate
Moderate echo, slight artifacts from DeReverb
iZotope RX Dialogue De-reverb
Intermediate
Heavy echo in a large space
iZotope RX + Adobe Audition
Advanced
Does Premiere Pro have a built-in echo remover?
Yes. The DeReverb option inside the Effects is Premiere Pro’s native echo and room reverb reduction tool. Contrarily, you can tag the clip as Dialogue, expand the Repair section, and check Reduce Reverb. It has been available since Premiere Pro CC 2018 and requires no additional plugins or subscriptions.
Why does my audio still sound echoey after applying DeReverb?
DeReverb works best on mild to moderate room reverb. If the echo is severe, such as audio recorded in a large room with hard surfaces, the native tool has limits. Increase the slider gradually to avoid artifacts, then consider layering Parametric EQ cuts or switching to iZotope RX Dialogue De-reverb for heavy cases that the built-in effect cannot fully resolve.
What is the difference between echo and reverb in audio editing?
Reverb is the diffuse, decaying wash of room reflections common in untreated indoor recordings. Echo is a distinct, repeated delay of the original sound. Premiere Pro’s DeReverb targets room reverb, which is the more common problem. True echo with clearly audible repeats may need a delay-specific approach or a dedicated tool like iZotope RX for full correction.
For most footage, the Essential Sound panel’s Reduce Reverb slider is all you need. If results fall short, layer in a Parametric EQ to address the muddier frequency buildup, and escalate to iZotope RX only when the native tools have clearly reached their limit.
