How to Use the Echo Effect in Premiere Pro (Video + Audio Guide)
The Echo effect in Premiere Pro is one of the most versatile tools for adding motion trails, ghosting, and audio repetition to your edits. Whether you’re building a dreamy flashback, a stutter title animation, or a music video with light-bleed visuals, knowing how to control this effect makes the difference between a polished result and a muddy mess. This guide walks you through both the video and audio versions, including every key parameter you need to know.
What Is the Echo Effect in Premiere Pro?
When editors search for the “echo effect” in Premiere Pro, they’re often looking for two completely different things, and it’s worth clarifying both before diving in.
The Echo video effect creates motion trails by blending previous frames of a clip onto the current frame. The result is a ghosting or smearing look where a moving subject appears to leave copies of itself behind. You’ll find this under Video Effects > Time in the Effects panel.
Audio echo is handled separately through the Delay and Echo folder inside the Audio Effects panel. These effects repeat a sound at a set interval, producing the classic echo or delay associated with vocal treatments and music production.
This guide covers both. Use the section headers to jump to whichever one you need.
How to Apply the Echo Video Effect in Premiere Pro
Where to Find the Echo Effect
The Echo video effect is easy to miss because it doesn’t live where most editors expect it. Here’s the exact path:
  1. Open the Effects panel (go to Window > Effects if it isn’t visible).
  2. Expand the Video Effects folder.
  3. Open the Time subfolder.
  4. Locate the Echo effect inside the Time folder.
“Echo” has been removed in Premiere Pro 2026. A workaround is to export the .prfset from Premiere Pro 2025 and any older versions, then import it into Premiere Pro 2026. It would be available in the Presets section.
Important: Do not look in the Generate, Blur, or Stylize folders. Echo is categorized under Time because it works by referencing multiple frames across a time span, not by manipulating pixel colors or shapes. Many editors waste time searching in the wrong places before finding it here.
You can also type “Echo” into the Effects panel search bar to find it immediately. Keep in mind the search may return audio effects with similar names, so confirm you are selecting the one listed under Video Effects > Time.
Applying the Effect to Your Clip
Once you’ve found the Echo effect, applying it takes only a few steps:
  1. Select the clip in your timeline that you want to modify.
  2. Drag the Echo effect from the Effects panel directly onto the clip in the timeline.
  3. Open the Effect Controls panel (Window > Effect Controls) to access and adjust the Echo parameters.
  4. Press the spacebar to preview the result and refine your settings.
Using an adjustment layer: If you want the Echo effect to apply across multiple clips at once, drag it onto an adjustment layer placed above those clips in the timeline. This is efficient for sequences and b-roll sections. Note that echoes will composite across clip cuts on an adjustment layer, which can produce unexpected artifacts where footage changes abruptly between frames.
Render behavior: The Echo effect is processor-intensive because Premiere Pro must reference and composite multiple previous frames in real time. If your preview is choppy, render the segment by pressing Return (Mac) or Enter (PC), or work with proxy files before fine-tuning.
Echo Effect Settings Explained
Understanding the Echo parameters is the most important part of getting usable results. Here’s a breakdown of each control:
Parameter
What It Controls
Practical Starting Value
Echo Time
Interval (in seconds) between each echoed frame
0.033 to 0.1 seconds
Number of Echoes
How many ghost frames are layered on top of the current frame
2 to 4
Starting Intensity
Opacity of the first echo layer (0 to 1)
0.5
Decay
How quickly each subsequent echo fades relative to the one before it
0.5
Echo Operator
Blend mode used to composite echoes onto the frame
Composite in Back or Screen
Echo Time controls how far apart the ghost images appear. A value of 0.033 seconds corresponds roughly to one frame at 30fps, giving you a tight, subtle trail. Increasing this to 0.1 or 0.2 seconds spreads the ghosts further apart for a more dramatic look.
Number of Echoes stacks additional ghost frames to create a longer trail. More echoes also increase render time and can cause overexposure if the blend mode is set to Add.
Starting Intensity sets how visible the first echo is. Values closer to 1 produce strong, opaque ghosts. Values below 0.3 create subtle, semi-transparent trails that read as polish rather than effect.
Decay determines how each echo fades relative to the previous one. A decay of 0.5 means each successive echo is half as bright as the one before it, producing a natural fade. A value of 1.0 keeps every echo at full intensity, which saturates the image quickly.
Echo Operator functions as the blend mode and has the biggest impact on the visual character of the effect. Add brightens the composite result and works well for dark footage or a light-bleed look. Screen is similar but caps at white, preventing total overexposure. Composite in Back places echo layers behind the current frame for a cleaner, more controlled trail. Maximum and Minimum use the brightest or darkest pixel values respectively, giving more abstract results.
Pro Tip: For a clean motion-trail look without overexposure, start with Echo Time at 0.05s, Number of Echoes at 3, Decay at 0.5, and Echo Operator set to Composite in Back. Adjust from there based on the speed and contrast of your footage.
How to Add Audio Echo in Premiere Pro
Audio echo in Premiere Pro is handled through dedicated audio effects, completely separate from the video Echo effect described above.
Finding and applying the effects:
  1. Open the Effects panel and expand the Audio Effects folder.
  2. Open the Delay and Echo subfolder.
  3. Choose Delay for a basic single-repeat echo or Multitap Delay for multiple timed repetitions.
  1. Drag your chosen effect onto the audio clip or track in the timeline.
  2. Open the Effect Controls panel to adjust the parameters.
Key parameters for the Delay effect:
  • Delay (ms): Controls the time gap between the original sound and its echo. Values under 100ms produce a tight slap-back effect common in pop vocals. Values of 300ms or more produce a distinct, spacious echo.
  • Feedback (%): Determines how many times the echo repeats itself. Higher percentages create a long, decaying tail of repetitions.
  • Mix: Balances the dry (original) signal against the wet (effected) signal. A mix of 50% blends both equally.
Use Multitap Delay when you need multiple delay taps at different intervals, such as for musical content or a synchronized echo effect that follows a beat. For simple single-echo treatments on dialogue or narration, the basic Delay effect is sufficient.
Note: If your audio already sounds like it has echo or reverb, that’s likely room acoustics captured during recording rather than a Premiere Pro effect. The Delay and Echo tools add intentional repetition. To reduce unwanted room sound, look into the DeReverb tool under Audio Effects instead.
Creative Ways to Use the Echo Effect
  • Stylized intro or stutter effect: Apply a short Echo Time (0.033 to 0.05s) with a high Starting Intensity (0.8) and low Decay (0.3) to a title card or action cut. This creates a rapid stutter that feels intentional and energetic, especially when timed to a music hit.
  • Dream or flashback sequence: Use a longer Echo Time (0.1 to 0.2s), moderate Starting Intensity (0.5), and Screen as the Echo Operator. The soft, layered result produces a hazy, ethereal look that signals a memory or fantasy moment without needing heavy color grading.
  • Speed ramp enhancement: Pair the Echo effect with Time Remapping on the same clip. As the clip accelerates from slow motion to full speed, the trailing ghost frames emphasize the ramp. Use keyframes to increase the Number of Echoes at the transition point for a more dramatic payoff.
  • Music video ghosting: Set the Echo Operator to Add with 4 to 6 echoes and a Decay of 0.6 to 0.7. On dark footage with a backlit subject, this produces a light-bleed ghosting look common in performance and dance videos. Keep your source clip’s exposure controlled to avoid total blowout.
Troubleshooting Common Echo Effect Problems
  • Effect is not visible on the clip: The clip may be too short relative to the Echo Time value, or there may be very little movement in the footage. Try reducing Echo Time to 0.033s and confirm the subject in the frame is actually moving between frames.
  • Result looks overexposed or blown out: The Echo Operator is likely set to Add. Switch it to Composite in Back or Screen, or lower the Starting Intensity. Using more than four echoes with the Add operator on bright footage almost always causes a washed-out image.
  • Rendering is very slow: The Echo effect is CPU-heavy. Apply it to a proxy clip during editing, pre-render the segment with Return/Enter, or reduce the Number of Echoes to lower the processing load.
Q: Is there a built-in reverb or echo preset in Premiere Pro?
Premiere Pro does not include named echo presets by default, but both the Echo video effect and the Multitap Delay audio effect are native to the software. Once you find settings you like, save them as a custom preset by right-clicking the effect name in the Effect Controls panel and selecting Save Preset for future use.
Q: What’s the difference between Echo and Motion Blur in Premiere Pro?
Motion Blur blurs movement within a single frame, simulating a camera’s shutter behavior for a realistic look. The Echo effect composites actual previous frames as semi-transparent ghost images, creating a visible trail of distinct positions across time. The result is stylized and layered rather than the smooth, naturalistic smear that motion blur produces.
Q: Can I keyframe the Echo effect in Premiere Pro?
Yes. All Echo parameters, including Echo Time, Number of Echoes, Starting Intensity, Decay, and Echo Operator, support keyframing through the Effect Controls panel. This allows you to animate the effect so it builds in intensity, fades out, or changes blend modes at a specific moment in the clip.
The Echo video effect lives under Video Effects > Time in the Effects panel, and its most important controls are Echo Time, Decay, and Echo Operator. For audio echo, head to Audio Effects > Delay and Echo and use either the Delay or Multitap Delay effect based on how complex you need the repetition to be. Once you’re comfortable with both, explore related techniques like time remapping, blend modes, and audio mixing in Premiere Pro to push your edits further.
